 Old 09-28-2011, 02:02 PM   #441
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Originally Posted by RichieRichness View Post
great read and deff in to see some ko4 logs on people running e85. I am beginning my e85 adventure and have already seen ~10 g/s increase with about 2* of timing. I'm currently hitting 265 g/s with stock fuel pump and 19psi...
Dude, I'm hitting those g/s values on a stock fuel pump and TMIC without E85. You can can do better.
Tapadatass
silvapain is offline
 Old 09-28-2011, 02:13 PM   #442
Matrix311's Avatar
Posts: 2,133   (View Stats)
Tapadatass
Agreed I hit 306g/s with my setup on 91 gas and k04
Sent from my DROIDX using Tapatalk
Matrix311 is offline
 Old 09-28-2011, 02:20 PM   #443
mrQQ's Avatar
Posts: 1,164   (View Stats)
HOW??
mrQQ is offline
 Old 09-28-2011, 03:04 PM   #444
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Every bolt-on possible, and probably borderline tune.
Edit: Also helps to be lower elevation where the stock turbo doesn't run out of breath so fast.
Enki is offline
 Old 09-28-2011, 03:15 PM   #445
mrQQ's Avatar
I'm at like 30ft or so, can't get lower than that.. but yea, I guess bolt ons.. still, what pressure is that at?
mrQQ is offline
 Old 09-28-2011, 04:27 PM   #446
silvapain's Avatar
Groans: 136
Not sure if you're asking me or not, but I'm at 18.5 PSI max tapering to about 16.5 at redline. I get blips of 0.35-0.70 degrees of knock on occasion at WOT.
 Old 09-28-2011, 04:28 PM   #447
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Originally Posted by driver311 View Post
IM still running e85. been running 50% e85 for months now but IM gonna scale back. Imcompletely maxed out on injector duty cycle. Im gonna go back to 25% and then take some logs. Im on my 4th turbo setup also. LOL I just can never make my mind up. Now rocking gtx3071.
^^^^^^^ changes turbos like most men change undewear.
you def need DJ to produce a top mount for the 3.
Dano is offline
 Old 09-29-2011, 12:34 AM   #448
mrQQ's Avatar
I also hit 265, but thats absolute max for me - cold day takes round 19 psi, hot day 21psi. But that's it. So I simply have no idea how can one hit 305, unless that's with some weird maf adjustments to account for fuel..
mrQQ is offline
 Old 09-29-2011, 07:21 AM   #449
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Tapadatass
Two things
1. I have a MS6
2. I have stock dp and exhaust
After adding more timing last night I was seeing 269g/s and my fuel pressure starting to dip below 1500psi...looks like it's time for KMD.
RichieRichness is offline
 Old 09-20-2012, 08:08 AM   #450
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: Drivers attempt at E85
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
My second attempt on a Datalog. ARES28 MazdaSpeed 3/6 - ECU Computer Tuning 9 03-30-2012 06:04 AM
1st attempt at vd tooslow10 2010 MS3 - ECU Computer Tuning 5 01-13-2012 05:25 AM
Drivers attempt at E85 driver311 MazdaSpeed 3/6 - Big Turbo Builds 448 09-29-2011 07:21 AM
British study suggests that older drivers are safer drivers Haltech Automotive News 0 05-01-2008 05:50 AM
Page generated in 0.31323 seconds with 27 queries
