![]() | | #161 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score
To be true ram air it must feed the intake only. It must have an opening large enough to flow the maximum cfm and air mass requirements of the engine under maximum power. It must feed a completely sealed plenum chamber in which the chamber size starts small and the cross section gets larger as the air enters and expands. It is a form of very mild supercharging. What happens is that as the air enters through the smaller intake hole it is then allowed to expand in a controlled manner that allows the air velocity to decrease. When the velocity goes down, pressure goes up. This has to be done in a very precisely shaped and controlled chamber shape that prevents turbulence. At somewhere between 100 mph and 200 mph these carefully designed scoops and chambers create about 1 psi of positive pressure in the intake manifold. Yeah, NHRA Pro Stock drag cars use these types of true ram air intakes, but only see about 1 psi of increased positive pressure beginning in the 100-115 mph range and increasing slightly with increased speed. What we have is a cold air intake (not ram air) and it's for the intercooler. That's a good thing, but it's not ram air. Here is what a ram air intake looks like. It is on Warren Johnson's Pro Stock GTO.
![]() | | #162 | ![]() |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score the corksport fmic w ram air. The ram air goes where the tmic did, and it is sealed off by the hood shroud. |
![]() | | #163 | ![]() |
| Not Ranked : 0 score Please read my edited post just above. What you have is a cold air intake. Cold air is very good. I like CAI's for that reason. But the CS "ram air" not ram air. A lot of companies call cold air intakes ram air, but unless they meet the design criteria, they are not. And at best you get 1 psi of increased MANIFOLD pressure with the best designs and only realize that above 100 mph. In the case of our cars, the MAF sensor and ECU are going to control your boost to the mapped target level, so you'd not even see that one psi gain, if you had a true ram air system.
![]() | | #164 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Please look at the Corksport FMIC kit. The kit moves the air intake to where the TMIC used to be, and forms a seal with the hood there. What he has is a ram air intake. |
![]() | | #165 | ![]() |
| Not Ranked : 0 score I'm familiar with the kit. Air comes into the intake from where the TMIC used to be. I fully understand that. Ram air design requires far more than that. What ram air is doing is increasing manifold pressure, not just providing cold air, as good as cold air is. And the most exotic ram airs are on Pro Stock normally aspirated drag cars and with thousands and thousands of dollars of development and testing, they get 1 psi at 100 mph and above. It's a good design - no - a great design to have cold air getting to the filter. But this is not ram air. There is no true ram air system for our cars and we wouldn't benefit from it with a turbocharger and intercooler between the air filter and the intake manifold and with boost pressure being targetted and controlled by the ECU. Show me that boost is higher with this "ram air" intake compared to a good SRI or CAI. That's what it would have to do. And it would have to be higher at high speed and not merely high rpm. Difference shows up on the road or going down the strip but not on a dyno. Sorry, guys I think we got off the topic. My bad.
![]() | | #166 | ![]() |
Groans: 134
| Not Ranked : 0 score You say that it must feed the intake only, but it does. The shroud pushes against the top of the filter cover. I have no idea about the cfm and air mass requirements of the engine under load. It is a small space which opens into a larger one. And I have no idea about the rest of that stuff. Anyway, 3 things. 1) I do get that it is not a ram air after your explanation, the above was just to point out a few similarities. 2) I guess, it really wouldn't matter anyway, because although I break the 100mph barrier from time to time, I don't spend enough time north of that mark to really get the benefit (which I don't have) anyway. 3) The intake which sits on top of the engine is heat shielded quite well and it does pull air in directly from the atmosphere and not the engine bay. Do you have any idea if this gives ANY advantage to a regular CIA? Either way, I guess it's a cool and unique way to make use of my hood scoop. ah, your last post clarified more. I don't think we got off topic though. This is all helpful information about intakes. |
![]() | | #167 | ![]() |
| Not Ranked : 0 score I think it is a good design. The object is to reduce IAT's and therefore BAT's. It all starts with the temperature of the air the MAF sensor "sees." Since the air is coming in from the outside and straight to the intake, in theory the CS top mount "ram air" might be superior to what we call CAI's. The truth is that a CAI for our cars is still in the engine bay, although the MSCAI and AEM CAI put the filter within about an inch of the outside air slots in the left front fender well. True CAI's would actually isolate the filter from the engine bay entirely. And as you point out, heat soak is not out of the question for you either, because it is sitting right on top of the engine. But it is a nice elegant way to get some cooler air while dressing up the ugly empty space where the old TMIC used to be. Honestly, I think the difference, if there is one, is academic and theoretical. What matters is the air temp that the MAF sees. Get it down whatever way you can and you have the potential to make more power. Just one opinion.
![]() | | #168 | ![]() |
Groans: 134
| Not Ranked : 0 score CIA... whoops. LOL Thanks for the information. Even if it is just an opinion, it seems pretty educated, and there is very little of that with this set up. |
![]() | | #169 | ![]() |
![]() Join Date: Aug 2008 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
Groaned at 81 Times in 33 Posts
| Not Ranked : 0 score Here's a question, Can anyone take pictures of their intakes from directly above the engine? I've noticed that both Corksport, CP-E, COBB and K&N all have different mounting points and different angles of which they put their filter. COBB - just about a 90* angled coupler that puts the filter right infront of the battery box CP-E - seems to only be about 60* angle? Puts the filter closer to the chassis Corksport - seems to just hang there, no mounting point at all actually K&N - mounts to the bpv, almost identical to COBB's setup. Can anyone take pictures of their setup's and post?
__________________ Mike 2008.5 CWP Mazda CX-7 Sport FWD - hers 2008.5 CWP Mazdaspeed 3 GT - traded 2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold |
![]() | | #170 | ![]() |
| Big Titty Sucker ![]() Join Date: Nov 2010 Location: NY
Rep Power: 744 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 579
Groans: 139
| Not Ranked : 0 score Okay, I have a general question. Lets say you will not be monitoring anything since you car is strictly a daily driver and will be staying stock other wise. What intake do you think is the “safest” as far as keeping things where they need to be and not causing CEL's and issues? |
![]() | | #171 | ![]() |
![]() Join Date: Dec 2010 Location: Lake St. Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
![]() | | #172 | ![]() |
![]() Join Date: Feb 2010 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
__________________ SOLD on 08/2013 2010 Black Mica MazdaSpeed3 Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC | |
![]() | | #173 | ![]() |
| Banned ![]() Join Date: Feb 2010 Location: Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 500
Groans: 132
Groaned at 166 Times in 92 Posts
| Not Ranked : 0 score I love the Genpu crowd, we're still stuck on intakes |
![]() | | #174 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 959
Groans: 59
| Not Ranked : 0 score Sorry if I missed it in this thread, but the Cobb SRI DOES fit the 2nd gen, or no? Are there other SRI's from the 1st gen that fit the 2nd gen?
__________________ [SIGPIC][/SIGPIC] Better to remain silent and be thought a fool than to speak out and remove all doubt. -Abraham Lincoln |
![]() | | #175 | ![]() |
| Not Ranked : 0 score It fits, and it's roughly the same size, although a few people have gotten CEL's from it. Then again, they've gotten them from SURE SRI's and initially the Corksport SRI's as well.
![]() | | #176 | ![]() |
Groans: 59
Unfortunately, I still can't make out from this thread which is the best. I've narrowed it down to maybe the Cobb, cp-e or the Sure. Don't know, though.
__________________ [SIGPIC][/SIGPIC] Better to remain silent and be thought a fool than to speak out and remove all doubt. -Abraham Lincoln | |
![]() | | #177 | ![]() |
| Not Ranked : 0 score Well, SURE is currently clearing up some CEL issues with a few owners who have had issues. COBB still only specifies on their site that the intake works with 07-09, even though much hasn't changed other than the intake on the +10 is a not even a few hundreths of an inch larger. And CP-E has a great setup, I just dislike the brand of filter they use. So i'm ultimately fucked trying to pick one as well. FWIW, COBB's uses all the stock equipment, where it seems CP-E and Corksport utilize a different intake breather valve hose.
![]() | | #178 | ![]() |
| Not Ranked : 0 score Lol trolls gonna troll
![]() | | #179 | ![]() |
| Not Ranked : 0 score Delete. Sorry. Posted in wrong thread! My bad.
![]() | | #180 | ![]() |
Groans: 59
![]() | | #181 | ![]() |
| Not Ranked : 0 score ^^^Oh my bad... I thought you were being sarcastic. Like as if you were following up MS33SM's post. Oh yeah and I thought you had a Gen 1 for some reason.
![]() | | #182 | ![]() |
![]() Join Date: Jan 2011 Location: Wisconsin
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
![]() | | #183 | ![]() |
![]() Join Date: Feb 2011
Rep Power: 0 ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score I have a K&N Typhoon. Got a great deal on it. It works fantastic, the gains were immediately noticeable, and the sound is lovely. I also have CS TIP that I installed months later. The TIP (I don't see why aluminum or silicone would be better when you consider the volume of air getting sucked in per minute) markedly increased the sucking/whooshing sound and you can clearly hear the turbo winding up. Both are great. Are there better intakes for cheaper? Probably. But at the time I knew the K&N name, reviews promised an easy install, with no CEL's. I did have a CEL the day after I installed it, but I pulled the code and the code was a 1000tightenthegascapidiot code. I like how the KN has a boxed area to prevent the hot air from getting sucked in.
__________________ 2010 Speed 3. Hooker Red. K&N Typhoon intake, Corksport TIP, CP-E RMM, CP-E driver and passenger motor mounts, Corksport catless test pipe, CP-E CBE, CP-E TMIC. |
![]() | | #184 | ![]() |
| Banned ![]() Join Date: Nov 2009 Location: Los angeles,Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
Groaned at 14 Times in 6 Posts
![]() | | #185 | ![]() |
![]() Join Date: Sep 2009 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
| Not Ranked : 0 score cp-e, k&n, or corksport for intakes right now. Sure aeros after the issue is sorted out (which i think it is). You could try the Cobb but even on Gen 1's, they can give you a CEL. |
![]() | | #186 | ![]() |
Groans: 139
| Not Ranked : 0 score Guys running the CP-E, how are your readings? All good? |
![]() | | #187 | ![]() |
![]() Join Date: Apr 2010 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
Groans: 39
| Not Ranked : 0 score I bought Aetherfury's CP-E CAI (after I said I would probably get an SRI) when he traded in his MS3 for the STI. I've had it installed for about a month now and no CEL's. I don't have anything to show fuel trims or anything though. |
![]() | | #188 | ![]() |
Groans: 139
| Not Ranked : 0 score |
![]() | | #189 | ![]() |
Groans: 39
| Not Ranked : 0 score It sounds about the same as stock when you lay off the boost. But as soon as you hit the boost, you can really hear the "whoosh" sound. It's a nice setup for a CAI because there's really no way water would ever get to the filter unless you were sitting in a 2 foot deep puddle. The filter is angled upwards, and it's pretty well isolated from the elements with the splash guards. |
![]() | | #190 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score i said it on the first page but i just wanna reiterate that i absolutely love my nano. never had a cel. never had any issues. the quality is obvious upon close inspection. zero complaints aside from needing a TIP to complete the setup and not havin no money yo
__________________ |
![]() | | #191 | ![]() |
Groans: 39
| Not Ranked : 0 score I'd like to get a TIP also, but I just can't justify spending $200 on it. |
![]() | | #192 | ![]() |
![]() Join Date: Feb 2010 Location: York, Pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,685
Groans: 50
Groaned at 15 Times in 8 Posts
| Not Ranked : 0 score I have a COBB SRI from a Gen 1 and have had 0 problems for about 10k now..
__________________ 2012 CWP Tech Package: Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems// |
![]() | | #193 | ![]() |
| Not Ranked : 0 score Save yo money, it's not that drastic of an improvement and a total pita to install imo.
![]() | | #194 | ![]() |
| Not Ranked : 0 score note on tip / aka tih design... Corksport relocates the valve cover vent onto their tip, intake combo (it is your choice {the default I believe} ). This does 2 things. It deletes the fitting from the silicone 45 degree elbow after the maf housing, and relocates it onto the tip. That may sound like nothing, but your tip will need to be capped, or your sri silicone tube for that matter if you mix intakes and corksport's tip. Again, just keep in mind you can order the Corksport set-up the traditional way, or with the valve cover vent on the tip. This is very specific to Corksport's tip and intake, all others use the stock valve cover vent plumbing locations. |
![]() | | #195 | ![]() |
![]() Join Date: Nov 2010 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Okay, I've been following this tread for a while now and think that it's time that I contribute a little. Let me caveat by saying that I am in NO way and automotive engineer and all the knowledge I have on this subject came from this tread. Now to the business... I took delivery of my Sure Aeros on 9 Feb but did not get around to installing until 18 Feb. I am currently using PLX kiwi wifi with my iphone and REV for data logging. Since installing the only issue I have had with my trims was on the initial drive home. After driving 80 mph constantly for about 10 miles I exited the freeway coasting in neutral and I had +11SB1 and +20LB1. This is the only time that this has happened. Since my 50 mile break in period I have not seen my trims this high since. Today I drove in to work (about a 59 mile drive) and I kept a close eye on my trims. Since install I have driven 220 miles with no CEL or pending trouble codes (knock on wood). The temp was 31 degrees. Idle - 0SB1 +12LB1 WOT - -7SB1 +11LB1 Medium Acceleration (3000rpm) - [-3 through +7]SB1 [+5 though +10]LB1 My trims did not surpass this range even when coasting off the freeway in neutral. I know that this is probably a jumbled mess, but I did want to contribute. I attempted to export this data to export and share but it is way too much info to be of any benefit. If you have any pointed questions I'll do my best to answer them. Thanks
__________________ R.I.P. ![]() l 2010 VRM MS3 w/ Tech l l ETS TMIC l SURE Aeros, TIP, Torq R3 l Autotech Internals l FORGE BPV v1 l Denso ITV-22 l JBR SSP, SSB, HSK, RSB l Magnaflow CBE l COBB AP w/ RFinkle2 Tune l Eibach Pro Kit l Tenzo DC5 v1 Continental Extreme Contact DW Tuned 235/40/18 (Summer) l Enkei RPF1 Kuhmo Exsta 4X XL 225/40/18 (Winter) l Dual Aeroforce Interceptor Scan Gauges l Block8Head Vent Pod l Current 2013 PBP Evo GSR K&N Intake/UICP UR ABE Swift Spec R 18x9.5 Work Emotion CR Ultimate ARC Knob |
![]() | | #196 | ![]() |
Rep Power: 0 ![]() Thanks: 0
![]() | | #197 | ![]() |
![]() Join Date: Nov 2010 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 227
Groaned at 74 Times in 30 Posts
| Not Ranked : 0 score can someone tell me what the actual part number is on the K&N? I know it is a 69 series, but what is the full part number? |
![]() | | #198 | ![]() |
Groans: 386
Let's see... If I was trying to find out something about K&N, where would I look? Maybe their website? Oh, look! They let you put in the year, make, and model, and give you all parts that fit your car! K&N Products by Vehicle Search - Year, Make, Model, Engine Search | |
![]() | | #199 | ![]() |
![]() | Not Ranked : 0 score did any of you guys with aftermarket intakes suffer power loss on part throttle driving? this what really concerns me |
![]() | | #200 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score All of your posts are moot, because someone has done "CAM SWAPS". Incredible... I didn't even know cam swaps were possible! Holy crap. You go to MIT? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f625/2010-mazdaspeed-3-performance-air-intake-discussion-125157/ | ||||
| Mazda speed3 parts | This thread | Refback | 09-05-2013 02:39 PM | |
| 2010+ Mazdaspeed 3 performance air intake discussion | Nataphen | 2010 MS3 - Turbo Induction | 467 | 12-30-2017 11:09 AM |
| ARk performance catback exhaust for the 2010 up Mazdaspeed 3 | ERZperformance | ERZPerformance | 9 | 09-24-2017 10:26 AM |
| Product Release! CorkSport Cold Air Intake for the 2010+ Mazdaspeed 3 | CorkSport | CorkSport | 26 | 09-08-2012 09:14 PM |
