 Old 08-24-2011, 09:47 AM   #1681
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Well, if you are spraying a constant amount of meth, then of course your AFR shift will decrease with RPM. You must scale the amount sprayed by change in airflow in order to maintain the AFR shift. From the meth kits I have seen, they are only variable based on boost pressure.
phate is offline
 Old 08-24-2011, 09:48 AM   #1682
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Agreed. Even so, by the time you hit redline, you are presumably flowing as much as your setup can. With 12GPH, my setup doesn't make a dent in AFRs by 6700RPM.
'07 CWP MS3
Forged.
BlueStreak is offline
 Old 08-24-2011, 09:49 AM   #1683
@BlueStreak...
I totally agree with the above. With the D07 and a 50/50 mix, I see no afr shift whatsoever.
I will be spraying 100% meth with a D05 first, and then if necessary, move up to a D07.
It almost seems that the manufacturers of the kits are covering there asses when suggesting nozzle size and overall mixture.
I have seen many people spray with large nozzles, and see no afr shift.
The only guys that I see with any appreciable afr shift and drop in bat's (below intake temp) are spraying 100% meth with a D07 or greater.
In short, agreed with the above (how can anyone argue with datalogs lol), but it seems to achieve the tuning method that the manufacturers recommend, one would need to spray 100% meth with a much larger nozzle than specified in the recommended nozzle / horespower charts.
rfinkle2 is offline
 Old 08-24-2011, 09:54 AM   #1684
Eth Fiend
phate's Avatar
In order to maintain the AFR shift, you would need to control based on MAF voltage, not pressure. You would also need to spray a ton of meth since the stoich ratio is so much richer than gas.
phate is offline
 Old 08-24-2011, 09:58 AM   #1685
BlueStreak's Avatar
I hear you, phate. You still require enough flow (i.e. nozzle size) in the system to keep spraying an increasing volume of meth to match the increased airflow.
'07 CWP MS3
Forged.
 Old 08-24-2011, 10:04 AM   #1686
I believe that is why cld12pk2go prefers maf based controllers vs. map.
He and Abilor put a meth tune together for Abilors car spraying 100% meth w/ a D07 nozzle, and I am pretty sure they were able to keep a constant afr shift to redline, but I am going from memory of the logs.
TBH, I wish I had done a bit more research before buying my kit, and may eventually convert to an maf based controller.
I have already had to spend a ton of additional $ on my DO kit, from bungs, nozzles etc.
The only thing that I'm using from the DO stage 2 kit at the moment is the pump and controller.
My nozzles are now Snow, as well as the bung itself and nozzle holder.
I would've purchased a Labonte kit, but believe the Tsunami put a cramp in his supply chain, and effectively put him out of business.
rfinkle2 is offline
 Old 08-24-2011, 10:07 AM   #1687
BlueStreak's Avatar
Agreed. MAF based or IPW based is far superior to MAP based for controlling meth spray.
EDIT: Actually, I have successfully converted my MAP based controller to MAF based but I find its a tad risky. I'll post a write up on it and will outline the risks involved if poop hits the fan.
'07 CWP MS3
Forged.
 Old 08-24-2011, 10:10 AM   #1688
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
MAF FTW...I have MAP and wish I had MAF.
once the spray is started and levels out MAP works great but you go rich when the spray first starts if you are using a honking nozzle. If you base off of MAF you can scale the MAF right at the trigger point which will never change, so you stay at target AF.
MAP based trigger can be at different MAF voltages so it doesn't work as well.
Coolingmist has the coolest controller. its a digital boost gauge/controller/flow meter. [52mm] I believe it is can be either MAP or MAF.
something like a CMG2 pro
Dano is offline
 Old 08-24-2011, 02:17 PM   #1689
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Thanks for all the info, guys. About making a safer meth tune, wouldn't a mechanical failsafe solve our worries here? aka nozzle stops spraying, failsafe cuts boost to spring pressure, meanwhile there's probably been a few counts of KR, and AFRs are richened and/or timing is automatically pulled?
On that note, do such failsafes exist for MAF-based WMI setups?
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline
 Old 08-24-2011, 03:10 PM   #1690
Absolutely.
Snow Performance comes to mind:
Snow Performance: SafeInjection? Wastegate Solenoid
rfinkle2 is offline
 Old 08-24-2011, 03:40 PM   #1691
Trail of Fail
Dano's Avatar
Mechanical FS sols don't work that great. They slow spool time by allowing boost pressure to act on the WG Until the flow sensor detects enough flow.
Snow does have one that connects to your EBC wiring which may work better.
So your FS controller is set to say 350ml/hr which is your max flow rate.
Well when flow starts it is not at max rate yet so pressure goes to the WG until you reach that flow rate
If you lower the set point enough you get the opposite and the controller detects an overflow condition and again trips the sol.
That has been my experience with the labonte equipment
When shopping for WMI FS controllers be careful as only a few support 100% meth. Coolingmist does not support it on their normal controller but do on their auto learning FS controller.
Tappin
Dano is offline
 Old 08-24-2011, 10:26 PM   #1692
Thanks, I guess I have quite a bit more research to do before diving into the meth pool. I'm still trying to wrap my head around how to set up a meth kit that would net me some extra power, while remaining reasonable enough so that if the kit were to fail, that my engine wouldn't epic fail afterwards.
 Old 08-24-2011, 10:43 PM   #1693
Trail of Fail
Dano's Avatar
That's easy...I can help you out and how I run my WMI. If it fails I will only be .2 leaner than target and if KR does show up the ECU will add fuel and pull timing to quell it. I also have conservative timing. My FS is actually just lights in my dash which you can see in my WMI thread. I removed the actual FS solenoid months ago.
When you get into trouble is when you completely rely on WMI with a very aggressively lean target AF and aggressive timing.
so you can have a DD map that won't blow the motor up if WMI fails and if you want some killer dyno plot make another "ragged edge" map.
Absolutely.
I would actually like to try their FS boost cut controller that interrupts the electrical signal to an EBC. It probably reacts much faster than a mechanical one but then again you would need to run the OE BC or any aftermarket EBC. MBC would still need a mechanical boost cut device.
Dano is offline
 Old 08-25-2011, 11:24 AM   #1694
rpm comp A and B tables (beta ATR) explained here:
http://www.mazdaspeedforum.org/forum/foru...ml#post1009814
rfinkle2 is offline
 Old 08-31-2011, 10:10 AM   #1695
dachtler's Avatar
Posts: 170   (View Stats)
dachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond repute
I received notification in AP Manager today that new firmware is available for the AP: 1.6.4.2-2553, and it comes with V200 maps. It references a new build of ATR: 1.8.6.0-2517. However, my version of ATR still shows 1760 as the most recent released ATR build, and 2212 as the most recent beta build. Has anyone else been able to download the new 2517 build of ATR yet?
dachtler is offline
 Old 08-31-2011, 05:43 PM   #1696
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
My AP also shows update available...ATR shows nothing. So basically this update will not work with the current Beta ATR correct? Also, per release notes, the update doesn't seem to be anything different than the current beta tables...so no real need to update for those running beta correct?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
mrmonk7663 is offline
 Old 08-31-2011, 08:25 PM   #1697
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
DONT DO IT! I updated my AP a couple hours ago, went to flash a new map and it froze. My fucking ECU is bricked and I am 100 miles from fucking home. UGH! I left COBB a voicemail and shit but avoid this for now.
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 08-31-2011, 09:12 PM   #1698
Trail of Fail
Dano's Avatar
fuck I was afraid of that...the AP FW release notes specify a newer ATR version. Why would they release the FW before ATR????
Dano is offline
 Old 08-31-2011, 09:19 PM   #1699
mrmonk7663's Avatar
Shit, thanks for letting us know. That sucks man I hope it gets fixed.
 Old 08-31-2011, 09:53 PM   #1700
Trail of Fail
Dano's Avatar
Just uncheck Beta in atr then u can update both atr and ap then have a happy day.
Dont forget to resave existing maps.
Tappin
Dano is offline
 Old 08-31-2011, 09:56 PM   #1701
mrmonk7663's Avatar
But what is the point in us updating if we have the beta already? IT looks like nothing changed from current beta to the new non beta...seems like they just updated non beta to what us beta guys are running?
 Old 08-31-2011, 09:56 PM   #1702
Bucker's Avatar
Groans: 451
Dint forget to resave existing maps.
Tappin
Yeah, that was my error... working with Cobb now to make it work again haha.
Bucker is offline
 Old 08-31-2011, 11:57 PM   #1703
PM in progress. I'm taking you up on your offer to help lol
 Old 09-01-2011, 07:04 AM   #1704
new version of ATR helpfile here:
http://www.accessecu.com/support/doc...MAZDASPEED.pdf
rfinkle2 is offline
 Old 09-01-2011, 08:41 AM   #1705
dachtler's Avatar
Did you flash an OTS map, or a custom one? I was able to flash a stage 1 OTS map just fine with the new firmware. Maybe I just got lucky?
dachtler is offline
 Old 09-01-2011, 09:22 AM   #1706
Bucker's Avatar
Groans: 451
Ok, I have talked to Cobb. It wasn't the update, it was coincidental that my ECU got bricked when it did. I was just unlucky. They said they have seen "a few" have this happen, but it is not very widespread.
Bucker is offline
 Old 09-01-2011, 09:24 AM   #1707
dachtler's Avatar
Tappin
Yeah, that works now. Wasn't yesterday morning. Anyone know if there have been any changes since the beta? I'm guessing there may have been some bug fixes and improvements in the last 1.5 months.
dachtler is offline
 Old 09-01-2011, 09:28 AM   #1708
Good to see you Dachtler!
Answer to your q. here:
http://www.mazdaspeedforum.org/forum/foru...-lc-ffs-90471/
rfinkle2 is offline
 Old 09-01-2011, 06:17 PM   #1709
Nice hefty update there, COBB! I wonder what use the new clutch in/out related tables are to us stock K04 guys, it seems like it'd only be really useful to people running BT. I'll probably just keep my current map as is, until the meth kit comes in, then I'll start tuning with the newest ATR and firmware.
 Old 09-05-2011, 07:35 PM   #1710
For anyone that's installed a PMM (JBR or otherwise) after a RMM:
Did you find you had to up the KR offset tables even more from when you first installed your RMM? I know the RMM was causing some false reports of knock, does the PMM require some KR offset changes as well?
Sent from my Thunderbolt (Tapatalk)
 Old 09-05-2011, 09:01 PM   #1711
Bucker's Avatar
Groans: 451
Maybe, but it is going to be different for each person. I didnt have to do shit directly related to the RMM, but I might have been lucky. Log and see if there is any difference in your KR reports.
Bucker is offline
 Old 09-05-2011, 09:25 PM   #1712
I see, well I haven't heard anything terrible from the engine bay, and the car pulls more or less as expected. I'll probably re-evaluate my map once I rent a dyno for my meth tuning session... whenever it comes in lol.
 Old 09-05-2011, 09:43 PM   #1713
mrmonk7663's Avatar
I know I hear alot more noise with my PMM installed. Not sure if this will translate into kr readings or not. I did not modify my kr tables with my RMM...but I really wouldn't know how to see "real" vs "fake" knock in my logs.
 Old 09-06-2011, 09:47 AM   #1714
Trail of Fail
Dano's Avatar
only way to weed out the difference is to substantially increase the octane and see if the KR goes away. If it does it was real, if not the KR is false and you can proceed to tune the offset.
Dano is offline
 Old 09-06-2011, 11:33 AM   #1715
I guess ill wait for my meth kit then. If, while dyno tuning while spraying, KR doesn't decrease from non-meth levels, ill bump the offset tables some
Has anybody bothered with the new clutch in/out ignition timing tables? I'm not too sure if they'll be useful for us that still have the stock K04
 Old 09-06-2011, 12:24 PM   #1716
Trail of Fail
Dano's Avatar
haven't messed with the new clutch in/out tables but they could be beneficial for any car, not just BT. There are situations when the ECU will get confused after a FFS and even on a normal shift and pull timing/add fuel. I think these tables might be what we need to resolve this but haven't had time to test.
My car would def fall on its face after a lift to shift IF I had FFS enabled so it will be an easy test once I get some time. I am talking like -15* advance after a shift LOL
Dano is offline
 Old 09-06-2011, 12:31 PM   #1717
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
I have all 3 mounts and had to do a bit of tuning on the offsets to clean up some engine noise.
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline
 Old 09-06-2011, 02:24 PM   #1718
mrmonk7663's Avatar
thanks Dano and Bewsted. I'll log and see what my KR looks like after my PMM and evaluate from there. Any tips on how to modify the offset table?
 Old 09-06-2011, 02:27 PM   #1719
Hyperlink to post:
http://www.mazdaspeedforum.org/forum/foru...tml#post937730
rfinkle2 is offline
 Old 09-11-2011, 12:32 PM   #1720
bewsted's Avatar
@Cobb Tuning
Anyone else triggering cel's that you have turned off after the newest update?
EWG K04...GETSUM!
bewsted is offline
Gen 2 Cobb ATR discussion Nataphen 2010 MS3 - ECU Computer Tuning 2261 05-12-2015 12:09 PM
Cobb Tuning Inlet Review Discussion Haltech Review Discussion 62 06-03-2011 06:16 AM
Cobb AP Dyno Graph/Discussion NYpest MazdaSpeed 3/6 - ECU Computer Tuning 212 05-13-2008 02:13 PM
Page generated in 0.56388 seconds with 29 queries
