 Old 09-27-2011, 09:13 PM   #1
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
Originally Posted by DuBz View Post
ok so i just finished making my bnoon bolt, but as i go deeper and deeper into the forums im starting to lose faith. For some, the bnoon bolt is the all mighty savior. For others, they need to raise the idle, throw in thicker oil, get the vent fix, etc. Then there's still other fuckers that say none of these fixes do shit. Seems like i have a 50/50 shot. i have a HT tune so i can only bump the idle up +200( i know i should just get the AP, forgive my brokeness), will that be enough? With all this bullshit being said, will there ever be an end to the dreaded smoking turbo, or is it BT time?
just up your idle and see. why you ask us? see if it works and TELL us!
tddvrrn is offline
 Old 09-27-2011, 08:35 PM   #2
DuBz's Avatar
Posts: 238   (View Stats)
DuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the world
no, no, no man. I was looking for,"It'll all be ok," or "just shove a potato in the tailpipe," or "just drive the fucker off a cliff" u know that sort of thing.
GenWin Mazdaspeed 3: HTP 3", CP-E RMM: HKS SSQV : masonville knob, JBR SSP, bushings, RSB: COBB AP: STRATIFIED: Saikou Michi OCC: CP-E DP & FMIC: Autotech Internals: Koni FSD's: DO Meth A La WW tank style
DuBz is offline
 Old 09-27-2011, 09:34 PM   #3
DuBz's Avatar
yes yes i know...i talk a lot of sheet
DuBz is offline
 Old 09-28-2011, 10:21 PM   #4
DuBz's Avatar
upped the idle today (+200) and voila! no smoke. I make no assumptions cuz she's infamous for being smoke free one day, then smoking at every red light the next. For the sake of science, I'll hold off on the bnoon bolt n see if the raised idle is enough, then throw it in there anyway for good measure
DuBz is offline
 Old 07-15-2012, 05:34 PM   #5
arrestmered07's Avatar
Posts: 17   (View Stats)
arrestmered07 is an unknown quantity at this point
How has this worked for you? Did you end up needing to buy the bold or was raising the idle a fix?
Thanks!
Blake Smith
@designwithpink
www.HelloBlake.com
2007 MazdaSpeed 3 // K&N Intake // AP // Exhaust Depot Front Mount // HKS BOV // ATP 3" Long Downpipe // CNT RACING Catback Exhaust // 18" Kazera KZ-J Wheels
arrestmered07 is offline
 Old 09-30-2011, 01:26 PM   #6
kkostec's Avatar
Posts: 8   (View Stats)
kkostec will become famous soon enough
Bnoon bolt, ptp pill, still nothing... :'( the next step will be raising the idle. It seems to work when I raise the idle myself.
kkostec is offline
 Old 10-01-2011, 06:30 PM   #7
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
Ive been raising the idle manually at red lights and still smoking like a SOB. Should I even bother throwing an upped idle tune on it?? I have cobb ap but I also have a Mac, ATR is Win only, so if anyone is bored can I get a CS 93oct TIH v200 tune with idle raised to 1050 or 1100 rpms???? pretty plz????? I'm still smoking a ton during shifts and coasting as well. I doubt idle raising will help at all
G Sp33dy is offline
 Old 10-02-2011, 03:02 AM   #8
RidenDirty's Avatar
Posts: 58   (View Stats)
RidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to behold
Hey bnoon, are you still making those restrictor bolts??? If so how much for me to get one from you??? I am having the same problem and would love to get it fixed asap!!!
RidenDirty is offline
 Old 10-05-2011, 06:06 PM   #9
G Sp33dy's Avatar
added rotella t-6 5w40 + my banjo bolt and still smoking. Unfortunately bnoon the files you sent me are "locked" to your AP ser# and I can't load them, but thanks anyway. I will be using atr tonight to raise the idle and see if that helps. Hope my new valve cover gets here early tomorrow...
G Sp33dy is offline
 Old 10-06-2011, 12:53 AM   #10
G Sp33dy's Avatar
IDK if this matters, but while changing the oil today I noticed some oil dripping from the oil drain line from the turbo, leaking down the drain tube, and a small amount was on my plastic undertray and speckles on my drive axle. Has anyone else had this happen? Its making me wonder if the oil drain tube is somehow clogged. Is there an oil screen in there? Idle bump to 1000 rpms did not work whatsoever.
G Sp33dy is offline
 Old 11-01-2011, 02:01 PM   #11
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
To me it could be a couple of things causing the smoke at idle and they all have something to do with the oil return from the tc, it couuld be compounding issues, but basically it is a pressure issue.
The crankcase vent system not venting properly can cause backpressure, ie a garrett GT series turbo seals are designed to weep once the cartridge chamber pressure exceeds @45psi, it will load the hot&cold side pipes with oil until the back pressure source is fixed. IDK know what the oe ms3 borgwarners are designed to do handle over pressurization....but smoke at idle is a clear signe oil is making it past the hotside seal.
A kinked or damaged return line, I actually had the lining come apart inside the return line causing this to happen, and it was not obvious.
I eventually found the damage of the liner after the fact when I was able to cut the line, clean it throroughly and throw some light down the inside/post mortem inspection, what I did in the meantime was to weld a -10an aluminum bung to the highest point possible in the oil pan, bought a -10 return adapter for the tc and ran -10an oil return line.....overkill but hey I know that fucker has no restriction problems do to size now, then I check the vent system out.
Tabasco69 is offline
 Old 11-01-2011, 02:05 PM   #12
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
<----- has a non-smoking k04 for sale, with bnoon bolt for a lil extra
07 MS3
The original Genpoo Hater
Chimmike is offline
 Old 02-15-2012, 10:45 AM   #13
boostinp's Avatar
Posts: 6   (View Stats)
boostinp is an unknown quantity at this point
Sorry for the noob question but the bnoon bolt fixes smoking or do you have to up the idle rpms as well? Also it swapping to the gt series turbo just a simple swap and does that eliminate smoking all together? I am looking into purchasing one of these cars but I dont want to start modding only to have it start smoking..
boostinp is offline
 Old 07-15-2012, 05:42 PM   #14
From what I have read, it seems like the bolt alone fixes it for some but others need both. I have the bolt and it hasn't helped me any. I'm getting an AP to raise the idle and crossing my fingers that it fixes the problem.
Blake Smith
@designwithpink
www.HelloBlake.com
 Old 07-15-2012, 06:14 PM   #15
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
Having the AP is a great mod and can help the smoking issue by raising the idle. I had the smoking issue too when I installed a re-worked K04 and a catted DP. I switched to 5W-50 oil and that stopped the smoking. I have, since then, installed bnoon bolt and switched back to 5W-40 oil and once in a great moon when temps are about 100 degrees I will see occassional smoke. Try the heavier oil first and then get the AP. But eventually get the AP. Guys here love it. GL
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline
 Old 02-15-2012, 02:45 PM   #16
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
^^^ if you're buying, i'd let the car idle for 10 minutes to see if it smokes. the current owner should be able to tell you if the turbo was replaced and / or the vent kit was installed.
i'd use the combination of 5w40, up the idle, and add a bnoon bolt and occ just to be on the safe side. oh, and don't forget to drain your occ.
check out the bt turbo swap how-to's. i wouldn't call it a simple swap.
karl-hungus is offline
 Old 02-15-2012, 03:37 PM   #17
bnoon's Avatar
Posts: 1,770   (View Stats)
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline
 Old 02-21-2012, 10:35 AM   #18
boostinp's Avatar
So stock if it smokes after 10 minutes it most likely needs a new turbo how much smoke am I looking for?
boostinp is offline
 Old 02-21-2012, 11:09 AM   #19
patrick failman
Groans: 74
you're looking for any smoke.
 Old 02-21-2012, 03:53 PM   #20
boostinp's Avatar
Cool thanks
boostinp is offline
 Old 02-27-2012, 08:50 PM   #21
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
Groans: 148
So i'm curious. If the PCV(is broken?) goes unfixed for a long time and you smoke for a long time.
Could this lead to piston ring failure?
DiGi Faggot is offline
 Old 06-30-2012, 03:18 PM   #22
zspalm1's Avatar
Posts: 16   (View Stats)
zspalm1 is infamous around these parts
Groaned at 20 Times in 5 Posts
i don't know if anyone has covered this, so i will. Mazda's final smoking turbo fix is the way to go with the smoking problem. i purchased the pt-performance pill thing and it did not work. my car being out of warranty mileage i had to do the fix my self. yes the factory recall replaces alot more then what i did but it works with no need for idle raising or pt pill or the oil restrictor bolt. all i did was go to advance auto purchase a universal vaccum T some 1\2 inch and 1\8 inch tubing just incase you F up (not sure about the 1\8, blah). looked up the diagram from mazdas recall and did it like that. let me know if you guys want pictures or want to give me lessons in writing.
zspalm1 is offline
 Old 07-06-2012, 09:29 AM   #23
bnoon's Avatar
Been there, tried that, didn't work for many many many members. Glad it worked for you.
2002 BMW M3 - Sold!
bnoon is offline
 Old 07-06-2012, 12:22 PM   #24
zspalm1's Avatar
Yep it worked for me I've only had one instance.where it smoked but it was because I was at idle with ac and reving it a little once.I stopped it went away quick though
zspalm1 is offline
 Old 07-11-2012, 09:33 AM   #25
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Default Bnoon bolt, where can I get one ?
I want to buy one of the bnoon bolts, where can I get one.
I've searched the threads and come up with varying answers so I apologize if the next questions seem redundant.
Do I have to have an AP to set my idle, the dash reads about 900rpm when warmed up, is that the correct rpm to potentially fix the smoking ?
Should I rebuild the turbo while I have the manifold off or just do the bolt and rpm ?
Last thing, I live in CT where it gets cold in winter and hot in the summer, can I still use 5/40 or should I use 5/30 ?
Does it have to be synthetic ? I cover a lot of miles on my daily commute so oil changes are frequent.
Thanks.
Mandinca is offline
 Old 07-15-2012, 10:51 PM   #26
DuBz's Avatar
Raising the idle was enough for me, then I switched to rotella and have been smoke free ever since. Some people have good results with 1 of the three fixes, others need to use all of them, and some people just never stop......who needs red lights and stop signs anyways. GL
DuBz is offline
 Old 09-19-2012, 06:00 PM   #27
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: Smoke at idle fixes, my thoughts and notes
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
Smoke at idle fixes, my thoughts and notes bnoon MazdaSpeed 3/6 - Turbo Induction 85 09-13-2014 07:42 AM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
Thoughts on venting the oil return line, another possible smoke fix? bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-10-2010 09:36 AM
idle smoke getting serious Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 16 11-03-2010 01:43 PM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
Page generated in 0.48884 seconds with 35 queries
