![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 853 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Neutral : +1 score In my own personal experience, I started smoking at between 1,000-1,500 miles on the car. This was on the 2 mile trip home immediately after installing my catless DP/RP combo. I had also installed a custom intake at about 100 miles on the car and that didn't make the car smoke at all by itself, but for sure contributed to it by decreasing the vacuum on the intake tubing due to removing the restrictive air box and filter. Think of the PCV system as two ends of a straw with one person sucking on each end. The intake manifold end sucks harder than the TIP end, but BOTH contribute to how much vacuum the crankcase sees. Since the intake manifold end has more vacuum at idle, the flows from the intake boot, through the valve cover, through the crankcase, and and then enters into the engine through the intake manifold barb. Flow under boost will reverse towards the turbo because the PCV closes under boost, the turbo inlet side suction increases as the turbo spools up, which is why we get a little residue in the inlet side of the intake boot. If you have more than just a little residue, you have other issues outside of what will be discussed here.
Ugh... enough typing for now.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
| The Following 3 Users Say Thank You to bnoon For This Useful Post: |
![]() Join Date: Oct 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 603
| Not Ranked : 0 score Great write up. Thanks. I think you have made a great assessment of your experience. I read in a book about turbos that too much pressure is an issue as well as too little. One of our fellow MSF members posted this: some pics of improved turbo. Showing Mazda updating their K04 with a new oil restrictor on the oil inlet. So you definitely hit the nail on the head. I'll be installing your bnoon bolt sometime this spring. Thanks for research. I vote for sticky.
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP RPM: Sport Springs, Shark Fin, LED side markers CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount |
(Thread Starter) | Not Ranked : 0 score Yeah I saw that thread. I wish I had documented which part number my newest turbo is that's on the car now. Early '09 was the install date if I remember right. If I ever get it, I'll update the first post with my part numbers.
![]() Join Date: Nov 2010 Location: rialto, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 433
| Not Ranked : 0 score Bnoon, are u still selling your restrictor bolts? |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score So what actually fixed the smoking? |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
(Thread Starter) | Not Ranked : 0 score Yes. From time to time they show up on Ebay. The oil restrictor and raised idle did it for me. Prior to me getting the Cobb AP, it took the PTP pill, thicker oil, and the restrictor bolt.
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score not right now ---> boon belt items - Get great deals on Books items on eBay.com!
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
| Not Ranked : 0 score actually raised idle (1100rpm) and bnoon bolt stopped my smoking. i still smoke at anything <~900rpm and 1000rpm vibrates too much
Might help if you spell bnoon right you dolt. EDIT: OK, I just can't be that harsh. I didn't have them up, but still... speeled wright end eet cums up noww. http://cgi.ebay.com/ebaymotors/ws/eB...m=140529933921
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall | |
![]() Join Date: Feb 2009 Location: Crete, IL.
| Not Ranked : 0 score Got any pics of this short ram of yours? Also, what would it cost? Thanx |
| Not Ranked : 0 score Very good write-up about this issue. Another "fix" - keeping slightly higher pressure on the exhaust end with a cat would also help the smoking issues with the stock turbo. |
![]() Join Date: Mar 2009 Location: VT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 255
| Not Ranked : 0 score your bolt immediately fixed my problem. I've had the PTP pill in forever and it didn't do shit. I've been meaning to take it out but I just keep forgetting. I've ran 5w30 all winter without any smoking. I've raised my idle to 900 just it case but really if I just ran your bolt I feel confident that's all I would really need.
__________________ 06 VRM MS6 - AP Stage 2 (Self Tuned to 18psi) - Forge BPV - PG SRI - PG TIP - Turboxs TP - ETS TMIC - TMW Stage1+JB SSP - CP-e RMM - PTP smokey turbo fix - Bnoon bolt - Prosport Boost Gauge in block8head vent pod |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
| Not Ranked : 0 score Do you have a coupon or code.... muahaha.....I just kiddinggggggg..... Seriously, I am getting this as well..you are the bman
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score bnoon bolt = nope 5w-40 = nope matt damond's occ = nope pea tea pee pill = nope raise idle w/ ap = yes (for 5 mins) everything altogether = still no gt3071r (like above poster said) = FUCKING YES fucking worthless piece of shit stock k04 faggot motherfucking cunt pole smoking bitch! DIE!!!
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
![]() Join Date: May 2009 Location: Tustin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
| Not Ranked : 0 score damnnit i just had this start happening...looks like i need to get a bolt and play with my ATR. yay............
__________________ "If I can't fix it, it was meant to be broken" [SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey TUNED BY NISHAN POWER SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG COSMETIC AND AUDIO Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4 |
| Not Ranked : 0 score 1100rpm
| Not Ranked : 0 score i'll make my own bolts for now and go to 950 first. Key word is make my own bolts...either i pull it off in the garage or i gotta go to the machine shop at work...shouldn't be too hard....I just bought 4 bolts in case i mess up some... We'll see if i can cure this. Since i'm pulling my battery i'll debate the EGR block off plate as well...maybe drill a tiny hole in the plate in that to deal with that issue too so i don't throw a CEL but it removes some of the soot traveling down...it's a drill a thon!
![]() Join Date: Mar 2010 Location: Jacksonville, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 79
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score short of gt3071r what else could it be. ive done all of the above and i still barrel smoke out the back at idle and stop lights. the turbo has been rebuilt aswell. ![]()
__________________ Corksport 3in catback resonator removed, Turbo XS catless downpipe, Cobb AP Stage 2 ots map, COBB SRI, RPMC inlet, Ported/ Rebuilt Ko4, ported exhaust manifold, ported and ects delete, JBR EGR delete, JBarone passenger, rear and tranny mount, JBarone SSP/ knob/ bushings,DDM HID low/high/fogs, Snow performance stage 2 MAF meth kit, Matt Damond OCC and check valve, Tenzo Concept-9 wheels, Turbosmart 50/50, Denso ITV-22, Tinted tailights-reflectors-corners, prosport boost gauge, DIY FMIC, Carbon hood wrap, NRG shorty antenna |
| Not Ranked : 0 score hey Bnoon, I just installed your bolt. Idled about 5 mins and no smoke. Generally I would see smoke after 10 mins. I was checking the install. Everything seems great so far. I'll see come summer time. I had a question on the OE banjo bolt. I know the holes are pretty big but could one recycle the OE by blocking up one hole? What possible material could you use to withstand the heat? Just a thought.
Having said that, I would go a totally different (easier) route if you were truly wanting to repurpose the stock bolt. I would drill and tap the center rifle drilled hole for a threaded allen plug, then drill that plug to .060" and epoxy it in place. It's something I looked at doing for my restrictor bolts, but I didn't want to rely on people sending in their core bolts to be modified. In the end, custom drilling the new bolts were cheaper and easier to keep in stock, so that's the direction I went.
| Not Ranked : 0 score Finally installed my bolt (home-built using bnoon specs) over the weekend with my TMIC install and it seems that all the smoke has stopped.... i will test it after work where i smoked everyone in the exact same spot for 3 weeks straight...however, i just changed my oil to 5W-30....so that may offset it as well... we shall see...however I want to say that the bnoon bolt works to solve that stupid smoke for me! Updates to come later...
Groans: 74
i've smoked twice over the years and wanted to confirm if this is the reason why. both times i had my ac running. would that make the difference? i don't like ac (prefer windows down) but run it when guests are riding with me and this week as i got a tint and can't roll my windows down yet. noticed i was smoking at a light this morning and started putting two and two together. smoke fixes include: 5w40, occ & ptp pill. probably going to buy your bolt before i trade the ht in for an ap so i can up the idle.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket | |
![]() | | #24 | ![]() |
Yes, the AC can make you smoke. Running the AC requires more throttle to keep at the same RPM and since the throttle opens with the increased load, vacuum goes down, causing the PCV vacuum to drop as well, causing the smoke. You have a return PM.
![]() | | #25 | ![]() |
![]() Join Date: Mar 2008 Location: ft bliss, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 221
Groaned at 40 Times in 20 Posts
| Not Ranked : 0 score hey bnoon does ur bolt work right away? i just installed it this morning. took it for a little drive and it smoked like crazy at a light. not sure if it takes a little time to work or not?
__________________ (RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT- 13' CWP MS3 |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've never had to wait long at all to know it's working or not. Usually a trip around the block for me when I was testing different combinations out. Do you have any other fixes installed? I notice you have the AP in your sig, what's your idle set at? My car takes 1000 RPM idle and my bolt to not smoke now and prior to the AP it took the PTP pill, thicker oil, and my bolt to not smoke.
![]() | | #27 | ![]() |
Groans: 74
| Not Ranked : 0 score installed mine friday night. as i was blowing into bnoon's to clean it out, i noticed bnoon's smaller hole makes it double as a rape whistle.
![]() | | #28 | ![]() |
![]() Join Date: Nov 2010 Location: Lebanon, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,064
Groans: 56
| Not Ranked : 0 score How does the EGR block off plate fit into the picture? Or is it something else entirely?
__________________ Speed 3 2007: NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer. |
![]() | | #29 | ![]() |
__________________ (RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT- 13' CWP MS3 | |
![]() | | #30 | ![]() |
| Not Ranked : 0 score The erg is something completely diff. It goes from the block to the IM. the oem pipe that is. With the block off kit u remove it and put the plate on the block and plug the IM.
![]() | | #31 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score So about a week before Brad posted this I actually just happened to compile the same sort of information and send it along to Haltech.. with the hopes it could be a sticky and stop a lot of the ? thread that pop up about smoking turbo... I'm just going to copy what I came up with here - Basically a large part of it is the same info - but there is also a basic explanation of how the stock pcv system functions in the first place there to help understanding... PCV - Positive Crankshaft Ventilation The concept has been around since the muscle car days. Basically it’s an answer to a simple question. How do we dissipate the excess pressures generated in the crankshaft area (bottom of the block)? In the muscle car days they would simply run a line right from the block with a 1-way valve to the ground allowing a bit of oil and crankshaft area gases to just vent to the air. This isn’t allowed today so manufactures have come up with all sorts of creative ways of recycling these pressures and pushing them through the engine itself The MZR uses a 2-way system - pcv pressures flow one way under idle/cruise conditions and go another way under boost conditions Under Idle/Cruise - Pressure flows from the intake pipe through the little tube attached into the valve cover and the intake pipe At idle you should be able to pull this line off and feel a slight vacuum here (at the valve cover input/output) - If you do not this is an indication that something greater may be wrong. The pressure flows into the valve cover - right where the line attaches (on the inside) there are a series of small baffle chambers - with little holes leading from one chamber to the next - the pressures flow through here - Then into the valve train/cam area - Next they flow down the timing chain area and mix with the pressures that are naturally being generated by the crankshaft Next they flow out the pcv valve (located under the intake manifold on the front of the block) - This pcv valve only opens up at low pressure levels that are generated at idle and cruise - and it’s supposed to be one-way only. It’s supposed to block higher pcv pressures that are generated by boost - If it malfunctions, this can be the cause of a number of issues. This pcv valve is mounted inside a small baffle plate that is held on by about 10 or so allan key bolts. Next the pressure flows through a small rubber line from the valve to the intake manifold. Once it’s here it goes into the combustion chamber and is mixed with normal air flowing in - It gets burnt and pushed out the exhaust - Under Boost - Under boost things flow in the opposite direction - The pcv valve on the front of the block is closed All the pressure flows back up the timing chain area into the valve train/cam area Then through the baffles and out the port on the valve cover Then back into the line on the intake - Through your turbo - through the intercooler - into you intake manifold and through the combustion chamber… Why does it smoke?? PCV imbalance is the typically the reason. What’s imbalanced? If the pressures don’t flow out the front pcv valve as fast as they can come in from the top, what you get is excess pressure in the block - This excess pressure can push against the drain side of the oil return from your turbo (oil gets pushed into the top of your turbo and then drains out the bottom back into the block) With the excess pressure pushing again the drain - the oil over-pressurizes inside the center section of your turbo and gets pushed past the seals into the turbine area (exhaust) - It burns and you have smoke out your tail pipe A downpipe, test pipe, or both can amplify this whole condition. When you add these the turbo is working harder, the center section is spinning faster and more pressures are being produced. There’s an order of tests and things to do to figure out what’s going on - 1. Compression test - This is a great way to help narrow down what’s happening. Do you really have an imbalance of pcv and oil leaking out into your turbo or do you have a bigger problem? Like oil getting past your piston rings into your combustion chamber? Basically - is the turbo smoking or is your engine actually burning oil? 2. What’s going on at the valve cover? If you pull off your line from intake to valve cover you should feel a vacuum at the valve cover. If you feel pressure coming out of the valve cover you may have compression leaking out of the combustion chamber. 3. Are you sure your pcv valve is good? It’s supposed to be a 1-way valve and only open under idle/cruise. You can pull it and check it’s flow by simply blowing on it - or applying compressed air. Does an Oil Catch Can fix the problem? Probably not, but it’s nice to have. Sometimes when pcv pressures come out of the pcv valve on the front of the block they carry oil along with them. The oil can go into the intake manifold and be burnt in the combustion chamber. All an oil catch can is a in/out pressurized can that goes in the line from the pcv valve to the intake manifold. If you install one an additional one way check valve is recommended after the factory pcv valve (as a double check) and make sure you are using high quality/strong lines to hook up the can. Dash 10 lines are strong and can handle the pressure without collapsing. Since this is connected to your intake manifold - This directly affects your short term/long term fuel trims. If there is anything wrong here you will see it in your trims… What about PTP’s pill? PTP’s pill works on the theory that if you decrease the diameter of the hole on the valve cover you will increase the flow inside the valve cover baffles/valvetrain area. - This is kind of like how a shop vacuum work with a smaller attachment. If you stuck a vac gauge in the line on the shop vac and switched from the more open-end attachment to the smaller one (like you use to clean your car) you would see more vac on the gauge. It can work under idle and cruise. The problem is that under boost, it blocks flow out the valve cover when the system is flowing the opposite way. What about the Bnoon bolt? The Bnoon bolt restricts the amount of oil going into the center section of the turbo. The thought process here is that if you put less oil in it won’t become over pressurized and leak out the seals. Also, that a downpipe or testpipe or both are actually causing too much oil to be pulled in, in the first place. This may be the case and may actually work, but I personally do not like anything that could restrict oil coming into the center section of the turbo. Hasn’t Mazda released a fix for this now? Yes they have From what the images flying around indicate now - Mazda has changed the design of the valve cover and it’s port. The have also changed the location of the line that runs from the valve cover to the intake. It’s now mounted down lower on the actual inlet vs the intake pipe. Bottom line is - If you are under warranty, not heavily modded, and you fall under the vin numbers that Mazda has indicated with this bulletin you should stock your car and take it to have these parts installed. Some advice - Just keep in mind if your car is in warranty and you want to go and get the dealer to fix the problem; you have to prove to them what is wrong. They will put your car down the path of diagnosis. One path can lead to a new turbo, one can lead to this pcv system, and one can lead to recommendations on different oil. Educate yourself before letting them start the diagnosis and communicate with service reps, managers, and technicians. Let everyone know about your theories about what’s wrong and tell them what you would like to have done. Always remember, don’t show up at the dealer for anything like this without your oil change records. If you don’t get the answers out of the dealer that you want, call Mazda corporate. Explain everything in detail. Mazda North America 7755 Irvine Center Dr Irvine, CA, 92618-2906 949-727-1990 cpolly69
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
| Not Ranked : 0 score glad you had the chance to...from what i read i don't get that same treatment of a new PCV upgrade... ![]() but the oil restrictor bolt worked for me thus far....no problems yet!
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score Hopefully Brad can chime in on this. With the restrictor bolt in place, how much less oil is the turbo seeing? And are there any detrimental effects because it may be seeing less oil? |
![]() | | #36 | ![]() |
Another point is that we're not starving the oil in the turbo housing. The volume remains the same because even with a restrictor in place, the oil feed side can easily supply MUCH more oil than will actually flow through the turbo center section itself. The same volume of oil is just under less pressure due to the restrictor. Now, important note here, that oil does sit in the center section longer before it cycles through the center section due to the pressure drop and this was one of my main concerns in researching my restrictor options. If the pressure were too low, the oil would stay in the center section too long and "cook". All you have to do to see if this is happening is send in your oil for an UOA, or Used Oil Analysis. I've sent in several and never once had any thermal breakdown on any of the many many oils I've tried. If you believe that the oil has any issues with cooking, let it idle a full minute or more after hard runs before shutting the car off. This will do more for your oil than the difference in oil supply will. I've run maybe 15+ thousand miles with the bolt in and 31,000+ miles total and never have an issue boosting to 19-20 psi. That extra psi cooks the oil more than my bolt will and I still have good UOA's.
![]() | | #37 | ![]() |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score After spending hours fighting with my stock downpipe and race pipe to pop in my Turbo XS stealthback exhaust (which is hardly stealthy but amazing nonetheless), I initiated the dreaded cloud of smoke. I just ordered a Cobb Turbo inlet pipe and restrictor bolt. Hopefully these two will resolve my issue.
__________________ |
![]() | | #38 | ![]() |
![]() Join Date: Jul 2010 Location: Chicago IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score how did this work out for you ^^^? |
![]() | | #39 | ![]() |
![]() Join Date: Sep 2011 Location: Pearl River, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 328
| Not Ranked : 0 score ok so i just finished making my bnoon bolt, but as i go deeper and deeper into the forums im starting to lose faith. For some, the bnoon bolt is the all mighty savior. For others, they need to raise the idle, throw in thicker oil, get the vent fix, etc. Then there's still other fuckers that say none of these fixes do shit. Seems like i have a 50/50 shot. i have a HT tune so i can only bump the idle up +200( i know i should just get the AP, forgive my brokeness), will that be enough? With all this bullshit being said, will there ever be an end to the dreaded smoking turbo, or is it BT time?
__________________ GenWin Mazdaspeed 3: HTP 3", CP-E RMM: HKS SSQV : masonville knob, JBR SSP, bushings, RSB: COBB AP: STRATIFIED: Saikou Michi OCC: CP-E DP & FMIC: Autotech Internals: Koni FSD's: DO Meth A La WW tank style |
![]() | | #40 | ![]() |
| Not Ranked : 0 score losing hope fast. BNR is looking better and better every red light i come to... |
| Smoke at idle fixes, my thoughts and notes | bnoon | MazdaSpeed 3/6 - Turbo Induction | 85 | 09-13-2014 07:42 AM |
| smoke on idle? | kraz3y | MazdaSpeed 3/6 - Turbo Induction | 20 | 01-09-2013 03:26 AM |
| Thoughts on venting the oil return line, another possible smoke fix? | bnoon | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 12-10-2010 09:36 AM |
| idle smoke getting serious | Chriscote | MazdaSpeed 6 - Engine, Transmission & Driveline | 16 | 11-03-2010 01:43 PM |
| Smoke at idle | sleeper329 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-13-2010 01:56 PM |
