| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
(Thread Starter) | Neutral : -1 score i'm going to do my best to keep this updated. i'm compiling a list of the most common stock part numbers that people might need. mazdaspeed accessories mazdaspeed3 coilovers - RAMS8ML10 mazdaspeed3 springs with 2 rear camber links - GRMS8ML25 mazdaspeed3 rear camber links - GRMS8ML07 mazdaspeed3 cold air intake - GRMS8ML29 - who knows if they sell this? mazdaspeed3 cai filter - GRMS8ML10 mazdaspeed3 exhaust - GRMS8ML26 mazdaspeed6 springs - GRMS8MH14 mazdaspeed6 cold air intake - GRMS8MH32 - who knows if they sell this? maintenance regular filter with o rings - L321143029U spin on conversion - L31114311 and gasket - LF0114342 spin on filter - LF0514302A drain plug washer - 995641400 - this normally comes with the filter filter wrench - AKS75140 spark plugs - 000018L3Y3 drive belt - L3K915909A9U radiator thermostat - L33615170 ignition coil - L3G218100A9U Lighting OEM HID ballast/control module for 3, CX7, CX9 - D530510H3 exterior front bumper mustache - BA6R50B31A - to remove the holes left from your front plate bracket undertray aka lower shield - BP4K56111L undertray fasteners/clip-nuts (sides, need 4) - BAY6-56-496 or BR5S-56-496 undertray fasteners/clip-nuts (front, need 3) - FB01-50-133C undertray bolts (7 total) - 90720-0620 (old) or 90720-0616 (new, shorter bolt) skid plate, radiator support, the piece that is on the bottom in the front of the vehicle - BP4K56112 mazdaspeed3 wheels - 9965097080 mazdaspeed6 wheels - 9965117080 forged mazdaspeed wheels - BLMS8MZ01 center caps - G22C37190A interior coin holder - G22C55225 shift knob - GP9A46030B under the hood cylinder block - L3K910300H valve cover - L3M610210A mazdaspeed3 battery box tray - B37F56040D mazdaspeed3 battery box and ecu cover - L33X18593B mazdsapeed3 battery box front panel - L33X18591A tmic cover - L3K9207B0F oem egr tube - L3K920310A oem egr valve - L3K920300 maf - L3K913215 map - L3K918211A pcv - L3K913890 primary o2 - L33X188G1C secondary o2 - L34B18861A boost solenoid - L3K918741 ambient temp sensor - G51861764 knock sensor - L80718921 crankshaft position sensor - L3K918221A mazdaspeed oil cap - BLMS8ML02 oem fuel pump - L3K91335ZC oem boost tube from turbo to intercooler - L33L13760B mazdaspeed3 (fits 2007 ms6) oem boost tube from intercooler to throttle body - L33X13770A mazdaspeed3 oem cold pipe - L33X13241A 2006 mazdaspeed6 oem cold pipe - L3K913241B 2007 mazdaspeed6 oem cold pipe - L3K913241A turbo oil drain/return line - L33E14290 gasket for top - L3K914293 gasket for bottom - L3K914264 bolts for previous two items - 9XF002127L tensioner pulley - LF1715980E OEM cam follower or "collar" - L3K9-12-615 brakes mazdaspeed3 caliper bracket bolt - 9YA02A225 mazdaspeed3 front brake pads - B3YF3323Z mazdaspeed3 front rotor - B37F3325XA mazdaspeed3 rear brake pads - C2Y32648ZA mazdaspeed3 rear rotor - C25Y26251B mazdaspeed6 front brake pads - GPYA3323ZG mazdaspeed6 front rotor - G31Y3325XA mazdaspeed6 rear brake pads - GPYB2648Z and apparently you need this as well - GPYB2649Z mazdaspeed6 rear rotor - G31Y26251 suspension mazdaspeed3 front sway bar - B37F34151 mazdaspeed3 front end links - B37F34170A nuts for front end links - 999401001 mazdaspeed3 rear sway bar - B37F28151 mazdaspeed3 rear end links - B37F28170A nuts for rear end links - 9YB101005 gaskets head gasket - L3K910271C turbo to manifold - L3K913710 turbo manifold to head - L3K913460 downpipe to turbo - L3F213490 intake manifold gasket to head - L3K913111 throttle body gasket - L3K913655 donut gasket - L3A140581 bpv to cold pipe oring diamond shaped "gasket" - L3K920255 fasteners turbo and manifold studs - L33E13146A nuts for studs - JE1040355 miscellaneous |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score subed
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score philly you suck but this thread might win.
__________________ 2008 STi Intake Turboback AP |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score guys, if there's something you want on here, let me know. i can probably find the info |
![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
| Not Ranked : 0 score philly I need the number for the plastic fastener that holds the side skirts... Its white. I ran over a semi tire a few weeks ago and it ripped part of my side skirt off, its currently dangling. Looks normal, but its barely hanging on lol
__________________ 321 HP/348TQ-- 13.940 @ 106 /3kft ASL |
![]() Join Date: Jul 2011 Location: Jax, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score I was wondering if you could look up a part for me on a genpu. I am looking for the part that the BOV is connected to. I believe it's the cold side of the intercooler pipe.
__________________ · 2010 Mazdaspeed3 · 1988 RX-7 · 2003.5 Protege5 - Sold! |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score you talking about something in this pic? |
Groans: 94
| Not Ranked : 0 score yea that looks like it. They are little plastic grommets that hold that side skirt on
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score scatt, those clips are - B09251833 i'm not sure if that's what you mean though. perhaps get a pic...or honestly take it to the dealer |
Groans: 356
| Not Ranked : 0 score whats the part # for the missing half of your brain philly??
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score nator? |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score i organized these lists a bit more. does anyone else have part numbers that are commonly used? things that often need to be replaced? or things that you'll need for particular mods? |
![]() Join Date: Jan 2009 Location: Towson, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,747
Groans: 76
| Not Ranked : 0 score philly anyway you could get the part number for the light bulb behind the fan dial on the speed6? |
Groans: 1,940
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score my source is down. fuck... |
Groans: 76
| Not Ranked : 0 score Link failed |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score yeah, shit is dead. i guess i can't use that shit no more. shit was dope |
![]() Join Date: Oct 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,135
Groans: 234
Groaned at 154 Times in 122 Posts
| Not Ranked : 0 score anybody else know of a good site to find part numbers?
__________________ '08 MazdaSpeed3 - sold |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score MY all data site gives part numbers if you need any.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
Groans: 234
| Not Ranked : 0 score cool. thanks. next time i do i'll let you know darky.
Groans: 137
| Not Ranked : 0 score all data ftw
Groans: 137
| Not Ranked : 0 score bump for stock turbo oil drain line part number. EDIT: found some good stuff... oil drain/return line (one that us ATP turbo guys were forced to cut) = 14-290 the gaskets for the two-bolt flange on top = 14-293 (accompanying bolt x2 = 9kf00-2127L) and the gasket for the bottom = 14-264D (accompanying bolt x2 = 9kf00-2147L
![]() Join Date: Jan 2010 Location: North Jersey
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score im kinda new to this but uhmm, u got the number for the speed6 wheels? |
![]() | | #24 | ![]() |
![]() Join Date: Feb 2010 Location: Gahanna OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score very useful thanks for the information in this post i was able to find the part i needed with ease.
__________________ |
![]() | | #25 | ![]() |
Groans: 1,940
gasket - L3K914293 and bolt you've done correclty - 9XF002127L gasket for the bottom - L3K914264 | ||
![]() | | #26 | ![]() |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score Here's the whole rear diff setup for the speed6 » 17122 PLUG,MAGNET » 17180 BEARING » 26060 BREATHER » 27012 WASHER » 27018 SEAL,OIL » 27020 FLANGE,COMPANION » 27020A DRIVING & DIFF. » 27030 NUT,LOCK » 27100 DRIVING & DIFF. » 27110 GEAR SET,FINAL » 27141 BEARING,PINION » 27144 SPACER » 27150 CARRIER,DIFFERENTIAL » 27171 PIECE,DISTANCE » 27200 DIFFERENTIAL » 27222A CUP,BEARING-DIFFERENTIAL » 27235 BOLT,RING GEAR » 27238 SEAL,OIL » 27305 BEARING » 27320A COVER,REAR » 27351 CONE,BEARING » 27355 SHIM,ADJUST » 27401 SPACER » 27431 SPACER » 27583A SPACER » 27604 BOLT » 27681A CASE,COUPLING » 27691A SHAFT,OUTPUT » 2797X COUPLING » 2798XA SENSOR » 90781 BOLT & WASHER » 90901 NUT » 99201 WASHER » 99305 PLUG » 99571 RING,SNAP » 99601 BOLT » 99601 BOLT » 99601 BOLT
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
![]() | | #27 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score those aren't the pns...but thank you |
![]() | | #28 | ![]() |
Groans: 40
| Not Ranked : 0 score Then what r the pns? Lol, sorry. Sent from my iPhone using Tapatalk
![]() | | #29 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score MPS emblem . rear in chrome BR6C-51-721 |
![]() | | #30 | ![]() |
![]() Join Date: Aug 2009 Location: Monroe,OH
| Not Ranked : 0 score Do any of these part numbers cross reff with Ford part #'s? Especially the block and other transaxle parts? |
![]() | | #31 | ![]() |
Groans: 1,940
![]() | | #32 | ![]() |
![]() Join Date: Jan 2009 Location: Frisco Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 802
Groaned at 26 Times in 10 Posts
| Not Ranked : 0 score part number for the stupid diamond shaped gasket for the bpv to cold pipe??? |
![]() | | #33 | ![]() |
Groans: 1,940
![]() | | #34 | ![]() |
| Blue 2 shims ![]() Join Date: Feb 2009 Location: Roswell, GA
Rep Power: 1476 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Groans: 66
| Not Ranked : 0 score Where is the best place to order these brake pads? I'm about to have to replace them.
__________________ I used to drive a MazdaSPED 3. It was retarded fast. |
![]() | | #35 | ![]() |
Groans: 1,940
![]() | | #36 | ![]() |
Groans: 66
| Not Ranked : 0 score Thanks phillyb. Good to be back, I take it that since you're still posting your car hasn't died yet...
![]() | | #37 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score hahahaha. alive and well. though it's leaking coolant, cylinder 2 misfires all the fucking time. |
![]() | | #38 | ![]() |
| Not Ranked : 0 score Wow... this thread is great... Thx phillyb!
![]() | | #39 | ![]() |
Groans: 66
| Not Ranked : 0 score haha, well this website will save me a bit, its still gonna be 380 before labor if I gotta replace pads and disks though. Oh well. and man philly, why can't you get that thing to just run normal
![]() | | #40 | ![]() |
Groans: 1,940
(Thread Starter) | Not Ranked : 0 score lol dustin, this thread has been here for almost a year...you're just seeing it?
lol. and dude, it's one thing after the next. when i replace plugs and fix leak, i'll need to replace my meth pump...it's leaking. and then when i fix that, something else will pop up. | |
| OEM MS6 engine part numbers | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 47 | 02-07-2016 01:34 AM |
| Looking for part numbers help | Necro_1015 | Mazdaspeed3/6 General Discussion | 1 | 03-28-2011 08:32 AM |
| Need help with part numbers | Blackspeed | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 02-21-2011 03:39 PM |
| Someone Hit my car need part numbers!! | KoleDeRacer | MazdaSpeed 3/6 - Appearance | 7 | 06-02-2010 09:56 AM |
