Brakes Database MS3/MS6! I am compiling a list for myself and have spent about an hour doing it so this may help someone else down the road. Any inputs or suggestions let me know and I will try to keep this updated. ROTORS Front Racing Brake $115.43 (each) #9115-111 Centric $144.95 #120 .45078 StopTech $156.80 #120.45078 StopTech D&S $250 #127.45078L & 127.45078R PowerSlot $230 #126.45078SL & 126.45078SR Rotora $223.95 #R .45078x DBA $224.95 #42962SL + 42962SR (104 each through tirerack.com) Italia $295 Royalty Rotors $133.99 #R R45067SD Centric Premium Rotor $55.41 (each) #120 .45073 Rear Racing Brake $79.15 (each) #9023-111 Centric $144.95 #120 .45067 StopTech $100 #120.45067 StopTech Slotted $148.18 #126 .45067 StopTech Drilled $140 #126 .45067 StopTech D&S $154 #127.45067L & 127.45067R PowerSlot $176 #126.45067SL & 126.45067SR Rotora $144.95 #R .45067x DBA $209.95 #42957SL + 42957SR Italia $215 Centric Premium Rotor $30.39 (each) #120 .45074 PADS Front Hawk HPS $80 # HB549F.702 Hawk HP Plus $116 # HB549N.702 Hawk Performance Ceramic $87.16 #HB549Z .702 Carbotech Bobcat 1521 $137 #CT915-1521 EBC RedStuff $109.34 #DP31574C OEM $163 #B3YF-33-23Z Rotora H2 Ceramic MS6 only $87.95 #RP.11860.01 Akebono Euro- msrp $138.09 (place for brakes $67.66) 915A Hawk HT-10 $126.42#HB519S .682 Hawk HT-14 $126.42 #HB519V .682 Hawk DTC-60 $144.61 #HB519G .682 Rear Hawk HPS $64 # HB478F.605 Hawk HP Plus $75 #HB478N .605 Hawk Performance Ceramic $72.56 #HB478Z .605 EBC RedStuff $90.30 #DP31749C OEM $51.40 #C2Y3-26-48ZA Rotora H2 Ceramic MS6 only $68.95 #RP.11610.01 Akebono Euro- msrp $140.75 (place for brakes $68.97) 1095 - Rear Hawk HT-10 $131.65 #HB478S .605 Hawk DTC-60 $131.65 #HB478G .605 LINES Racing Brake $108 #BL908 Goodridge $129 #25048-4-LINE Corksport $99 #AXE-3-451 FLUID Motul RBF 600 Dot4 ~ $30 liter ATE Super Blue Dot4 ~ $14 liter >don't know enough still have to research what's worth using< Well for now this is what I have, I have excluded AutoExe since their stuff is super pricey and if you are spending that much you should probably just look at Big Brake Kits. My information was found in a few different places: http://www.corksport.com,http://edgeautosport.com all vendors. Also http://racingbrake.com, http://www.brakeworld.com, http://www.therpmstore.com, http://www.mazdaspeedstore.com, http://tripointengineering.com UPDATE 12-16-2011 MS6! Brake Rotors, Pads, SS Lines & BBKs for the MS6 ROTORS Front2960S AutoEXE Street Rotor $ -- MGS550S DBA Street Standard $ -- 2960 DBA Premium Street Slotted T2 $349.95 2960S DBA Street Drilled & Slotted $449.95 2960XS DBA 4000 Standard $ -- 42960 DBA 4000 Slotted $ -- 42960S DBA 4000 Drilled & Slotted $ -- 42960XS Disc Italia Slotted $280 -- Disc Italia Drilled & Slotted $280 -- EBC Ultimax USR Slotted $307.77 USR7393 Genuine MS6 Rotor $73.33 G31Y-33-25XA Powerslot Slotted $225 126.45073 Rotora Slotted $239 -- Rotora Drilled & Slotted $269 -- StopTech Street $80 309.11860 StopTech Coated $150 125.45073 StopTech Drilled $170 128.45073 StopTech Cryo Drilled $208 128.45073C StopTech Drilled & Slotted $250 127.45073 Rear AutoEXE Street Rotor $ -- MGS555S DBA Street Standard $ -- 2961 DBA Street Slotted $349.95 2961S DBA Street Drilled & Slotted $449.95 2961XS DBA 4000 Standard $ -- 42961 DBA 4000 Slotted $ -- 42961S DBA 4000 Drilled & Slotted $ -- 42961XS Disc Italia Slotted $245 -- Disc Italia Drilled & Slotted $245 -- EBC Ultimax USR Slotted $202.95 USR73934 Genuine MS6 Rotor $70.85 G31Y-26-251 Powerslot Slotted $159 126.45074 Rotora Slotted $165 -- Rotora Drilled & Slotted $199 -- StopTech Street $54 309.11610 StopTech Coated $110 120.45074 StopTech Drilled $104 128.45074 StopTech Cryo Drilled $146 128.45074C StopTech Drilled & Slotted $185 127.45074 PADS Front AutoEXE Street $137 MGS510P AutoEXE Sport $246 MGS510W Carbotech $146 CT915 Centric PosiQuiet $57 104.11860 Disc Italia Titanium Kevlar $80 -- Disc Italia Hyper Ceramic $95 -- EBC GreenStuff $89.95 DP217773 EBC RedStuff $119 DP31773C Genuine MS6 Pads $112.63 GPYA-33-2326 Hawk HPS $79.64 HB549F.702 Hawk HP Plus $115 HB449N.702 Hawk DTC $195 HB549W.702 ProACT Ceramic $64.95 ACT1164 Rotora H2 Ceramic $72 RP.11860.1 StopTech Street Performance $80 309.11860 Front AutoEXE Street $124 MGS520P AutoEXE Sport $217 MGS520W Carbotech $259 CT1161 Centric PosiQuiet $42 105.11610 Disc Italia Titanium Kevlar $60 -- Disc Italia Hyper Ceramic $75 -- EBC GreenStuff $69.95 DP217766 EBC RedStuff $119 DP31766C Genuine MS6 Pads $85.59 GPYB-26-49Z Hawk HPS $64.13 HB564F.567 Hawk HP Plus $115.94 HB564N.567 Hawk DTC $145 HB564W.567 ProACT Ceramic $59.95 ACT1161 Rotora H2 Ceramic $68 RP.11610.01 StopTech Street Performance $54 309.11610 SS Lines Auto EXE Sports Lines $560 MGS540 Corksport SS Lines $99 -- Techna-Fit SS Lines $89 MA-1255 Big Brake Kits Brembo BBK $1,429.99 -- Rotora BBK $1,795.99 RBK043.01 Corksport BBK $799.99 Wilwood 13" BBK $1,995 KSport ProComp 13" BBK $1,663 Taken from all the same website as OP, a few extra from google, and also www.tirerack.com/. |
Are those numbers posted after the price supposed to be part numbers? If so, something's up at least with the Hawk pad numbers... Those are not the part numbers for the Hawk MS3 pads. These are: Hawk HPS Front: HB549F.702 Rear: HB478F.605 Hawk HP+ Front: HB549N.702 Rear: HB478N.605 I don't have the numbers for the Ceramics, but I'm guessing they're not right either... |
Quote:
Quote:
whoa OEM front pads for $130? where at?? |
Quote:
unless you are being sarcastic, but everyone knows they are pricey so I can't tell..... |
Quote:
also I think the part number ends in a "Z" not a 2. here is a decent price, $163, not sure about shipping though. FRONT PADS 2007-2009 MAZDASPEED3 |
your right supposed to be Z, fixed.. thanks gotta update op, just found tri-point has rotors for cheap!.. SO FAR I APPRECIATE EVERYONES INPUT AND CORRECTIONS. I want this to be as correct and helpful as possible! |
Quote:
Quote:
also im not sure if that price is for set or single |
Quote:
Pads Front Carbotech Bobcat 1521 $137 P/N CT915-1521 (At 07 08 MAZDA 3 MAZDASPEED Carbotech Bobcat 1521 Brake Pads CT915-1521) |
to the op: thanks for taking the time. There is also a thread where people were experimenting with volvo s40 t5 awd brakes and had some success. http://www.mazdaspeedforum.org/forum/foru...-brakes-12248/ |
EBC Red Stuff Pads: Front: DP31574C ($109.34) Rear: DP31749C ($90.30) +10% off right now for Presidents Day. AJUSA.com |
Quote:
Quote:
Quote:
Quote:
Thanks for all of the work. It doesn't go unnoticed. |
added a couple more Hawk Motorsports pads..the first Hawks in list are labeled street, for what it's worth.. |
Cool awesome info. So are the MS6 and MS3 front brakes pads the same? Thanks. |
I don't see the OEM Rotors Front/back listed? Does anyone have the part numbers? i need to get some pretty soonish here Cheers, TriO` |
It looks as if Akebono finally got the idea that the ms3 has bigger brakes and is adding a euro 915 (a) ceramic. I will definitely be getting these. Great performance... minimal dust. They haven't been released yet, but I'm going to e-mail them tonight for an estimated release date. |
This is a great resource! I can't tell you how helpful this is! also to add some current info...this popped up on tirerack for my car....i pulled from another thread for an MS6: Dunno how long they will be this price but it looks like a damn steal.... http://www.tirerack.com/brakes/resul...6&autoModClar= Centric Premium Rotor FRONT: P/N: 120.45073 Price: $65 REAR: P/N: 120.45074 Price: $38 |
These are only for MS6. I have had these on mine for almost 25k and they are great. Rotora H2 Ceramic Brake Pads for Mazdaspeed 6 (front) $87.95 RP.11860.01 http://www.therpmstore.com/product_i...roducts_id=592 Rotora H2 Ceramic Brake Pads for Mazdaspeed 6 (rear) $68.95 RP.11610.01 http://www.therpmstore.com/product_i...roducts_id=593 |
Also found this as well... Centric Premium Rotor (FRONT) Manufacturer Part #: 120.45073 Price: $55.41 each Next Day Auto Parts - Discounted Price Auto Parts - NY, TX, FL, CA, DC, MD, NJ Centric Premium Rotor (REAR) Manufacturer Part #: 120.45074 Price: $30.39 each Next Day Auto Parts - Discounted Price Auto Parts - NY, TX, FL, CA, DC, MD, NJ |
wicked good list guy |
added some of people's update to op..on a side note i have my rotors, pads, and ss brake lines on order! just gotta get fluid now... |
BTW Centric and Stoptech are the same and the numbers i posted are for the MS6 ONLY.. ..just FYI |
yeah Centric, StopTech, and PowerSlot are all the same company now.. |
EBC rotors (drilled (with blind hole even, not through hole) and slotted) front: GD7501 340.96 pair Rear: GD1315 185.44 pair EBC rotors (slotted) front: USR7501 311.70 pair Rear: USR1315 166.00 pair found here Edge Autosport also...i would like to start another database regarding what people are running...if you want to start it jax that would be cool...othewise i will get it going later today...something like year, mileage, mileage of first replacement, current set, mileage on current set....stuff like that |
Quote:
I purchased a set of Wagner ThermoQuiet brake pads (front only) from Rock Auto for something ike $45 (before $15 mail-in rebate). You certainly get what you pay for. Do they stop you? Yes. Well? Not really. Conclusion: I wish I would have gotten something better but frankly spending $100+ for brake pads on my daily driver wasn't something I had considered. Please put these in your brake pad database as a "better than no brakes at all" contender. |
I am looking at getting the StopTech Drilled front and back with RedStuff in the back and YellowStuff in the front with the Techna-Fit SS for my Speed6. Anyone used that combination? P.S. Sry, dont mean to jack your thread, just need some pronto help :) |
My advice is to stay away from drilled rotors, for one. I've never used EBC products on my Mazda. I haven't used EBCs stuff since ~10 years ago after being wholly unimpressed with a set I had on my first Focus. |
The new P/N for: Centric Premium Rotors (Front) is 125.45078 Centric Standard Rotors (Front) is 121.45078 Both for the Mazdaspeed 3. |
Changed rotors/pads this weekend with Centric Premium rotors and Hawk HPS pads. Also flushed the system with Valvoline synthetic DOT3/4 fluid. As far as the pads go, the Hawk's definitely don't have the initial bite the OE pads do. Even with the OE pads down at 5mm, they still had more initial bite than the Hawks do which is amazing, but lay into the Hawks and they do stop just as good if not better. It just doesn't feel like it because you don't get that initial neck jerking of the stock pads, but make no mistake, the Hawks do perform. After bedding them in and putting about 100 miles on them already, I like the feel of the Hawk pads over the OE pads. |
AIMCO (no idea, Chinese low end) front rotors: rwiamerica.com SKU 31363 $89 shipped pair Stoptech SS brake lines P/N 950.61010G: vr-speed.com $105 shipped set |
Stoptech complete brake kit 977.45001 $585 Front and rear slotted rotors Front and rear street/track pads Front and rear ss brake lines This is probably what Ill end up doing here soon. My shits shot from autocross season. |
Post up how you like them. |
I'm updating the OP with proper Centric rotor part #'s for front/rear MS3 if no one objects. Premium rotor (coating) 120.45078 Front 120.45067 Rear C-tek rotor (no coating, cheaper) 121.45078 Front 121.45067 Rear |
Brake Rotors, Pads, SS Lines & BBKs for the MS6 ROTORS Front AutoEXE Street Rotor $ -- MGS550S DBA Street Standard $ -- 2960 DBA Street Slotted $349.95 2960S DBA Street Drilled & Slotted $449.95 2960XS DBA 4000 Standard $ -- 42960 DBA 4000 Slotted $ -- 42960S DBA 4000 Drilled & Slotted $ -- 42960XS Disc Italia Slotted $280 -- Disc Italia Drilled & Slotted $280 -- EBC Ultimax USR Slotted $307.77 USR7393 Genuine MS6 Rotor $73.33 G31Y-33-25XA Powerslot Slotted $225 126.45073 Rotora Slotted $239 -- Rotora Drilled & Slotted $269 -- StopTech Street $80 309.11860 StopTech Coated $150 125.45073 StopTech Drilled $170 128.45073 StopTech Cryo Drilled $208 128.45073C StopTech Drilled & Slotted $250 127.45073 Rear AutoEXE Street Rotor $ -- MGS555S DBA Street Standard $ -- 2961 DBA Street Slotted $349.95 2961S DBA Street Drilled & Slotted $449.95 2961XS DBA 4000 Standard $ -- 42961 DBA 4000 Slotted $ -- 42961S DBA 4000 Drilled & Slotted $ -- 42961XS Disc Italia Slotted $245 -- Disc Italia Drilled & Slotted $245 -- EBC Ultimax USR Slotted $202.95 USR73934 Genuine MS6 Rotor $70.85 G31Y-26-251 Powerslot Slotted $159 126.45074 Rotora Slotted $165 -- Rotora Drilled & Slotted $199 -- StopTech Street $54 309.11610 StopTech Coated $110 120.45074 StopTech Drilled $104 128.45074 StopTech Cryo Drilled $146 128.45074C StopTech Drilled & Slotted $185 127.45074 PADS Front AutoEXE Street $137 MGS510P AutoEXE Sport $246 MGS510W Carbotech $146 CT915 Centric PosiQuiet $57 104.11860 Disc Italia Titanium Kevlar $80 -- Disc Italia Hyper Ceramic $95 -- EBC GreenStuff $89.95 DP217773 EBC RedStuff $119 DP31773C Genuine MS6 Pads $112.63 GPYA-33-2326 Hawk HPS $79.64 HB549F.702 Hawk HP Plus $115 HB449N.702 Hawk DTC $195 HB549W.702 ProACT Ceramic $64.95 ACT1164 Rotora H2 Ceramic $72 RP.11860.1 StopTech Street Performance $80 309.11860 Front AutoEXE Street $124 MGS520P AutoEXE Sport $217 MGS520W Carbotech $259 CT1161 Centric PosiQuiet $42 105.11610 Disc Italia Titanium Kevlar $60 -- Disc Italia Hyper Ceramic $75 -- EBC GreenStuff $69.95 DP217766 EBC RedStuff $119 DP31766C Genuine MS6 Pads $85.59 GPYB-26-49Z Hawk HPS $64.13 HB564F.567 Hawk HP Plus $115.94 HB564N.567 Hawk DTC $145 HB564W.567 ProACT Ceramic $59.95 ACT1161 Rotora H2 Ceramic $68 RP.11610.01 StopTech Street Performance $54 309.11610 SS Lines Auto EXE Sports Lines $560 MGS540 Corksport SS Lines $99 -- Techna-Fit SS Lines $89 MA-1255 Big Brake Kits Brembo BBK $1,429.99 -- Rotora BBK $1,795.99 RBK043.01 Taken from all the same website as OP, a few extra from google, and also www.tirerack.com/. |
^^^nice work, thanks! but you missed centriz rotors, it's too lte and i'm too drunk to look them up but i know kns brakes has them |
| All times are GMT -7. The time now is 04:17 AM. |
