oem part numbers i'm going to do my best to keep this updated. i'm compiling a list of the most common stock part numbers that people might need. mazdaspeed accessories mazdaspeed3 coilovers - RAMS8ML10 mazdaspeed3 springs with 2 rear camber links - GRMS8ML25 mazdaspeed3 rear camber links - GRMS8ML07 mazdaspeed3 cold air intake - GRMS8ML29 - who knows if they sell this? mazdaspeed3 cai filter - GRMS8ML10 mazdaspeed3 exhaust - GRMS8ML26 mazdaspeed6 springs - GRMS8MH14 mazdaspeed6 cold air intake - GRMS8MH32 - who knows if they sell this? maintenance regular filter with o rings - L321143029U spin on conversion - L31114311 and gasket - LF0114342 spin on filter - LF0514302A drain plug washer - 995641400 - this normally comes with the filter filter wrench - AKS75140 spark plugs - 000018L3Y3 drive belt - L3K915909A9U radiator thermostat - L33615170 ignition coil - L3G218100A9U Lighting OEM HID ballast/control module for 3, CX7, CX9 - D530510H3 exterior front bumper mustache - BA6R50B31A - to remove the holes left from your front plate bracket undertray aka lower shield - BP4K56111L undertray fasteners/clip-nuts (sides, need 4) - BAY6-56-496 or BR5S-56-496 undertray fasteners/clip-nuts (front, need 3) - FB01-50-133C undertray bolts (7 total) - 90720-0620 (old) or 90720-0616 (new, shorter bolt) skid plate, radiator support, the piece that is on the bottom in the front of the vehicle - BP4K56112 mazdaspeed3 wheels - 9965097080 mazdaspeed6 wheels - 9965117080 forged mazdaspeed wheels - BLMS8MZ01 center caps - G22C37190A interior coin holder - G22C55225 shift knob - GP9A46030B under the hood cylinder block - L3K910300H valve cover - L3M610210A mazdaspeed3 battery box tray - B37F56040D mazdaspeed3 battery box and ecu cover - L33X18593B mazdsapeed3 battery box front panel - L33X18591A tmic cover - L3K9207B0F oem egr tube - L3K920310A oem egr valve - L3K920300 maf - L3K913215 map - L3K918211A pcv - L3K913890 primary o2 - L33X188G1C secondary o2 - L34B18861A boost solenoid - L3K918741 ambient temp sensor - G51861764 knock sensor - L80718921 crankshaft position sensor - L3K918221A mazdaspeed oil cap - BLMS8ML02 oem fuel pump - L3K91335ZC oem boost tube from turbo to intercooler - L33L13760B mazdaspeed3 (fits 2007 ms6) oem boost tube from intercooler to throttle body - L33X13770A mazdaspeed3 oem cold pipe - L33X13241A 2006 mazdaspeed6 oem cold pipe - L3K913241B 2007 mazdaspeed6 oem cold pipe - L3K913241A turbo oil drain/return line - L33E14290 gasket for top - L3K914293 gasket for bottom - L3K914264 bolts for previous two items - 9XF002127L tensioner pulley - LF1715980E OEM cam follower or "collar" - L3K9-12-615 brakes mazdaspeed3 caliper bracket bolt - 9YA02A225 mazdaspeed3 front brake pads - B3YF3323Z mazdaspeed3 front rotor - B37F3325XA mazdaspeed3 rear brake pads - C2Y32648ZA mazdaspeed3 rear rotor - C25Y26251B mazdaspeed6 front brake pads - GPYA3323ZG mazdaspeed6 front rotor - G31Y3325XA mazdaspeed6 rear brake pads - GPYB2648Z and apparently you need this as well - GPYB2649Z mazdaspeed6 rear rotor - G31Y26251 suspension mazdaspeed3 front sway bar - B37F34151 mazdaspeed3 front end links - B37F34170A nuts for front end links - 999401001 mazdaspeed3 rear sway bar - B37F28151 mazdaspeed3 rear end links - B37F28170A nuts for rear end links - 9YB101005 gaskets head gasket - L3K910271C turbo to manifold - L3K913710 turbo manifold to head - L3K913460 downpipe to turbo - L3F213490 intake manifold gasket to head - L3K913111 throttle body gasket - L3K913655 donut gasket - L3A140581 bpv to cold pipe oring diamond shaped "gasket" - L3K920255 fasteners turbo and manifold studs - L33E13146A nuts for studs - JE1040355 miscellaneous |
subed |
philly you suck but this thread might win. |
guys, if there's something you want on here, let me know. i can probably find the info |
philly I need the number for the plastic fastener that holds the side skirts... Its white. I ran over a semi tire a few weeks ago and it ripped part of my side skirt off, its currently dangling. Looks normal, but its barely hanging on lol |
yea that looks like it. They are little plastic grommets that hold that side skirt on |
scatt, those clips are - B09251833 i'm not sure if that's what you mean though. perhaps get a pic...or honestly take it to the dealer |
whats the part # for the missing half of your brain philly?? |
nator? |
i organized these lists a bit more. does anyone else have part numbers that are commonly used? things that often need to be replaced? or things that you'll need for particular mods? |
philly anyway you could get the part number for the light bulb behind the fan dial on the speed6? |
my source is down. fuck... |
Link failed |
yeah, shit is dead. i guess i can't use that shit no more. shit was dope |
anybody else know of a good site to find part numbers? |
Quote:
Quote:
all data ftw |
bump for stock turbo oil drain line part number. EDIT: found some good stuff... oil drain/return line (one that us ATP turbo guys were forced to cut) = 14-290 the gaskets for the two-bolt flange on top = 14-293 (accompanying bolt x2 = 9kf00-2127L) and the gasket for the bottom = 14-264D (accompanying bolt x2 = 9kf00-2147L |
im kinda new to this but uhmm, u got the number for the speed6 wheels? |
very useful thanks for the information in this post i was able to find the part i needed with ease. |
Quote:
Quote:
gasket - L3K914293 and bolt you've done correclty - 9XF002127L gasket for the bottom - L3K914264 |
Quote:
http://allmazda.net/epcimg/2G6/2G68021.GIF Here's the whole rear diff setup for the speed6 » 17122 PLUG,MAGNET » 17180 BEARING » 26060 BREATHER » 27012 WASHER » 27018 SEAL,OIL » 27020 FLANGE,COMPANION » 27020A DRIVING & DIFF. » 27030 NUT,LOCK » 27100 DRIVING & DIFF. » 27110 GEAR SET,FINAL » 27141 BEARING,PINION » 27144 SPACER » 27150 CARRIER,DIFFERENTIAL » 27171 PIECE,DISTANCE » 27200 DIFFERENTIAL » 27222A CUP,BEARING-DIFFERENTIAL » 27235 BOLT,RING GEAR » 27238 SEAL,OIL » 27305 BEARING » 27320A COVER,REAR » 27351 CONE,BEARING » 27355 SHIM,ADJUST » 27401 SPACER » 27431 SPACER » 27583A SPACER » 27604 BOLT » 27681A CASE,COUPLING » 27691A SHAFT,OUTPUT » 2797X COUPLING » 2798XA SENSOR » 90781 BOLT & WASHER » 90901 NUT » 99201 WASHER » 99305 PLUG » 99571 RING,SNAP » 99601 BOLT » 99601 BOLT » 99601 BOLT |
those aren't the pns...but thank you |
Re: oem part numbers Then what r the pns? Lol, sorry. Sent from my iPhone using Tapatalk |
Do any of these part numbers cross reff with Ford part #'s? Especially the block and other transaxle parts? |
no clue unfortunately. i don't have access or haven't found a ford site with pns Quote:
part number for the stupid diamond shaped gasket for the bpv to cold pipe??? |
Quote:
Where is the best place to order these brake pads? I'm about to have to replace them. |
Thanks phillyb. Good to be back, I take it that since you're still posting your car hasn't died yet... |
hahahaha. alive and well. though it's leaking coolant, cylinder 2 misfires all the fucking time. |
Wow... this thread is great... Thx phillyb! |
haha, well this website will save me a bit, its still gonna be 380 before labor if I gotta replace pads and disks though. Oh well. and man philly, why can't you get that thing to just run normal |
Quote:
Quote:
lol. and dude, it's one thing after the next. when i replace plugs and fix leak, i'll need to replace my meth pump...it's leaking. and then when i fix that, something else will pop up. |
Quote:
| All times are GMT -7. The time now is 09:45 PM. |
