 Old 03-19-2012, 03:10 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Neutral  :  -1 score
Default big turbo stock block thread
Resource thread for big turbo STOCK blocks
This is not meant to be a cut and dry this is what's ok thread. Its a guideline/ball park figures other people are running on stock blocks. If you blow your engine because you copyed what smeone else is running then lawls.
What you guys pushing? I.e timing/boost/fuel on the stock block
91 + 2.5 gal e85
Do7 pre tb / Do1 pre turbo
100 percent meth
17 deg to RL
6031@27psi
400 g/s RL
chinacharger bt@ 50k miles
6031 bt @ 61k miles
current mileage 64k
Running strong =)
dooderek is offline
big turbo stock block thread dooderek MazdaSpeed 3/6 - Turbo Induction 100 12-01-2016 11:42 PM
stock block big turbo dyno kmac MazdaSpeed 3/6 - Dyno Sheets/Discussions 178 06-24-2012 08:35 PM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
So...Turbo/motor limits on stock block & internals? 94jedi MazdaSpeed 3/6 - Turbo Induction 26 05-31-2008 08:01 AM
Page generated in 0.58549 seconds with 39 queries
