 Old 12-13-2010, 03:23 PM   #201
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
good to hear buddy!
i wouldn't worry about it!
you know what you've done to your car...
if you haven't pulled to many boner moves, you will be alright ...
pm me when videos are up !
at 104000 2 bent rods
tuned by nishan
rigor is offline
 Old 12-13-2010, 03:48 PM   #202
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
alright ...car is set..wga adjusted and locked down. mbc has softer spring and ball and will start running wg spring pressure to see what wot does on logs.....
as far as the person that blew up it was hnda etr ... he swapped ko4 for pg reworked... did some runs last night and car pulled strong... today idk what happened but he shot up to 24psi and now has some serious fucken head noise... no hole in block. idle car sounds normal...but step on it a hair and u hear rattling up on the top end... compression is 145-160-160-160.... ill let him add to thsi if he wants.... but pretty demoralizing so ill do what i can to help
rodrigo is offline
 Old 12-13-2010, 03:51 PM   #203
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
im excited and pretty fucken worried too..... the other turbo swap we did yesterday ended up in a blown motor just a few hours ago..... so im treading with caution.
oh no...Roy [hnda etr]??
if you will leave the lock nut lose on the wga arm it is easily adjustable from the top of the car. Leave it lose for like a week or two until you get everything dialed in. It can't turn by itself.
Dano is offline
 Old 12-13-2010, 03:57 PM   #204
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
i wonder if he had a boost source to his wastegate pop off, this has happend to alot of people....
make sure you somehow secure all vac lines to and from the turbo. one popping off (especially on the atp turbos, they only have one line on the actuator), the boost will skyrocket.
socks is offline
 Old 12-13-2010, 04:06 PM   #205
zx2man's Avatar
Posts: 1,356   (View Stats)
I wasnt planning on messing with my wg arm. But maybe I need to look into this.
As for hnda etr..fuck...Hope in the end that its not a bad prab,though it sounds like it is. Ill will pray to the cargods that his car will be fine. I too have heard the vac lines poping off and causing insane boost. Is it that people are not clamping them down?
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline
 Old 12-13-2010, 04:09 PM   #206
Trail of Fail
Dano's Avatar
zip tie everything guys...esp if you are using silicone hose
if its close to heat use heat resistant ties...
@ zx2
factory set preload on the ATP should net you around 12PSI pressure from my test. Loosen it up and you end up with ~11...tighten all the way ~14 BUT that isn't a stable way to leave it...much boost occiliation...
Dano is offline
 Old 12-13-2010, 04:12 PM   #207
rigor's Avatar
Groans: 40
that is what i did ^^^^
tuned by nishan
rigor is offline
 Old 12-13-2010, 04:14 PM   #208
Trail of Fail
Dano's Avatar
if the noise Roy is having is topside toward the passenger side he may have busted his VVT, which in turn may have bent some valves. if this is the case a much better outcome than a VTA block experience.
Roy I am pullin for ya!
Dano is offline
 Old 12-13-2010, 04:33 PM   #209
Fuck that PG turbo.... Glad we had some fail out of all of this... The suspense was killing me.
Told you that your car is fine and your engine isnt beat... now lets get a real tune on there.
Haltech is offline
 Old 12-13-2010, 04:51 PM   #210
zx2man's Avatar
Thank you Dano Looks like Ill just leave it alone then. Think thats what Anthony=driver311 did, and hes running great. Think ill run ninja clamps and zip tie living shit out of all my connections, then have Peter North shoot some man glue on em to seal the deal lol...Dont wanna play the zoom zoom boom game because of a simple overlooked install step.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
zx2man is offline
 Old 12-13-2010, 05:06 PM   #211
Trail of Fail
Dano's Avatar
Peter North FTW....get you some heat resist ties for the WGA nipple...gets hot down there...
Tefzel ties 300* operating temp..they only come in ghey blue and teal but they are good chit.
Heat stabilized nylon 257* and come in any color...
http://www.cabletieguys.com/specialt...htm#tefzelties
Dano is offline
 Old 12-13-2010, 05:18 PM   #212
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ok...had to wait for my son to get out of school to go drive around.
mbc turned all the way to zero leaves me with 15psi in 2nd.. 16psi in 3rd and about 16.5psi in fourth.... zero spike zero creep.
its still daylinght and too many cars so i wont log until tonight. the car feels decent... i dont expect much with 15-16psi only i just want to get everything dialed in before i start messing with boost. incidentally once i had fixed wga i turned the mbc one click down and went out... touched..and i mean touched the gas in 2nd gear and fucken spun like it was on water.... i let off soon as i saw 21psi in 2nd and went back to soft spring and zero d out.
egts are so much lower its not even funny...im talking about 2-300 degrees lower.
ill take some below pics...right now im super tired, i took a couple lame ones from top. u can see a tapped silicone coupler for boost source. , u can also see how the cpe inlet doesnt actually mate up to the end of the machined turbo inlet. but its there and no leaks.
ill add more shit as i go along.
rodrigo is offline
 Old 12-13-2010, 05:28 PM   #213
Trail of Fail
Dano's Avatar
so all it was was the WGA preload??
my CPE inlet is a POS as well and looks about like yours...you'ed expect better from them...What is another 1/4 inch of material gonna cost.
edit: better get that boost source zip tied! I know it fits tight but well worth the .5 minutes to throw one on there.
Dano is offline
 Old 12-13-2010, 05:49 PM   #214
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
I used heat sleeves on the vac lines near the turbo and zip ties for the peace of mind.
NJSPEED3 is offline
 Old 12-13-2010, 05:50 PM   #215
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
will do soon as i wake up from my nap.
one thing worth mentioning i had to clock my turbo and cut firewall shielding off to clear the nipple from it...or wouldnt have been able to put a vacuum line on it
rodrigo is offline
 Old 12-13-2010, 05:51 PM   #216
DSIT995's Avatar
Posts: 1,768   (View Stats)
Nice and clean Lenny, cant wait to see some logs tomrw
Hnda etr - that sux so bad man, sorry about ur luck
99 Miata NB - Stock for now
DSIT995 is offline
 Old 12-13-2010, 05:52 PM   #217
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
so we took off the valve cover and took a look around... physically, everything looks fine... we cranked the motor over (without coils attached) to look at the cams and valve buckets and vtc and everything looked fine - no collapsed valves, no physical damage to the VTC or cams...
So I button everything up and fired it up to see if the clattering sound is still there - yup... only now I can feel the clutch pedal vibrating when I let it out almost all the way...
so looks like it's a bent rod... FML...
Not sure what I'm gonna do at this point...
Thanks for the well wishes guys (except Kevin - smnf)
hnda etr is offline
 Old 12-13-2010, 05:58 PM   #218
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
fycn
phillyb is offline
 Old 12-13-2010, 06:01 PM   #219
rigor's Avatar
Groans: 40
sorry to hear that man
tuned by nishan
rigor is offline
 Old 12-13-2010, 06:15 PM   #220
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
damn roy sorry to hear and hope you get back up and running asap
skeeter149 is offline
 Old 12-13-2010, 06:21 PM   #221
hnda etr's Avatar
Groans: 90
fycn
It been fucked good
Thanks Guys!
I would have bet money it would have happened to Lenny and not me... lol...
hnda etr is offline
 Old 12-13-2010, 06:22 PM   #222
Trail of Fail
Dano's Avatar
yes very sorry to here about the diagnosis...
still bent rod better than VTA rod...right? you don't need to source a block now.
it still sucks nuts though....
Dano is offline
 Old 12-13-2010, 06:26 PM   #223
hnda etr's Avatar
Groans: 90
Thanks Dano... The irony of it all is, I just got a torn down motor from Ken at PG (after making payments for the last 10 months lol) about 2 weeks ago... it's sitting on a pallet in my driveway...
hnda etr is offline
 Old 12-13-2010, 06:28 PM   #224
Trail of Fail
Dano's Avatar
well FML at trying to cheer you up! LOL
i'll just keep my fingers to my self...wait...no I mean keep my mouth shut...wait...no not that either....fuck it!
Dano is offline
 Old 12-13-2010, 06:32 PM   #225
hnda etr's Avatar
Groans: 90
lol... no problem bro... anything to cheer me up!
hnda etr is offline
 Old 12-13-2010, 06:34 PM   #226
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
idk wtf but im so tired i cant sleep...there goes my godamn nap.
oh well, ill go lift the car up and take some below pics, plus i gotta bolt back up the bellypan (left it off purposely to reveal any possible leaks.
ill post up some pics in an hour
rodrigo is offline
 Old 12-13-2010, 06:37 PM   #227
phillyb's Avatar
Groans: 1,940
this is how i found out...
lenny called me (that's right, he actually called me). he said, i have good news and bad news.
now, normally i ask for the bad news first so the good news seems better, but this was car related, so i said something along the lines of, "i want the good news first, cause i'll care more about the bad news."
lenny goes on to describe what he did to the wastegate and i said, "yeah yeah yeah, way to go...bad news is...you blew?"
he said no, buuuuuuuuuuuuuuuuuuuuuuuuuuuuuut, "roy did"
laughter ensued afterward...
fuck you roy.
phillyb is offline
 Old 12-13-2010, 07:17 PM   #228
zx2man's Avatar
Yeah sucks Balls for Hndr etr....but looks like hes got a option sitting in his driveway. Maybe one of your rods was already tweaked, and that 24 psi of love did it in, who knows. But best of luck to you in getting your car up and running.
Lenny-Looking good, thanks for taking pics, and looking for further progress. Is that the ideal location for the boost source? Do you make a pre-hole first? ie like pre-drill.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
zx2man is offline
 Old 12-13-2010, 07:25 PM   #229
Tripple OG
NJSPEED3's Avatar
Groans: 113
Yup you do need to drill and install you're self Dave. That is just a fitting the comes from ATP with the turbo.
NJSPEED3 is offline
 Old 12-13-2010, 07:42 PM   #230
driver311's Avatar
Posts: 1,769   (View Stats)
Move the boost source to the intake manifold and you will have more consistant boost, that my suggestion. My boost holds the same in every gear. Also when I turn my bc all the way down its at 12psi I believe. Glad to hear all is well.
Weird mine fits on there perfect.
Mazdaspeed
driver311 is offline
 Old 12-13-2010, 07:56 PM   #231
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
zx2 ..yes u gotta drill the coupler or tap the compressor housing and get a bronze one threaded in there. i waited until everything was in place before drilling.... i like to do things in order and drilling prior didnt seem prudent... plus i tried keeping the vacuum lines as short as possible for the mbc.
alright took some more pics from the bottom where u can actually see the turbo. i also got some of the ko4 v2 I had on there .
U will see all the stainless lines, the one water line i was to lazy to cut to size so i just looped it... it clears the dp and the axle so it just looks funky but works perfect.
got pics of the bracket and worked like a fucken charm...was able to push it up there to desired height and bolt it down tight... the turbo feels super solid there
u can also see where i had to cut a lil off the firewall heat shielding (the metal one not that cardboard one) just to clear and give the wga some room..... (zx2 remember u might run into issues man.... clocking the turbo was perfect)
also I took a pic of the axle seal we replaced.
all in all i am super content that everything seems in order... im pretty bummed roy is feeling the opposite...but you know we will help u figure this shit out man.
here s some pictars
ko4 v2 i bought from anthony (driver311) looks a lil white ... (race gas , leaded...turns yo shit light gray)
oil return line (didnt have to shorten it.... (trick is mounting the fitting to the block first and then hooking up the hose to it
lil long on the waterline to the heater lol
oh shit.... did i forget a sock up there?? oh no...thats ma awesome bracket!!!!!!!!!!!
lil bit wider shot of the set up.....lines have no way to hit anything as odd as they might look
heres a nice shot of the subpar inlet from cpe... (great job guys!!!) so far i have talked to at least 4 other guys that noticed this!!!)...btw i got an email today from cpe trying to offer help or how they could fix the situation... ill respond later
theres the shielding i cut off... at the point i cut it it really isnt blocking the brake lines so fuck it
for reference on rod length heres the wga rod adjusted
and heres the axle seal we replaced....
hope i can help anyone trying to go for an atp iwg set up..... i see no issues with this set up... turbo spool is quick... there is no creep... no spike.... just super fun turbo.
as the weeks go ill be getting some help tuning this and ill post some results. .... dont expect dynos.... i never go to them., i have my own views on that scene..... when the time comes ill dyno it by trap speed....
thanks for the support and the help , dano, dj, sean, cldpck, mark for the hook up... the local socal guys tha helped me yesterday , tony, roy , julio....everyone that i have learned from i am truly very appreciative that this turned out successfuly
anyways enough bullshit for one day.... whos next?????
rodrigo is offline
 Old 12-13-2010, 08:35 PM   #232
Trail of Fail
Dano's Avatar
good job and good pictoral...
BTW...only way CPE can fix their POS inlet is to re-tool their mold...I had forgotten all about my anger with this...I expected more from CPE...oh well no vendor is perfect...thanks for bringing it back to the surface Lenny
enjoy the new powa!
I guess a 3071 is enough bigger to require cutting the shielding from the firewall. I didn't need to do that and I think I have 1/2 inch to spare...
Anthony,
The CPE inlet bottoms out on the inside taper in the inlet before the outside bottoms out on the turbo flange. You end up with just enough surface contact between the inlet pipe and turbo flange to just barely get the clamp down. If it isn't lined up just right it will come off. When mine is lined up good enough to clamp the inlet is not even square with the turbo flange.
12PSI is also what I saw with factory ATP preload.
Dano is offline
 Old 12-13-2010, 08:56 PM   #233
m4tic's Avatar
Posts: 4,928   (View Stats)
dang wheres my mention... i even dropped $90 on crows foot tools because i care lenny, because i care... im just glad we werent stuck there all night and tony got is family dinner in.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 12-13-2010, 09:19 PM   #234
Token black guy support.. only at Nator OG... See, Darkgums should take notice!
Get your FP sorted out yet bro?
Haltech is offline
 Old 12-13-2010, 09:27 PM   #235
driver311's Avatar
Dano, mine sits perfectly flush. Weird. Should I hack it up so it doesnt so I can be part of the group???
Mazdaspeed
 Old 12-13-2010, 10:14 PM   #236
Trail of Fail
Dano's Avatar
Too late. You're and outsider.
Hope you enjoy your properly fitted TIP.
Dano is offline
 Old 12-13-2010, 10:21 PM   #237
m4tic's Avatar
yea swapped out the relief valve and im good to go
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 12-13-2010, 10:23 PM   #238
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
^^^ thanks boynton... i seriously appreciated u flying to sears for that crows foot, saved my ass thank you very much.
rodrigo is offline
 Old 12-14-2010, 01:02 AM   #239
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ok, here some more pics of the day.
here s the turbo in car b4 the inlet.... u can see there is plenty of room to get that inlet on there and it not leak... just looks like complete shit.
heres a nice shot of my tits and gut.... oh ya... I forgot to mention...because the inlet is such a bad fit and the metal insert/reducer is so fucken odd shaped I had to cut the sri about an inch short for the bracket to line up.....
here s the awesome insert/reducer..... makes it great having a ring basically that the clamp needs to fit perfectly over to seal....(<<< insert sarcasm here)
home stretch ....(JCMS07, me, bmorrisj, tony)
and here is yours truly hoping to god I dont get wedged under the car !!!
(how u guys like my farmers tan?)
rodrigo is offline
 Old 12-14-2010, 01:28 AM   #240
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Groans: 179
good shit man, good luck with the car, enjoy the new found tire spinnage!
ZOOM ZOOM BOOM
Hamilton69 is offline
ATP 3071r swap how to , lenny gets BT fever too rodrigo MazdaSpeed 3/6 - Big Turbo Builds 955 01-21-2019 06:45 AM
A mild case of hybrid fever at GM Haltech Automotive News 0 12-11-2011 10:10 PM
coyote fever karl-hungus Mazdaspeed3/6 General Discussion 50 08-06-2011 09:36 AM
World Cup Fever: A1GP to make a comeback? Haltech Automotive News 0 07-07-2010 09:00 AM
Page generated in 0.58170 seconds with 34 queries
