 Old 10-04-2008, 11:02 AM   #41
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
There is a couple... but I have never been to ether one. I had an appointment to go to a place, then that shop closed down. I know that National Speed in Wilmington is supposed to be good.
That sucks about the PG headers. I need to order some headers i am thinking about going with the DNP?
7mileshome is offline
 Old 10-04-2008, 08:23 PM   #42
JimmyMac's Avatar
Posts: 558   (View Stats)
JimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the world
Well the PG manifold might be here by next weekend maybe. But I'll be out of state Saturday. Might do the install Sunday. But I have 5 mid-term essay's due the following week. So if not next weekend, maybe the next. Although I do have 3 days off of school. So maybe? I'll post up any results and how the GT28 responses to it. Tonight I spiked up to 24psi. I think that happens when I run up too high in the rpms to shift. I try to keep my shifts under 6000rpms to hit a sweet spot for the next gear. Usually the spikes are 22 psi.
Anyways, I'll look up that Wilmington shop. Thanks for the info.
2012 MX-5 SE
JimmyMac is offline
 Old 10-27-2008, 12:02 AM   #43
JimmyMac's Avatar
Manifold finally arrived Friday. Installed it friday night. Here's the pic of the PG manifold with ceramic coating by Jet-Hot. (posted this pic in the PG threads) Now I can start to get down and dirty with some SB tuning. Then off to the dyno. Gotta wait for decent weather though...
2012 MX-5 SE
JimmyMac is offline
 Old 10-28-2008, 05:55 PM   #44
7mileshome's Avatar
Nice... Looks good. How hard was it to get the stock manifold off?
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
 Old 10-28-2008, 07:50 PM   #45
JimmyMac's Avatar
Well for me, getting the stock manifold off with the stock turbo was a piece of cake. However, with the GT turbo, it's kinda a pain in the ass because of the studs sticking out of the head and the big fat compressor housing on the GT turbo. I played dumb and didn't unbolt the dp from the turbo. So I had to man handle the manifold out of there. I didn't bother taking off the valve cover either. It may seem impossible. But I found a way to get the PG manifold in there. Kinda like the preschool ball with shaped holes in it, and you had to put the correct block into the correct hole to fit it in there.
I wish the weather would warm up so I can head out to tune the car some. I'll play with it this weekend. Wish I had the Standback V3 software. I hate the V2 software. PITA.
Hey, where do they cruise in Fay? What's the main strip?
2012 MX-5 SE
JimmyMac is offline
 Old 10-29-2008, 06:15 PM   #46
7mileshome's Avatar
the main places alot of people go are skibo rd. or raeford rd.
Have you noticed any other exhaust manifolds that are good? Besides PG?
Built motor, Etc.
 Old 10-29-2008, 07:41 PM   #47
JimmyMac's Avatar
DNP looks good. But I would wait for the Steedspeed. That looks to be a pretty good unit with an external wg port already machined into the unit for future upgrade possibilities.
2012 MX-5 SE
JimmyMac is offline
 Old 03-13-2009, 05:33 PM   #48
ilusch's Avatar
Posts: 48   (View Stats)
ilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to behold
Did ATP fix the problem with the boost creep?
When not, how can we fix it without using a external westgate?
ilusch is offline
 Old 09-06-2009, 08:28 AM   #49
dlogic's Avatar
Posts: 9   (View Stats)
dlogic is an unknown quantity at this point
Any update if ATP fix the problem with the boost creep?
dlogic is offline
 Old 09-06-2009, 09:15 AM   #50
7mileshome's Avatar
No, they said it was not the turbo causing the issue. They suggested getting an external wastegate, or porting the internal wastegate (causing it to leak boost BTW.) Another option that they offer is a "surge protected compressor housing"
Built motor, Etc.
 Old 10-12-2009, 11:48 PM   #51
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
anyone have pics of the restricter pills ?>
 Old 12-23-2009, 04:09 PM   #52
cageyvet's Avatar
Posts: 715   (View Stats)
whos using the 2871
cageyvet is offline
 Old 12-23-2009, 05:59 PM   #53
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Use t3 flanged turbos. I would advise going with that over an ATP stock flanged turbo ANY day.
www.cp-e.com is offline
 Old 01-16-2010, 08:30 PM   #54
phong3992's Avatar
Posts: 8   (View Stats)
phong3992 is an unknown quantity at this point
Groaned at 8 Times in 5 Posts
gt turbo's ftw
phong3992 is offline
 Old 03-21-2010, 06:14 PM   #55
silverspeed 3's Avatar
Posts: 16   (View Stats)
silverspeed 3 is on a distinguished road
Groaned at 8 Times in 4 Posts
I took my turbo off my 2007 speed 3 today no blades left on compressor side of turbo and was making 5 to 9 psi.I spoke to B N R turbo has anyone used there stage two upgrade whch bolts up to my down pipe and exhaust manifold .Looking for feed back before i make a purchase,i would greatly appreciate ny members imput.My car has mazdaspeed cai,greedy exhaust,turbo xs dp,rp,bov,accessport.
silverspeed 3 is offline
 Old 03-21-2010, 07:05 PM   #56
DSIT995's Avatar
Posts: 1,768   (View Stats)
Bryan is working on mine now. Probably goin to be a month or so b4 its done, but ill let u know how it all works out when I get it
99 Miata NB - Stock for now
DSIT995 is offline
 Old 03-23-2010, 09:22 AM   #57
mattizle14's Avatar
Posts: 96   (View Stats)
mattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the rough
im wanting to get the gt35r and i had a question about how the whole 2-1 hoses work and how it goes to stock soleniod...i kno u will say read the thread and go to link but the link isnt working for me and ive tried searching and thats not working so if u could paste it in here on how u could hook that up that would be great
2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel...
mattizle14 is offline
 Old 03-23-2010, 10:01 AM   #58
7mileshome's Avatar
JimmyMac describes it best on the first post of this thread.
Built motor, Etc.
 Old 03-23-2010, 10:11 AM   #59
mattizle14's Avatar
but what about the boost prob?
 Old 03-23-2010, 11:44 AM   #60
7mileshome's Avatar
Check my proir posts (about 8 ago) on this thread.
You can call ATP and ask them their opinion, but if your asking me, the only way
to manage your boost correctly on a non-oem turbo is to have an external
wastegate+manual/electronic boost controller.
Built motor, Etc.
 Old 03-23-2010, 08:40 PM   #61
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
supposedly their porting the housings now?? not sure if you have to ask for it, and if it is actually enough to effectively control lower boost lvls.
be curious to see results???
at 104000 2 bent rods
tuned by nishan
rigor is offline
 Old 03-25-2010, 04:08 AM   #62
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
ATP FAIL FLANGE
holeinmypocket is offline
 Old 03-25-2010, 09:50 PM   #63
7mileshome's Avatar
^^Explain Please^^
Built motor, Etc.
 Old 03-25-2010, 10:46 PM   #64
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
atp fail flange?
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline
 Old 03-25-2010, 11:01 PM   #65
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
the atp mazda specific turbine housing that is set up for iwg is restrictive - a regular t3 flange with out the internal blockage of a iwg setup flows better - you have to run an ewg t3 mani setup to make this work tho
here's a story about when socks changed turbine housings
Byebye ATP Fail
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cpolly69 is offline
 Old 12-09-2010, 09:21 AM   #66
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
it might be a fail flange, i personally cant believe a turbo that works in IWG config on other cars magic/epic fails on ours, that is the only reason they would insist its not their turbos and not wind up with a civil suit up their anal crevass
dont worry, before you start typing ur flame, i am going to possibly eat dirt when my atp 3071 arrives this week(then the saving begins, since i am getting this B protuned again)
since the sad fact is, people upgrade their turbos and dont change the tune... how or why ppl think this is ok if you want your car to run... nm im not going any further
but well see if given all the love and care if this thing will in fact run... otherwise ATP needs to STFU and withdraw their product from the market
either way, i willr eport back my personal experiance(probable rape according to this forum)
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline
 Old 12-09-2010, 09:25 AM   #67
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
holy fucking old thread genius!!! Look at post dates first
tbot is offline
 Old 12-09-2010, 09:36 AM   #68
cpolly69's Avatar
Groans: 27
Haha this^^
Man ATP has redesigned their iwg setup for the 3071 since this old ass thread.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cpolly69 is offline
 Old 09-19-2011, 03:01 PM   #69
focoms3's Avatar
Posts: 30   (View Stats)
focoms3 is on a distinguished road
So problem is fixed for the 2871 too i take it? Or is BNR the way to go...
focoms3 is offline
 Old 09-19-2012, 05:52 PM   #70
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: GT Series Turbo Questions.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
BIG TURBO Questions! EdgeAutosport.com EdgeAutosport.com 483 08-21-2016 11:00 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
Questions about porting the WG on the stock turbo Lymerock MazdaSpeed 3/6 - Turbo Induction 2 11-30-2008 02:49 PM
Page generated in 0.46439 seconds with 38 queries
