 Old 04-18-2012, 02:17 PM   #41
Shit looks good ray
EdgeAutosport.com is offline
 Old 04-18-2012, 02:22 PM   #42
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Originally Posted by RayRay (rg73gz) View Post
Just Installed...
GTX3076 / IWG
24psi
17* at RL
50/50 E85
100% Meth, D05
About 500 miles on current setup.
39k on Motor, And Beat the Shit out of it Daily!!
Dude wind that shit out to 7k. This aint no k04 anymore. Short shifting is a hard habbit to break after thousands of miles on the k04
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
86AmishMs3 is offline
 Old 04-18-2012, 02:38 PM   #43
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
LOL!! I usually do. I hit the button on the AP a little early!!
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline
 Old 04-18-2012, 02:49 PM   #44
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
bumpin to stickies, thanks guys appreciate the knowledge!
dooderek is offline
 Old 04-27-2012, 12:47 PM   #45
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
@Daddy Chinkus
We need you to take out the trash again
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline
 Old 05-30-2012, 11:16 AM   #46
2zz mr-s
dooderek's Avatar
Groans: 239
updated:
430 awhp 415 awtq @23.3 psi 6031
VVT 30 tapered to 0 by RL
19.50 degrees of timing by RL
91 + 3 gal e85
d07 pre tb
d02 pre turbo
68k miles
dooderek is offline
 Old 06-22-2012, 10:07 PM   #47
RaisedOnPunk's Avatar
Posts: 11   (View Stats)
RaisedOnPunk will become famous soon enough
Originally Posted by Daddy Chinkus View Post
updated:
91 + 3 gal e85
d07 pre tb
d02 pre turbo
68k miles
I may have missed it, but are you making this on stock internals?
RaisedOnPunk is offline
 Old 06-24-2012, 04:03 PM   #48
2zz mr-s
dooderek's Avatar
Groans: 239
This thread isn't called stock block for nothing
dooderek is offline
 Old 06-24-2012, 04:20 PM   #49
bwspeed's Avatar
Posts: 286   (View Stats)
bwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the world
gtx3071
tmic fail
12.5deg
50/50 100octane/93
21.5psi
334whp 322wtq
Cobb AP, CNT TBE, Jbr intake CPE TMIC, JBR PMM & 88 Duro RMM, GTX 3071R turbo, Grimmspeed EBC, AEM methanol kit, 3 bar map sensor, Freektune
Moore Automotive 10/19/13
397whp 392wtq
bwspeed is offline
 Old 08-14-2012, 05:28 PM   #50
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
GTX3071R
vvt 35 tapered to 0
19 degrees timing at rl
11.7 afr targeted
1808 hpfp desired fp
vd ~ 425-440hp / 420-430 lbftq 1.01 cf
4gal e-85/rest 93 oct (w/marvel mystery oil)
25psi
~4k miles on turbo, 51k on car, still trying to tune my spool quicker.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline
 Old 08-14-2012, 08:02 PM   #51
Voltwings's Avatar
Posts: 3,713   (View Stats)
As it sits:
ATP GT3071r
4 gal E85
23 psi
18.5* at redline
45k on car, ~3k on BT, gonna crank the bitch up once i get the 5th port sorted though.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Voltwings is offline
 Old 08-28-2012, 08:12 PM   #52
Voltwings's Avatar
You guys running 2 and 2.5 gallon E85 blends, what are your fill ups like?? 1 gallon of e85 and 7 gallons of 93? half a gallon and 3.5 gallons? seems like thats barely any E85.
Past:
-Sold-
-Sold-
Current:
 Old 08-28-2012, 08:16 PM   #53
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
You guys running 2 and 2.5 gallon E85 blends, what are your fill ups like?? 1 gallon of e85 and like 6 gallons of 93? half a gallon and 3 gallons?
Personally I just guess. If my light comes on 3 gallons of E and fill up the rest. If im at half of a quarter I put 2.5 of E. 1/4 tank I put 2 gallons and fill the rest. I just try to keep the ratio close I don't get to anal about it
crazyp is offline
 Old 08-28-2012, 09:26 PM   #54
Voltwings's Avatar
i guess its not enough e85 to really mess with the trims too much but guess work isnt gonna work for someone like me haha -_-
Past:
-Sold-
-Sold-
Current:
 Old 08-28-2012, 09:38 PM   #55
crazyp's Avatar
Groans: 68
well for me the e-85 is strictly for knock. The less e-85 I use the more fuel I have available. Plus I run 100% METH WITH A d07 NOZZLE i'M SURE THAT HELPS LOL.
at 25 psi I'm still at high 90 IDC
crazyp is offline
 Old 08-28-2012, 09:48 PM   #56
Voltwings's Avatar
The IDC is what im looking to lower by reducing my e85 as well. Thanks for the input. i started on 50/50, then went to a 4 gal blend and hoping i can run my 25 psi without the need for meth on a 2 gal blend. We'll see.
Past:
-Sold-
-Sold-
Current:
 Old 08-28-2012, 09:57 PM   #57
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
ATP GT3071r
4 gal E85
22 psi
18.5* at redline
80k on car, ~3k on BT
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline
 Old 09-19-2012, 06:05 PM   #58
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: big turbo stock block thread
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
big turbo stock block thread dooderek MazdaSpeed 3/6 - Turbo Induction 100 12-01-2016 11:42 PM
stock block big turbo dyno kmac MazdaSpeed 3/6 - Dyno Sheets/Discussions 178 06-24-2012 08:35 PM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
So...Turbo/motor limits on stock block & internals? 94jedi MazdaSpeed 3/6 - Turbo Induction 26 05-31-2008 08:01 AM
Page generated in 0.37908 seconds with 31 queries
