 Old 07-01-2011, 01:46 PM   #1281
evidence's Avatar
Posts: 1,033   (View Stats)
You gen 2 guys should let us know if the LC + FFS work when both enabled. I'd guess the Gen1s still have the old logic causing low timing and rich fueling issue after a normal shift with LC/FFS enabled?
Some things.
evidence is offline
 Old 07-01-2011, 01:51 PM   #1282
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
some def do have the issue
Gen 2 Cobb ATR discussion
I don't have the new genwan beta but judging from the genpu guys they still have the issue and they just got LC/FFS
Dano is offline
 Old 07-01-2011, 08:20 PM   #1283
m4tic's Avatar
Posts: 4,928   (View Stats)
Ok dano I don't think that was it.. My car is bouncy to all hell trying to modulate light throttle
Sent from my iPhone using Tapafawk
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 07-02-2011, 09:32 AM   #1284
SJP0tato's Avatar
Posts: 322   (View Stats)
Originally Posted by bmorrisj View Post
and what happened to the DBW tables?
I just download the latest ATR for my 07 MS6, and my DBW values look exactly like this as well. I think I'll hold off on flashing my ecu until Cobb can tell us what's going on.
SJP0tato is offline
 Old 07-02-2011, 10:58 AM   #1285
Trail of Fail
Dano's Avatar
Just edit the tables and flash that bitch
Don't forget to zero out the new load error wgdc comp table.
Bmorris,
Maybe the "b" table is your issue. Did you correct that one. It should be for DSC active but who knows.
I'll post my B table when I am back at my PC.
Dano is offline
 Old 07-02-2011, 05:18 PM   #1286
m4tic's Avatar
ok I really think something is wrong with reducing the doubled DBW tables.. It seems I can't quite reach boost targets and I'm only seeing 160-180 maf gs. I'm going to make a map with the double DBW and see how it runs
*edit also I'm being limited to 1.7 load
haha Dano these are your values x2
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 07-03-2011, 02:55 AM   #1287
friscoplayrsf's Avatar
Posts: 71   (View Stats)
friscoplayrsf will become famous soon enoughfriscoplayrsf will become famous soon enough
My shit is money. GEN 1, Stage 1 mscai tih 91 bt102. Fucking money. I edited some shit though. APP tables, dbw tables, Boost tables, wgdc cut in half to start tuning. didn't touch TRL tables. Shit is money. NEW COBB atr beta is money. FTW.
friscoplayrsf is offline
 Old 07-03-2011, 08:15 AM   #1288
Trail of Fail
Dano's Avatar
that is messed up! Post over on Cobb's forum and see what they say..
ATR Resolution to Oddities Reported with the Pressure-Based Boost Tuning Calibrations
Dano is offline
 Old 07-03-2011, 10:24 AM   #1289
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Another thing to look at if you guys haven't already is the IAT Comp table.. It is defaulting to 75%.
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline
 Old 07-03-2011, 10:52 AM   #1290
m4tic's Avatar
Well I think I got it.. I put the doubled DBW tables and the car came alive. it was like when I put 100 in the cells, the ecu would only run up to 50% throttle for tables that use throttle input on the y-axis.
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 07-03-2011, 11:16 AM   #1291
SJP0tato's Avatar
Are you talking about the Wastegate Tables: WG Duty - IAT Comp. table?
That one looks normal on mine:
Code:
-40.00	-4.00	32.00	68.00	104.00	140.00	176.00	212.00
0.99	0.99	0.99	0.99	0.99	1.05	1.12	1.20
SJP0tato is offline
 Old 07-03-2011, 04:45 PM   #1292
fjames's Avatar
Posts: 1,058   (View Stats)
Code:
Unless I'm completely confused, those are the factory settings. The latest ots maps are significantly different, rolling off WG as temp increases (which only makes sense, especially with more boost.)
Code:
0.80	0.90	0.95	1.00	1.00	0.98	0.95	0.92
fjames is offline
 Old 07-03-2011, 05:05 PM   #1293
Trail of Fail
Dano's Avatar
I have what fjames has. not altered by the new ATR.
Dano is offline
 Old 07-04-2011, 01:49 AM   #1294
bewsted's Avatar
I also wasn't using an OTS tune. This is why i said check that mofo....
EWG K04...GETSUM!
bewsted is offline
 Old 07-04-2011, 10:30 AM   #1295
m4tic's Avatar
these new WGA error options are sweet.. with 0 load error the ecu isnt trying to hit 15psi when im barely touching the gas. actually my boost gauge is showing more vacuum while cruising and light acceleration.
fvck i love it
this is just 3rd gear, i need to squash that early KR blip
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 07-05-2011, 07:25 AM   #1296
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Looks like boost tuning is the way to go now...I'll need some help from you experts since i'm new to the AP .
RichieRichness is offline
 Old 07-16-2011, 09:10 PM   #1297
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Originally Posted by manelscout4life View Post
When getting out of my car tonight I did notice the rad fan turn on. And that's with a map from the previous ATR
Just going back to this; my car has always done this. Our cars will pump coolant through the turbo after you shut her down and above a certain temperature, the rad fan will run. Perfectly normal.
Frequentflyer is offline
 Old 07-19-2011, 09:27 PM   #1298
SJP0tato's Avatar
I finally got this loaded up and setup a new map.
What strategy are you guys using to hit your boost targets?
I setup my WGDC table with the new values, 0'd out the Load Error Comp, and used Cobb's suggested Boost Error Comp values.
Code:
-9.00	-7.00	-5.00	-3.00	-1.00	0.00	1.00	3.00	5.00	7.00	9.00
0.04	0.02	0.02	0.00	0.00	0.00	-0.02	-0.07	-0.15	-0.20	-0.25
I've got my boost targets set for 17psi, but the ecu is targeting the values for WGDC very closely, which results in a lot of underboost. Logged WGDC values are very close to the ones in the table... so are you guys just bumping the values in WGDC? Or is it better/easier to adjust the Boost Error Comp "under" values (The ones at -3.00 and -1.00) to bump up boost when it's under my targeted 17psi?
From my datalogs it looks like the ecu is using the BEC values to hold boost at target minus 4 psi. Since the error table only tells it to increase WGDC up to a value of -4 (I'm assuming interpolation at -4 is 0.01) it holds at a range of 17psi - 4psi = 13psi, which closely matches the psi reached on the datalogs.
I'm going to try bumping the WGDC values slightly, and raising the BEC values to:
Code:
0.04	0.02	0.02	0.01	0.01	0.00	-0.02	-0.07	-0.15	-0.20	-0.25
and see what happens
SJP0tato is offline
 Old 07-19-2011, 10:07 PM   #1299
fjames's Avatar
The new Cobb maps are setup to basically run an unaltered WGDC - the values are quite high and there's no comp until the -5 cell in BEC.
So if a person is using the ots BEC values, but with a "normal" WGDC table, it would probably underboost.
I use .03 and .10 in the first two cells of BEC (-1 and -3), with much lower WGDC values than the appropriate ots map for my car and have no problem at all. I can actually find several consecutive rows in logs where it's cycling 3% WG changes.
With the new logging resolution, and it responding so well to the newly exposed tables, it's kind of fun to play with.
If it matters, I have load error comp and rpm comp A&B zeroed, and 10 for boost high ramp limit. For me it's now officially better than load tuning. I love that you can easily set a WG upper limit - that means you can set a higher boost target than WG will allow in warm weather, but (hopefully) make your target in cooler weather. So you can tailor your boost with either WG or boost targeting, play them against each other, really fine tune an individual car.
fjames is offline
 Old 08-09-2011, 06:32 PM   #1300
Has anyone had problems with the new firmware? I installed it and now I can't get my AP to read any sensor info and the screen just flashes like it's hitting limits. I uninstalled and reinstalled with no luck. I'm just going to try going back to the previous firmware.
AP-MAZ-002 v1.6.4.2-2276
 Old 08-09-2011, 08:27 PM   #1301
m4tic's Avatar
make sure you are loading and saving your maps using the latest ATR (then reflashing the resaved map)
old maps without new logic on newer firmware will show wild discrepancies in logging
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 08-12-2011, 07:02 PM   #1302
I've got ATR 1.8.6.0-1760 from April. Is that the latest ATR?
 Old 08-12-2011, 07:05 PM   #1303
Todd98SE's Avatar
Posts: 1,077   (View Stats)
I think 2276 is the latest.
Sent from my SCH-I500 using Tapatalk
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 08-13-2011, 07:03 AM   #1304
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I am still on the June 30, 2011 1.8.6.0-2212 Beta, which I believe is the latest ATR release. Its big upgrade was that it incorporated the fast logging capability.
cld12pk2go is offline
 Old 08-13-2011, 08:42 AM   #1305
Hmmm... OK. I'll have to request a new copy. Thanks.
 Old 08-13-2011, 09:33 AM   #1306
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
No, update it. The "latest" is the Beta that also had LC/FFS.
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 08-13-2011, 05:52 PM   #1307
Roger. I didn't have the BETA option checked. Updating now.
 Old 08-13-2011, 09:04 PM   #1308
Trail of Fail
Dano's Avatar
that should resolve the logging issues.
Dano is offline
 Old 08-19-2011, 02:27 PM   #1309
SRTie4k's Avatar
Posts: 1,715   (View Stats)
I'm glad I was relatively close with my BD table experimentation, although a little on the high side. It seems like Cobb's original explanation of the BD table adjusting in mm Hg (I believe) was wrong.
SRTie4k is offline
 Old 09-07-2011, 12:57 AM   #1310
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
So I never found a solid solution to limiting boost in 1st and 2nd gear. Has anyone figured this out yet?
I had one idea I wanted to run past people:
Instead of zeroing out the WG Duty Load Error Comp like has been suggested, what if we only zero out "0" and below. Wouldn't this cause the ECU to pull WG Duty cycles if the load is above the specified value, but if below the specified value dont do anything with load? If so, Couldn't we then change each of the "Throttle - Req Load" tables and set them to be a load cap? So in 1st gear, set the load cap to 1.5, 2nd gear 1.8, 3rd-6th 5.0 or whatever? Would the ECU then stop building boost once the load is reached or if the boost target is reached before the load (5.0 for 3rd-6th) then it would use the boost targets?
This is not as nice of a solution as just being able to set boost targets by gear, but if it works...
Just a late night thought. Let me know if this makes sense and sorry if this has been said before. Just never found a solid solution to limiting boost in 1st/2nd.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline
 Old 09-07-2011, 05:21 AM   #1311
Eth/Meth Junkie
cld12pk2go's Avatar
Adjust your APP Translation tables for 1/2nd gear to cap at ~35%.
Here is my 2nd gear:
Code:
0.00	0.25	0.65	1.68	3.25	4.50	6.00	7.50	9.00	10.00	11.50	13.00	14.50	16.00	18.00	20.00	24.00	27.00	30.00	33.00	35.50	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00
 Old 09-07-2011, 09:10 AM   #1312
Trail of Fail
Dano's Avatar
but it does seem that I have heard gen2 guys having issues with trying to use APP to lower power but don't remember who it was. As 12pk said, works like a charm on gen1.
I had my 1-3 limited until I got the sticky A048s which let me have full power in 3rd again BUT then I started tweaking VVT and well, lost some traction in 3rd gear again due to decreased spool time...then went and added 3 gallons of E and all hope of traction in 3rd is gone again without APP tweaking. LOL
1-2nd gear code going to 49
Code:
0.00	0.25	0.65	1.68	3.25	4.50	6.00	7.50	9.00	10.50	12.00	13.75	16.00	17.50	19.50	21.50	26.50	29.50	33.00	36.00	37.50	38.80	40.20	41.60	43.00	44.40	45.80	46.50	47.20	48.60	49.00
IIRC boost comp would work for 1st but not 2nd or 3rd for me. it is all covered in the beginning of this thread...Id say the first 5 pages
Dano is offline
 Old 09-07-2011, 09:20 AM   #1313
I think it may be an issue of not cutting the table down enough gen1 vs gen2.
I cannot speak for the entire gen2 community, but I would think it may be a matter of us being more aggressive in cutting those tables down.
rfinkle2 is offline
 Old 09-07-2011, 10:58 AM   #1314
Trail of Fail
Dano's Avatar
you rash gen2 youngsters....lol
it takes some finesse to tweak APP. you don't want to start at 0 pedal because that will throw off clutch release to pedal feel too much. IIRC my scaling started around 45% pedal pos and I only translated up to 49%.
Dano is offline
 Old 09-07-2011, 11:26 AM   #1315
Nataphen's Avatar
Posts: 2,704   (View Stats)
APP worked for me to limit 1-2 gear boost, so I'm not sure what the issue may be there. Some cars may react differently, as we've seen before. IIRC, I was hitting 15,17, and 19psi in 1st-3rd respectively. 15 is still a handful in 1st, but it's better than 19.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 09-07-2011, 12:28 PM   #1316
fywdyl's Avatar
Posts: 370   (View Stats)
fywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the world
APP didn't work for me. I capped it at 50% for 2nd gear, and nothing happened. I was still hitting 19 psi.
However, I'm using TRL tables now and I've had great success with that.
2010 Black Mica MS3
Mods to date:
Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071
Mods to come:
Driver Mod || Snow Performance Meth Kit
fywdyl is offline
 Old 09-07-2011, 01:20 PM   #1317
martin_nj's Avatar
Posts: 581   (View Stats)
martin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the world
Groaned at 9 Times in 5 Posts
has anyone heard when this will be out of beta?
2009 Mazdaspeed3 SOLD!
Summit Point Main 1:32.725 (on all seasons)
Lime Rock Park 1:05.419 (R888)
Pittsburgh Int. 1:09.594 (R888)
NJMP Lightning 1:21.203 (R888)
2013 Ford Mustang GT
NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons)
NJMP Lightning - 1:20.087 (modded car with 245 summers)
Pocono North - 1:06.xx (Dunlop SP600 245x18) wet
Pocono North - 1:00.655 (275mm Conti Slicks)
Lime Rock - 1:07.2 (Dunlop SP600 245x18)
1989 Honda CRX Si
VIR Full Course - slowww
Summit Point Main 1:35.230
Renault Spec Racer
Lime Rock Park 1:04
VIR Full Course 2:30
martin_nj is offline
 Old 09-07-2011, 01:21 PM   #1318
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
it already is sir
manelscout4life is offline
 Old 09-07-2011, 01:25 PM   #1319
martin_nj's Avatar
no shit? i guess i missed the email from cobb
1989 Honda CRX Si
Renault Spec Racer
Lime Rock Park 1:04
 Old 09-07-2011, 01:42 PM   #1320
Yea I tried the APP tables already (gen1) but it didnt seem to do anything. Let me try it again with lower values.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-02-2014 06:32 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MazdaSpeed 3/6 - ECU Computer Tuning 1518 02-25-2014 07:30 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Cool Cobb Tuning Video Haltech MazdaSpeed 3/6 - ECU Computer Tuning 1 06-24-2008 12:22 AM
Page generated in 0.57848 seconds with 39 queries
