 Old 08-17-2011, 02:59 PM   #121
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
yeah, everytime I open my hood somewhere, eyes get big and jaws drop.
jmhinkle is offline
 Old 08-17-2011, 03:02 PM   #122
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
Doug - your set up is what I will do I'd I get the balls and money to go BT. I would do the GTX3071 instead.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline
 Old 08-17-2011, 03:10 PM   #123
Axle Breaker
jmhinkle's Avatar
Groans: 162
3071 = waste of time and money on this car. GTX3076 would be sick, but I don't think I'd want to spool any faster than I can.
jmhinkle is offline
 Old 08-17-2011, 03:12 PM   #124
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I agree, 3076 and go with a bigger a/r hot side.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 08-17-2011, 03:13 PM   #125
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Yeah we both have the divided 3076... it spools ridiculously fast. I wouldn't want it to spool any quicker either. If I were to consider another turbo for this set up, it'd be a divided gt35r
dougefresh_ is offline
 Old 08-17-2011, 03:16 PM   #126
Axle Breaker
jmhinkle's Avatar
Groans: 162
Yup, I'm thinking twinscroll GTX35 with .82 would be fucking nasty.
jmhinkle is offline
 Old 08-17-2011, 03:21 PM   #127
Captain
QFT.
www.permtuning.com
 Old 08-17-2011, 03:25 PM   #128
I stand corrected. I have plenty of time prior to getting there. I'm just learning from the experts.
Funkster777
 Old 08-18-2011, 01:31 AM   #129
MSP611's Avatar
Posts: 2,291   (View Stats)
ya ill be runnin the gt3076 divided with the .82 hotside as well... the gtx would be crazy
In progress:
MSP611 is offline
 Old 08-21-2011, 08:03 PM   #130
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
I have 16 pound spring in 44mm tial and its still jumping to 22 psi. Socket caps 16mm were to small for my oil slide, I guess my flange was thicker.
Thanks man if it wasnt for this HOwto I would have been screwed on what to do
crazyp is offline
 Old 08-21-2011, 08:20 PM   #131
You're welcome for the how to. My 3076 with the 16psi spring used to hold 20psi by redline as well. My oil slide didn't fit either, but iirc DJ didn't have a gasket at the time to use as a template, so he just eye-balled it. We had to drill mine out to almost 2x the size, but a couple washers on top, and it was all good.
 Old 08-22-2011, 10:41 AM   #132
Captain
Hmm.... flange redesign time me thinks.
Thanks for the feed back guys. I really appreciate it.
www.permtuning.com
 Old 08-22-2011, 10:49 AM   #133
Anytime holmes. Just to be clear, the angle of the slide itself was perfect. The holes for the allen bolts were just off... no biggie
 Old 08-22-2011, 10:51 AM   #134
Captain
Yeah. The new flanges i tried with crazyp had bolts with them, but i wasn't 100% sure if they were correct ones cause i don't have a garret to test fit on. And he ended up having to "slot" them.
Finding blank flanges without an AN fitting on them is difficult. I hand made the first ones, but that was a ridiculous amount of work for a flange. I really need a source for them.
I'll find some somewhere, or just pre-slot the one like he has.
I'm stoked the down pipes have been fitting as well. The jig seems pretty accurate.... especially considering i used it for my 4" down pipe, and it actually fit, hahahahaha.
www.permtuning.com
 Old 08-22-2011, 11:05 AM   #135
The correct size for the allen bolts is in the OP of this thread if that helps. Yeah, my DP fit perfect man... I'm glad you're monster one did too! haha. Glad to see it finally coming to together . Thanks so much for bring the top mount set ups to life DJ!
 Old 08-22-2011, 11:10 AM   #136
Captain
www.permtuning.com
 Old 08-22-2011, 12:36 PM   #137
Ziggo's Avatar
Posts: 3,843   (View Stats)
<---- Jealous
Even more so after installing the BNR. Working behind the motor is a bitch.
- Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 08-22-2011, 01:12 PM   #138
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Im not jealous. I just have all out hate for the top mount guys
That is all.
Tappin
Dano is offline
 Old 08-24-2011, 07:06 PM   #139
Axle Breaker
jmhinkle's Avatar
Groans: 162
Check this post for an update on the manifold flange. If you have installed yours, you may consider doing this or if you haven't you should definitely do this.
jmhinkle is offline
 Old 08-25-2011, 01:31 PM   #140
Doug, keep an eye on your feed and return lines. I ended up buying this line and replacing both the feed and return lines completely. The line coming off the turbo return got brittle and cracked and was squirting coolant. This stuff should hold up to the heat. It is tight, but will fit over the PTO input. The feed side will need clamped down.
Finally ordered this hose. My feed line is pretty flat right where it comes off the turbo... it can't take the heat! Thanks again Joel for the tips on this. I looked under that, and it's a really easy swap. I wasn't sure if I'd have access to the PTO, but I always forget how close everything is under there! Got it shipped priority mail, so I'll be able to bang this out next week.
 Old 09-10-2011, 09:31 AM   #141
steedspeed's Avatar
Posts: 582   (View Stats)
Default T4
Here's some pics of the T4 manifold next to T3 for comparison. Gates are 44mm on both.
steedspeed is offline
 Old 09-10-2011, 09:41 AM   #142
Wish I went T4. Do you get a free jar of Afro Sheen with the purchase of a T4?
 Old 09-11-2011, 02:13 AM   #143
Axle Breaker
jmhinkle's Avatar
Groans: 162
Why t4? Because racecar!
jmhinkle is offline
 Old 09-11-2011, 09:23 AM   #144
steedspeed's Avatar
I must say the T4 version looks very "right"
 Old 09-11-2011, 10:46 AM   #145
Captain
T4 is perfect on these cars when going for power IMO.
www.permtuning.com
 Old 09-13-2011, 11:24 AM   #146
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
yup your right about that ...
SPEED6 KILLAH is offline
 Old 09-13-2011, 03:24 PM   #147
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
<--- BT newbie, please dumb it down for me.
So stock k04 turbo has a T3 flange, right? What makes a T4 flange better? (BTW, which one in the picture is the T3 and which is the T4?)
● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ●
● 2010 Mazdaspeed 3 - GONE ●
alien_sporez is offline
 Old 09-13-2011, 05:09 PM   #148
crazyp's Avatar
Groans: 68
stock ko4 is a mazda flange, not sure if the t3 is much bigger. T4 is the much bigger flange
crazyp is offline
 Old 09-15-2011, 09:09 AM   #149
steedspeed's Avatar
Let me know what you need and I'll machine some flanges for you no charge.
 Old 09-15-2011, 09:17 AM   #150
Captain
I wish i could quadruple thank this post Leen.
PM'ing you right now.
www.permtuning.com
 Old 09-15-2011, 10:14 AM   #151
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
subbed in hopes of news for top mount speed 3. also for amazing write up. good job everyone.
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline
 Old 09-15-2011, 10:38 AM   #152
Captain
If / when i sell my wrx and possibly pick up a speed3... this will be one of my top priorities.
www.permtuning.com
 Old 09-15-2011, 11:39 AM   #153
Trail of Fail
Dano's Avatar
/tease
Tappin
Dano is offline
 Old 11-01-2011, 12:37 AM   #154
Uncorrected put down 338/318, and now 385/370 @25psi, uncorrected. Baseline Dyno SAE 318/308, and now 369/357 SAE @25psi.
Was running mid-11s, high-10s on last dyno w/ the D010 w/m nozzle. Had to pull fuel 3x, and ran out of time tuning. I'm going back to the D07 @24psi, and maybe a few gallons/tank of E85 to get me over 400whp/wtq
 Old 11-01-2011, 09:57 AM   #155
Captain
Your car looks sexy man.
www.permtuning.com
 Old 11-02-2011, 10:34 PM   #156
Thanks man! ...and thanks to you . I'm also loving the H&R Sport springs... nice (much needed) drop, handles better, but rides close to stock. I think the springs are 33% stiffer, but not choppy like race springs. I wanted COs down the road, but my buddy game me these new in exchange for some stock shit, so I couldn't resist I'd like to powerdercoat my stock wheels black, charcoal, or gun metal, and put those back on at some point. Stockers look nasty, esp w/ some paint.
 Old 11-30-2011, 04:22 AM   #157
hank25's Avatar
Posts: 71   (View Stats)
hank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant future
Wow so you did this work in visitors parking. . You are the man Doug! If you ever feel like driving an hour north to use my garage you are more than welcome. No lift and small but better than a parking lot. Great work and excellent write up !
Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ
hank25 is offline
 Old 11-30-2011, 09:02 AM   #158
Thanks man, I may take you up on that if I get around to upgrading my map sensor, and maybe my fmic. Dude, you must live like 5 miles from New England Dragway, that's sweet.
 Old 12-02-2011, 07:41 AM   #159
hank25's Avatar
Yeah its probably 3 miles away, so close I even get a discount for the noise lol. A friend I went to school with lives even closer to the track and hes got a nice lift set up. Just gotta bring some :phillyb: and I know he wouldn't mind either. I am gonna do my downpipe with it when i get around to ordering it. Great build your car looks amazing!
hank25 is offline
 Old 12-05-2011, 12:41 AM   #160
Axle Breaker
jmhinkle's Avatar
Groans: 162
Just incase someone is wondering, a GT35 fits just fine on this setup. Playing with one right now just to try it out.
jmhinkle is offline
HOW TO: TOP MOUNT TURBO SET UP!! dougefresh_ MazdaSpeed 3/6 - Big Turbo Builds 187 10-22-2014 05:42 PM
Top Mount Turbo Speed3 JacksonMS30 MazdaSpeed 3/6 - Big Turbo Builds 157 04-29-2013 06:21 AM
Top mount turbo setups djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 1856 09-18-2011 08:46 AM
Page generated in 0.57309 seconds with 33 queries
