![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 35
| Not Ranked : 0 score Now that I finally have the aem wideband in my car, I saw that I'm running rich as fuck. Cruising: ~14.5 Half: ~12.5 WOT: 10-10.5 I'm still running the stock bpv with a SRI and stock exhaust. Will an aftermarket one help out in this situation, or make me run even more rich? |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 760 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
![]() Join Date: May 2010
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score thanks for that info |
![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
__________________ 2012 BMW 135i //M-Sport | |
| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 240 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
| Not Ranked : 0 score i'm running the AP v1.03 Stage1+SRI map, combined with my Forge BPV (blue spring) and HKS SRI. LTFT's of about 7 when engine breaking, 5 when idle/cruising, -1 at part throttle, and -7 at WOT. those values seem counterintuitive, indicating that the ECU is reducing fuel as throttle increases (right?), but the AFR does stay below 12 at WOT. fuel pressure is consistently above 1600PSI as well. the problem --> boost is low, as in staying closer to 14-16PSI than the 18 prescribed by the map. i get a decent peak of 19-20 but it quickly drops. the primary suspect is the BPV. i'd like to keep my forge installed, but i'm not sure about the 'ideal' spring setup. blue was working well for awhile. any suggestions, Sacrilicious? FWIW my latest maps are posted in the Cobb AP forum, "103 finals are out", top of page 7. Here. My current plan is to swap to the stock BPV and check boost. |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score Try 1 shim with that blue spring?
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
| Not Ranked : 0 score i've entertained that idea although i thought using the stock BPV should show me what the boost is supposed to look like. IMHO the Forge is a better unit with quicker response and added reliability, and i would like to get it 'tuned' appropriately for my car. but should i try the stock (and potentially leaking) BPV first or screw around with springs/shims? i swear a few people on here use the Forge BPV with the new AP maps, but i've never verified what spring/shim combo they use to get the full boost. |
(Thread Starter) | Not Ranked : 0 score i would try the stocker on as a baseline for like 50 miles and then take some logs (including one with WG DC). that way, you know what your baseline should be. also, check to be sure that you don't have any weird leaks in the system. your boost should be holding more than that, so let's have a look see what's wrong. keep in mind that it COULD just be the cold weather messin with your car's ECU logic. the fact that your LTFTs turned out however they did does not necessarily mean they are wrong, since it's dependent on the variances in your intake system. you really have to get more info before you can decide if something is wrong. |
i'll try to put some mileage on the car in the next couple days and subsequently perform a log for the stock BPV. why is the WG DC so important, by the way? shouldn't it just open when the ECU tells it to? or is it possible that the ECU is opening it too much? | |
please let me know what you think. | |
![]() Join Date: Feb 2009 Location: Upland, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I have to say using the old style HKS SSQV I have TONS OF BACKFIRING, and lots of pops on deceleration. The deceleration pops are cool actually, but the backfiring on shifting is extremely loud sometimes. I'm changing to the new HKS BPV and see if that helps. |
![]() Join Date: Apr 2009 Location: Midlothian, Virginia
Rep Power: 165 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Good info, thanks. Looking to get a Tursmart BOV. |
![]() Join Date: Aug 2008 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
Groaned at 81 Times in 33 Posts
| Not Ranked : 0 score I'm sorry for posting on an old thread but it seemed relevant to my situation. Since having a Dashhawk, I haven't been able to really get the higher PSI's that everyone else seems to gain with doing any BPV on their MS3 (Forge, HKS, Turbosmart, etc. etc). I ran a Forge for the longest and didn't like the part-throttle driveability, so I switched to stock. The car ran pretty smooth and didn't have any heavy surges or drops in boost, however, I'd still never see a consistent 15psi during WOT. Now, i've got the Turbosmart BPV and the spring seems pretty soft. After doing some testing today, Boost is holding the same or even maybe .50 psi less. So i'm having SU send me the stiffer spring. I'm hoping this will fix it, or the 30* cold weather here is royally messing with the car. I noticed someone said to log WG DC? What should you be looking for during test runs? During WOT, or higher PSI scenarios, what SHOULD your WG DC be? I've checked over and over for leaks and nothing seems to be leaking. I've thought maybe a vacuum hose is plugged or something so I unplugged it (as Turbosmart suggests) and it hisses air and idled poorly (meaning, it's working properly, no kinks).
__________________ Mike 2008.5 CWP Mazda CX-7 Sport FWD - hers 2008.5 CWP Mazdaspeed 3 GT - traded 2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold |
so, to answer your other two questions: 1. your TS BPV sounds like it's working as intended. 2. the "correct" WGDC depends entirely on what your mods, boost control, and weather conditions. in general, people log to see if it's being maxed out at the top of the rev range to see if they're overworking their turbo. they also use it to diagnose boost spikes as boost kicks in...if your WGDC pins itself to wide open when you floor it and then you see a gigantic boost spike before the boost settles back to like 16psi, then you know that you should try retuning your WGDC tables so that your car isn't overly-aggressive with the WGDC as it applies boost. EDIT: fyi: mods that mess with how load is calculated have been known to cause boost spikes beyond what a stock ms3 should see, but the boost that is held still remains pretty close to stock unless you get a tuning solution like the AP, SB, or a MBC (this is the most basic "tuning" solution, imo...not the best by far, but it does screw around with boost). | |
| Not Ranked : 0 score Well, i've done zero tuning, only MSCAI, MSCBE are mods. I was spiking in the high 20's and it would settle down to 13psi which just seems so odd to me when everyone else will see 15psi or higher. I know of a few local MS3's who run with Forge BPV's that consistently sit around 15 or 16 psi. And i've tried understanding why my car just simply won't have it. Also, when I was watching WG, I think I remember it would go to 0 when i'd floor it, then slowly creep up to 25?
(Thread Starter) | Not Ranked : 0 score do you have the airflow straighteners on your MSCAI? one of the main issues with the MSCAI is that its MAF housing doesn't have stock airflow characteristics, so it screws up how the ECU calculates load and how much air it thinks is coming in. |
| Not Ranked : 0 score Yep, and I have it installed properly per MSCAI's instructions. It just seems like the car is so quick to bring the boost back down. Or if I'll do a 3rd gear pull, i'll never see anything north of 12psi. It's typically 12 or lower.
(Thread Starter) | Not Ranked : 0 score does this happen only in the cold, or even when it's warm out? our cars detune themselves in the winter. |
| Not Ranked : 0 score Well, it has happened more recently in the cold. But in the summer, it's not like it was very willing to hit those pressures either. I know nothing can be determined without a log really, but it's hard to log, trying to figure out where I can run the car hard and safely to log anything.
(Thread Starter) | Not Ranked : 0 score ya, it would be really useful if you could give us logs with the AFR, boost, WGDC, etc. the MSCAI works better with the straightener, but i have heard of people having issues even with the straightener. |
| Not Ranked : 0 score So, AFR, Boost, WG DC, i'd assume Throttle Position too right?
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score I wouldnt worry about not holding boost especially in the colder months. The air is more dense and the car hits its load targets with less boost because of the increased density of the air charge. Even when its warm out my car on stock tune and mods in my sig will hit like 15.5 lbs of boost and then taper to about 12 by redline. Its just the stock tune nothing to worry about. I just finished checking out my ltfts and at idle it is 0, during decel in gear it is about +3%, light load it is around 5%, and 13% at wot and heavy throttle. Thanks for this post it was very informative. How do those numbers seem?
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Thanks for the info on the stock boost though! Just seems odd when others are holding better than me, and they're in the same area as where i'm at. My LTFT's with stock BPV were opposite. +9.4 cold idle, +2.3 cruise and +0.0 WOT.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score addikted: what spring/shim combo are you using on your forge BPV? your WOT ltft is pretty high. silver: your LTFTs look good...addikted is right that your car may be running 100% as intended because it thinks it has achieved its commanded load value. intakes can affect how load is calculated, and i bet that it's probably fooled around with what your car is doing to lower your boost. remember: our cars are load tuned, which means that cars that have skewed load calculations can boost more/less accordingly. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I see! Thanks so much!! I am going to attempt a few logs if I get the space to do so.. I have AFR, Vac/Boost, WG DC, Abs Thrttle Pos. I noticed while cruising, WG stays at 0, when I go WOT, it'll shoot up real high near 100 for a flash of a second, then reel it down almost to 0. What does that mean?
![]() | | #27 | ![]() |
I am running the forge with blue spring and 0 shims. I had the cpe xcel cai for about a year and i recently took it off and switched to the cobb sri, and my ltft's were pretty much what i posted in my previous post. During the year or so i had the cpe xcel on my wot ltft was 0 or maybe .8, and at idle it was like -8% now i have switched back from the cobb to the cpe and im still getting those screwy ltft's that i posted above. Maybe its because of the colder weather and they will settle back down. when you are cruising you are building no boost, when the car goes under load at wot the wastegate is what determines how much boost is bled off to meet boost and load targets. Fore example, if youre cruising in 6th gear and nail the gas at like 60mph, the boost isnt needed because the calculated load is not high enough and it will bleed all the boost at first and then gradually introduce the boost as load gets higher and higher, until it gets to the point where it has reached its boost/load equilibrium that it wants then it will bleed boost again. At least that is how i understand it someone please correct me if i am wrong. It cuts boost after like 5000 rpm on stock tune and tapers down to 11-12 psi by 6000 rpm.
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s | |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score EDITTED TO REMOVE BAD WGDC INFO |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score hrrm...not sure what to tell you about your LTFTs, addikted...it's hard to tell whether you have a slight leak somewhere in your intake or not. have you tried cleaning your MAF sensor (not the teardrop thing, but the 2x resistors way up the tube)? a dirty MAF sensor can cause your LTFTs to go up. |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
ya, just drop the log here whenever you get it and we'll all have a look at it and tell you what we think. | |
![]() | | #32 | ![]() |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
__________________ 09 Speed 3 GT | |
![]() | | #33 | ![]() |
| Not Ranked : 0 score See, with some Forge MS3's, they'll hold 16psi. Shouldn't the WGDC stay in a higher range then to bleed it off? I guess what would help is, spoon-feeding just what the WGDC # means during different scenarios.
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Ok makes sense. But shouldn't it keep it spinning while you're making boost? Obviously, it never shuts down completely while the car is running but 0 should mean it's making zero power? Or am I understanding this wrong.
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Ok I do understood correct. But i'll be in Boost showing whatever measly #'s i'm getting and my WGDC is at 0 during WOT after the initial big spool up. That's what I don't get...
![]() | | #38 | ![]() |
| Not Ranked : 0 score You are overthinking this one man, a waste gate duty cycle of 0 means that no boost is being bled off and all of it is going into the engine and out the exhaust the way it is intended. If the waste gate was opening then the duty cycle would show 5, 15, or whatever percent it needs to bleed off in order to achieve its load targets. A wgdc of 0 is a good thing when you nail it.
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Exactly!! I wonder if my wastegate is fubared, or the hose is not properly connected. I'll try to log tonight but I don't have a way to download the log damnit... (Apple, no copy of win xp around)..
| Display Modes | |
| Discussion on how bypass valves can affect LTFTs. | Sacrilicious | MazdaSpeed 3/6 - Turbo Induction | 155 | 01-04-2016 05:50 PM |
| LTFTs -18 at idle | 09Speed3Z | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 06-30-2011 07:56 PM |
| LTFTs at WOT | volodya84 | MazdaSpeed 3/6 - ECU Computer Tuning | 9 | 06-26-2011 10:09 AM |
| Negative LTFTs at idle. | Tokay444 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 34 | 05-28-2011 08:09 PM |
| LTFTs and Winter | MidwestSpeed3 | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 11-12-2008 09:34 AM |
