Like Tree3Likes
 Old 04-13-2011, 06:30 PM   #241
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Originally Posted by Dizzy Turbo View Post
ok so i cut a hole in a pipe, put maf in and siliconed shut and strapped a filter on it. No cels and its been 2 days and has been cold. would buying a legit sri be worth it or do you think the custom one i made will do the job? I was using a longer pipe for a cai but i had no way of shielding it from water. Obviously quality will not be as good as one from a vendor, just asking if gains from custom vs vendors part is worth a couple hundred bucks.
Well 2 days isn't the same as a month + of smooth operation.
I would venture to say you want to secure your MAF a little better - it is quite fragile and I don't know how well it'll hold up if/when you hit a pothole or how silicone will hold up over time.
I don't see anything wrong with a homebrew intake if you can keep your MAF well secured against movement relative to the pipe, and if you have a way to tune for it. If you don't have a way to tune for it, you should at least make sure the MAF diameter is very close to stock. What throws a code isn't the MAF recognizing that the diameter of the pipe is too large or too small, it's the variance of the fuel trims in closed loop/part throttle driving.
Note that fuel trims are measured using percentages, which use decimal places. Think about what that means - the ECU can detect a fraction of a percentage change in air coming into the engine by analyzing the exhaust output of that engine. While having sensors this accurate is great for closed loop driving - it lets the ECU target stoich and get the best possible gas mileage - it also means that when we enter open loop (ecu doesn't adjust for what it sees), fueling or other parameters of the engine can become dangerous and significantly reduce the longevity of your engine. That particular CEL isn't to protect the engine in CL operation IMO - it serves as a warning to avoid OL until you can get the issue addressed.
If you don't plan on getting a tuning device, I'd get one of the popular brands of SRI - cobb, cp-e, corksport, etc.
K&N is too expensive for an intake without an air straightener. Cobb has the straightener in the filter, and idk how long the filter will last so buying a replacement filter may or may not become a problem/be expensive.
As for the cobb vs. k&n claims - the dyno sheet that came with my k&n shows the 24 hp gain is the largest gain along the powerband, not the peak gain. I also got the K&N when they were going for $171+shipping, and it comes with a heat shield, so at the time it offered the best value proposition.
FWIW, I think the MAF diameter in the cobb is larger than stock for both gen 1 and gen 2. Guys are running it no problem without any codes, but some people have gotten a code. The code people get from intakes comes from having their ltft's get too far out of wack. This wouldn't be a problem if the car stayed in closed loop all the time, but because it does operate in OL at WOT, The ECU doesn't compensate for extra air when it is most important to do so. You could configure the car to operate in CL at WOT with the cobb AP, but if you're going to use an AP anyway, then it's 100x easier to just calibrate your MAF.
As for the temperature differences between SRI vs. CAI - while I'm sure your BATs will be hotter with a SRI, I'm not aware of anyone being able to demonstrate a consistent difference in power between the two. And, at the end of the day, we're concerned with power. We only learn and discuss all of this other stuff so we can go faster.
Speed3eak is offline
 Old 04-13-2011, 06:33 PM   #242
This link is now relevant:
Thanks to @Nataphen
Cold air box for SRI comparison logs...finally!
rfinkle2 is offline
 Old 04-13-2011, 06:34 PM   #243
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
@Dizzy Turbo
Okay. Now that I look at you, you only have 3 posts..
I'll be nice.
I don't think your custom intake is safe.
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline
 Old 04-14-2011, 07:25 AM   #244
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
thank you for useful information this time. This is my first car actually worth sinking money/time into when i have it available. the pipe diameter is the same and the hole was die grinded so that the o ring on the maf alone secures it tightly and silicone was added just as extra, at least until i get paid and can get a proper one. I will probably go with the corksport one, thank you for the feedback.
Dizzy Turbo is offline
 Old 04-14-2011, 07:30 AM   #245
Also, i know it is impossible to tell without any sort of readings or data, but in your opinion, do you guys think that intake will hold for a couple weeks to a month until i can get a new one or should i put airbox back on. Ive also been reading and it seems i need to start saving for a rmm also
 Old 04-14-2011, 08:08 AM   #246
The question is more of a risk / reward question.
Is 15 HP worth the potential cost of damage?
rfinkle2 is offline
 Old 04-14-2011, 08:11 AM   #247
Well that's where my problem is. I am unaware of what damages could occur from this intake, only thing I can think of is the sensor getting innaccurate readings, but I do not know what damage that will do. Anyone care to enlighten me?
 Old 04-14-2011, 08:13 AM   #248
Your fuel trims will be off, and @ high loads, that is not particularly good for the motor.
We don't know exactly what will / won't happen. I can tell you that a new maf sensor is as much as the intake or rmm you are saving for.
rfinkle2 is offline
 Old 04-14-2011, 08:23 AM   #249
Thank you very much for your input. I just joined this forum and after the first reply i got was negative I figured this would be just another forum full of people who have a superiority complex and think they know it all. I appreciate all the useful info i got from multiple people. As for the sensor, the garage i work at gets a hefty discount on stock parts so i think im just gonna stick it out till i get money. Ill let yall know if things get messy haha.
 Old 04-14-2011, 01:56 PM   #250
CEL just came on, bummer because there is no difference in performance that i can notice. Oh well back to stock i suppose haha
 Old 04-14-2011, 02:01 PM   #251
Your fuel trims were way off if they caused a cel.
If you have the opportunity, and feel the site will save you some $ on installs etc. in the long run, please donate a couple bucks to keep it all going.
rfinkle2 is offline
 Old 04-15-2011, 05:42 PM   #252
AppleJacks's Avatar
Posts: 58   (View Stats)
AppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud ofAppleJacks has much to be proud of
Well I was attempting to order the Cobb SRI but their website is down and no one answers the phone. Not cool.... So I went ahead with the CP-E and I will post pics and my thoughts after install and hopefully later down the road as well.
On a side note on the dry vs. oiled filter debate, the LS series of engines is more susceptible to oil getting on the MAF because of the grid style design of the MAF. There is a huge amount of surface area that the oil can get stuck on. I ran a K&N CAI on my 04 GTO for a long time with no problems what so ever, but I am always really light on the oil after I clean those filters. Anyways, those guys a poor example to cite because their MAF is of a completely different design than ours. The guys running FI on those cars don't even use the stock MAF, they get the 2 bar MAP out of the Cobalt SS and tune with that.
AppleJacks is offline
 Old 04-25-2011, 05:21 PM   #253
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
I recently picked up a K&N SRI (69-6012TS) and I thought it'd be worth taking measurements of the intake, in comparison to stock.
The coupler then sizes down to 2.5" to fit the stock TIP.
*EDIT*
I'm not sure this is the 69-6012TS kit now, since this is sized for the 1st Gen's stock air box.. hmm..
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline
 Old 05-20-2011, 01:47 PM   #254
Ghoust619's Avatar
Posts: 6   (View Stats)
Ghoust619 will become famous soon enough
Hi guys, been running a Spectre MAF hsg part # 9405 with the 2.5'' reducer it came with for almost two years now and have had no cel yet knock on wood.[IMG]IMG00129[/IMG] : )
Ghoust619 is offline
 Old 05-21-2011, 07:24 PM   #255
davinspeed3's Avatar
Posts: 252   (View Stats)
davinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the world
ok guys so i just sat here and read through seven pages of stuff and man it gets confusing.lol. everybody has there own opinion i guess.well let me ask now.i am brand new to this car.just bought a brand new 2011 speed3 and man do i love this car.im not really a noob to the turbo world as i had a sr20det powered 240sx before.anyways im buying a intake soon and i think im set on the injen cai i just dont understand this talk about a air straightner and fuel trim issues.why do i need a air straightner? and do i really need to worry about some fuel trim thingy issue with a name brand cai like injen? since yall know more about this car then me (well some of you) i just wanted to ask.
davinspeed3 is offline
 Old 05-21-2011, 11:01 PM   #256
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
You need an air straightener so the MAF can get a proper reading of the air going into your motor.
If you fuel trims are off too much it will cause a CEL. Wacky fuel trims also mean your car will not be able to hit the desired AFRs, which can cause problems at WOT (i.e. KR = boom boom)
wolly6973 is offline
 Old 05-23-2011, 11:44 PM   #257
Beebespeed's Avatar
Posts: 13   (View Stats)
Beebespeed is an unknown quantity at this point
Thumbs up Cobb AP and Injen CAI
I noticed Cobbs' AP has maps for what they think are the 7 best CAI on the gen 2 speed3. I have searched for the answer to this and even called Cobb twice but could not get anyone at the time to answer with any confidence. Can you use the Cobb AP with Injen CAI? And or use one of the other maps for a CAI that is similar to the Injen. It doesn't sound promising. And no Im not going to switch I takes and get the sri because i have had the Cobb and 2 others on the AP list and they don't come close to the real performance the full CAI Injen has-that's why I tossed them. And yes I know- fucking DONATE!! I will-it's only my 3-4 fucking day super mod call everyone outs donate this make dip shit comments that. Anyone that has a useful answer to my question would be cool to hear from you....or if you are a VIP super mod legend and want to nerd out and talk shit behind your keyboard go ahead and do that too i love it!!!
Most of the time I do what I want too..other times I do what I have too.
Beebespeed is offline
 Old 05-23-2011, 11:46 PM   #258
Speed3eak's Avatar
Groans: 82
holy wall of text batman
You can use the cobb AP with any intake
HOW TO CALIBRATE YOUR MAF! With An Example
I had a hard time getting through it so I hope there isn't anything important after the question about injen compatibility.
 Old 05-24-2011, 12:00 AM   #259
08speeder's Avatar
Posts: 17   (View Stats)
08speeder is a splendid one to behold08speeder is a splendid one to behold08speeder is a splendid one to behold08speeder is a splendid one to behold08speeder is a splendid one to behold08speeder is a splendid one to behold08speeder is a splendid one to behold
i got the k&N cai typhoon sounds looks and performs amazing.
i have had it for about a month no problems......till now i just got a CEL i havent got a diagnostics test on it so idk if its my intake but i did the cheap thing and just reset my car and the light went away ha
2008 speed3 GT
k&n CAI
other wise stock for now
08speeder is offline
 Old 05-24-2011, 12:41 AM   #260
Beebespeed's Avatar
Cool thanks man. I appreciate it a lot. I noticed however that the maps they have kinda pre-loaded don't include Injen at all..so how do I use it then with any intake? With that being said would I have to take it in to a pro to do custom Calibration with the AP since the Injen map is not pre-loaded? Thanks again.
 Old 05-24-2011, 12:45 AM   #261
rgz
rgz's Avatar
Posts: 397   (View Stats)
rgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the world
I have a hacked up suby maf housing with an AEM dryflow and an AEM air straightener. No CEL.
rgz is offline
 Old 05-24-2011, 12:47 AM   #262
Speed3eak's Avatar
Groans: 82
The link in my post contains instructions on how to calibrate your AP for your particular intake.
The only real difference between different OTS maps is the MAF calibration - how the car turns voltage into MAF g/s numbers - and you can do your own calibration without too much trouble.
You'll need to download ATR though - I forget if you need to e-mail cobb or if they have a form on their site under the AP product page that you fill out, but one way or another you'll need ATR.
With boost tuning it's actually pretty easy to tune your car yourself - yeah, it won't be as good as a pro-tune, but it'll be better than an OTS map in terms of how much power you make and how safe your tune is. Plus, it's $free.99 so that's always nice.
edit: You can also just run whatever OTS map is closest to your intake - if you have a way of measuring the inside diameter of your MAF housing then you can just go with whatever intake is closest to that. There are photos of those somewhere on this site I think, but off the top of my head the Cobb intake is 2.75" and the rest are 2.67" or so.
If you really don't want to open ATR and you have no way of measuring the MAF housing I.D., then you can always compare the ltft's of different maps - just load the map and drive for ~50 miles, whichever map has the lowest long term fuel trims is the one for you.
ATR is way quicker though, and just about as easy.
At the guy above me, good for you? I take it you're on the stock tune, I was talking about AP maps.
FWIW CEL goes off when your trims (ltft) are greater than +/- 15% or something ridiculous. You probably shouldn't go WOT if they're more than +/- 8%, as per cobb, but on the stock tune requested AFRs at WOT are so rich you'll probably be fine on the stock TBE.
 Old 05-31-2011, 08:42 AM   #263
How's everyones COBB SRI fuel trims on the 2010's? (Without COBB AP maf recalibrations?)
Mike
 Old 05-31-2011, 09:25 AM   #264
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
Never mind, I figured out that CS had an older version of the TIP that had a slightly smaller fitting.
Anyone have any fitment issues with the corksport SRI?
I used to have the CS sri until I got bored and purchased a cp-e nano. I got bored of the nano again and went back to the cs sri (to run with the cold air box) but during the install of the corksport, the BPV hose that connects to the TIP from the BPV fits loose.
I don't recall having this issue originally when I purchased the corksport or even with the nano. I can slide the hose all the way onto the TIP tube and the oem clamp that is supposed to be re-used does not clamp down enough to create a perfect seal.
I ended up moving the clamp all the way down to the hose (toward the bpv) in order to create a seal. I still don't feel 100% comfortable with the way the hose sits on the TIP right now.
Just wondering if anyone had any issues like this. Should I look into a new bypass valve hose? Is the clamp worn out? It's odd because I just uninstalled the stock TIP and the fitment was fine.
dizzydtrain is offline
 Old 06-02-2011, 02:13 AM   #265
Beebespeed's Avatar
Default Jerking and cut out after CAI instal
I know I'm gonna get mad shitty responses from this question alright. I searched with every key word and phrase I could but could not fnd the answer. I installed the Injen CAI on my 11" ms3 and just recently only in like 2nd gear mid to high rpm it jerks or like cuts out. It doesn't happen often but it happens. Please don't respond with some lame thing like you should have gotten a Corksport or CP-e or Cobb Sri instead. Well here is some news- i have had those and they performed worse overall if you add everything up. I checked for leaks but cannot find any.. I dont know man...someone must have had something similar happen somewhere. Thanks for the help and criticism!! Lol
 Old 06-02-2011, 06:19 AM   #266
From your description, it sounds like fuel cut, but that typically happens in much cooler temps. You may need some way to diagnose this with some kind of scanner. It's either your fuel pump giving out, or Knock, in. which case I would stock out and see if it happens.
FWIW, all of the intakes work extremely well for this car. If you have tried several intakes with poor results, theres a different problem. Could also quite possibly be your TIP is loose.
That'll be $10, please.
Mike
 Old 06-02-2011, 02:57 PM   #267
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
Do you have an air straightener in the CAI? Also, most intakes that are made for a Gen 1 will cause problems on a Gen 2. The pupu is very sensitive.
MS33SM is offline
 Old 06-02-2011, 03:24 PM   #268
Ex_WRX_driver's Avatar
Posts: 719   (View Stats)
Ex_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the world
Just go get a worm clamp if its fitting loosely.
2011 Liquid Silver
Corksport SRI/TIP/AIRBOX
Ultimate Racing catback
JBR stage 2 shift kit
SURE RMM
Ex_WRX_driver is offline
 Old 06-02-2011, 03:32 PM   #269
Injen doesn't utilize air straightener. Anything smaller than stock doesn't need one.
Mike
 Old 06-02-2011, 03:51 PM   #270
iirc, the hose is ~27mm or 1 1/8 inches ID. If it is stretched, you can get a small piece of hose that is snug, and fit the other hose over top to get a snug fit.
rfinkle2 is offline
 Old 06-02-2011, 03:53 PM   #271
Beebespeed's Avatar
Thanks for all the feedback. It has stopped doing it right now but who knows if it will start again. The clamps appear to be really tight but I will check them again. I did notice one clamp on the TIP that kinda moved sideways the harder I tightened it down. Maybe that's the small leak. I only have 2300 miles on it so I'm not sure if it's the fuel pump shitting out-but who knows again.
 Old 06-02-2011, 04:03 PM   #272
I know when I uninstalled my stock airbox, I kept pulling on the hose to remove it from the TIP. It didn't move too much but it's not unheard of for stock TIP's to be extremely loose for some odd reason.
Honestly, it's really easy to remove the battery box and check the TIP, but I'd probably just stock out and see if it's still a problem.
Mike
 Old 06-03-2011, 09:16 AM   #273
MS33SM's Avatar
Groans: 132
What mods do you have? Can you monitor trims? Why the fuck am I helping a brownie?
MS33SM is offline
 Old 06-08-2011, 12:52 AM   #274
Beebespeed's Avatar
I cannot monitor trims yet no. I have an Injen CAI, HTP TIP, Cobb down pipe, oil catch can, and some interior shit. I would say you might be helping me because at one point you were probably a brownie to unless of course you were born with a new speed3 and a computer chip in your brain that gave you all the answers and a fat wallet to afford all this crap. Other than that I think it's probably the fact that sometime in history you were a brownie too. Thanks
 Old 06-08-2011, 07:15 AM   #275
wolly6973's Avatar
Groans: 386
We were all brownies until we realized the value of this site.
 Old 06-08-2011, 10:56 AM   #276
MS33SM's Avatar
Groans: 132
To help diagnose your issue you might want to get an ultragauge, Torque+Bluetooth, or AP. It will tell you if your trims are out of whack or if your FP is taking a dump. Those mods shouldn't lead to cut.
I'm still a brownie on the inside.
MS33SM is offline
 Old 06-22-2011, 05:46 AM   #277
NinjaT1985's Avatar
Posts: 551   (View Stats)
NinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the world
Groaned at 33 Times in 10 Posts
Ok, I'm torn...
CP-E Xcel cold air intake
Sure Aeros
I know they are total opposite sides of the spectrum as far as intakes go, but thats what I've narrowed it down to for me. I've heard a lot of good and bad things about CP-E. I've also heard nothing but good (except for parts being back-ordered) about SURE.
So what would would you choose?
2012 Toyota Tacoma
NinjaT1985 is offline
 Old 06-22-2011, 07:42 AM   #278
SURE Aeros, i'm waiting also.
Mike
 Old 07-13-2011, 08:47 AM   #279
Blindeye_03's Avatar
Posts: 131   (View Stats)
Blindeye_03 is a splendid one to beholdBlindeye_03 is a splendid one to beholdBlindeye_03 is a splendid one to beholdBlindeye_03 is a splendid one to beholdBlindeye_03 is a splendid one to beholdBlindeye_03 is a splendid one to beholdBlindeye_03 is a splendid one to behold
I will most likely have my Corksport intake for sale soon...
Blindeye_03 is offline
 Old 07-28-2011, 10:23 AM   #280
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
So im confused with the cobb intake i have on right now. At idle stft are at 0.7+/-...but my ltft is at +10... boost is holding fine the afr is fine... ive checked for leaks nothing... wtf? lol no cel... but i dont like the ltft at +12 @ Wot.... lol
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f625/2010-mazdaspeed-3-performance-air-intake-discussion-125157/
Mazda speed3 parts This thread Refback 09-05-2013 02:39 PM
2010+ Mazdaspeed 3 performance air intake discussion Nataphen 2010 MS3 - Turbo Induction 467 12-30-2017 11:09 AM
ARk performance catback exhaust for the 2010 up Mazdaspeed 3 ERZperformance ERZPerformance 9 09-24-2017 10:26 AM
Product Release! CorkSport Cold Air Intake for the 2010+ Mazdaspeed 3 CorkSport CorkSport 26 09-08-2012 09:14 PM
Page generated in 0.61673 seconds with 38 queries
