 Old 12-08-2011, 09:24 PM   #1481
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
There is no side effects with 2gal of the corn juice. Put the e85 in before you fill up and I would say about 30-50 miles then do a maf cal.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosted Beluga is offline
 Old 12-09-2011, 04:23 AM   #1482
Nataphen's Avatar
Posts: 2,704   (View Stats)
You shouldn't even need a MAF cal with 2 gallons. I didn't.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 12-09-2011, 07:40 AM   #1483
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
FWIW - I have been running 3 gallons for a long time, and didn't need to adjust my MAF until they switched to E70, and there was just a tiny spot around 4.9v that needed adjusted.
wolly6973 is offline
 Old 12-09-2011, 08:02 AM   #1484
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
depending on how accurate your petrol MAF cal is you shouldn't need to change it for 2-2.5 gallons.
you will want to add some timing to get the full benefit though.
Dano is offline
 Old 12-09-2011, 08:25 AM   #1485
lol 4.9v!?!?!
just tickling the tip of the curve huh?
superskaterxes is offline
 Old 12-09-2011, 12:23 PM   #1486
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
So closest E85 to me is 25 miles away. Seems E85 is in short supply around here
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline
 Old 12-09-2011, 01:04 PM   #1487
wolly6973's Avatar
Groans: 386
lol 4.9v!?!?!
lol, typo
should be 4.3
 Old 12-09-2011, 01:08 PM   #1488
Todd98SE's Avatar
Posts: 1,077   (View Stats)
I drive 18 miles for mine. Just buy a bunch of 5 gallon gas cans and a single 2 gallon can so you can measure correctly. I do it this way and have about 2 months worth of E85 before I have to go back, works great so far.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 12-09-2011, 03:21 PM   #1489
Groans: 50
Did you check out propelfuels.com?
08 Mazdaspeed 3
 Old 12-09-2011, 03:38 PM   #1490
Ziggo's Avatar
Posts: 3,843   (View Stats)
I am about 20 miles from the corn pump as well and I couldn't be happier, it's worth the drive.
I use a bathroom scale to measure the fuel. 20lbs of the juice and 9 gal of 93. I couldn't find any 3 gallon containers.
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 12-09-2011, 04:38 PM   #1491
Boost_creep's Avatar
Posts: 829   (View Stats)
I have one at the end of my road. I could freakin throw a stone there.
Why am I not using it??
www.dizzytuning.com
www.facebook.com/dizzytuning
Boost_creep is offline
 Old 12-09-2011, 05:06 PM   #1492
Trail of Fail
Dano's Avatar
b/c your boost control is all fucked up...that's why....you need a good tuner....I know of a couple...DJ, Lex, Socks....any one of them could help you out.
Dano is offline
 Old 12-09-2011, 05:11 PM   #1493
I know of a great tuner named Dano, but he is just having a bit of trouble with the comp tables on some cars (as we all are).
rfinkle2 is offline
 Old 12-09-2011, 05:36 PM   #1494
Lmao. That's some funny shit.
Coughloadtunecough
www.dizzytuning.com
 Old 12-09-2011, 05:49 PM   #1495
Trail of Fail
Dano's Avatar
my next suggestion is to pour 2 gals of E85 on the motor, strike a match and walk away. Should make a nice blue flame right?
Coughloadtunecough
all kidding aside I don't think load tuning will work either...I've sent your BCS test logs to David and we'll see what he thinks but to me it looks like your BCS is laggy at best and can't reach targets at worst.
for everyone else we completely neutered the comp tables to test if the BCS would just follow commanded values and to me it failed but I don't know how closely logged DC should match commanded.
Here were the commanded DC values from 2500:
Code:
40.00	45.00	40.00	45.00	45.00	50.00	60.00	65.00	70.00	70.00
to me the BCS starts to really have trouble reaching target in the 55%+ DC/5K RPM range which interestingly enough is where we get our boost drop on the regular maps.
logs attached.
edit: imma gonna cut a load map this weekend and have boost_creep give it a try.
Dano is offline
 Old 12-09-2011, 06:06 PM   #1496
Wgdc like a stegosaurus is the new coolest thing.
You guys are all jealous.
Who's everyone else? Lol.
www.dizzytuning.com
 Old 12-09-2011, 08:02 PM   #1497
Trail of Fail
Dano's Avatar
just guys reading the thread wondering WTF I am talking about.
Dano is offline
 Old 12-11-2011, 04:48 PM   #1498
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
I think my car is doing something similar to boost creeps. Boost is on target but strays off somewhere near 5k and the ecu does not seem to do anything to correct it.
Pure boost tune only BEC active.
I also have a lean condition during and sometimes after spool in rare cases that
can hold close to 5k rpms. I think a bit lean on spool is common on this car? I have no idea why it sometimes holds for the majority of the run and I am out of ideas on how to fix this. Most logs run about .2 or .3 high during initial spool but hit their target right after.
This log shows both. intake/tip/dp/fuelpump - sealevel and its 50 degrees outside. 18 psi boost target and 11.1 afr target.
Meder is offline
 Old 12-13-2011, 09:21 PM   #1499
Im gonna go try and get some E85 shortly and test it out. If it sells me on it then I will work something out on how to store it.
Would 100octane race gas be comparable to E85 performance wise? Cost wise its WAY more I know.
 Old 12-13-2011, 10:26 PM   #1500
Trail of Fail
Dano's Avatar
why are you targeting a PI car's AF target? Maybe your ECU is > you...lol
E85 > all other fuels. 105 octane at the lowest and has a very high endothermic reaction in the cylinders that can't be matched.
Dano is offline
 Old 12-14-2011, 02:29 PM   #1501
Trail of Fail
Dano's Avatar
Code:
logs attached.
So to update:
I haven't heard back from David so I cut a load based tune and sent it over to @Boost_creep and as I suspected, the same issue was there. Plus, his WGDC actually dropped into the single digits during the middle of a WOT run. This proves to me we have some underlying issue since the ECU is dropping DC like that.
We are gonna remove the AP and see what DC looks like on an OE tune via DH and go from there.
so the bottom line, his issues are not directly related to any boost targeting logic and his car just wants to be difficult
Dano is offline
 Old 12-14-2011, 04:01 PM   #1502
So to update:
I hate to beat a dead horse, but this is what I was referring to when I was seeing the wgdc values cut down so hard with the Grimmspeed.
Whether it be the ots comp values, the grimmspeed, or the combo of the 2, something is crushing the wgdc table down to nothing when load values are being approached (sometimes) or exceeded.
(in a way you'd expect a protective table to act vs. a compensation table)
rfinkle2 is offline
 Old 12-14-2011, 05:25 PM   #1503
Trail of Fail
Dano's Avatar
interesting but not sure this is the case here but I did exceed load target just prior to the DC drop but then DC is increased right before it is hacked IDK...running OE BCS and WGDC goes from 50 to 2 while load values are at 2.21 on a 2.30 target. This can be seen in the second tab between 3-3.5K.
TRL from 2.5K
2.00 2.30 2.30 2.25 2.15 2.10 2.00 1.75 1.55 1.50
logs attached.
BTW his WGDC sometimes shoots up to 99 while in vacuum/cruise as well. And lets not forget the "shark fin" effect which I have never seen before.
Edit: so you have seen DC cut this much when a target is exceeded?
Dano is offline
 Old 12-14-2011, 07:53 PM   #1504
Ive been thinking about this. When I log, I usually pull over to the side, cause I have bad connection issues. So I start a log, then pull out onto the highway and usually try to get to 4th pretty quick. Lol. If you look at the OTS wgdc table at anything over 25% TP and under 2250 rpm's, I am targeting 100% wgdc. Could this just be my ecu hitting the target, but then a compensation table knocks it down?
www.dizzytuning.com
 Old 12-14-2011, 08:38 PM   #1505
Trail of Fail
Dano's Avatar
I suppose that is possible however I just looked back thru some of your logs and see 90 and 75DC @ 16TPS which doesn't approach higher TPS in any surrounding cells so its isn't a resolution issue....but do see quite a bit of 99 at over 20TPS.
I forgot you had one of the APs that has trouble logging.
is yours a v2b? [dongless]
so lets chalk up the PT DC as BS and move on.
the drop from 50 to 2 DC at WOT is unexplainable to me and couple that with issues with a BT tune and Load tune right at about the same RPM/DC of 5K/50+
I'd like to hear back from finkle and anyone else that has seen this happen.
me your ECU
Dano is offline
 Old 12-14-2011, 08:40 PM   #1506
I'm looking for the thread right now, and as soon as I find it, I'll hit you with a link.
rfinkle2 is offline
 Old 12-14-2011, 08:50 PM   #1507
I think I was able to find 2 similar situations here:
1) speed6 not hitting boost targets
2) Boost Tune Woes
rfinkle2 is offline
 Old 12-14-2011, 08:58 PM   #1508
Meder's Avatar
Afr was set low while I am working on my lean issue. I've seen 12.7 when targeting 11.1. I'd hate to see what a higher afr looks like...
I can't say I notice any power increase going from low to high 11's. If there us one I doubt it's much. This car doesn't seem to make much power off running leaner.
Meder is offline
 Old 12-14-2011, 09:10 PM   #1509
I have the V2b dongless AP.
I still feel a load table is getting in the way here. Or possibly a table yet to be discovered by Cobb.
www.dizzytuning.com
 Old 12-15-2011, 08:06 AM   #1510
Trail of Fail
Dano's Avatar
2) Boost Tune Woes
I'll take a look at these...thanks
Dano is offline
 Old 01-13-2012, 11:30 AM   #1511
Been a while since this has been touched. Alas, I have documented this WGDC "issue" with several customers that is present in both boost and load based tunes.
In the upper RPM the ECU just doesn't follow load or boost targets and drops WGDC. This will be worse in cold weather, E85 cars, BT cars. Stay tuned, I will do a write-up ... and then COBB will have to be doing some work I should say that I really like how we're getting more and more control of the ECU and COBB have been awesome and very responsive at catering to our requests.
GOAT likes this.
Lex is offline
 Old 02-16-2012, 03:14 PM   #1512
mikeySP307's Avatar
Posts: 38   (View Stats)
mikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud ofmikeySP307 has much to be proud of
subd
mikeySP307 is offline
 Old 09-20-2012, 06:47 AM   #1513
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: http://www.mazdaspeedforum.org/forum/foru...l-stuff-68239/
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-02-2014 06:32 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MazdaSpeed 3/6 - ECU Computer Tuning 1518 02-25-2014 07:30 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Cool Cobb Tuning Video Haltech MazdaSpeed 3/6 - ECU Computer Tuning 1 06-24-2008 12:22 AM
Page generated in 0.51910 seconds with 34 queries
