 Old 03-19-2012, 03:10 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Neutral  :  -1 score
Default big turbo stock block thread
Resource thread for big turbo STOCK blocks
This is not meant to be a cut and dry this is what's ok thread. Its a guideline/ball park figures other people are running on stock blocks. If you blow your engine because you copyed what smeone else is running then lawls.
What you guys pushing? I.e timing/boost/fuel on the stock block
91 + 2.5 gal e85
Do7 pre tb / Do1 pre turbo
100 percent meth
17 deg to RL
6031@27psi
400 g/s RL
chinacharger bt@ 50k miles
6031 bt @ 61k miles
current mileage 64k
Running strong =)
dooderek is offline
 Old 03-19-2012, 04:11 PM   #2
92/2.5 gallons E85
t3 3076r
16* up top
20k+ miles on BT 75k on the car
Car pulls like a freight train
EdgeAutosport.com is offline
 Old 03-19-2012, 04:14 PM   #3
2zz mr-s
dooderek's Avatar
Groans: 239
What psi eric?
dooderek is offline
 Old 03-19-2012, 04:18 PM   #4
Originally Posted by Daddy Chinkus View Post
What psi eric?
Ive been running 26psi. Im doing seals and other shit then retune til I max my injectors out or get the 5th port installed. Whichever comes first and im hoping its the 5th port being installed.
 Old 03-19-2012, 10:13 PM   #5
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
nub.
Stock Block BT build threads
Edit: lolololol
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 03-19-2012, 10:30 PM   #6
2zz mr-s
dooderek's Avatar
Groans: 239
that thread sucks and is old
dooderek is offline
 Old 03-20-2012, 06:32 AM   #7
obijack's Avatar
Posts: 1,830   (View Stats)
c'mon needz moar info, where's everyone at? @Daddy Chinkus How many miles have you been BT? Ebay turbo and all. When/if there is enough info in here this thread should be made a sticky.
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
obijack is offline
 Old 03-20-2012, 09:02 AM   #8
Before I was BT I ran reworked for 30k fully bolted. 330whp&374wtq my car is abused lol
 Old 03-20-2012, 11:20 AM   #9
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Out of (noob) curiosity, and to have this info in this thread, what's the advantage of going reworked, and how much would it cost?
EDIT: Im loving this thread
2010 LSM Speed3
#BakeryTuned
Roddiy is offline
 Old 03-20-2012, 11:22 AM   #10
Its fail imo and it came on my car. From what I have read its 900 for one and at best they do a lil more up top and imo its not even noticeable.
 Old 03-20-2012, 09:23 AM   #11
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Before building I ran
superstocker 24psi
16* @ rl
70/30 meth do7
aprox 10k
made about 320/380
then
t3 3076 .82 (22psi)
do7 70/30
16* @ rl
aprx 5k miles
made 420whp
NJSPEED3 is offline
 Old 03-20-2012, 10:01 AM   #12
atvfreek's Avatar
Posts: 7,787   (View Stats)
Good shit guys!
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
atvfreek is offline
 Old 03-20-2012, 10:18 AM   #13
Realgib3's Avatar
Posts: 2,443   (View Stats)
93/2 gallons E85
ATP() GTX76
20.5* up top
23-25psi
15k+ miles on BT 55k on the car
~430whp
Realgib3 is offline
 Old 03-20-2012, 01:04 PM   #14
2zz mr-s
dooderek's Avatar
Groans: 239
93/2 gallons E85
ATP() GTX76
20.5* up top
23-25psi
~430whp
hahaha i would love me some 20.5 timing up top!!! 91 shit ghes =[
dooderek is offline
 Old 03-20-2012, 01:32 PM   #15
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Your using meth and e85 tho.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosted Beluga is offline
 Old 03-20-2012, 11:10 AM   #16
Alpha's Avatar
Posts: 3,711   (View Stats)
What if you have a lil turbo?
Alpha is offline
 Old 03-20-2012, 11:13 AM   #17
What if you have a lil big turbo?
fixed
 Old 03-20-2012, 01:14 PM   #18
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Currently have 1k on turbo 22k on car.
93/2g E85 + Do7 in cold pipe 80/20 mix
17 deg at RL
GTX3071r@24.5psi
370g/s @ Redline. VD shows 409hp 408tq w/ 1.01 CF
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline
 Old 03-20-2012, 02:47 PM   #19
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Running GTX3071r at 24psi
200 on turbo, 51k on car
Will be running 91/E85 2.5gal mix
Tune still in progress
2009 CWP Speed3
SleeperHatch is offline
 Old 03-20-2012, 06:48 PM   #20
ATP 3076
93 for 18k @16*
5050/100 meth D07
93/E30 3k @19.5*
100 meth D10
26psi on the regular
430/464
superskaterxes is offline
 Old 03-21-2012, 09:15 AM   #21
@superskaterxes what did your egts look like on that atp hotside at that psi?
 Old 03-21-2012, 05:33 PM   #22
i never broke ~1700
 Old 03-22-2012, 04:55 AM   #23
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
2009- 32k miles with 500 on the turbo
GT3076 ATP hotside
21psi and 13 degrees currently
91/ 2.5g E85
Still tuning....will update once done
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
86AmishMs3 is offline
 Old 03-24-2012, 06:53 PM   #24
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
93 with 4 gal E
M10 meth nozzle with 100% VP Racing M1
ATP GTX3071
Boost Targets from 2500-7000:
Code:
16.00	19.00	21.00	22.00	23.00	23.50	24.00	25.00	25.00	25.00
Ignition Timing from 2000-7000:
Code:
0.00	4.00	6.00	8.00	9.00	10.50	12.00	14.00	16.50	17.50
EGT ~1630°F peak on 4th gear pull from 2k to RL
Need to get to a dyno soon...
cld12pk2go is offline
 Old 03-24-2012, 07:57 PM   #25
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
.5557 with billet wheel 4''inlet .63 hotside
93 octane
recently switched from sandback to ap ( huge difference!)
so currently tuning only at 21 psi, should be back to 26psi after fifth port
going with 5th port injection soon
been bt 15000 miles no problems
at 104000 2 bent rods
tuned by nishan
rigor is offline
 Old 04-11-2012, 06:15 PM   #26
2zz mr-s
dooderek's Avatar
Groans: 239
@dturboman spill the beans
dooderek is offline
 Old 04-12-2012, 06:58 AM   #27
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
the engine let go last night while driving on the turnpike... no hole on block but bent a rod
dturboman is offline
 Old 04-12-2012, 08:44 AM   #28
It was just a matter of time at those boost and power levels.
Lex is offline
 Old 04-12-2012, 09:13 AM   #29
dturboman's Avatar
was not even in power when it happen, was doing 50 through a construction zone and it let go.
Looks like its going to be built now.
 Old 04-12-2012, 09:26 AM   #30
86AmishMs3's Avatar
Groans: 338
Sad to see it give....you pushed that little 3071 hard. Any thing seem off before it went.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 04-13-2012, 06:25 AM   #31
dturboman's Avatar
Well here are the specs when it was running
Gt3071r with back half ported and coated.
22.5* max timing
625ML & 375ML nozzle running 100% meth
c16/93 mix
31-32.5PSI
518 whp 497tq
ran 11.9@ 123.4 on 26psi and 450whp
PRIME-B likes this.
 Old 04-12-2012, 08:14 AM   #32
Groans: 50
so what are your plains with it now?
08 Mazdaspeed 3
 Old 04-12-2012, 10:15 AM   #33
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Damn sucks, then again your car was a trooper 160kmi and at 30 psi lol beast.
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline
 Old 04-15-2012, 11:43 PM   #34
2zz mr-s
dooderek's Avatar
Groans: 239
dude wtf is this shit? take your chit chat outa here, cleaning up in 1 day
dooderek is offline
 Old 04-16-2012, 03:22 AM   #35
Eth/Meth Junkie
cld12pk2go's Avatar
Neutral  :  -1 score
FYI,
Here is my BT with stock block dyno thread:
http://www.mazdaspeedforum.org/forum/foru...7-9wtq-110833/
 Old 04-18-2012, 02:07 PM   #36
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
Just Installed...
GTX3076 / IWG
24psi
17* at RL
50/50 E85
100% Meth, D05
About 500 miles on current setup.
39k on Motor, And Beat the Shit out of it Daily!!
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline
 Old 04-18-2012, 02:22 PM   #37
86AmishMs3's Avatar
Groans: 338
Originally Posted by RayRay (rg73gz) View Post
Just Installed...
GTX3076 / IWG
24psi
17* at RL
50/50 E85
100% Meth, D05
Dude wind that shit out to 7k. This aint no k04 anymore. Short shifting is a hard habbit to break after thousands of miles on the k04
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 04-18-2012, 02:38 PM   #38
RayRay's Avatar
LOL!! I usually do. I hit the button on the AP a little early!!
2009 MazdaSpeed 3
RayRay is offline
 Old 04-18-2012, 02:17 PM   #39
Shit looks good ray
 Old 04-18-2012, 02:49 PM   #40
2zz mr-s
dooderek's Avatar
Groans: 239
bumpin to stickies, thanks guys appreciate the knowledge!
dooderek is offline
big turbo stock block thread dooderek MazdaSpeed 3/6 - Turbo Induction 100 12-01-2016 11:42 PM
stock block big turbo dyno kmac MazdaSpeed 3/6 - Dyno Sheets/Discussions 178 06-24-2012 08:35 PM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
So...Turbo/motor limits on stock block & internals? 94jedi MazdaSpeed 3/6 - Turbo Induction 26 05-31-2008 08:01 AM
Page generated in 0.55771 seconds with 39 queries
