 Old 02-15-2011, 06:53 PM   #281
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
not sure about per cyl but I just copy my OL/HT ign table over my limit table. I still hit target timing and its way higher than OTS.
Seems to work.
Dano is offline
 Old 02-15-2011, 08:18 PM   #282
Yes, I am running a M7 nozzle with straight meth. My exhaust backpressure has to be insane with the stock turbo and stock TBE, which will certainly limit my timing advance potential.
I think my current timing is pretty close to optimized. I have added a good 3° or so up top since raising the KR threshold to 6700 RPMs.
Here is my most recent good log to redline:
In this case I sustained a pretty high load up top since the ambient temp was low. Mid 290 g/s isn't anything to sneeze at from the stocker (especially since it is really more than that since I am spraying so much meth and still hit my targeted AFR)...
I used to peak at 22 PSI around 3500-4500 RPMs, but my stock clutch won't take that in the cold so I am now targeting 18PSI until I can get my ACT installed (evidently the stock clutch doesn't respond well to loads > 2.3).
The airflow values are definitely nothing to sneeze at. How were the g/s affected as you added timing and by how much?
Also the ACT might not be the best clutch from what people here have experienced.
Lex is offline
 Old 02-15-2011, 08:52 PM   #283
Trail of Fail
Dano's Avatar
shhhhhh....I don't want mine to hear the rumors...I will blow my top if my brand new clutch takes a dump....LOL
I have about 6K on it so far but its winter so not much hammering nor heat buildup yet...FML
Dano is offline
 Old 02-16-2011, 05:50 AM   #284
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I did not notice any significant g/s change when adding timing. Ambient temp changes completely muddle any small changes due to timing.
While we are on the topic, the only reason I can imagine g/s would increase when timing is increasing would be due to a reduction in exhaust back pressure due to extracting more heat from the exhaust during the power stroke. Is there some other mechanism at play?
What exactly are the issues with the ACT clutch? I didn't see any mentioned when researching. I got the full face organic disk material (most tame) if that is relevant to the issues.
cld12pk2go is offline
 Old 02-16-2011, 08:36 AM   #285
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
My pressure plate broke after 10k miles. 2 teeth broke off but they replaced it under warranty.
Boosted Beluga is offline
 Old 02-16-2011, 08:44 AM   #286
Trail of Fail
Dano's Avatar
Lenny's went out after 10 or so runs down the strip, same with another member. They both had the street kit and they both were drag racing with them. This happened on the supposedly newer batch of kits. ACT had a run of bad PP about a year ago and it was supposedly fixed. ACT appears to warranty them but shit, you have to pull the tranny again, send them the parts THEN they determine the cause and send you replacements.
thats about all I know.
Dano is offline
 Old 02-16-2011, 11:21 AM   #287
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Also, i would think if the timing advancement improved piston acceleration, you could see some gains in airflow from improved vacuum on the intaking cylinders... not sure. Superskater said his g/s increased quite a bit when advancing timing.
I wouldn't have expected it... but who knows.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 02-16-2011, 11:35 AM   #288
I am a little perplexed about this since super did say he saw more g/s. However, g/s represent flow and I don't see flow changing much with timing. However, g/s is also representative of a hp curve which would be affected by timing.
However, timing DOES affect AFR. So it affects burn, cylinder filling/emptying, efficiency in general which may result in better cylinder emptying and filling, exhaust volume, temperature, velocities ... it gets pretty complicated. This is why I wanted to see what people saw first hand.
Still wet here and can't do a proper 4th gear pull but I was generally seeing ~26x g/s at 17-18psi and all I changed was timing. The car is definitely more willing.
Lex is offline
 Old 02-16-2011, 11:45 AM   #289
Trail of Fail
Dano's Avatar
Lots of good information coming out here.....I need to talk Lenny into changing the thread title to something more general like "Dano's Boost Tuning 101, etc" LOL
we have covered:
Load based tuning [touched]
boost based tuning
CL/OL transition tuning
AFR tuning
timing
did I miss anything?
so basically a pretty comprehensive 101 class and maybe even some 201 stuff....
I also want to give a big thanks to all of you for your contributions to this thread!
Give yourselves a big round of applause
Dano is offline
 Old 02-16-2011, 12:14 PM   #290
SRTie4k's Avatar
Posts: 1,715   (View Stats)
Is there any room for increasing timing on a non WMI car? I can't imagine very far if any at all, but just curious if its feasible.
SRTie4k is offline
 Old 02-16-2011, 12:48 PM   #291
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Is there a guide somewhere that states the order in which to tune each parameter for optimal performance?
My guess is the following (for WOT tuning):
- Increase fuel and decrease timing for safety purposes.
- Dial in boost targets.
- Set fuel pressure targets and adjust fuel mix to reach desired AFRs across the rev range.
- Increase timing to desired (safe levels) while monitoring changes in AFRs.
- Done.
BlueStreak is offline
 Old 02-16-2011, 12:50 PM   #292
SRTie4k's Avatar
- Done.
There's no need to decrease stock timing.
SRTie4k is offline
 Old 02-16-2011, 01:50 PM   #293
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Not for gen 1
For gen 2 cobb decreased timing for the OTS maps though
Stock gen 2 timing is pretty aggressive
Speed3eak is offline
 Old 02-16-2011, 02:00 PM   #294
Captain
Where's the CL / OL stuff? I wanna read through that.
I know the delays control both the transition delya into OL, and out of OL.... but i don't know which is which, so i just set both values real low.
Ideally, i'd leave the transition delay returning to CL from OL at a fairly large number, to avoid reverting to CL during shifts... and make the delay for entering OL very short.
www.permtuning.com
 Old 02-16-2011, 02:33 PM   #295
Originally Posted by Speed3eak View Post
Not for gen 1
Then gen 1 (at least) is very knock happy around 5-5.5k RPM on the stock tune. The COBB maps all pull timing in that region.
Lex is offline
 Old 02-16-2011, 03:15 PM   #296
Trail of Fail
Dano's Avatar
its just the stuff I used when fighting the load cap that you suggested at that time. ya know CL Max Load D to 1.25 across the board in the CL RPM range up to 4500, negate any throttle input with CL Max Throttle to 100 and 15-40-40 on the exit delays but I don't think we know which is which, right A, B and C?
I believe by setting the throttle to 100 and having your CL load at 1.25 you will not revert to CL between shifts unless maybe you shift like grandma
I haven't logged multi gear pulls in so long thought but IIRC I didn't revert to CL
^^^^^^ this!
when I push timing, KR first rears its head at 5K then disappears for the most part the rest of a run, even with KR enabled to 7k
Dano is offline
 Old 02-16-2011, 06:18 PM   #297
Eth/Meth Junkie
cld12pk2go's Avatar
Here is another pull from today. It was warmer outside and I lifted a little too early...
But 14° at 6300 RPMs...
 Old 02-17-2011, 09:33 AM   #298
Captain
Looks about perfect for what i like to see.
www.permtuning.com
 Old 02-17-2011, 09:56 AM   #299
Did a few pulls yesterday ... noted about a 4 g/s change with the timing change ... nothing to even note really as it could have been caused by a number of factors.
Lex is offline
 Old 02-17-2011, 10:15 AM   #300
Trail of Fail
Dano's Avatar
N I C E !
Dano is offline
 Old 02-17-2011, 10:46 AM   #301
Captain
The proper way to add timing is to multiply the maf curve by 10%, then pull your OL fuel by 10%..... and then add 1 degree.
That's the secret to power Lex
www.permtuning.com
 Old 02-17-2011, 10:57 AM   #302
Trail of Fail
Dano's Avatar
what??
gtfo with that bs hahaha
add 10% MAF then remove 10% fuel = no change in fueling
then add timing...is that how a SB works? hahahah
Dano is offline
 Old 02-17-2011, 11:01 AM   #303
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
4g/s could very well be weather related. did you say you regularly pull 26x g/s? That seems quite low...
when Christian was dyno-tuning my car, he told me afterwards that my air filter was really dirty...I was pulling 268 g/s on the dyno. then again, I've always pulled way more than that on the street...about 10% more.
-- Mario Andretti --
Fobio is offline
 Old 02-17-2011, 11:04 AM   #304
Captain
what??
Lolol, it was a joke to get the g/s up you meatball. Total slapstick haha.
"my car is flowing 500 g/s"
"yeah, but your target afrs are 19:1"
www.permtuning.com
 Old 02-17-2011, 11:05 AM   #305
Trail of Fail
Dano's Avatar
yup...and that's how Driver get's his high g/s numbers LOL maf scaling FTW
Dano is offline
 Old 02-17-2011, 11:10 AM   #306
Captain
I know joel is up to about low 400's...........
... funny part is his afr's aren't far from his target
www.permtuning.com
 Old 02-17-2011, 11:13 AM   #307
Trail of Fail
Dano's Avatar
well I could add 30% to my maf and get 400 g/s and match my AFR target no problem.
but my afr target would no longer be 11.9 LOL
Dano is offline
 Old 02-17-2011, 11:52 AM   #308
That's about what I see on the street at around 8 degrees ambient. By that point I'm pretty high in the RPM curve and I see 17 dropping to 16psi. Will have to do a proper log one of these days.
Joel? The internetz don't compute real names.
Lex is offline
 Old 02-17-2011, 12:03 PM   #309
Trail of Fail
Dano's Avatar
I think he means jwilkins88 AKA "tranny man"
http://www.mazdaspeedforum.org/forum/foru...d-share-71928/
Dano is offline
 Old 02-17-2011, 08:25 PM   #310
Driver
Fobio's Avatar
Groans: 44
to be honest, we've been logging in Toronto w/ +5 to -25*C...I wonder if that's why we get such elevated g/s on the street vs. on the dyno.
the tuners' said my turbo's kinda beat. I don't really know what that means nor did I dig further (like details as to what's likely failing)...but obviously the car can use a new turbo, and because of this, Christian said that my car's "maxed out"...so as much as I'd like to try things out, I'm wondering, since Christian already optimized my timing, whether it's worth it to play with timing anymore.
however, the meth is going in next week...and I'm torn whether to tune for it or not, or whether I can go like halfway with the aggressive timing.
Fobio is offline
 Old 02-18-2011, 05:09 AM   #311
Eth/Meth Junkie
cld12pk2go's Avatar
The stock K04 is only rated for ~34 lbs/min at 25°C ambient; however, when it is -10°C I have pushed close to 40 lbs/min through mine....
So yes, the flow on maxed out turbos varies greatly with ambient temp.
 Old 02-18-2011, 08:17 AM   #312
Trail of Fail
Dano's Avatar
I would guess that Christian put a conservative timing curve in the map as per Cobb's policy. If so, there is room for more timing and still be safe. Add WMI to the mix and even more timing can be had.
Keep in mind if you tune your timing at -25* when it is 80-90* it might be too much, all other things being equal, so you will want to monitor KR.
engine running inside a deep freeze would have cooler cylinder temps I would think LOL
Dano is offline
 Old 02-18-2011, 09:04 AM   #313
The ambient temps make a big difference as everyone said. Yesterday I did a pull in 3rd with boost a hair under 17psi near redline and saw 270 g/s at 7 degrees ambient temp. The west coast is warmer
How many Km on your car?
Lex is offline
 Old 02-18-2011, 09:38 AM   #314
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
Also if your turbo is out of steam... it could be better suited to make your power of more timing than more boost. I'm guessing with the WMI installed you will get your BATs down further and have more cushion to push some more timing through it.
You know.... Moose stuff
amoosenamedhank is offline
 Old 02-18-2011, 09:41 AM   #315
Captain
I've seen k04's die. A local can't hold more than 13-14 at redline. And Triplejumper's turbo is looking aged as well (possible boost / exh leak, but not sure).
They just weren't sized for the abuse we put em through.
www.permtuning.com
 Old 02-18-2011, 09:45 AM   #316
Driver
Fobio's Avatar
Groans: 44
Ok...that's good to know, maybe not for ego, but knowing the truth helps, esp for extrapolating whp and comparison. My car has 92,000km on it.
that's what I want to know. I was worried that pushing timing with a beat turbo would be bad.
yes, those are some of the figures we were throwing around on MSN for discussion, and it sounds so bad ass! I wanted to point out on your log that your g/s on the legend says /20, as in right hand y-axis/20? or are you using the left hand y-axis but *20 instead?
Fobio is offline
 Old 02-18-2011, 03:15 PM   #317
Eth/Meth Junkie
cld12pk2go's Avatar
The g/s /20 is against the left hand axis, so if I had 280 g/s and divide by 20 then the chart shows 14.
Looks like my left y-axis units were out of synch with what I am currently logging.
I will correct these issues in my future charts.
The only items on the right y-axis are engine RPM and DI pressure.
 Old 02-18-2011, 03:20 PM   #318
Captain
GET YOUR FUCKING SHIT TOGETHER 12PACK
www.permtuning.com
 Old 02-18-2011, 03:22 PM   #319
Eth/Meth Junkie
cld12pk2go's Avatar
Need beer...
 Old 02-18-2011, 04:03 PM   #320
Groans: 53
Oh sweet jesus I just realized what your sn was....
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-02-2014 06:32 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MazdaSpeed 3/6 - ECU Computer Tuning 1518 02-25-2014 07:30 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Cool Cobb Tuning Video Haltech MazdaSpeed 3/6 - ECU Computer Tuning 1 06-24-2008 12:22 AM
Page generated in 0.65955 seconds with 30 queries
