 Old 09-06-2012, 07:08 PM   #1
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Default Failed ATP/Garrett Turbo Thread
So there seems to be a recent rash of failed GT and or ATP/GT BB turbos, so I thought it might be a good idea to have a database of which turbos failed, failure mode, and outcome.
I think the following criteria should be included;
Turbo type: [GT30xx or ATP GT30xx, GTX30xx, etc]
Restrictor used: [no restrictor, .035, .040 etc]
Failure Mode: [CHRA bearing falure, hotside cracking, etc.]
Oil feed line used: [OE, ATP, other]
Oil return line used and if modified for length.
Vendor Purchased from:
Answer/resolution from vendor or manufacturer:
Symptoms: [cloud of smoke out of the back + no boost, etc.]
Turbo mileage:
Turbo failure after blown motor: [yes/no]
I think that's about it unless anyone has other ideas of what would be useful.
@chimmike
@BlueStreak
@crazyp
and any others
Dano is offline
 Old 09-06-2012, 07:18 PM   #2
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
Here is my wall of frustration...
Turbo type: GTX3076
Restrictor used: Told by ATP that no restrictor was needed on new GTX series.
Failure Mode: Two time Seal failure. First time had metal bur left inside CHRA housing that caused rubbing and excessive heat. Defective Oil Return line sent from ATP.
Oil feed line used: OE Feed line.
Oil return line used and if modified for length. Original install had Oil Feed line used supplied by ATP. Now running custom line supplied by ATP that is 1in shorter in length.
Vendor Purchased from: Edge AutoSports
Answer/resolution from vendor or manufacturer: First time ATP rebuilt entire CHRA housing. Still waiting on resolution for second issue.
Symptoms: Oil blow back through Compressor housing. Oil in Intercooler, Intake and Throttle Body. Massive "Spy Hunter" smokescreen from tail pipe.
Turbo mileage: About 5k on original install, 1.5k on second failure.
Turbo failure after blown motor: No Blown Motor
Here are some pics of the bur in the CHRA housing and of the defective Oil Return line sent to me by ATP.
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline
 Old 09-06-2012, 07:23 PM   #3
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
Turbo type: T3 GT3071
Restrictor used: .035
Failure Mode: CHRA bearing failure
Oil feed line used: custom ATP steel braided line
Oil return line used : Custom ATP steel Braided line
Vendor Purchased from: bought used forum user
Symptoms: no boost , mileage unknown and boosted up to 24 psi
Turbo type: T3 GTX3076
Restrictor used: .035,
Failure Mode: no failure as of yet
Oil return line used : Custom ATP steel Braided line.
Vendor Purchased from: Edgeautosport
Symptoms:working fine so far, bought november 2011 boosted up to 27 psi
crazyp is offline
 Old 09-06-2012, 07:25 PM   #4
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Turbo type: GT3071R /w ATP IWG
Mileage: 30K KMs
Restrictor used: None
Failure Mode: Bearing failure. Shaft play in all directions. Damaged compressor wheel.
Oil feed line used: OEM
Oil return line used and if modified for length: ATP oil return line. Not modified.
Vendor Purchased from: StreetUnit
Answer/resolution from vendor or manufacturer: Haven't sent it out yet.
Symptoms: Zero positive manifold pressure. Smokescreen out the exhaust.
I added mileage in there. Figured it would be a good parameter to list.
'07 CWP MS3
Forged.
BlueStreak is offline
 Old 09-06-2012, 07:26 PM   #5
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
did your turbos blow after a blown motor, or just all by themselves?
TWOptSL0W is offline
 Old 09-06-2012, 10:24 PM   #6
Trail of Fail
Dano's Avatar
From rayray pending more details
Originally Posted by RayRay View Post
I have definitely had similar issues with my gtx. First time I had a metal burr left on the inside of my housing. This supposedly caused excessive heat. This caused the seals to go bad. From there I sent the turbo in and they rebuilt it.sent it back and I am having the same issues. My oil return line from them had a mountain range inside of it. They sent me a new one, 1 in shorter. (I let them know the one in their kit was too long). I am still having issues. Everything is pointing to the seals again. I am actually pulling the gtx this weekend and putting the stock k04 in. ATP had told me I will have first priority when I.. send it back to get looked at. We will see what they say but I have very little faith right now. I am hoping they will take care of it!
Tappin
Dano is offline
 Old 09-06-2012, 10:55 PM   #7
RayRay's Avatar
Tappin
Updated my post with all important details!!
2009 MazdaSpeed 3
RayRay is offline
 Old 09-07-2012, 05:35 AM   #8
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Turbo type: GTX3076R
Restrictor used: No, stock oil line via ATP fittings
Failure Mode: 'clog' in oil feed inside turbo, bearings failed.
Oil feed line used: OE via ATP fittings
Oil return line used and if modified for length: ATP, not modified
Answer/resolution from vendor or manufacturer: "user-induced error"
Symptoms: No boost, metallic whirring
Turbo mileage: 15k
Turbo failure after blown motor: NO
07 MS3
The original Genpoo Hater
Chimmike is offline
 Old 09-07-2012, 06:43 AM   #9
@SPEED6 KILLAH.. You made mention of seeing this more than once. Could you tag the owners of the turbos in this thread when you have a chance?
rfinkle2 is offline
 Old 09-07-2012, 06:57 AM   #10
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Pablo's precision turbo blew due to a bottom end assembly failure.
Ms3ko he owned an t3 gt3071 turbo blew post zzb
Twoptslow atp gt 3076 turbo blew post zzb
If you blow you're motor there is a big change for the contaminated oil to take out your turbo, this is why he recommended the oil feed filter.
NJSPEED3 is offline
 Old 09-07-2012, 08:04 AM   #11
Trail of Fail
Dano's Avatar
now we're startin to get somewhere.
Ziggo made an interesting observation in chimmike's thread about the in-line filter, in that it can be a blessing or a curse. if you don't monitor it and keep it clean of debris it will be the cause of your failure. It will likely never get anything in there unless you do lose a motor but as Pablo said you have to check it religiously.
From your data it would seem that if you do blow the motor you WILL blow the turbo as well..
Dano is offline
 Old 09-07-2012, 09:47 AM   #12
Tripple OG
NJSPEED3's Avatar
Groans: 113
That's exactly what we are seeing, we can't stress enough how important it is to continuously check your filter. I would run a oil feed filter only if I was breaking in a new motor, but not after that.
NJSPEED3 is offline
 Old 09-07-2012, 09:49 AM   #13
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Yeah, definitely did NOT pop the motor on this end, lol. OEM pistons/rods completely intact, hg intact, etc.
07 MS3
Chimmike is offline
 Old 09-07-2012, 10:30 AM   #14
Trail of Fail
Dano's Avatar
My immediate plan is to not change my setup. Namely no restrictor or filter until some data can be gathered.
IMO a guy should install a pressure gauge in the feed line and measure actual pressure at higher RPMs then compare to Garrett's recommended pressure and install the correct size restrictor if needed.
It could very well be that we are over oiling the GTs but really have no idea by how much. So ATP is erring on the side of caution and so will I.
Maybe when I install my GTX I'll throw a gauge on there and see what's what.
Tappin
Dano is offline
 Old 09-07-2012, 11:46 AM   #15
Trail of Fail
Dano's Avatar
pertinent info from the other thread
holy shitstorm of conflicting information batman!
Garratt says use a restrictor..but only if you are under 40PSI
ATP says..do not use one.
some guys use them
some guys dont
has anyone actually measured oil pressure at the feed line in the upper RPMs?
edit: I see that Garrett wants pressure at least 40-45PSI if lower then the restrictor will increase said pressure in the CHRA.
This may be the same source @rfinkle2 quoted
Ball Bearing Turbo
"An oil restrictor is recommended for optimal performance with ball bearing turbochargers. Oil pressure of 40 - 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger's internals. In order to achieve this pressure, a restrictor with a 0.040' orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor in insure that the components are functioning properly. Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID. As always, use an oil filter that meets or exceeds the OEM specifications. "
Oil & Water Lines | Turbobygarrett
Dano is offline
 Old 09-07-2012, 11:49 AM   #16
Will fuck up ur day
Chimmike's Avatar
Groans: 433
ATP told me specific to the MZR disi a restrictor is not needed. This is why they use the OEM feed without a restrictor. ATP also tells me you cannot "over oil" a turbo, but oil can leak by the seals, at which point a properly sized restrictor will stop the leaking. They say the seals are not rubber and do not "go out", that it's usually another problem.
Just repeating what I'm told, that's all.
I would be willing to believe we're not over-oiling them if we're not getting smoke/oil leak past the seals, though.
07 MS3
Chimmike is offline
 Old 09-07-2012, 11:54 AM   #17
Trail of Fail
Dano's Avatar
I understand completely and am in the "no restrictor" camp. I was putting that information up for the restrictor guys.
a blanket statement like "all BB turbos on all platforms need a restrictor" is BS until proven otherwise IMO. not hating on the guys that are running them but perhaps ATP knows something we don't in that our motor runs 45PSI in the feed line..enough to feed the bearings.
it sounds like Garrett only wants a restrictor to get you to the 40-45PSI oil pressure in the CHRA...but I can't say that for sure...just going off the statement on their site.
so if pressure is higher a smaller orifice will only make it more right?
so perhaps they are indicating they want a restrictor in there to INCREASE pressure if you don't have enough.
Dano is offline
 Old 09-07-2012, 11:57 AM   #18
Will fuck up ur day
Chimmike's Avatar
Groans: 433
a blanket statement like "all BB turbos on all platforms need a restrictor" is BS until proven otherwise IMO. not hating on the guys that are running them but perhaps ATP knows something we don't in that our motor runs high pressure in the OE feed line..enough to feed the bearings.
from what ATP told me, the only reason for a restrictor would be if you're getting leaking past the seals.
They apparently tested the oil pressure in the feed line to determine this data.
Doesn't change the fact that these failures are "mysterious" at best, and I'm not sure exactly who is at fault the most; ATP or Garrett or both
07 MS3
Chimmike is offline
 Old 09-07-2012, 12:02 PM   #19
Trail of Fail
Dano's Avatar
right.
we are covering two different topics here...lol
I don't think your failure mode has anything to do with running or not running a restrictor.
the other thing I am trying to put to rest is do we need one or not? lol it may always be a matter of opinion.
If I put a gauge on mine and wide open it reads 40-45PSE I will feel confident no restrictor is needed.
but if you are flowing too much oil IDK how to solve that...if you put in a restrictor you up the pressure correct? Then you are beyond spec for pressure but running correct volume.
catch 22 and prob why ATP says leave it alone unless you blow out smoke/seals.
edit: I am wrong according to @Lex so there you have it.
restrictor apparently does not increase pressure...I was thinking of the gargen hose analogy...put finger over part of it and the pressrue goes up and volume decreases...still don't understand why that is not the case but it doesn't matter...lol
Dano is offline
 Old 09-07-2012, 12:09 PM   #20
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Your question was answered in my other thread as you know.
restrictor reduces pressure/flow.
07 MS3
Chimmike is offline
redboat (04-07-2014)
 Old 09-07-2012, 12:12 PM   #21
Trail of Fail
Dano's Avatar
haha
I love being wrong...I am getting dizzy and must take a break from MSF for awhile....
Dano is offline
 Old 09-07-2012, 01:15 PM   #22
haha
Ahhh. It was a good theory, and useful for the topic.
rfinkle2 is offline
 Old 09-10-2012, 09:58 AM   #23
Rokusek's Avatar
Posts: 5,551   (View Stats)
sub'd for future reference
Rokusek is offline
 Old 09-10-2012, 01:59 PM   #24
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Groaned at 9 Times in 9 Posts
Subbed, I'll probably join the list eventually
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline
 Old 09-10-2012, 03:57 PM   #25
@bwallace04
Raider is offline
 Old 09-19-2012, 06:07 PM   #26
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: Failed ATP/Garrett Turbo Thread
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
Failed ATP/Garrett Turbo Thread Dano MazdaSpeed 3/6 - Turbo Induction 47 08-13-2015 02:59 PM
Garrett m33 turbo skiptowncat MazdaSpeed 3/6 - Turbo Induction 9 08-14-2012 03:41 PM
Who DOESN'T run a Garrett turbo Ezekiel81923 2010 MS3 - Turbo Induction 138 08-02-2012 05:20 PM
Failed Thread essejkcamraw MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 57 11-17-2010 11:16 AM
Page generated in 0.44510 seconds with 32 queries
