 Old 06-30-2011, 08:55 AM   #1241
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
That sounds about right to me as well...no more (table value X2+9) Either Cobb removed that logic, or the new table was causing it..IDK which.
So the table value should be very close to logged value +- LD, BD, and Baro compensations.
Just guessing at this point...i'll give it a whirl this weekend.
Dano is offline
 Old 06-30-2011, 09:11 AM   #1242
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I agree with superskater that even if the doubled values end up at or close to achieving targets, it's likely better to go under targets and tune up, just for safety...
moving on, I wonder if the new logic will also aid in effectively controlling boost in the lower gears like 1 - 2...I'm looking at offering my friends a new boost tune that's comparable to a load tune, but the real difference really only needs to be control of power in 1 - 2...3 - 6 can be balls out.
-- Mario Andretti --
Fobio is offline
 Old 06-30-2011, 09:35 AM   #1243
Realgib3's Avatar
Posts: 2,443   (View Stats)
the way i understood it is that it is now going to use exactly those values and theres no more need to double anything in any equation.
HOWEVER, for some reason, just because you were targeting say 80 before to hit your desired boost (and were seeing 80's on your log for WGDC), this may not still hold true. so reduce your WGDC values and start your boost tuning again just to be sure. im not 100% on this but better safe then sorry.
This is how I understood it as well and if this logic is right then boost control should ne amazing now and I will be in love with Cobb. Someone should zero out all load tables in ATR just to test that load targets will really have no effect on a boost tune now...
Realgib3 is offline
 Old 06-30-2011, 10:39 AM   #1244
Abilor's Avatar
Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Posts: 839   (View Stats)
Abilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the world
Might try that this weekend. Work is killing me ATM
Traded
Abilor is offline
 Old 06-30-2011, 01:05 PM   #1245
BlueStreak's Avatar
Posts: 1,467   (View Stats)
You can make a hybrid boost/load tune and use the load dynamics tables with the TRL X Gear tables to achieve your desired goal.
I use this in 1st and part of 2nd. Works like a charm. That, and its easier to target a load value to assist in traction since you can target a constant, optimal load (torque) value and let boost be what the ECU determines is necessary to achieve said load.
This is prior to the Beta update though. Haven't tried with the new update.
'07 CWP MS3
Forged.
BlueStreak is offline
 Old 06-30-2011, 01:12 PM   #1246
Trail of Fail
Dano's Avatar
or set them all to 3.5 so there is actually a non zero number in the tables.
Dano is offline
 Old 06-30-2011, 01:19 PM   #1247
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
Yeah, I've had mine (all Load tables) set way outside the realm of possibility forever. I never had a problem with the boost shenangins until I fubar'ed the BD table....
FORZDA 1 is offline
 Old 06-30-2011, 01:19 PM   #1248
Driver
Fobio's Avatar
Groans: 44
That's basically what I've been advocating for the boost tuned guys prior to the beta's. I prefer to not have to work around the tables and with the new logic, I prefer to give pure boost tuning another go.
How's tuning coming along? You tuning with the new beta's?
Fobio is offline
 Old 06-30-2011, 01:24 PM   #1249
BlueStreak's Avatar
Tuning will happen on Saturday. I just picked up the turbo this morning and it's going in tomorrow.
I also got off the phone with APH. Their dyno is being loaned out to another shop on Saturday. I guess it'll be street tuning for me!
'07 CWP MS3
Forged.
 Old 06-30-2011, 01:57 PM   #1250
Nataphen's Avatar
Posts: 2,704   (View Stats)
I was itching to try it out now, so I updated before I left for lunch and took some logs. I'm mainly looking at WGDC right now, so I'll fine tune everything else later. My commanded WGDC held within 1%. Now, if you want 32% WGDC, you type in 32.00, and that's what it does. I also made the changes recommended by Cobb to the WG Dynamics tables. Now, I'll have to figure out the best way to adjust dynamics to reach my boost targets in varying conditions. Obviously, WGDC will be lower to reach the target boost in colder weather. So far, I believe that I like this.
EDIT: Also, this update enables FFS, LC, and idle tables on gen 2. I've been waiting for those for a while now.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 06-30-2011, 03:35 PM   #1251
any one try the rad fan tables yet?
superskaterxes is offline
 Old 06-30-2011, 03:40 PM   #1252
Nataphen's Avatar
I changed mine to 90*C, but I didn't pay attention to coolant temps or fan kick on during my logs. I'll check it out later tonight and let you know.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 06-30-2011, 04:09 PM   #1253
Nataphen's Avatar
skater, I just went out and checked, and the fan kicked on at 194*. As any of you guys with a unit converter will know, that is exactly 90*C, so we actually have a cooling fan control that fucking works now!
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 06-30-2011, 04:12 PM   #1254
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Hopefully this works for Gen 1 now; gonna flash tonight and report back.
Enki is offline
 Old 06-30-2011, 04:13 PM   #1255
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
Damn it I am actually satisfied with my current map but I would love to lower the rad fan temp. I wonder if it's possible to change it without having to worry about any of the new tables and different wgdc setup.
manelscout4life is offline
 Old 06-30-2011, 04:27 PM   #1256
Trail of Fail
Dano's Avatar
I'm liking the reports of goodness!!
Hope to get my hands on it this weekend.
Dano is offline
 Old 06-30-2011, 05:11 PM   #1257
Enki's Avatar
Groans: 189
Cross-posted from the radfan thread in the Cobb Tuning section.
Now running the beta version of both ATR and APM. Updated my map, saved to 190 deg F. and still no love. A log is linked.
I've also found one thing that does trouble me a fair bit; it used to be that when the car was above some unknown temperature threshold and was shut down, the radiator fan would kick on balls deep for a few seconds to cool down the water a fair bit. I've just realized it has not done this for quite some time (possibly since I started flashing with the AP).
The linked log shows the fan kicking on at a "high" 217 deg, and shutting off when it reaches a "low" 213. I shut the car down @ 217 and there was no audible sound from the radiator fan.
http://www.mazdaspeedforum.org/forum/foru...r-datalog1.csv
This makes me sad.
Enki is offline
 Old 06-30-2011, 06:33 PM   #1258
Groans: 661
This makes me sad.
I've noticed something weird as well, when turning my car on after hard driving on a hot day my temp gauge will be up like 3/4s of the way, which caused me to shit my pants the first time I saw it, but it drops down to the halfway mark in like 5 seconds. Maybe the fan isn't turning on with the car off. Cobb please look into this!
 Old 06-30-2011, 06:37 PM   #1259
Nataphen's Avatar
Mine hasn't kicked on with the car off, but it is running with the car on at my commanded temps. Maybe gen 2 works and gen 1 doesn't.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 06-30-2011, 06:44 PM   #1260
Enki's Avatar
Groans: 189
I've emailed Cobb Tech about this. Hopefully they respond. Kind of scary stopping at a shop for a minute, coming back out and seeing 250+ on the coolant temp readout on the AP briefly.
Enki is offline
 Old 06-30-2011, 06:50 PM   #1261
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
FYI,
There is a glitch in the current version of ATR (even the beta...it was in the last version as well).
The "Radiator Fan - ECT Thresholds" tables shows °C even when standard units are selected and the axis displays °F.
I am currently running 90.56° (shows units of °F, but is really °C), which equates to 195°F.
cld12pk2go is offline
 Old 06-30-2011, 06:56 PM   #1262
Nataphen's Avatar
Yes, good point. Remember that it's Celcius, guys. Mine's at 90 commanded, and it comes on at 194*F.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 06-30-2011, 07:16 PM   #1263
Enki's Avatar
Groans: 189
Must be a safety thing that it keeps it below 220 Fahrenheit then; gonna go test it.
Enki is offline
 Old 06-30-2011, 07:50 PM   #1264
Enki's Avatar
Groans: 189
Just reflashed with it set to 88 (190). Didn't come on till 219/220.
Enki is offline
 Old 06-30-2011, 07:53 PM   #1265
Eth/Meth Junkie
cld12pk2go's Avatar
What year/model do you have?
Mine is an 08 MS3...
So you have a table set to something like this?
 Old 06-30-2011, 07:54 PM   #1266
Enki's Avatar
Groans: 189
09 (8.5 listed iirc)
Enki is offline
 Old 06-30-2011, 07:56 PM   #1267
Eth/Meth Junkie
cld12pk2go's Avatar
Is your table like the one in my edited post?
 Old 06-30-2011, 08:35 PM   #1268
m4tic's Avatar
Posts: 4,928   (View Stats)
so whats the point of the wga rpm comp tables?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 06-30-2011, 08:52 PM   #1269
m4tic's Avatar
and what happened to the DBW tables?
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 06-30-2011, 08:59 PM   #1270
Enki's Avatar
Groans: 189
I've had this set both ways; 88 and 190.
Edit: To keep thread on-topic, let's move this conversation to the thread already about this subject in the root of the Cobb section.
Enki is offline
 Old 06-30-2011, 09:20 PM   #1271
Eth/Meth Junkie
cld12pk2go's Avatar
Interesting.
My 08 MS3 maps didn't double the DBW tables at all...
 Old 06-30-2011, 09:44 PM   #1272
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
genpu dbw tables didn't change for me either.
wolly6973 is offline
 Old 06-30-2011, 11:13 PM   #1273
Nataphen's Avatar
My dbw tables stayed the same. Just halve them and you'll be good though.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 06-30-2011, 11:38 PM   #1274
Groans: 661
When getting out of my car tonight I did notice the rad fan turn on. And that's with a map from the previous ATR
 Old 07-01-2011, 06:46 AM   #1275
Enki's Avatar
Groans: 189
Mine turned on after this last test as well; perhaps that's what this table actually controls for me.
Enki is offline
 Old 07-01-2011, 10:02 AM   #1276
Trail of Fail
Dano's Avatar
FWIW
I have not flashed this new FW but my fan always comes on after the car has been shut off.
07 model
guess I ginxed things with my last post. sorry
Dano is offline
 Old 07-01-2011, 11:30 AM   #1277
m4tic's Avatar
anybody else have the double DBW tables, halve them and now have erratic throttle response? my throttle feels like its either "all or nothing" .. i cant retrieve old values with this version of ATR, all of my maps load with the high DBW values
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 07-01-2011, 11:37 AM   #1278
Driver
Fobio's Avatar
Groans: 44
my DBW tables were NOT doubled.
Fobio is offline
 Old 07-01-2011, 11:40 AM   #1279
Trail of Fail
Dano's Avatar
Here are my slightly modified DBW A and C table values. I only changed the 80 to 100 so if you want completely stock values change the 100s to 80.
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
1.50	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	2.00	2.00
1.70	1.50	1.50	1.50	1.80	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	3.50	3.50
1.90	2.50	2.60	2.60	2.90	3.30	3.00	2.60	3.00	3.00	3.00	4.00	4.00	5.00	5.00
2.10	3.50	4.40	4.40	4.60	4.90	4.60	4.50	3.90	4.50	4.50	5.50	6.00	7.00	5.80
2.30	4.00	5.00	5.70	6.10	6.50	6.40	6.20	6.00	6.70	7.00	7.00	7.60	8.10	7.70
2.50	4.50	5.50	7.30	7.80	8.20	7.80	7.60	7.60	8.20	8.40	8.90	9.90	9.60	9.60
2.70	5.00	6.80	9.50	9.70	9.90	9.80	9.20	9.20	10.00	10.10	10.40	11.40	11.20	10.30
2.90	5.50	8.20	10.90	11.30	11.70	11.00	10.70	10.50	11.40	11.70	12.00	12.20	12.50	12.20
3.10	6.00	10.00	12.60	12.80	13.10	12.50	12.30	11.80	12.20	12.60	13.10	13.80	13.80	14.10
5.30	7.20	11.70	14.20	14.50	14.80	13.80	13.20	12.80	13.30	14.50	14.40	14.70	14.90	16.70
7.40	9.40	13.60	15.90	16.10	16.40	15.50	14.40	13.60	14.50	15.30	15.50	16.00	15.80	19.30
18.00	11.10	16.10	17.90	17.90	17.90	16.50	15.30	14.70	15.60	16.00	16.50	17.80	19.50	22.50
60.00	22.00	18.60	19.00	18.70	18.30	17.10	16.10	15.80	16.90	17.30	18.20	19.50	21.50	24.10
60.00	60.00	20.30	20.50	20.00	19.50	17.80	16.90	16.50	17.70	18.60	19.70	21.10	22.00	27.00
60.00	60.00	23.80	22.00	26.00	25.55	24.02	23.21	22.85	23.93	24.74	25.73	26.99	27.80	32.30
60.00	60.00	35.60	33.80	32.00	31.60	30.24	29.52	29.20	30.16	30.88	31.76	32.88	33.60	37.60
60.00	60.00	70.00	54.00	38.00	37.65	36.46	35.83	35.55	36.39	37.02	37.79	38.77	39.40	42.90
60.00	60.00	70.00	57.00	44.00	43.70	42.68	42.14	41.90	42.62	43.16	43.82	44.66	45.20	48.20
60.00	60.00	70.00	60.00	50.00	49.75	48.90	48.45	48.25	48.85	49.30	49.85	50.55	51.00	53.50
60.00	60.00	70.00	100.00	56.00	55.80	55.12	54.76	54.60	55.08	55.44	55.88	56.44	56.80	58.80
60.00	60.00	70.00	100.00	62.00	61.85	61.34	61.07	60.95	61.31	61.58	61.91	62.33	62.60	60.00
60.00	60.00	70.00	100.00	68.00	67.90	67.56	67.38	67.30	67.54	67.72	67.94	68.22	68.40	60.00
60.00	60.00	70.00	100.00	74.00	73.95	73.78	73.69	73.65	73.77	73.86	73.97	74.11	74.20	60.00
60.00	60.00	70.00	100.00	100.00	100.00	100.00	100.00	100.00	100.00	100.00	100.00	100.00	100.00	100.00
Dano is offline
 Old 07-01-2011, 11:44 AM   #1280
m4tic's Avatar
thanks ill work with this.
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-02-2014 06:32 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MazdaSpeed 3/6 - ECU Computer Tuning 1518 02-25-2014 07:30 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Cool Cobb Tuning Video Haltech MazdaSpeed 3/6 - ECU Computer Tuning 1 06-24-2008 12:22 AM
Page generated in 0.57455 seconds with 33 queries
