> MSF KB - Mazdaspeed 3/6 - Suspension & Brakes
 Old 02-18-2011, 12:14 PM   #1
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
Default Brakes Database MS3/MS6!
I am compiling a list for myself and have spent about an hour doing it so this may help someone else down the road. Any inputs or suggestions let me know and I will try to keep this updated.
ROTORS
Front
Racing Brake $115.43 (each) #9115-111
Centric $144.95 #120 .45078
StopTech $156.80 #120.45078
StopTech D&S $250 #127.45078L & 127.45078R
PowerSlot $230 #126.45078SL & 126.45078SR
Rotora $223.95 #R .45078x
DBA $224.95 #42962SL + 42962SR (104 each through tirerack.com)
Italia $295
Royalty Rotors $133.99 #R R45067SD
Centric Premium Rotor $55.41 (each) #120 .45073
Rear
Racing Brake $79.15 (each) #9023-111
Centric $144.95 #120 .45067
StopTech $100 #120.45067
StopTech Slotted $148.18 #126 .45067
StopTech Drilled $140 #126 .45067
StopTech D&S $154 #127.45067L & 127.45067R
PowerSlot $176 #126.45067SL & 126.45067SR
Rotora $144.95 #R .45067x
DBA $209.95 #42957SL + 42957SR
Italia $215
Centric Premium Rotor $30.39 (each) #120 .45074
PADS
Front
Hawk HPS $80 # HB549F.702
Hawk HP Plus $116 # HB549N.702
Hawk Performance Ceramic $87.16 #HB549Z .702
Carbotech Bobcat 1521 $137 #CT915-1521
EBC RedStuff $109.34 #DP31574C
OEM $163 #B3YF-33-23Z
Rotora H2 Ceramic MS6 only $87.95 #RP.11860.01
Akebono Euro- msrp $138.09 (place for brakes $67.66) 915A
Hawk HT-10 $126.42#HB519S .682
Hawk HT-14 $126.42 #HB519V .682
Hawk DTC-60 $144.61 #HB519G .682
Rear
Hawk HPS $64 # HB478F.605
Hawk HP Plus $75 #HB478N .605
Hawk Performance Ceramic $72.56 #HB478Z .605
EBC RedStuff $90.30 #DP31749C
OEM $51.40 #C2Y3-26-48ZA
Rotora H2 Ceramic MS6 only $68.95 #RP.11610.01
Akebono Euro- msrp $140.75 (place for brakes $68.97) 1095 - Rear
Hawk HT-10 $131.65 #HB478S .605
Hawk DTC-60 $131.65 #HB478G .605
LINES
Racing Brake $108 #BL908
Goodridge $129 #25048-4-LINE
Corksport $99 #AXE-3-451
FLUID
Motul RBF 600 Dot4 ~ $30 liter
ATE Super Blue Dot4 ~ $14 liter
>don't know enough still have to research what's worth using<
Well for now this is what I have, I have excluded AutoExe since their stuff is super pricey and if you are spending that much you should probably just look at Big Brake Kits.
My information was found in a few different places: http://www.corksport.com,http://edgeautosport.com all vendors. Also http://racingbrake.com, http://www.brakeworld.com, http://www.therpmstore.com, http://www.mazdaspeedstore.com, http://tripointengineering.com
UPDATE 12-16-2011 MS6!
Brake Rotors, Pads, SS Lines & BBKs for the MS6
ROTORS
Front2960S
AutoEXE Street Rotor $ -- MGS550S
DBA Street Standard $ -- 2960
DBA Premium Street Slotted T2 $349.95 2960S
DBA Street Drilled & Slotted $449.95 2960XS
DBA 4000 Standard $ -- 42960
DBA 4000 Slotted $ -- 42960S
DBA 4000 Drilled & Slotted $ -- 42960XS
Disc Italia Slotted $280 --
Disc Italia Drilled & Slotted $280 --
EBC Ultimax USR Slotted $307.77 USR7393
Genuine MS6 Rotor $73.33 G31Y-33-25XA
Powerslot Slotted $225 126.45073
Rotora Slotted $239 --
Rotora Drilled & Slotted $269 --
StopTech Street $80 309.11860
StopTech Coated $150 125.45073
StopTech Drilled $170 128.45073
StopTech Cryo Drilled $208 128.45073C
StopTech Drilled & Slotted $250 127.45073
Rear
AutoEXE Street Rotor $ -- MGS555S
DBA Street Standard $ -- 2961
DBA Street Slotted $349.95 2961S
DBA Street Drilled & Slotted $449.95 2961XS
DBA 4000 Standard $ -- 42961
DBA 4000 Slotted $ -- 42961S
DBA 4000 Drilled & Slotted $ -- 42961XS
Disc Italia Slotted $245 --
Disc Italia Drilled & Slotted $245 --
EBC Ultimax USR Slotted $202.95 USR73934
Genuine MS6 Rotor $70.85 G31Y-26-251
Powerslot Slotted $159 126.45074
Rotora Slotted $165 --
Rotora Drilled & Slotted $199 --
StopTech Street $54 309.11610
StopTech Coated $110 120.45074
StopTech Drilled $104 128.45074
StopTech Cryo Drilled $146 128.45074C
StopTech Drilled & Slotted $185 127.45074
PADS
Front
AutoEXE Street $137 MGS510P
AutoEXE Sport $246 MGS510W
Carbotech $146 CT915
Centric PosiQuiet $57 104.11860
Disc Italia Titanium Kevlar $80 --
Disc Italia Hyper Ceramic $95 --
EBC GreenStuff $89.95 DP217773
EBC RedStuff $119 DP31773C
Genuine MS6 Pads $112.63 GPYA-33-2326
Hawk HPS $79.64 HB549F.702
Hawk HP Plus $115 HB449N.702
Hawk DTC $195 HB549W.702
ProACT Ceramic $64.95 ACT1164
Rotora H2 Ceramic $72 RP.11860.1
StopTech Street Performance $80 309.11860
Front
AutoEXE Street $124 MGS520P
AutoEXE Sport $217 MGS520W
Carbotech $259 CT1161
Centric PosiQuiet $42 105.11610
Disc Italia Titanium Kevlar $60 --
Disc Italia Hyper Ceramic $75 --
EBC GreenStuff $69.95 DP217766
EBC RedStuff $119 DP31766C
Genuine MS6 Pads $85.59 GPYB-26-49Z
Hawk HPS $64.13 HB564F.567
Hawk HP Plus $115.94 HB564N.567
Hawk DTC $145 HB564W.567
ProACT Ceramic $59.95 ACT1161
Rotora H2 Ceramic $68 RP.11610.01
StopTech Street Performance $54 309.11610
SS Lines
Auto EXE Sports Lines $560 MGS540
Corksport SS Lines $99 --
Techna-Fit SS Lines $89 MA-1255
Big Brake Kits
Brembo BBK $1,429.99 --
Rotora BBK $1,795.99 RBK043.01
Corksport BBK $799.99
Wilwood 13" BBK $1,995
KSport ProComp 13" BBK $1,663
Taken from all the same website as OP, a few extra from google, and also www.tirerack.com/.
PERM TUNED
jax ms3gt is offline
The Following User Says Thank You to jax ms3gt For This Useful Post:
dead-zone (10-18-2012)
 Old 02-18-2011, 01:48 PM   #2
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Are those numbers posted after the price supposed to be part numbers?
If so, something's up at least with the Hawk pad numbers...
Those are not the part numbers for the Hawk MS3 pads.
These are:
Hawk HPS
Front: HB549F.702
Rear: HB478F.605
Hawk HP+
Front: HB549N.702
Rear: HB478N.605
I don't have the numbers for the Ceramics, but I'm guessing they're not right either...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
 Old 02-18-2011, 01:53 PM   #3
TRex's Avatar
Posts: 3,139   (View Stats)
these?
Royalty Rotors Slotted/Drilled Performance Rotors (Mazdaspeed3 2007) - Modern Automotive Performance
TRex is offline
 Old 02-18-2011, 02:13 PM   #4
jax ms3gt's Avatar
Fixed and thank you. I got those from one of the sites..yours look right-er
added, those are fronts only?...
PERM TUNED
 Old 02-18-2011, 02:19 PM   #5
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
whoa OEM front pads for $130? where at??
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
 Old 02-18-2011, 02:20 PM   #6
jax ms3gt's Avatar
from what I found earlier just said mazdaspeed motorsports..hold on I still have a million tabs open I will search again.
unless you are being sarcastic, but everyone knows they are pricey so I can't tell.....
PERM TUNED
 Old 02-18-2011, 02:27 PM   #7
rabble rabble
802MS3's Avatar
Groans: 221
no mang, thats cheap! I thought the cheapest we've found was about $170.
also I think the part number ends in a "Z" not a 2.
here is a decent price, $163, not sure about shipping though. FRONT PADS 2007-2009 MAZDASPEED3
802MS3 is offline
 Old 02-18-2011, 02:31 PM   #8
jax ms3gt's Avatar
your right supposed to be Z, fixed.. thanks
gotta update op, just found tri-point has rotors for cheap!..
SO FAR I APPRECIATE EVERYONES INPUT AND CORRECTIONS. I want this to be as correct and helpful as possible!
PERM TUNED
 Old 02-18-2011, 02:43 PM   #9
jax ms3gt's Avatar
k can't find where I got that price, so until I find it agian I will list price you found..
PERM TUNED
 Old 02-18-2011, 03:40 PM   #10
TRex's Avatar
couldnt really tell from the site as it has an option that only says Rear Set...but i pmed the map guy on here and he said he can get them for both front and rear...so i would just say pm him if you want them
also im not sure if that price is for set or single
TRex is offline
 Old 02-18-2011, 06:27 PM   #11
dkapetansky's Avatar
Posts: 171   (View Stats)
dkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond repute
ROTORS
Front
Centric $144.95 #120.45078
Rotora $223.95 #R.45078x
Italia $295
Royalty Rotors $133.99 #RR45067SD
Rear
Centric $144.95 #120.45067
StopTech Slotted $148.18 #126.45067
StopTech Drilled $140 #126.45067
Rotora $144.95 #R.45067x
Italia $215
PADS
Front
Hawk Performance Ceramic $87.16 #PD1186-13
Rear
Hawk HP Plus $75 #HB478N.605
Hawk Performance Ceramic $72.56 #PD1095-13
LINES
Racing Brake $108 #
BL908
Corksport $99 #
AXE-3-451
FLUID
http://www.streetunit.com, http://www.corksport.com both vendors. Also http://racingbrake.com, http://www.brakeworld.com, http://www.therpmstore.com, http://www.mazdaspeedstore.com, http://tripointengineering.com
On part numbers..they may be fucked up, I just cut and pasted from different websites...
For those who might be interested, I also found:
Pads
Front
Carbotech Bobcat 1521 $137 P/N CT915-1521
(At 07 08 MAZDA 3 MAZDASPEED Carbotech Bobcat 1521 Brake Pads CT915-1521)
dkapetansky is offline
 Old 02-18-2011, 06:31 PM   #12
to the op: thanks for taking the time.
There is also a thread where people were experimenting with volvo s40 t5 awd brakes and had some success.
OEM MS3 brakes = Volvo S60 brakes?
rfinkle2 is offline
 Old 02-18-2011, 07:14 PM   #13
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
EBC Red Stuff Pads:
Front: DP31574C ($109.34)
Rear: DP31749C ($90.30)
+10% off right now for Presidents Day.
AJUSA.com
Frequentflyer is offline
 Old 02-18-2011, 07:17 PM   #14
jax ms3gt's Avatar
cool, update if he gives you more info
Pads
Front
added, thanks
yeah I read some of that..have been searching brake stuff, and figured we needed this..
Originally Posted by Frequentflyer View Post
EBC Red Stuff Pads:
AJUSA.com
adding now, thanks! There is a lot of EBC stuff didn't add any of it yet..lol
PERM TUNED
 Old 02-18-2011, 07:25 PM   #15
Thanks for all of the work. It doesn't go unnoticed.
rfinkle2 is offline
 Old 02-19-2011, 11:13 AM   #16
jax ms3gt's Avatar
added a couple more Hawk Motorsports pads..the first Hawks in list are labeled street, for what it's worth..
PERM TUNED
 Old 02-21-2011, 08:29 AM   #17
SpicyOrangeMSP's Avatar
Posts: 236   (View Stats)
SpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the world
Cool awesome info. So are the MS6 and MS3 front brakes pads the same? Thanks.
SpicyOrangeMSP is offline
 Old 02-25-2011, 05:13 PM   #18
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
I don't see the OEM Rotors Front/back listed?
Does anyone have the part numbers? i need to get some pretty soonish here
Cheers,
TriO`
TriO is offline
 Old 02-28-2011, 09:59 AM   #19
It looks as if Akebono finally got the idea that the ms3 has bigger brakes and is adding a euro 915 (a) ceramic.
I will definitely be getting these. Great performance... minimal dust.
They haven't been released yet, but I'm going to e-mail them tonight for an estimated release date.
rfinkle2 is offline
 Old 02-28-2011, 11:27 AM   #20
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
This is a great resource! I can't tell you how helpful this is!
also to add some current info...this popped up on tirerack for my car....i pulled from another thread for an MS6:
Dunno how long they will be this price but it looks like a damn steal....
http://www.tirerack.com/brakes/resul...6&autoModClar=
FRONT:
P/N: 120.45073
Price: $65
REAR:
P/N: 120.45074
Price: $38
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline
 Old 03-01-2011, 09:01 AM   #21
CherryMicaChick06's Avatar
Posts: 235   (View Stats)
CherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond reputeCherryMicaChick06 has a reputation beyond repute
These are only for MS6. I have had these on mine for almost 25k and they are great.
Rotora H2 Ceramic Brake Pads for Mazdaspeed 6 (front) $87.95 RP.11860.01 http://www.therpmstore.com/product_i...roducts_id=592
Rotora H2 Ceramic Brake Pads for Mazdaspeed 6 (rear) $68.95 RP.11610.01 http://www.therpmstore.com/product_i...roducts_id=593
2006 Mazdaspeed6 - "Cherry"
* Forge BPV * Cobb SF SRI * Cobb TIP * NGK Iridium 1-step colder plugs * Side vent mounted 60mm Prosport Premium Boost Gauge
* SU Test Pipe * CX-7 antenna * Clear side markers w/super white led's * R1 Concepts Slotted Rotors/Rotora Ceramic Pads * SU Rear Engine Mount * Magnaflow CBE * TWM Stage 2 SS w/bushings
CherryMicaChick06 is offline
 Old 03-01-2011, 10:17 AM   #22
meelo88's Avatar
Also found this as well...
Centric Premium Rotor (FRONT)
Manufacturer Part #: 120.45073
Price: $55.41 each
Next Day Auto Parts - Discounted Price Auto Parts - NY, TX, FL, CA, DC, MD, NJ
Centric Premium Rotor (REAR)
Manufacturer Part #: 120.45074
Price: $30.39 each
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
meelo88 is offline
 Old 03-01-2011, 10:30 AM   #23
SPEEDRAC3R's Avatar
Posts: 399   (View Stats)
SPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the world
wicked good list guy
2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint
SPEEDRAC3R is offline
 Old 03-01-2011, 11:53 AM   #24
jax ms3gt's Avatar
added some of people's update to op..on a side note i have my rotors, pads, and ss brake lines on order! just gotta get fluid now...
PERM TUNED
 Old 03-01-2011, 12:58 PM   #25
meelo88's Avatar
BTW Centric and Stoptech are the same and the numbers i posted are for the MS6 ONLY..
..just FYI
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
meelo88 is offline
 Old 03-03-2011, 05:56 PM   #26
jax ms3gt's Avatar
yeah Centric, StopTech, and PowerSlot are all the same company now..
PERM TUNED
 Old 03-23-2011, 06:59 AM   #27
TRex's Avatar
EBC rotors (drilled (with blind hole even, not through hole) and slotted)
front: GD7501 340.96 pair
Rear: GD1315 185.44 pair
EBC rotors (slotted)
front: USR7501 311.70 pair
Rear: USR1315 166.00 pair
found here Edge Autosport
also...i would like to start another database regarding what people are running...if you want to start it jax that would be cool...othewise i will get it going later today...something like year, mileage, mileage of first replacement, current set, mileage on current set....stuff like that
TRex is offline
 Old 03-24-2011, 09:53 AM   #28
jax ms3gt's Avatar
do it man. If you start it I will thread jack my own thread here and tell you I am 2008.5 43k, just replaced with PowerSlot (slotted) front rotors, StopTech Rear rotors, Hawk HPS pads, Goodridge SS lines, and ATE Super Blue Dot4.
PERM TUNED
 Old 03-24-2011, 11:20 AM   #29
TRex's Avatar
it is up
Brake Review/Opinion Database
fill it in =D
TRex is offline
 Old 08-17-2011, 10:42 AM   #30
zehnder.eric's Avatar
Posts: 7   (View Stats)
zehnder.eric is an unknown quantity at this point
I purchased a set of Wagner ThermoQuiet brake pads (front only) from Rock Auto for something ike $45 (before $15 mail-in rebate). You certainly get what you pay for. Do they stop you? Yes. Well? Not really.
Conclusion:
I wish I would have gotten something better but frankly spending $100+ for brake pads on my daily driver wasn't something I had considered. Please put these in your brake pad database as a "better than no brakes at all" contender.
zehnder.eric is offline
 Old 08-18-2011, 12:48 AM   #31
its_stili_time's Avatar
Posts: 11   (View Stats)
its_stili_time is an unknown quantity at this point
I am looking at getting the StopTech Drilled front and back with RedStuff in the back and YellowStuff in the front with the Techna-Fit SS for my Speed6. Anyone used that combination?
P.S. Sry, dont mean to jack your thread, just need some pronto help
its_stili_time is offline
 Old 08-18-2011, 08:24 AM   #32
Nliiitend1's Avatar
My advice is to stay away from drilled rotors, for one. I've never used EBC products on my Mazda. I haven't used EBCs stuff since ~10 years ago after being wholly unimpressed with a set I had on my first Focus.
2008 MS3 GT
2016 MX-5 Club
 Old 10-24-2011, 10:27 AM   #33
Monkey_3's Avatar
Posts: 131   (View Stats)
Monkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to behold
The new P/N for:
Centric Premium Rotors (Front) is 125.45078
Centric Standard Rotors (Front) is 121.45078
Both for the Mazdaspeed 3.
TheFlash likes this.
Monkey_3 is offline
The Following User Says Thank You to Monkey_3 For This Useful Post:
SpankyCuervo (04-29-2013)
 Old 10-24-2011, 06:12 PM   #34
Changed rotors/pads this weekend with Centric Premium rotors and Hawk HPS pads. Also flushed the system with Valvoline synthetic DOT3/4 fluid.
As far as the pads go, the Hawk's definitely don't have the initial bite the OE pads do. Even with the OE pads down at 5mm, they still had more initial bite than the Hawks do which is amazing, but lay into the Hawks and they do stop just as good if not better. It just doesn't feel like it because you don't get that initial neck jerking of the stock pads, but make no mistake, the Hawks do perform. After bedding them in and putting about 100 miles on them already, I like the feel of the Hawk pads over the OE pads.
 Old 10-24-2011, 07:12 PM   #35
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
AIMCO (no idea, Chinese low end) front rotors: rwiamerica.com SKU 31363 $89 shipped pair
Stoptech SS brake lines P/N 950.61010G: vr-speed.com $105 shipped set
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline
 Old 12-07-2011, 08:48 AM   #36
driver311's Avatar
Posts: 1,769   (View Stats)
Stoptech complete brake kit 977.45001 $585
Front and rear slotted rotors
Front and rear street/track pads
Front and rear ss brake lines
This is probably what Ill end up doing here soon. My shits shot from autocross season.
Mazdaspeed
driver311 is offline
 Old 12-07-2011, 10:01 AM   #37
Post up how you like them.
Lex is offline
 Old 12-13-2011, 01:57 PM   #38
rabble rabble
802MS3's Avatar
Groans: 221
I'm updating the OP with proper Centric rotor part #'s for front/rear MS3 if no one objects.
Premium rotor (coating)
120.45078 Front
120.45067 Rear
C-tek rotor (no coating, cheaper)
121.45078 Front
121.45067 Rear
802MS3 is offline
 Old 12-16-2011, 09:02 PM   #39
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
ROTORS
Front
DBA Street Slotted $349.95 2960S
Rear
PADS
Front
Front
SS Lines
Big Brake Kits
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline
 Old 12-16-2011, 09:08 PM   #40
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
^^^nice work, thanks! but you missed centriz rotors, it's too lte and i'm too drunk to look them up but i know kns brakes has them
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline
Brakes Database MS3/MS6! jax ms3gt MazdaSpeed 3/6 - Suspension & Brakes 103 09-23-2017 01:14 AM
HOW-TO DATABASE MS6 MATT DAMOND MazdaSpeed 6 - How-To's 42 11-21-2016 07:07 AM
HOW-TO DATABASE MS3 MATT DAMOND MazdaSpeed 3 - How-To's 39 07-15-2015 07:29 AM
OEM MS3 brakes = Volvo S60 brakes? levitron MazdaSpeed 3/6 - Suspension & Brakes 109 03-02-2012 06:14 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
Page generated in 0.71200 seconds with 39 queries
