| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
(Thread Starter) | Neutral : -1 score i'm going to do my best to keep this updated. i'm compiling a list of the most common stock part numbers that people might need. mazdaspeed accessories mazdaspeed3 coilovers - RAMS8ML10 mazdaspeed3 springs with 2 rear camber links - GRMS8ML25 mazdaspeed3 rear camber links - GRMS8ML07 mazdaspeed3 cold air intake - GRMS8ML29 - who knows if they sell this? mazdaspeed3 cai filter - GRMS8ML10 mazdaspeed3 exhaust - GRMS8ML26 mazdaspeed6 springs - GRMS8MH14 mazdaspeed6 cold air intake - GRMS8MH32 - who knows if they sell this? maintenance regular filter with o rings - L321143029U spin on conversion - L31114311 and gasket - LF0114342 spin on filter - LF0514302A drain plug washer - 995641400 - this normally comes with the filter filter wrench - AKS75140 spark plugs - 000018L3Y3 drive belt - L3K915909A9U radiator thermostat - L33615170 ignition coil - L3G218100A9U Lighting OEM HID ballast/control module for 3, CX7, CX9 - D530510H3 exterior front bumper mustache - BA6R50B31A - to remove the holes left from your front plate bracket undertray aka lower shield - BP4K56111L undertray fasteners/clip-nuts (sides, need 4) - BAY6-56-496 or BR5S-56-496 undertray fasteners/clip-nuts (front, need 3) - FB01-50-133C undertray bolts (7 total) - 90720-0620 (old) or 90720-0616 (new, shorter bolt) skid plate, radiator support, the piece that is on the bottom in the front of the vehicle - BP4K56112 mazdaspeed3 wheels - 9965097080 mazdaspeed6 wheels - 9965117080 forged mazdaspeed wheels - BLMS8MZ01 center caps - G22C37190A interior coin holder - G22C55225 shift knob - GP9A46030B under the hood cylinder block - L3K910300H valve cover - L3M610210A mazdaspeed3 battery box tray - B37F56040D mazdaspeed3 battery box and ecu cover - L33X18593B mazdsapeed3 battery box front panel - L33X18591A tmic cover - L3K9207B0F oem egr tube - L3K920310A oem egr valve - L3K920300 maf - L3K913215 map - L3K918211A pcv - L3K913890 primary o2 - L33X188G1C secondary o2 - L34B18861A boost solenoid - L3K918741 ambient temp sensor - G51861764 knock sensor - L80718921 crankshaft position sensor - L3K918221A mazdaspeed oil cap - BLMS8ML02 oem fuel pump - L3K91335ZC oem boost tube from turbo to intercooler - L33L13760B mazdaspeed3 (fits 2007 ms6) oem boost tube from intercooler to throttle body - L33X13770A mazdaspeed3 oem cold pipe - L33X13241A 2006 mazdaspeed6 oem cold pipe - L3K913241B 2007 mazdaspeed6 oem cold pipe - L3K913241A turbo oil drain/return line - L33E14290 gasket for top - L3K914293 gasket for bottom - L3K914264 bolts for previous two items - 9XF002127L tensioner pulley - LF1715980E OEM cam follower or "collar" - L3K9-12-615 brakes mazdaspeed3 caliper bracket bolt - 9YA02A225 mazdaspeed3 front brake pads - B3YF3323Z mazdaspeed3 front rotor - B37F3325XA mazdaspeed3 rear brake pads - C2Y32648ZA mazdaspeed3 rear rotor - C25Y26251B mazdaspeed6 front brake pads - GPYA3323ZG mazdaspeed6 front rotor - G31Y3325XA mazdaspeed6 rear brake pads - GPYB2648Z and apparently you need this as well - GPYB2649Z mazdaspeed6 rear rotor - G31Y26251 suspension mazdaspeed3 front sway bar - B37F34151 mazdaspeed3 front end links - B37F34170A nuts for front end links - 999401001 mazdaspeed3 rear sway bar - B37F28151 mazdaspeed3 rear end links - B37F28170A nuts for rear end links - 9YB101005 gaskets head gasket - L3K910271C turbo to manifold - L3K913710 turbo manifold to head - L3K913460 downpipe to turbo - L3F213490 intake manifold gasket to head - L3K913111 throttle body gasket - L3K913655 donut gasket - L3A140581 bpv to cold pipe oring diamond shaped "gasket" - L3K920255 fasteners turbo and manifold studs - L33E13146A nuts for studs - JE1040355 miscellaneous |
| OEM MS6 engine part numbers | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 47 | 02-07-2016 01:34 AM |
| Looking for part numbers help | Necro_1015 | Mazdaspeed3/6 General Discussion | 1 | 03-28-2011 08:32 AM |
| Need help with part numbers | Blackspeed | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 02-21-2011 03:39 PM |
| Someone Hit my car need part numbers!! | KoleDeRacer | MazdaSpeed 3/6 - Appearance | 7 | 06-02-2010 09:56 AM |
