 Old 03-31-2009, 11:06 PM   #1
Y o o z's Avatar
Posts: 28   (View Stats)
Y o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud ofY o o z has much to be proud of
Post CSV Grapher v0.1a
So I got my AP today, and to celebrate I coded a CSV web based grapher for my data logs.
CSV Grapher v0.1a
It isn't up to par with what you DH folks have, but it works for me
UPDATE: Got on it after 50 miles. Pulls like crazy 1st-3rd gear, but 4th+ feels tame, albeit stronger than stock.
Stage 1+ v1.03 WOT logs look clean to me, however, the second log is from a non-launch start from 1st gear. The fuel pressure sensor PSI drops below 1400, which is a bit unnerving IMO. But then again, my wheels are spinning at that point so I modulated the throttle (boost drops), so I guess its expected? It's about 60 degrees, sea level, CA 91.
Log 1:- 3rd gear pull
Log 2: w/wheels slipping
Regarding the CSVG,
Let me know if anything is unclear, have any suggestions, or if you find any bugs D:
Also, if you put in ridiculously large log files, you'll have to wait a few seconds for everything to render.
HAVE FUN - DON'T BREAK IT
Thanks to xandrake for posting his CSV file and Haltech for letting me use his MS3 image without permission
TODO (3/31/09):
* More Color Choices
* Thicker Font
* Input new data without refreshing the page
* Tool to help trim logs
Y o o z is offline
 Old 04-01-2009, 02:53 PM   #2
Stan-O's Avatar
Posts: 182   (View Stats)
Stan-O is just really niceStan-O is just really niceStan-O is just really niceStan-O is just really niceStan-O is just really nice
Groaned at 5 Times in 1 Post
This should be stickied, good work.
I'm in the process of building one in VB.NET to use Excell in the background, but we'll see how it goes.....
Speed-less
Stan-O is offline
 Old 04-01-2009, 04:16 PM   #3
when i click ok it doesent make a graph for me
EDIT: nm
superskaterxes is offline
 Old 04-03-2009, 08:22 AM   #4
acidbbg's Avatar
Posts: 208   (View Stats)
acidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud of
Thanks for the Graphing Tool!
Def should be stickied.
All content created by this user is for entertainment purposes only.
Mods: Wouldn't you like to know
acidbbg is offline
 Old 04-03-2009, 08:31 AM   #5
Good work!
Haltech is offline
 Old 04-05-2009, 01:52 PM   #6
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
+1 on the sticky! Thannnnnk you!
Arrowpoint is offline
 Old 04-14-2009, 10:29 AM   #7
Matrix311's Avatar
Posts: 2,133   (View Stats)
hmm ya i've having some difficulties with it as well. I paste my .csv data log from wordpad into the text box and hit graph and nothing happens. I've tried 3 different browsers and non work (IE7, Chrome and FireFox).
got it working, great tool and thanks!
Matrix311 is offline
 Old 04-14-2009, 11:25 AM   #8
acidbbg's Avatar
It's not the web browser..I was having this problem as well.
First, You need to watch out for any weird characters in the first cell.
such as:
Seconds (sec)
should actually be
Seconds (sec)
Also, your data should look like this:
Seconds (sec),Accel. Pedal Pos. (%),Knock Retard (°),RPM (RPM),Actual AFR (AFR),Fuel Press. Sens. (PSI),Boost (PSI)
0,16.38,0,2207,14.99,1154.46,-8.56
0.21,16.38,0,2220,14.55,1137.06,-8.7
0.48,16.38,0,2226,14.7,1129.8,-8.7
0.77,16.77,0,2235,13.96,1141.41,-8.7
1.02,16.77,0,2236,14.55,1126.9,-8.7
1.26,16.77,0,2238,14.55,1147.21,-8.7
1.52,16.77,0,2228,14.85,1138.51,-8.7
1.78,24.57,0,2235,14.99,1171.86,-8.56
2.05,53.04,0,2234,14.99,1147.21,-7.83
2.32,99.06,0,2302,14.41,1654.82,0.29
2.57,99.06,0,2415,13.67,1675.13,3.48
2.83,99.06,0,2486,13.38,1609.86,6.53
3.11,99.06,0,2629,12.64,1721.54,13.49
3.4,99.06,0,2844,12.49,1595.36,17.4
3.64,99.06,0,3051,12.35,1641.77,18.42
3.93,99.06,1.05,3213,11.76,1682.38,18.42
4.17,99.06,0.35,3632,12.35,1654.82,17.69
4.45,99.06,0.35,3672,12.35,1675.13,17.26
4.71,99.06,0,3862,12.35,1741.84,16.97
4.99,99.06,0,4100,12.35,1659.17,17.11
5.28,99.06,0,4271,12.35,1714.29,16.68
5.52,99.06,0,4393,12.2,1686.73,16.24
5.81,0,0,4629,29.25,1679.48,15.81
6.01,0,0,4564,29.25,1689.63,-3.19
6.31,0,0,4067,29.25,1728.79,-12.62
6.57,0,0,3761,29.25,1746.19,-12.62
6.84,0,0,3331,29.25,1763.6,-12.62
7.06,0,0,3280,29.25,1781,-12.33
7.27,0,0,3225,29.25,1791.15,-11.89
7.57,0,0,3199,29.25,1798.4,-11.89
7.83,0.39,0,3160,29.25,1811.46,-11.89
8.08,0,0,3146,29.25,1823.06,-11.75
8.3,0,0,3113,29.25,1830.31,-11.75
8.57,0,0,3090,29.25,1836.11,-11.75
8.82,0,0,3051,29.25,1846.27,-11.6
9.05,0,0,3024,29.25,1854.97,-11.75
9.31,0,0,3009,29.25,1857.87,-11.6
9.54,0,0,2984,29.25,1860.77,-11.6
9.78,0,0,2952,29.25,1862.22,-11.6
10.07,0,0,2934,29.25,1862.22,-11.6
10.31,0,0,2894,29.25,1862.22,-11.6
10.58,0,0,2879,29.25,1862.22,-11.75
10.86,0,0,2845,29.25,1862.22,-11.6
11.1,0,0,2810,29.25,1862.22,-11.75
11.33,0,0,2783,29.25,1862.22,-11.75
11.56,0,0,2755,29.25,1860.77,-11.75
11.8,0,0,2730,29.25,1862.22,-11.75
12.09,0,0,2714,29.25,1862.22,-11.75
12.34,0,0,2679,29.25,1862.22,-11.75
12.54,0,0,2645,29.25,1862.22,-11.89
12.8,0,0,2629,29.25,1860.77,-11.75
13.02,0,0,2604,29.25,1860.77,-11.89
13.3,0,0,2574,29.25,1862.22,-11.89
13.58,0,0,2552,29.25,1862.22,-11.89
13.85,0,0,2527,29.25,1860.77,-11.89
14.07,0,0,2493,29.25,1862.22,-11.75
14.32,0,0,2475,29.25,1862.22,-11.89
14.52,0,0,2443,29.25,1862.22,-11.75
14.74,0,0,2423,29.25,1862.22,-11.75
14.94,0,0,2397,29.25,1862.22,-11.75
15.15,0,0,2384,29.25,1862.22,-11.75
hope that helps.
acidbbg is offline
 Old 07-03-2009, 08:39 PM   #9
djthom's Avatar
Posts: 368   (View Stats)
djthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the worlddjthom is the leader of the world
Groans: 40
how do i copy the image so i can paste it here??
djthom is offline
 Old 11-02-2009, 10:52 PM   #10
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
Nice work. But is there any chance that we can save the graph as a jpg or png file?
Ferdball is offline
 Old 11-02-2009, 11:02 PM   #11
Y o o z's Avatar
Its rendered inside of the browser, so not really. What you can do, is press the "Print Screen" button on your keyboard, Paste it into MSPaint (or whatever image editor you use) and crop it to your liking.
Y o o z is offline
 Old 11-13-2009, 06:40 PM   #12
nukechemist's Avatar
Posts: 64   (View Stats)
nukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond repute
Seconds (sec),RPM (RPM),Knock Retard (°),Calculated Load (%),Long Term FT (%),Mass Airflow (g/s),Short Term FT (%),Actual AFR (AFR),DI Fuel Press. (PSI),Boost (PSI)
0.00,3265,0.00,203.45,-0.16,154.59,-0.16,12.20,1577.96,18.71
0.11,3312,0.00,198.74,-0.16,162.24,-0.16,12.05,1609.86,18.13
0.23,3366,0.00,200.31,-0.16,168.81,-0.16,11.91,1622.92,18.56
0.35,3406,0.00,204.62,-0.16,175.53,-0.16,11.91,1707.03,18.85
0.47,3440,0.00,204.62,-0.16,172.14,-0.16,11.91,1592.46,18.56
0.57,3490,0.00,200.31,-0.16,172.14,-0.16,11.91,1689.63,18.13
0.67,3539,0.00,195.22,-0.16,170.14,-0.16,12.05,1738.94,17.98
0.77,3588,0.35,193.26,-0.16,176.21,-0.16,12.05,1738.94,18.13
0.87,3616,0.35,194.43,-0.16,178.26,-0.16,11.76,1746.19,18.42
0.97,3683,0.35,195.22,-0.16,179.65,-0.16,11.91,1721.54,17.98
1.07,3737,0.35,192.86,-0.16,178.96,-0.16,11.76,1627.27,18.13
1.17,3768,0.00,192.86,-0.16,185.24,-0.16,11.76,1662.07,17.98
1.27,3822,0.00,191.30,-0.16,183.12,-0.16,12.05,1659.17,17.69
1.37,3894,0.00,190.90,-0.16,189.50,-0.16,12.05,1686.73,17.55
1.47,3916,0.00,190.51,-0.16,186.65,-0.16,12.05,1714.29,17.40
1.57,3966,0.00,187.77,-0.16,191.67,-0.16,12.05,1622.92,17.55
1.67,4010,0.00,188.16,-0.16,195.31,-0.16,12.05,1675.13,17.26
1.77,4045,0.00,188.55,-0.16,196.78,-0.16,11.91,1669.33,17.26
1.87,4100,0.00,188.16,-0.16,196.78,-0.16,11.91,1686.73,17.26
1.97,4139,0.00,187.77,-0.16,199.73,-0.16,12.20,1709.93,16.97
2.07,4176,0.00,186.59,-0.16,201.23,-0.16,12.05,1644.67,16.82
2.17,4242,0.00,185.81,-0.16,199.73,-0.16,12.05,1721.54,16.82
2.27,4268,0.00,185.81,-0.16,202.74,-0.16,11.91,1692.53,16.97
2.37,4305,0.35,186.20,-0.16,205.76,-0.16,11.91,1728.79,17.11
2.47,4363,0.00,185.42,-0.16,208.06,-0.16,11.76,1679.48,17.11
2.57,4391,0.00,185.42,-0.16,206.52,-0.16,11.91,1672.23,16.82
2.67,4451,0.00,185.02,-0.16,215.83,-0.16,11.91,1615.66,16.82
2.77,4496,0.00,185.02,-0.16,214.26,-0.16,12.05,1734.59,16.97
2.89,4520,0.00,183.46,-0.16,214.26,-0.16,11.76,1675.13,16.97
2.99,4581,0.00,184.24,-0.16,218.19,-0.16,11.76,1711.39,16.97
3.09,4615,0.00,183.85,-0.16,218.99,-0.16,11.91,1714.29,17.26
3.19,4673,0.00,183.46,-0.16,219.79,-0.16,11.91,1707.03,17.26
3.29,4714,0.00,183.85,-0.16,225.42,-0.16,11.76,1679.48,17.26
3.39,4723,0.00,184.63,-0.16,226.24,-0.16,11.76,1746.19,17.40
3.49,4789,0.00,183.06,-0.16,223.00,-0.16,11.76,1682.38,17.26
3.59,4841,0.00,180.71,-0.16,227.88,-0.16,11.76,1751.99,17.26
3.69,4876,0.00,180.32,-0.16,228.70,-0.16,11.76,1664.97,17.40
3.81,4905,0.00,180.32,-0.16,232.83,-0.16,11.76,1672.23,17.11
3.91,4960,0.00,180.71,-0.16,233.66,-0.16,11.76,1637.42,17.26
4.01,4996,0.00,179.93,-0.16,234.50,-0.16,11.76,1676.58,17.26
4.11,5030,0.00,180.32,-0.16,237.01,-0.16,11.76,1731.69,17.26
4.21,5081,0.00,179.14,-0.16,236.17,-0.16,11.76,1728.79,17.26
4.31,5112,0.00,178.75,-0.16,236.17,-0.16,11.76,1699.78,17.11
4.41,5112,0.00,178.75,-0.16,236.17,-0.16,11.76,1699.78,17.26
4.51,5165,0.70,176.79,-0.16,237.01,-0.16,11.76,1675.13,17.11
4.61,5201,0.70,175.62,-0.16,241.25,-0.16,11.47,1615.66,17.11
4.71,5241,0.70,175.62,-0.16,240.40,-0.16,11.61,1666.42,17.11
4.81,5289,0.70,174.44,-0.16,241.25,-0.16,11.61,1651.92,16.97
4.91,5323,0.70,173.26,-0.16,241.25,-0.16,11.47,1738.94,16.97
5.01,5357,0.70,172.87,-0.16,245.53,-0.16,11.61,1741.84,16.97
5.11,5357,0.70,172.87,-0.16,245.53,-0.16,11.47,1741.84,16.97
5.21,5403,0.70,172.48,-0.16,246.40,-0.16,11.47,1612.76,16.68
5.31,5458,0.35,170.91,-0.16,245.53,-0.16,11.76,1692.53,16.68
5.41,5502,0.35,169.74,-0.16,244.67,-0.16,11.76,1728.79,16.68
5.51,5531,0.35,168.95,-0.16,244.67,-0.16,9.70,1724.44,16.68
5.61,5539,0.00,143.08,-0.16,132.56,-0.16,10.00,1605.51,13.63
Here's a copy of a datalog that I'm trying to graph. When I copy and paste from wordpad into the csv grapher it pulls the items logged but only two lines of data. Any ideas? It copied the whole log when pasting here.
nukechemist is offline
 Old 11-13-2009, 11:19 PM   #13
Ferdball's Avatar
Works for me. Make sure you check the boxes of the items you want, and also pick the colors.
Ferdball is offline
 Old 11-14-2009, 04:40 AM   #14
I can't even get that far. When it trys to graph I get a data error and nothing happens. Is there a limit on # of items logged(sec, rpm, di press, etc.)?
I noticed that when I paste in the text box each time stamped data line is split into two lines.
 Old 11-16-2009, 11:45 AM   #15
evidence's Avatar
Posts: 1,033   (View Stats)
Try a different browser.
Some things.
evidence is offline
 Old 11-16-2009, 06:00 PM   #16
Chrome works. Thanks
 Old 03-11-2010, 05:07 PM   #17
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Great job! Thanks for the graphing tool!
dougefresh_ is offline
 Old 09-18-2012, 08:56 AM   #18
N2o
BoooOost !
N2o's Avatar
Posts: 85   (View Stats)
N2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond repute
Does not work anymore...Account suspended
2010 Mazdaspeed3 - Freektuned with some bolt ons.
N2o is offline
 Old 09-20-2012, 07:16 AM   #19
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: CSV Grapher
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
CSV Grapher Y o o z MazdaSpeed 3/6 - ECU Computer Tuning 17 09-18-2012 08:56 AM
Page generated in 0.38971 seconds with 33 queries
