> MSF KB - Mazdaspeed 3/6 - General
 Old 12-13-2011, 08:46 AM   #1
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
Default THE OFFICIAL INTAKE/ TURBO INLET PIPE THREAD!!
Updated 2/2015 by @Inquisitive;! Thank you!
**********THE OFFICIAL INTAKE/ TURBO INLET PIPE THREAD**********
NOTE: This is an informative discussion and a resource for gathering information on which route to go (Short Ram Intake, Cold Air Intake). All-in-all it is up to you on which you decide to go with.
Abbreviations used on this sticky:
Gen1 MS3---> Mazdaspeed 3: 2006-2009
Gen2 MS3---> Mazdaspeed 3: 2010+
Difference between SRI and CAI: According to research and discussions there are inherent pros and cons of both intake systems, but the main difference between a short ram intake and a cold air intake is where the intake gets its air from. A short ram intake sits and the engine bay where the air temps are warmer due to the heat the engine produces while a cold air intake sits away from the engine bay, usually in the front fender where it can suck in cooler air from the outside. Sucking in cool air is important because cool air is denser than warm air, which means cool air molecules are closer together, so more air can fit into a given amount of space. An engine creates power by mixing and compressing air and fuel. The more air you can fit into a cylinder at one time, the bigger explosion you can create which in turn creates more horsepower.
NOTE: I've decided to list the filter covers first because I noticed that people have expressed concerns about water penetrating their engines with the cold air intake systems. First, it is HIGHLY unlikely that this will ever be a problem. Rain and water droplets are no problem. The only case that could be a potential threat is if you drove into an extremely deep puddle, submerging the intake head. The car would have to be in the water so that the intake was submerged, and then it would start sucking up water, making your engine hydro-lock.
Intake Kits and Battery Trays
Intake Kits: SRI, TIP, CAI
Battery Trays to accommodate wide Intake Kits
CAI
Cold air is denser than hot air, and will ultimately have more power producing potential. Cold air induction (CAI) provides colder air than SRI / TIPs and can provide 12% more power and torque, but experiences pressure drops associated with the longer tubes used and are prone to easily hydro-locking in deep puddles (MSF wiki). Therefore, SRI / TIPs with air-box are the preferred option. Use a filter cover (CP-E, Outerwears. AMSoil) and / or splash shield (CP-E, Sure) if you are concerned about rain and water droplets, but they will not prevent hydro-lock if your intake is submerged.
SRI / TIP
Points to consider when improving the intake airflow are the future needs, such as BT for the K04 will most likely fail at some point. Although some members progress through different BTs, perhaps choosing a three inch intake initially will prevent having to replace it again later. The only problem with this course of action is that a MAF calibration must be done, which requires an ECU re-flash. See the “Larger than stock MAF housing” calculation below installation time in this section.
TIPs can flow 14% more, but are usually limited by the SRI. The main advantages to TIPs are the reduction of backwash turbulences away from the MAF housing from the blow-by valve and PCV.
However, SRI / TIPs allow the turbo to spike more easily. (Cobb) Note that with no other changes, tilting the MAF more than the OEM 15 degrees causes over fuelling with the ECU removing fuel through large negative LTFT and you exceed your previous g/s readings during WOT. MAF recalibration is strongly recommended.
Larger than stock MAF housing offers larger cross section for more airflow, but has less cooling to the MAF resistors due to the decreased air velocity. In order to develop a scalar for a larger than stock intake diameter, you must take the (New MAF Cross-Sectional Area) and divide (/) it by the (Stock MAF Cross Sectional Area), which is technically pi * radius squared (Djuosnteisn), but you can actually just take the new diameter squared / old diameter squared (ms3blackmica). Say you decide to upgrade to a 3" intake (76.2mm). The stock MAF housing is 66.5mm diameter (2.61811").
(76.2^2) / (66.5^2) = 1.313
Take 1.313 and multiply it by the entire MAF curve. Now you are ready to start your MAF Calibration. This is only an example for a 3" intake. (ms3blackmica)
CorkSport TIP
Power Series III 3” SRI / TIP with velocity stack and AEM dry air filter: “impressive improvement in power” with 35% more air flow; CorkSport Stage II Power Series SRI / TIP; 33 more HP and 25 lbs more torque from 14% more airflow with billet aluminium air straightener to prevent air leaks and CELs from inaccurate readings and dry air filter; CorkSport Power Series I SRI: 12 more HP, 17 more lbs torque with air straightener and dry air filter; relocated valve cover breather tube to prevent Genwon smoking turbo (rfinkle2).
Available from: CorkSport TIP
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $115.99 Standard Vent Breather Hose or Mazda Service Bulletin Fix 01-002/11; Polished or Powder Coated Black; Black, Red or Blue Silicone; Polished or Black Clamps
CorkSport SRI
Available from:
MS6
CorkSport SRI MS6
MS3
CorkSport SRI MS3
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $179.99 Black, Red, Blue or White Silicon Tubing; Black, Red (+$5) or Blue MAF (+$5); Blue, Red or Black Filter, Polished or Black Clamp
HTP 3" TIP
T6061, black powder coat, recirculation hose delete option with BOV, reducer size options, some require optional smaller HTP battery tray
Available from: HTP 3" TIP
MS6 (Yes), MS3 Gen1 (Yes) and Gen2 (Yes) $125 polished ($140 for black powder coated version) + optional: mounting bracket $10 + couplers $0 to $5 (2”, 2.25”, 3”, 4”), VTA $10, elbow $0 to $24 + shipping
Cobb SRI
MS6
MS3
11 HP gain, 16 lb-ft gain, removes pre-turbo restriction, optimises flow, minimizes turbulence, velocity stack, air flow straightener, conical cloth air filter, possibly CARB certified, reduces heat transfer; Cobb Turbo Inlet Hose: taper design to smooth airflow, silicone rejects high engine bay temperatures; steel wire reinforced to prevent collapsing. RMM replacement is recommended to avoid breaking the intake bracket.
Available from:
MS6
Cobb SRI MS6
MS3
Cobb SRI MS3
MS6 (Yes) $150, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $195
Cobb TIP
Available from: Cobb TIP
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $180
James Barone Racing (JBR) DISI TIP
(Stage I SRI, Stage II SRI / TIP, Stage III CAI) or Wide Path (3” tube 59% up to 3.5” 41% for 4” turbo inlet, but then requires a small battery box (JBR 51R) (Black, Blue, Red, White); or stock 2.25” turbo inlet) 5-ply, wire reinforced silicon. The TIP reduces turbulence seen in the OEM factory accordion rubber hose version and can flow to 300 g/s on stock K04 turbo. SS T-Bolt Clamps, plug to run in non-recirc mode; James Barone Racing (JBR) Filter: soap and water washable dry filter (avoids over oiling) can flow 200% more air than OEM while providing superior engine protection capable of removing extremely fine particles down to < 0.1 micron; developed with K&N (similar to CorkSport and Cobb)
Available from:
MS6
JBR TIP MS6
MS3
JBR TIP MS3
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $165 Silicone: Black, Blue, Red
JBR SRI
Available from:
MS6
JBR SRI MS6
MS3
JBR SRI MS3
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $170 MAF / Filter: Black, Blue, Red; Silicone: adds White
JBR Dry Filter Wrap
Available from: JBR Dry Filter Wrap
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $25 Black, Red, Blue
JBR Tru-3.0 Wide Path Full Aluminium / Silicone Intake
Aluminium
Silicone
Available from:
Aluminium
JBR Tru-3.0 Wide Path Full Aluminium Intake
Silicone
JBR Tru-3.0 Wide Path Full Silicone Intake
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $285 TIP: 2.25” Stock, 2.5” BNR, 3” (aluminium only), 4” GT; Silicone: Red, Blue, Black, White; Filter: Blue, Red or Black
HTP 3.5" Full Intake
Available from: HTP 3.5" Full Intake
MS6 (Yes) $414.75 for 51R battery or $435.70 small battery, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $275 stock battery or $432.92 for 51R battery; Coupler: 2.25”, 2.5”, 3”, 3.5”; Air Straightener included; VTA $10; Pre-Filter $30; Air Filter: Red or Black
HTP 3” SRI MAF Housing
Available from: HTP 3” SRI MAF Housing
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $154 polished aluminium, +$10 black powder coated; Elbow: 3” standard, 2.5” +$10; Air Filter: Red or Black; Pre-Filter $30
CP-E Nano SRI
See CP-E nViscid below
Available from: CP-E Nano SRI
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $223.60 Silver or Black; Filter: DFlow or SynoilD; Pre-Filter: $16.10
K&N Typhoon SRI
24 HP, mandrel bent aluminium induction tube with heat shield, Million Mile limited warranty
Available from: K&N Typhoon SRI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $696.18 Red Filter
CorkSport Airbox
MS6
MS3 for Cobb SRI
MS3 Gen2
Available from:
MS6
CorkSport Airbox MS6
MS3 for Cobb SRI
CorkSport Airbox MS3 for Cobb SRI
MS3 Gen2
CorkSport Airbox MS3 Gen2
MS6 (Yes) $98.99, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $99.99
JBR Tru-3.5 Wide Path Full Aluminium / Silicone Intake
Aluminium
Silicone
Available from:
Aluminium
JBR Tru-3.5 Wide Path Full Aluminium Intake
Silicone
JBR Tru-3.5 Wide Path Full Silicone Intake
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $295 TIP: 2.25” Stock, 2.5” BNR, 3” (aluminium only), 4” GT; Silicone: Red, Blue, Black, White; Filter: Black only
CP-E nViscid TIP
(Nano is OEM size and does not require a MAF calibration, but xcelXL is for BT and does): low-restriction design and silicon’s thermal insulation properties, 3-inch cross-sectional flow area throughout. Silicon is 1000 times more heat reflective than aluminium and being steel wire re-enforced, it prevents collapsing under vacuum
Available from:
K04
CP-E nViscid TIP for K04
BT
CP-E nViscid TIP for BT
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $218.40 for K04 or $234 for BT
CorkSport Stage III CAI
10-12% increase in power and torque. enables your engine to take in larger volumes of cold air for better acceleration, includes a one piece of billet aluminium MAF housing with included air straightener to prevent CELs, cleanable dry flow air filter, silicone connectors, T-bolt clamps, mandrel bent aluminium piping, optional TIP
Available from: CorkSport Stage III CAI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $279.99 with TIP +$70; Silicone, MAF and Filter: Black, Red or Blue; Pipe: Polished or Black Powder; Clamp: Polished or Black;
Injen CAI
15 HP gain, cast multi-stage tuned mid-section for “volumized” airflow throughout the entire power band. The SP Series tuned intake system uses MR technology for optimal gains and safe AFRs.
Available from: Injen CAI
MS6 (Yes), MS3 Gen1 (Not found), MS3 Gen2 (Not found) $293.03 Polished or Black
Cobb Airbox
MS3 Gen1
MS3 Gen 2
Available from:
MS3 Gen1
Cobb Airbox 3 Gen 1
MS3 Gen2
Cobb Airbox 3 Gen 2
MS6 (Not found), MS3 Gen1 (Yes) $199, MS3 Gen2 (Yes) $289
AEM CAI Gunmetal
Info: AEM Cold Air Intake Systems - Performance Air Intakes and Air Filters
Lightweight aircraft 6061 aluminium, mandrel bent, reinforced TIG-welded brackets, complete hardware kit with soft mounts for a guaranteed perfect fit, AEM’s lifetime DRYFLOW Synthetic air filter is 99.4% efficient, filters to one micron, and never needs filter oil, available powder-coated in red, blue or silver, or with a mirror-polished finish, guaranteed for life
Available from: AEM CAI Gunmetal
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $293.99
HKS Racing Suction Reloaded Short Ram Intake SRI
Info: HKS USA
Noticeably louder than stock, quicker spool time, polished intake piping, but must change the air filter every 5,000 miles
Available from: HKS Racing Suction Reloaded Short Ram Intake SRI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $338.50
ATP 3" MAF Housing Billet Aluminium for DENSO Element
Info: ATP TURBO
Attached directly to the turbo compressor inlet nozzle, which is often the bottleneck of the entire intake system. The OEM provides a pinched and convoluted air path. Specify Garrett 4" inlet or stock turbo 2" inlet, Specify colour: black, red or blue silicone connectors
Available from: ATP 3" MAF Housing Billet Aluminium for DENSO Element
MS6 (Yes), MS3 Gen1 (Not found), MS3 Gen2 (Not found) $95
ATP Turbo SRI
High flow inlet extension including 3" billet aluminium MAF housing, 3" inlet elbow, and 3" open element filter. Bolts onto ATP 3" inlet pipe kit (TIP) to complete a true high flow 3" intake tract. Deletes the restrictive factory air-box and clears the area inside the driver side fender and headlight area to run FMIC pipes in and out. Specify colour: black, red, or blue silicone connectors
Available from: ATP Turbo SRI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $185 in Black, Blue or Red
JBR Power Path Stage III CAI
14% HP and torque, capable if reducing intake air temperatures up to 15 degrees by drawing cool, fresh, oxygen rich air from deep inside the fender well area, far away from the heat of the engine, mandrel bent, 6061 polished aluminium tube & MAF housing with air straightener, reinforced silicone elbow, SS T-Bolt Clamps, Dry-Flow air filter flows 200% more air, no CELs guarantee
Available from: JBR Power Path Stage III CAI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $280 MAF / Filter: Black, Blue or Red; Silicone / TIP: plus White
CP-E Xcel CAI
MS6
MS3
CNC machined aluminium MAF housing with airflow straightener improves sensor precision
Available from:
MS6
CP-E Xcel CAI MS6
MS3
CP-E Xcel CAI MS3
MS6 (Yes) $310.96 Silver or Black: Filter: DFlow or SynoilD; Pre-Filter: $16.10, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $269.95
JFB SRI
Available from: can anyone assist with this one? @freakms3; ?
MS6 (), MS3 Gen1 (), MS3 Gen2 () $?
Injen SRI
Gain15 HP and 24lb torque with filter heat shield and a web nano-fibre dry filter
Available from: Injen SRI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $243.20 Polished or Black
Ultimate Racing SRI
12 WHP, 3.42 ft-lbs torque, high flow cone filter, MAF housing only
Available from: Ultimate Racing SRI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $150 + optional Black powder coating
Weapon Secret R SRI
Includes heat shield, laminar flow feeds 3X more air than conventional system, 6061 Aluminium on automated CNC mandrel bender and polished, SW1 Air filter features a tuned velocity stack to increase velocity and decrease turbulence, 1 Million Mile Limited Warranty open pore high density re-usable foam
Available from: Weapon Secret R SRI
MS6 (Not found), MS3 Gen1 (Not found), MS3 Gen2 (Yes) $320
Takeda CAI
Designed to place the air filter in the prime location to produce horsepower and torque gains, polished aluminium tube
Available from: Takeda CAI
MS6 (Not found), MS3 Gen1 (Not found), MS3 Gen2 (Yes) $280.50
TurboXS CAI
Mandrel bent 3” diameter aluminium pipes and a custom CNC machined aluminium MAF Sensor Housing, reduces the intake restriction caused by the stock air-box Available from: TurboXS CAI
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Not found) $309
DC Sports CAI
MS6
MS3
Info: DC Sports: Cold Air Intake System CAI4101 for Mazda
Washable dry filter (to one micron), funnel top and velocity stack, SS mesh
Available from: Amazon, eBay
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $144.83
Fujita CAI
Polished 6061 T6 aluminium intake tubing, silicone hose with nomex, carbon plated t-bolt clamps, Fujita super flow high performance air filter, TIG welded brackets, vibration mounts, Fujita duffel bag, Fujita hat, NOS energy drinkInfo: FUJITA EUROPE - Air Intake
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $215.97
Custom Airbox
Temperature drop observed making possible a delay in the FMIC decision
Instructions located at: MS3 normal progression of modifications (stages)
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) <$10 for aluminium sheet
Freek Tunes 3.5” (It’s new, but popularity is expected to rise @jdmadge_mx5; )
AEM dry filter
Available from: Freek Tunes 3.5”
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $299 Coupler: K04, BNR S3, 3”, 4”
DIY Alternative to ATP
Spectre Air Filter
Available from:
 3? TIP 3” TIP
Gen2 red air filter $24.06
Spectre 3” MAF
Available from:
 3? MAF 3” MAF
Gen2 $29.99
Boesch 3” (76mm) to 2.5” (63mm) Silicone Reducer
Available from:
 Boesch 3? to 2.5? Coupler Reducer Boesch 3” to 2.5” Coupler Reducer
Gen2 $25 + $8 shipping
MAF Honeycomb Insert
Available from: Honeycomb insert (5:1 shown) order the 6:1 ratio $12.67
JBR 51R Small Battery Tray
MS6
MS3
Available from:
MS6
JBR 51R Small Battery Tray MS6
MS3
JBR 51R Small Battery Tray MS3
MS6 (Yes) $95, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $120
HTP Small Battery Tray
MS6
MS3
Available from:
MS6
HTP Small Battery Tray MS6
MS3
HTP Small Battery Tray MS3
MS6 (Yes) $158.60 + Black Wrinkled Powder Coat $10, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $145
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline
The Following 6 Users Say Thank You to DISIindahead For This Useful Post:
Alextopdj (06-24-2013), cciepunk (12-27-2013), demonspeed09 (12-16-2012), esestak (01-22-2013), Muzzybud (12-04-2015), turbod_3 (04-23-2013)
 Old 09-19-2012, 01:29 PM   #2
Discuss:
THE OFFICIAL INTAKE THREAD!!
Raider is offline
THE OFFICIAL INTAKE THREAD!! DISIindahead Mazdaspeed3/6 General Discussion 220 10-08-2017 09:39 PM
Official Gen One MS3 CBE Thread!! supertubesocks MazdaSpeed 3 - Engine, Transmission & Driveline 53 03-06-2016 11:18 AM
SilverDemon/JM Fabrications Intake Manifold Interest Thread SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1707 02-25-2013 03:33 PM
MA Performance Product and Info Thread Rev 3 Intake Manifold maperformance Modern Automotive Performance 195 05-21-2012 02:28 PM
Page generated in 0.43022 seconds with 21 queries
