Like Tree3Likes
 Old 03-22-2012, 11:38 AM   #401
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Originally Posted by Speed3eak View Post
^ Didn't know that.
I've got the k&n sri, oiled it when I put it on. Have had it on for about 1.5k miles, no code yet. We will see though when it starts to get colder out. Lowest temps I've seen so far have been 50-ish.
I wish it would get warmer out, because when I shift from 1st to 2nd WOT with the dsc off, my tires just chirp perpetually in 2nd until I let off the gas. I desperately want CP-E to release their engine mounts because this kind of tire hop is just ridiculous. It's probably down to the weather though, but this has happened twice in 50-60 degree weather. I checked the RMM and it's bolted down tightly (cp-e 75 duro), so I dunno.
So I guess I should update - I had the K&N on for ~7k miles without a problem. fuel trims stayed fine. I eventually swapped it out for a CP-e CAI just because I wanted to see lower IATs (using a TMIC), and I got a great deal on it. The K&N is great though, but for the price you can get a used intake and a TIP so there's that.
I didn't install a TIP until after the downpipe. Made a noticeable difference, which is weird. I guess the TIP does become a bottle neck at some point, though probably not until you're almost fully bolted.
Got the JBarone side mounts instead of the CP-e mounts. SU mounts look to be a little bit cheaper still and people love those as well. JBarone mounts replace the bottom portion on the transmission mount, while others replace just the plate (... I think... don't remember fully CP-e's design)
Honestly, if I was getting an intake for the first time, I'd just get whatever came up used unless you have your heart set on a SRI or a CAI.
Or, if you're planning on getting an accessport, I wouldn't even bother with one of the name brand intakes - just get a section of 3" MAF housing:
3" MAF Housing - Billet Aluminum-for DENSO Element
And a 3" filter. I don't know a whole lot about filters so I won't express a preference for one or the other, but I'd invest in a high quality filter FWIW.
Get some "mounting hardware" from lowes/home depot, and you've got an intake for less than $200. You're also going to need a coupler to reduce it down to the stock TIP, I forget what diameter it is though.
Also, I'm sure you can find the MAF housing for cheaper than $90, it was just the first thing that came up.
Speed3eak is offline
 Old 03-27-2012, 09:58 PM   #402
Scoobs's Avatar
Posts: 750   (View Stats)
Scoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the world
Originally Posted by crtguns View Post
Dude- you just need to go to edge autosport, get a Cobb SRI, and put it in your car.
No CEL, no hassle, no problems. Just results.
No more thinking, no more searching.
Edge Autosport, give them your credit card number.
Then get your resnators and mufflers removed.
Your car will be all shouty and assertive at all rev ranges.
I just ordered my Cobb SRI from Edge Autosport today, as for the exhaust work, I'll wait for my AP, FP upgrade, DP, CBE.
I ain't modding the OEM parts, never know if I'll need it down the road.
Sold
2010 Speed3 Black Mica tech pack, JBR RMM 80 duro, Cobb SRI, stupid horn fixed with low tone add on.
New
2012 Mazda2 GS Aluminum Metallic Mica, Corksport rear torsion bar, Corksport H11 Led fog bulbs, Piaa H4 x-treme white bulbs, AWR rmm 70duro....more to come
Wife's car
2011 Mazda2 True Red GS (Touring in the US), wifes car, no mods so far but she want a Corksport CBE, Corksport SRI and a drop in the futur. <-----
Scoobs is offline
 Old 04-21-2012, 01:19 PM   #403
Scoobs's Avatar
So, I have the COBB SRI installed. The engine feels better, 1l per 100km better on gas (so it will pay it self in 2000km).
The sound is great, no need to waste money on a BPV until it leaks on higher boost level but that will be next year.
Sold
New
Wife's car
Scoobs is offline
 Old 06-19-2012, 11:32 AM   #404
narezzaspeed3's Avatar
Posts: 171   (View Stats)
narezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the world
Groaned at 5 Times in 1 Post
hey guys, can someone edumacate me between stage 1 vs stage 2 corksport intake?
narezzaspeed3 is offline
 Old 06-19-2012, 11:36 AM   #405
Dr. Speed's Avatar
Posts: 610   (View Stats)
Dr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the world
Stage 2 comes with TIP... stage 1 does not.
Dr. Speed is offline
 Old 06-19-2012, 11:47 AM   #406
yes, but what the TIP do for you? and more like if I decide to get stage 2, do I need tune? or do I need to change/upgrade something else?
 Old 06-19-2012, 11:51 AM   #407
Dr. Speed's Avatar
It's basically like the 2nd half of the intake right before it reaches the turbo. Just helps remove more of the stock bottleneck. If you're getting an intake, just get one with a TIP. And yes, you should get a tune and fuel pump upgrade if you plan on doing ANY power mods. That, more than anything else, will give you more useable power and ensure you're running safe.
 Old 06-19-2012, 12:52 PM   #408
CorkSport's Avatar
Posts: 3,416   (View Stats)
You also save $39 by purchasing the Stage II intake compared to the TIP and the Stage I intake.
-Derrick
WWW.CORKSPORT.COM
CorkSport is offline
 Old 06-19-2012, 01:02 PM   #409
-Derrick
i'm sold,
but if i get the stage 2 SRI/TIP how soon do i need to upgrade my HPFP/Internals?
 Old 06-19-2012, 01:30 PM   #410
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
i'm sold,
You won't know unless you have the Cobb Access Port to monitor your fuel pressure. Personally, I'm waiting to order my SRI and TIP. I'll order that, the AP and internals all at once. Then you can tune for your upgrades and actually see some power increases.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
 Old 06-19-2012, 02:12 PM   #411
so SRI and TIP mod requires me to upgrade internal/hpfp? damn. staying bone stock then. LOL.
 Old 06-19-2012, 02:37 PM   #412
bigriver's Avatar
Posts: 1,123   (View Stats)
Bone stock is kinda fun too lol. I actually dont mind it at all after demodding my car.
bigriver is offline
 Old 06-19-2012, 02:42 PM   #413
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Some people get away with SRIs, others throw Lean CEL codes. I prefer not to take the chance.
Like I said, I'm choosing the safe route and waiting til I get all my shit at once.
Rich Tuned
330WHP and 363TQ
CWP_MS3 is offline
 Old 06-19-2012, 03:21 PM   #414
shawn19's Avatar
Posts: 51   (View Stats)
shawn19 is infamous around these partsshawn19 is infamous around these parts
Groaned at 38 Times in 11 Posts
Default Corksport
How would you guys rate the corksport sri with turbo inlet pipe? Is it worth buying for $250? If not what would you guys recommend for an sri?
shawn19 is offline
 Old 06-19-2012, 04:25 PM   #415
Dr. Speed's Avatar
Best bang for your buck. Get it.
 Old 06-19-2012, 06:16 PM   #416
Speed3eak's Avatar
Groans: 82
This entire thread is dedicated to the discussion of SRIs
I'm not trying to be a dick but maybe you should search and read some before posting
I'm sure someone has posted their review of the corksport somewhere on this website somewhere, lots of people have bought them
There's been some debate about whether a TIP makes any difference at all on the stock turbo, so if you read and decide it isn't worth it for you, then you might well go with a different one.
But if you read and decide that you want it, then you might want to spend the extra $$$ and get the combo pack
Again, if it were one size fits all this thread would be 1 post long
But it isn't
So to answer your question . . . It depends.
You're going to get a lot more answers doing a simple search than you will asking people which intake they'd recommend. Do you want an oiled filter? A dry flow? Do you want stock MAF diameter? An air straightener? Where do you want to draw air from? The engine bay, the tire well? Are you planning on modifying the car further? Do you have a preference for color? Warranty? How experienced are you at working on cars? What climate do you live in? Do you have a tuning solution?
Every one of those questions is something that could swing your decision one way or the other.
The point is search before you post. Your question has been answered hundreds of thousands of times over. No matter what your question is, unless you're dropping in a corvette engine and converting to RWD, your question has been answered.
 Old 06-19-2012, 10:47 PM   #417
shawn19's Avatar
you come off sounding like a dick. Thanks for the advice.
shawn19 is offline
 Old 06-20-2012, 11:04 AM   #418
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Trying to find out what kind of intake this is. It looks like a cs TIP (blue silicone and t-bolts) and CPE sri. WILL donate asap. thank you
covelife1016 is offline
 Old 06-20-2012, 12:25 PM   #419
bigriver's Avatar
Thats not a cpe sri. The cpe has the breather hose connection right below the maf housing and the oem breather hose connects directly (no coupler is used).
bigriver is offline
 Old 06-20-2012, 04:00 PM   #420
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Cheapest SRI/TIP combo on the market, it's also a nice, well made piece. I have it and love it.
ASHMS3 is offline
 Old 06-20-2012, 06:21 PM   #421
shawn19's Avatar
Did you have to tune for it and also did you have any problems with CEL?
shawn19 is offline
 Old 06-20-2012, 06:48 PM   #422
bigriver's Avatar
The stickies would provide helpful answers to your questions. Not all cars perform exactly the same. Also install fails usually trigger codes, not the intake itself.
bigriver is offline
 Old 06-20-2012, 07:05 PM   #423
ASHMS3's Avatar
Groans: 126
I didn't have any issues with CEL's at all. But, to be honest if I had it to do again I would've done AP first. Much better power gains and a way to monitor what's going on with your car. AP is all win all day.
ASHMS3 is offline
 Old 06-20-2012, 09:27 PM   #424
shawn19's Avatar
If I have the AP do i also have to get a tune at a shop as well when i get aftermarket parts or does it depend on what the mod is?
shawn19 is offline
 Old 06-21-2012, 03:39 AM   #425
ASHMS3's Avatar
Groans: 126
No, the AP comes with what they call Off The Shelf maps. You pick the OTS that matches your mods, flash it and go. You also can download ATR and self-tune, or get an e-tune from one of our tuners, all of which are very good. Go to Gen 2 General Discussion and click on the "link to all ultimate resource threads" near the top, its a sticky. Read all of those links and you have a better idea of what's up with your car, and modding. If you need anyhing else, let me know.
ASHMS3 is offline
 Old 06-22-2012, 11:46 AM   #426
shawn19's Avatar
Very helpful. Thank you very much. Last question...So i can use the stage 2 corksport sri with tip even on my stock speed 3?
shawn19 is offline
 Old 06-22-2012, 12:13 PM   #427
shawn19's Avatar
Also if i got the Corksport would I be able to tune it still with the cobb acessport or do i need the cobb sri in order for that to work?
shawn19 is offline
 Old 06-22-2012, 12:34 PM   #428
ASHMS3's Avatar
Groans: 126
@shawn19 On Cobb's website the AP OTS maps are available for just about every intake on the market, Corksport included. But, you shouldn't have any issues running it without an AP if that's the route you choose. I ran mine for about 3 months without an AP, no problems. But like I said earlier, if I were to go back and do it again. AP would definately be my first mod.
ASHMS3 is offline
 Old 06-22-2012, 02:58 PM   #429
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
I hope you. are being sarcastic because his post was a helluva a lot nicer than most would give you and his advice was actually pretty sound. If you don't learn that pretty early on you are going to have a hard time in here
2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's
Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice)
OBAMA SUCKS
Stratified Tune by Lex
Bosox is offline
 Old 06-22-2012, 03:15 PM   #430
shawn19's Avatar
Okay thanks and last question...What hp and tq gain did you see with just the intake, tip, and ap?
shawn19 is offline
 Old 06-22-2012, 03:24 PM   #431
bigriver's Avatar
Please stop being lazy. You can find this easily.
bigriver is offline
 Old 06-23-2012, 12:15 AM   #432
shawn19's Avatar
I dont get why half the Mazda owners are such assholes. I asked a simple question that ASH said I can ask if i had further questions. So mind your own business and shut the fuck up. Thanks buds.
shawn19 is offline
 Old 06-23-2012, 06:59 AM   #433
ASHMS3's Avatar
Groans: 126
According to Virtual Dyno, which has been proven fairly accurate. I am sitting at 240whp/270wtq. I could get more out of the intake, but I am tuning around the stock pump. So, I am being pretty conservative with the boost. People are ribbing you because if you searched and read a few threads on your own you can find these answers. I don't mind helping, but poke around the forum a bit and learn about your car. Take it easy and happy boosting.
ASHMS3 is offline
 Old 06-23-2012, 08:16 AM   #434
Dr. Speed's Avatar
Actually, they're pretty nice and helpful if you just take the time to show you've put in some searching effort and don't ask questions to which there are readily available answers. I've been lurking, learning, and posting on this forum for several months and I'm not even getting my speed3 'til January (and I've never been flamed). Learn how to do the forum thing the right way and it'll be a huge benefit to you. MSF is 100x better than any other car forum I've been a part of.
 Old 06-23-2012, 08:59 AM   #435
bigriver's Avatar
Don't muck up good threads.
And DONATE since @ASHMS3 did your searching for you.
bigriver is offline
 Old 06-23-2012, 05:04 PM   #436
how are you tuning around the stock pump?!?!?!?!!? :O
 Old 06-23-2012, 05:09 PM   #437
ASHMS3's Avatar
Groans: 126
Just by keeping the boost turned down to around 17, and taking logs frequently to make sure it's holding up. I could probably eek a bit more out, but I see no reason to play with fire.
ASHMS3 is offline
 Old 06-23-2012, 05:15 PM   #438
you gotta tell me how to do that :[ ha. cause im gonna be getting a CS SRI and debating if i should get the TIP cause i dont see myself buying internals anytime soon.
 Old 06-23-2012, 05:21 PM   #439
ASHMS3's Avatar
Groans: 126
I would go with the stage 2 package with the TIP included. Do you have an AP? Because that and ATR is what I'm using to tune.
ASHMS3 is offline
 Old 06-23-2012, 05:25 PM   #440
im in the process of buying an AP. ha. ATR?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f625/2010-mazdaspeed-3-performance-air-intake-discussion-125157/
Mazda speed3 parts This thread Refback 09-05-2013 02:39 PM
2010+ Mazdaspeed 3 performance air intake discussion Nataphen 2010 MS3 - Turbo Induction 467 12-30-2017 11:09 AM
ARk performance catback exhaust for the 2010 up Mazdaspeed 3 ERZperformance ERZPerformance 9 09-24-2017 10:26 AM
Product Release! CorkSport Cold Air Intake for the 2010+ Mazdaspeed 3 CorkSport CorkSport 26 09-08-2012 09:14 PM
Page generated in 0.58649 seconds with 31 queries
