Like Tree3Likes
 Old 01-25-2012, 06:55 PM   #1
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
subbed
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline
 Old 04-01-2012, 01:44 PM   #2
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Subbed for my future bnr build. Awesome right up man. Got any more pics of where the collant drain line you fabed up connects to?
dantes5823 is offline
 Old 04-01-2012, 03:41 PM   #3
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Originally Posted by Domino81 View Post
I learn SO much more and SO much easier with visual aid. I can gernally do anything if I've seen it done once.
Is that how you learned to masturbate?
Tapadatass
silvapain is offline
 Old 04-01-2012, 04:49 PM   #4
Domino81's Avatar
Posts: 5,081   (View Stats)
No. That came naturally.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Domino81 is offline
 Old 04-01-2012, 06:06 PM   #5
Ziggo's Avatar
Posts: 3,843   (View Stats)
In 3.5.2 there is a pic of its routing. If you follow the braided hose you can see where it plugs into the EGR.
Ask Me About My:
Ziggo is offline
 Old 04-02-2012, 08:36 AM   #6
dantes5823's Avatar
@Ziggo, any recent vd plots? updates? Im starting to peace my parts up and just wanna make sure im going the correct route.
 Old 04-02-2012, 09:08 AM   #7
Ziggo's Avatar
I don't have any VD plots since I worked the tune on the drag strip a few weeks ago. I have a few more pieces to install and then I am going to dyno it.
The additional "power" parts are a high pressure relief valve and injector seals. Also going to clean my intake valves while I have it open (45k miles with no catch can or EGR blockoff)
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 04-02-2012, 11:54 AM   #8
dantes5823's Avatar
Zigatapatalka
Ouch...might wanna pull off the mani and let it drain lol. I saw my valves after 10k miles and having both things on for about the last 3k and i was disappointed. AND i run meth -__- . But im curious on your gains. Ill prob beat ya to it tho lol.
 Old 05-17-2012, 06:03 AM   #9
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Zigatapatalka
Any updates?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosted Beluga is offline
 Old 05-17-2012, 07:24 AM   #10
Ziggo's Avatar
Originally Posted by Boosten Ya(josh) View Post
Any updates?
This weekend is EGR, injector seals & studs and intake valve cleaning. Thermal gaskets and port the intake manifold if I am feeling frisky. Decided to hold off on the HPRV till we have better ECU controls.
Ask Me About My:
Ziggo is offline
 Old 04-02-2012, 09:30 AM   #11
Groans: 50
Nice. Looking forward to see the results.
08 Mazdaspeed 3
 Old 05-17-2012, 01:30 AM   #12
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
I think someone should put this in the how to date-base
This is some good shit, helped me install my s3
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline
 Old 05-17-2012, 08:29 AM   #13
Groans: 50
Nice keep us posted. And post pics if you have time to take any.
08 Mazdaspeed 3
 Old 05-19-2012, 09:40 AM   #14
Ziggo's Avatar
Since there have been questions regarding the Coolant line routing I snapped an extra picture.
Ask Me About My:
Ziggo is offline
 Old 05-19-2012, 09:55 AM   #15
Ziggo's Avatar
Valves were in various states of disarray. Left valve of driver side cylinder was the worst:
Right Valve of Middle passenger side cylinder was the best, with just some gunk on the stem:
No evidence of injector seal leaks.
Ask Me About My:
Ziggo is offline
 Old 05-20-2012, 09:31 PM   #16
Ziggo's Avatar
Whoops..
Be careful reinstalling your fuel rail
Ask Me About My:
Ziggo is offline
 Old 05-22-2012, 12:34 PM   #17
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Subbed for awesomeness.
Pickles Tune in progress
himurax13 is offline
 Old 05-28-2012, 08:46 PM   #18
Ziggo's Avatar
So everything is now back to normal and running great. 22psi tune is rock solid, with just a bit of boost oscillation. After getting everything back together I had a boost leak which I traced back to the EGR port plug on the manifold. Got that sealed up using the permatex #2 on the threads. After that I had trouble with blowing the coupler that is on the mini extension between the turbo and the 90* coupler. It was just a 2" dia piece of unbeaded pipe with worm gear clamps so I am not surprised it called it quits. The pipe has been replaced with a beaded version, and 2" tbolt clamps from siliconintakes.com are on the way.
Because of all these issues I never got a clean pass at the drag strip this weekend, and did not make it on the dyno. I did coast to a 14.5 @ 97 after my coupler blew in 4th just after the 1/8th, that has to be worth something....
Now that the 3bar is in, its time to start working on the ramp to 25psi tune and see if the turbo has anything left up top for use on the drag strip. I would not use the 25psi tune for road racing, but should be ok for strip/street use. Once its done I'll hit the dyno to dial in the timing and get some data that should help set VVT.
Ask Me About My:
Ziggo is offline
 Old 05-28-2012, 08:59 PM   #19
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Good stuff, @Ziggo. Are you still running/tuning on e85?
EDIT: DOH! Fail. I didn't see the attached log.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline
 Old 05-28-2012, 09:07 PM   #20
Ziggo's Avatar
Its a 5/7 mix that I am using. We will see how it works, I may drop down to 3/9 if I continue to not see any knock. It appears that some of the knock I was seeing up top might have been due to the seals even though there was no evidence of leaking. I have not seen a return of the small counts of knock I used to get above 5500rpm
Ask Me About My:
Ziggo is offline
 Old 05-28-2012, 09:24 PM   #21
skeurton's Avatar
Interesting. I just replaced my injector seals yesterday and had the same observations. I had previously seen consistent counts of knock above 5500 RPM, as well. I had wondered if the stock seals were leaking because I was hearing a louder ticking noise than usual in the past few weeks. I logged a few pulls today and the most knock I saw above 5500 was 2 rows of 0.47 KR.
Here's what my injectors looked like when I pulled them...
2011 MAZDASPEED 3
skeurton is offline
 Old 05-31-2012, 08:09 PM   #22
Mistersix's Avatar
Posts: 2,585   (View Stats)
So this is 5 gallons E85 and 7 gallons 93 octane? Same with the 3/9 mix?
Any advice for someone who wants to run a modest blend for extra knock protection?
Mistersix is offline
 Old 06-01-2012, 12:07 AM   #23
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
3 gal per tank should be plenty to get your all the way to MBT (or beyond - so be careful if you are pushing timing) without KR or enough to offer plenty of extra protection against KR with an existing tune.
cld12pk2go is offline
 Old 05-28-2012, 09:35 PM   #24
Ziggo's Avatar
No evidence of leaking there either. You have more buildup on the tips than I did, and the shaft stuff looks a little brown which is odd. I didn't have any buildup on the ends, but had some carbon buildup on the sides of the nozzle that easily wiped clean.
Ask Me About My:
Ziggo is offline
 Old 05-28-2012, 09:46 PM   #25
skeurton's Avatar
Yeah, the injectors cleaned up pretty easily with some gasoline and a rag. I'm not really sure what that brown stuff is either. When cleaning out the injector ports in the head, I didn't really see any of that. It was all black carbon.
What kind of spark plugs and gap are you running?
2011 MAZDASPEED 3
skeurton is offline
 Old 05-29-2012, 03:31 PM   #26
Ziggo's Avatar
ITV22s @ .028"
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 05-29-2012, 04:51 PM   #27
Ziggo's Avatar
Here is some strangeness for you. Both are the exact same tune except with different boost targets and WGDC tables. Same MAFCAL, same fueling tables, boost leaks make you run rich, maybe a pre-turbo vacuum leak? But then why would it go up and down. I have two logs that show the exact same behavior.
The turbo seems to tolerate 25psi just fine. BATS did not rise unreasonably and I even overestimated the WGDC needed so it has a small boost oscilliation. Per VD I picked up 25hp as well, which is on the low side for a ~2.5psi increase, but that just means the hotside is probably getting pretty backed up.
Ask Me About My:
Ziggo is offline
 Old 06-01-2012, 04:32 PM   #28
Hey guys... wasn't sure where to post this but was really interested in the opinions of Ziggo and cld12pk2go of the option to the right of the gtx3071 on this page.
I didn't know up until today that the 3071 could be had with a 3" inlet and 2" outlet.
I have been reading cld12pk's posts about how he is glad he went 3071 and I've already contacted JP and agreed that paying a restocking fee for the 2867 and think it is worth the long run headroom I'll get with the 3071.
Garrett GTX3071R Dual Ball Bearing Turbo : atpturbo.com
rfinkle2 is offline
 Old 06-01-2012, 04:50 PM   #29
Eth/Meth Junkie
cld12pk2go's Avatar
Either turbo will be sweet. The 2867 will likely spool several 100 RPM earlier, but since the GTX3071 spools PDQ, this isn't a big deal IMHO.
I do not have any data on what the efficiency or flow hit might be on the GTX3071 with the smaller compressor housing; however, if you are going for the bigger turbo you might as well not limit the compressor with a smaller than ideal housing...
 Old 06-01-2012, 04:54 PM   #30
Ziggo's Avatar
Don't do it. If you are going to get the 3071 don't hamstring it with the smaller ID inlet. You are going to have to get some couplers to connect to your intercooler piping anyway, so you are really only saving on the big turbo TIP. And FYI, I am going to a larger diameter TIP/SRI/MAF as soon as JBR releases it. That and the 5th port setup are the last surrounding pieces I am putting into place. I'll live with that for awhile and see if I really want/need more.
So with @Lex 's help I resolved the lean spot issue. Apparently the injector scaling only works as long as you are not pushing it too hard. Had to rescale the MAF (by 22.5%!)
Log for the run (need to downscale the MAF/load values by 22.5% for them to make sense)
http://www.mazdaspeedforum.org/forum/foru..._4th_60112.csv
Ask Me About My:
Ziggo is offline
 Old 06-01-2012, 05:23 PM   #31
Glad it worked out for you too with the MAF scaling. That kind of strangeness makes me a little scared of what's going on behind the scenes with those scalars.
Lex is offline
 Old 06-01-2012, 05:47 PM   #32
Eth/Meth Junkie
cld12pk2go's Avatar
I have been running a 1.12 scaler for a long time and have never seen any oddities like that...
 Old 06-01-2012, 07:36 PM   #33
Ziggo's Avatar
I am also running ~twice the ethanol content (E40ish) and probably pushing the stock injectors harder since I am not spraying any fuel in the intake (yet...)
Ask Me About My:
Ziggo is offline
 Old 06-02-2012, 05:08 AM   #34
Eth/Meth Junkie
cld12pk2go's Avatar
Good point, you are pushing the IDC higher.
With the 0.87 latency, I am typically in the upper 70's on IDC.
 Old 06-02-2012, 07:11 AM   #35
Ziggo's Avatar
Yeah, I am using .87 latency as well and my IDCs are ~95% I can only get away with it because of boost targeting, load tuning would have my WGDC locked.
Ask Me About My:
Ziggo is offline
 Old 07-04-2012, 09:48 AM   #36
Ziggo's Avatar
Since I continue to get questions regarding the coolant drain line I went a took another picture.
1) Its important to slightly angle the banjo bolt towards the compressor housing so that it does not interfere with the manifold flange/gasket. I mocked things up prior to installing them to ensure it all fits together right.
2) Using a plain rubber hose in this location is very risky because of the exposure to the very hot turbine housing. The coolant will keep the hose from getting too extremely hot, but the radiative heat coming off the manifold/turbine housing will eventually make the rubber brittle and prone to cracking. Thus the replacement of this hose with a high temp rated, with a SS braided shield, not only to protect from abrasion, but also to shield the hose from the heat off the manifold/turbine housing.
Ask Me About My:
Ziggo is offline
 Old 07-04-2012, 09:58 AM   #37
dereeek's Avatar
Posts: 2,053   (View Stats)
Groans: 386
Great info. going to start studying this for saturday, when i install mine.
BNR3-FREEK-PU-398HP
dereeek is offline
 Old 07-04-2012, 01:02 PM   #38
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
thanks ziggo that helps a lot (:
breakfstincluded is offline
 Old 07-05-2012, 11:54 AM   #39
himurax13's Avatar
Groans: 255
thanks @Ziggo that helps a lot (:
I am glad that I put a 6AN line in there. There is a lot of heat in that area. 11.5" is just about perfect.
 Old 07-06-2012, 05:39 PM   #40
Ziggo's Avatar
Changed the intake situation around a little bit. JBR WP intake installed. Should prevent those pesky water on the MAF issues I had, and give me some headroom on the MAF sensor , I was exceeding 4.9V before. This should drop it considerably. Rescaled, 4.92v is now 662g/s, before it was 379g/s so I think I have sufficient headroom.
Ask Me About My:
Ziggo is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f626/bnr-s3-swap-how-125223/
Turbo ausbauen?? - Seite 2 This thread Refback 10-21-2014 02:18 AM
BNR S3 Swap How To Ziggo MazdaSpeed 3/6 - Big Turbo Builds 244 12-13-2016 09:07 PM
LSD Swap out Tomas MazdaSpeed 3 - How-To's 81 10-08-2012 09:16 PM
BNR GTX Swap Possible? Kydizzle MazdaSpeed 3/6 - Turbo Induction 12 03-28-2012 12:24 PM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.65490 seconds with 35 queries
