Like Tree3Likes
 Old 07-28-2011, 10:25 AM   #281
Originally Posted by bigjimms6 View Post
So im confused with the cobb intake i have on right now. At idle stft are at 0.7+/-...but my ltft is at +10... boost is holding fine the afr is fine... ive checked for leaks nothing... wtf? lol no cel... but i dont like the ltft at +12 @ Wot.... lol
Do you have any plans on getting an AP?
rfinkle2 is offline
 Old 07-28-2011, 10:27 AM   #282
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
You should be making plans on getting an AP
Corrected, hehe.
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline
 Old 07-28-2011, 10:33 AM   #283
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
wish i kept my ap.......... smh...... but as of right this second no.... i want too though.... i should lol
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline
 Old 07-28-2011, 10:35 AM   #284
Those trims aren't going to be that big of a problem. Just keep an eye on things with your
current montioring device in regards to KR and AFR, especially @ wot.
rfinkle2 is offline
 Old 07-28-2011, 10:57 AM   #285
BigJimMs3's Avatar
Groans: 76
i have a aeroforce scan gauge i can see everything besides kr.... but i mean ive felt fuel cut/ bad kr.... back in my gen1 ms3...when i was stage 2 with no colder plugs...... that feeling i never want again lol thanks guys
2006 Mazdaspeed 6
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
Stock
 Old 07-28-2011, 11:03 AM   #286
They are working on getting all of the pids working for gen2 cars as I type.
You can send your gauge back soon and have it reflashed.
http://www.mazdaspeedforum.org/forum/foru...io-area-83509/
rfinkle2 is offline
 Old 08-02-2011, 11:06 AM   #287
Toymachinespeed's Avatar
Posts: 244   (View Stats)
Toymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the world
Groaned at 7 Times in 3 Posts
Originally Posted by dizzydtrain View Post
Never mind, I figured out that CS had an older version of the TIP that had a slightly smaller fitting.
Anyone have any fitment issues with the corksport SRI?
I used to have the CS sri until I got bored and purchased a cp-e nano. I got bored of the nano again and went back to the cs sri (to run with the cold air box) but during the install of the corksport, the BPV hose that connects to the TIP from the BPV fits loose.
I don't recall having this issue originally when I purchased the corksport or even with the nano. I can slide the hose all the way onto the TIP tube and the oem clamp that is supposed to be re-used does not clamp down enough to create a perfect seal.
I ended up moving the clamp all the way down to the hose (toward the bpv) in order to create a seal. I still don't feel 100% comfortable with the way the hose sits on the TIP right now.
Just wondering if anyone had any issues like this. Should I look into a new bypass valve hose? Is the clamp worn out? It's odd because I just uninstalled the stock TIP and the fitment was fine.
Well last night I installed my CS Sri and the only fitting problems I had was the tip was tough to get onto the turbo it's self. It was hard for me to get it just right on there so hopefully it holds up. But other than that like you said with your hose that your having problems with I didnt have this problem. I would look into getting a better/new sort of clamp cause it could be that it's not clamping down as hard as it should be
2011 Black Mica Mazdaspeed3 w/ Tech Package
CorkSport SRI/TIP Combo: COBB AP Custom Tune @20psi: Autotech Internals: OBX Racing Cat Back: CNT Catless Long DP: CPe TMIC: Forge V1 BPV:
JBR 80 duro RMM: JBR SSP+Knob+Bushings: H&R Springs: Rota G-Force 18x8.5 +48 Continental Extreme Contact DW 235/40/18:
Toymachinespeed is offline
 Old 08-08-2011, 10:05 AM   #288
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
Default will mazdaspeed branded CAI for 2010 model and up?
hey guys im new to the forum i have had a 2011 mazdaspeed 3 since January and looking to buy a good sri or cai. however ive talked to my dealership and it seems like they dont like me having aftermarket intake. so im consider the mazdaspeed branded cai. but it looks like they dont have a specific one that fits the 2010+. so i want to ask if anybody knows whether if the old model cai would fit the new car?? thanks guys for the replies!
dhsieh911018 is offline
 Old 08-08-2011, 10:11 AM   #289
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Welcome to the forums.
First of all, fuck all dealers.
Now that we got that out of the way, don't believe their shit. DO NOT get the mazdaspeed brand CAI. A SRI (short ram intake) will do just fine. Most members here go with that over CAI. You can do your own research but the most popular brands here are Cobb, CorkSport, cp-e, SURE as far as SRI's go. Difference will be in pricing and what they include. The performance will be the same practically between them.
The dealer just wants more of your money. An intake literally takes 10minutes to put back to stock if you need to. Putting aftermarket parts does NOT void your warranty. They can only deny claims, but just keep your stock parts and you'll be good.
If you become VIP in the forums by donating, you can get access to the For Sale section in which you will always find great deals on used SRI's.
adlpb is offline
 Old 08-08-2011, 10:17 AM   #290
bro2's Avatar
Posts: 384   (View Stats)
bro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the world
Like adlpd said, just keep you stock parts and swap them when you go to the dealer. It take 10 mins to do it.
2010 Mica black ms3 ~ cobb AP ~ cp-e nano/ AEM dryflow ~ TRZ rmm ~ 35% tint all around with 15% strip on top ~ 6k hid ~ nokya hyper yellow fogs ~ cp-e towplate
bro2 is offline
 Old 08-13-2011, 11:07 AM   #291
Posts: 2,827   (View Stats)
Can't speak for gen 2 version of Mazda's own Mazdaspeed CAI, or whether they even have one. But I am a huge believer in CAI intake, and run the Mazdaspeed version on my gen 1 car. It's actually made by AEM and rebranded for Mazda. I do know that the gen 2 car has a different MAF tube diameter and matching that diameter is very important.
Not wanting to start the bitching and arguing again. Just know that regarding the general issue of CAI v. SRI there are two points of view. If you spend a lot of time in city driving or snarled in bumper to bumper slow speed commuting, or dealing with heat soak issues or staging lane delays at the drag strip, you'll appreciate that the difference between an intake drawing underhood air that can reach 140-160 degrees, compared to even 100 degree ambient air pulled from the left front fender well, becomes huge during the first 15 seconds of going WOT.
Remember that it takes 15 seconds or more for air pulled through the front grill to drop that hot under hood temps coming from that 1500 degree exhaust manifold being radiated and reflected to that SRI filter. For each 10 degree increase in temperature at the filter, there is a 1% drop in wheel horsepower. A 50 degree difference (quite realistic) is 5% of a 300 horsepower engine or 15 horsepower. That's like negating the entire gains of the intake!
Each to his own. Not trying to start the fight again. Out on the open highway or in unimpeded traffic with plenty of flow through the grill, performance is essentially equal. Under the extreme conditions I describe above, I don't want to lose those 15 horses.
MSMS3 is offline
 Old 08-13-2011, 03:06 PM   #292
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
My IATs are typically about 5-10 higher than ambient, so...
Not quite 50 deg diff you are talking about bud.
Also, I'm pretty sure the Mazdaspeed CAI does not have an air straightener.
wolly6973 is offline
 Old 08-14-2011, 12:55 PM   #293
hazynighthawk's Avatar
Posts: 325   (View Stats)
hazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond reputehazynighthawk has a reputation beyond repute
Groaned at 12 Times in 7 Posts
I know they are pretty much the same . But what should i go with i am ordering one tomorrow. The SURE SRI or the Cobb SRI?
If you cant keep up, don't step up.
Mods- Cobb SFI, CS TIP, Cobb AP ,10,000k 55w H.I.D.s, 5% tint on all back windows and visor strip, Lamin-X Yellow Fogs.
hazynighthawk is offline
 Old 08-14-2011, 07:19 PM   #294
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
So now that Sure has fixed the issues, would you guys get that before the CP-E one? I wanna get an intake soon, but keep reading so many different opinions.
BLK_MS3 is offline
 Old 08-14-2011, 08:30 PM   #295
To be completely honest, the CP-E is fairly identical to the SURE. Major difference is, CP-E uses a silicone coupler that goes from 2.25" to 2.5" right at the TIP and angles slightly away from the motor. The SURE utilizes the full silizone reducer that is all one piece. I REALLY like the SURE piece better.
Mike
 Old 08-14-2011, 08:41 PM   #296
no one answered me =(
 Old 08-14-2011, 08:49 PM   #297
mtran's Avatar
Posts: 195   (View Stats)
mtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond repute
Sure
2010 Black Mica MS3
mtran is offline
 Old 08-14-2011, 10:18 PM   #298
Mike
 Old 08-14-2011, 11:26 PM   #299
Buddhamonk's Avatar
Posts: 174   (View Stats)
Buddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the worldBuddhamonk is the leader of the world
Groaned at 15 Times in 8 Posts
I have the same issue. Can't decide cobb or sure =(
Buddhamonk is offline
 Old 08-15-2011, 01:04 AM   #300
Yeldarb's Avatar
Posts: 24   (View Stats)
Yeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the world
CS Intake, TIP and Carbon Lidded Airbox. Love it!!!
GENII 2009 VR MPS LUX
Best Mufflers DP | 200 Cell CAT by 2XS | 3" Custom OPEN System with MAGNAFLOW Muffler & 4" tips | Speedy Lite Fin 18" Alloys with Sumitomo HTR ZIII
CORKSPORT SRI-TIP-Airbox | DGR Coilovers
OPTICOAT by ZAS | 2XS LED Fogs | 68 SMD LED (in the post) Parkers | Rear LED Reflectors | EYELIDS by MPS | Visual Garage Shark Fin Antenna
Hollandia 700 Sunroof
Yeldarb is offline
 Old 08-15-2011, 01:53 AM   #301
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
Cp-e CAI ftw.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline
 Old 08-15-2011, 02:15 PM   #302
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
Yeah, the Sure seems to be getting a lot of good reviews now, and no CEL's.
BLK_MS3 is offline
 Old 08-15-2011, 02:45 PM   #303
i bought the cobb =p
 Old 08-15-2011, 02:50 PM   #304
nick779's Avatar
Posts: 215   (View Stats)
nick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud of
Groans: 32
cobbs intake sucks, i dont even believe the maf calibration on their own OTS maps is right
'11 Speed 3 Black Mica (Sold unfortunately, going back to school)
'12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it
Licensed PA State Inspection and Emissions Tech
nick779 is offline
 Old 08-15-2011, 03:38 PM   #305
Buddhamonk's Avatar
I just bought SURE. We'll see about CEL or not
 Old 08-15-2011, 10:00 PM   #306
stang9779's Avatar
Posts: 1,066   (View Stats)
stang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the world
Get the CS you get more for the money, You get a tip too. If you really have you heart set on Sure or Cobb, go Cobb. Cobb is the top of the line for our cars.
2010 MS3 Velocity Red w/ Tech Package
Custom FreekTune e85 mix
GTX3071r - Cobb AP - CP-e Big TIP, XcelXL - Hallman PRO RX MBC - Steedspeed exhaust manifold - CS TMIC, CBE, Air Box, Interior LED kit, Mud Flaps - JBR EGR Block off, 88D RMM, 80D PMM, 88D TMM, HSK, RSB, SSP - KMD V2.1 internals - CNT DP - Forge BPV V2 - MD OCC - TWM FSS - NGK LTR7IX-11 - Konig Kilograms 18x8 +45 on 245/40zr18 Hankook V12's - H&R sport springs - SPC RC kit - Aeroforces Dual gauges - DDM tunning HID 35w 6000k - 20% black window tint, clear bra
Future Mods DO stage 2 WMI, Intake manifold of some type.
stang9779 is offline
 Old 08-16-2011, 01:03 PM   #307
I can consistently demonstrate with dual digital temp sensors, one at the left wheel well and one sitting on top of the MAF sensor a 30 degree rise in underhood temps in five minutes of idling from a COLD start. I have photos of this posted in an album here. This gets worse in stop and go traffic and in commuter snarled snail crawling bumper to bumper freeway stuff. It get higher than a 50 degree spread. Think 160 degrees under the hood! And it does take at least 15 to 30 seconds of good sustained higher speed air (over 40 mph) through the front grill to bring the temps back down.
As to the air straightener, all I can say is that the complete kits for the gen 1 CAI from both Mazdaspeed and AEM have an air straightener. Everybody with a gen 1 MSCAI or AEM CAI knows this. I don't know about gen 2. Don't even know if Mazda even has a CAI out for it. Others will have to speak to this.
MSMS3 is offline
 Old 08-16-2011, 01:11 PM   #308
wolly6973's Avatar
Groans: 386
If you want to be so technical about things... you should probably base your recommendation off of what kind of driving the person does. Not everyone lives in or regularly visits someplace where they do stop and go driving.
99% of my driving is always on the go, with little time for IATs to rise.
Also, it depends a lot on what your IC situation is. If you have a good IC or meth, IATs do not play as large of a role.
BATs are all that really matter in the end.
 Old 08-16-2011, 01:16 PM   #309
I completely agree with this. Just remember that BATs are always going to be tied to IAT's because no intercooler is anywhere close to 100% efficient. And it would have to exceed 100% efficiency to compensate for increased IAT. For every one degree that IAT's increase, the BAT's will end up 1 degree higher than they otherwise would be. The ratio is direct. Raise IATs 10 degrees and BATs after all is said and done will also be 10 degrees higher.
MSMS3 is offline
 Old 08-16-2011, 02:23 PM   #310
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
Says who? Intake wise, Sure and CP-E is made better if you ask me.
Plus remember, without an AP you don't want a TIP. Boost spike can suck.
BLK_MS3 is offline
 Old 08-16-2011, 02:42 PM   #311
i did get the cobb =)
 Old 08-16-2011, 07:32 PM   #312
stang9779's Avatar
If you are gong to mod your car the AP should be on the list. I think everyone should get one.
 Old 08-23-2011, 01:13 PM   #313
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
So I've got a new (to me) 2010 Speed3. I'm looking to start making some mods (despite just getting the car on Friday). I can't help it.
I'm considering a CorkSport TIP/SRI combo and Cobb AP. Also, the air box from CorkSport for the SRI sounds interesting, helping get you colder air. Has anyone used that, and does it work? Worth it? I want an SRI, but I do spend a lot of time sitting in traffic and it's hot here. If it would actually do what it says, seems like it's worth $90 or whatever.
Anything wrong with these as my first set of mods? I'm gonna get at least an RMM, but not sure which one or if I'll get all three or anything else.
Pedal-Force is offline
 Old 08-23-2011, 01:17 PM   #314
adlpb's Avatar
Groans: 669
Your first mod should be the donation mod, which gives you access to the For Sale section in which you can search for some of the items you are looking for.
Honestly, I can't speak for myself as I do not own the "cold air box," but I do not see it helping your air temps much (maybe 10 degrees at max), and these temps will be increased by the turbo anyway. Save the $90 and use it in either a methanol kit later down the road, or an upgraded FMIC.
My suggestion for mods would be:
SRI
RMM
AP
FP or internals
DP
etc
adlpb is offline
 Old 08-28-2011, 05:56 PM   #315
I've worked on reading this whole thread, but can't really find my answer.
Does anyone think that the Cobb or SURE SRI/TIP are worth the $100 more than the CorkSport is? I don't really care how it looks or anything, I just want it to fit well, be well made, not throw codes and give me the most HP possible. Has anyone done a dyno between the two sets?
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
 Old 08-28-2011, 10:10 PM   #316
adlpb's Avatar
Groans: 669
I honestly doubt there's any performance difference between these. For SRI/TIP it really comes down to preference. I can tell you from personal experience, having the Cobb SRI/TIP, that I have never had a CEL. 6000 miles with them.
adlpb is offline
 Old 08-28-2011, 10:56 PM   #317
Scoobs's Avatar
Posts: 750   (View Stats)
Scoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the world
But you changed the filter, why?
Sold
2010 Speed3 Black Mica tech pack, JBR RMM 80 duro, Cobb SRI, stupid horn fixed with low tone add on.
New
2012 Mazda2 GS Aluminum Metallic Mica, Corksport rear torsion bar, Corksport H11 Led fog bulbs, Piaa H4 x-treme white bulbs, AWR rmm 70duro....more to come
Wife's car
2011 Mazda2 True Red GS (Touring in the US), wifes car, no mods so far but she want a Corksport CBE, Corksport SRI and a drop in the futur. <-----
Scoobs is offline
 Old 08-28-2011, 10:56 PM   #318
Buddhamonk's Avatar
Got my SURE intake last week. The packaging was amazing, it sounds awesome, throttle response is better, I can't otherwise notice any gain in HP but the best is... NO CEL!!!
 Old 08-29-2011, 12:04 AM   #319
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
odd considering for the money it is the best power mod you can do on these cars.. usually like 10-20 hp most peeps say
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline
 Old 08-29-2011, 12:18 AM   #320
Buddhamonk's Avatar
It's just hard to tell. 10hp is only a 5% difference from stock
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f625/2010-mazdaspeed-3-performance-air-intake-discussion-125157/
Mazda speed3 parts This thread Refback 09-05-2013 02:39 PM
2010+ Mazdaspeed 3 performance air intake discussion Nataphen 2010 MS3 - Turbo Induction 467 12-30-2017 11:09 AM
ARk performance catback exhaust for the 2010 up Mazdaspeed 3 ERZperformance ERZPerformance 9 09-24-2017 10:26 AM
Product Release! CorkSport Cold Air Intake for the 2010+ Mazdaspeed 3 CorkSport CorkSport 26 09-08-2012 09:14 PM
Page generated in 0.60323 seconds with 40 queries
