Like Tree3Likes
 Old 04-24-2012, 08:53 PM   #81
Police - Grammarhead
Vansquish's Avatar
I've been hoping to avoid this section, but unfortunately, here I am! I was checking that my MAF calibration was on-point given that we're starting to have some warmer weather and I just cleaned the filter on my SRI (less detritus = better flow), and decided to do a few little WOT runs to see how things were holding up on that end too.
The result...well...mixed at best.
I'm seeing KR up to 5.5 in the 1.6-1.8 load range, and between 4700 and 5700rpm. On my latest map I forgot to enable the knock sensor above 5700, so I'm assuming/extrapolating that it continued to knock up near the redline as well.
My map is based on a 91 Octane Stage 1, CpN OTS map from Cobb, but I've tweaked Boost, AFR, and timing per Abilor's/Bucker's guides. This is the first time I've seen this much knock at WOT, so I'm wondering if you guys think it might be transitory (spark plugs, bad gas, etc...), or something a little more serious.
Apologies in advance for the log. I took the knocking portions of my long-ass log and dumped them into a single CSV file with each separate occurrence separated by a single line gap.
Thanks in advance for any insights you might have!
EDIT:
For anyone looking for an example of what not to do, check my log.
I believe that my knock was real, but related to a few pretty easy-to-fix things (please let me know if I'm wrong).
1) I was running significantly too much timing in the mid-upper rev range given my modest mods.
2) BATs were reasonably high (100*-120*)
3) IAT was reasonably high as well (that's what I get for having an SRI).
At any rate, I flashed to a map with significantly less aggressive timing and now things are running more or less perfectly again (0-.35* knock), and on my last log, I made about 25lb-ft more (though 10whp less) than the more aggressive map.
Vansquish is offline
 Old 05-05-2012, 11:00 PM   #82
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Originally Posted by bertrand_CX_7 View Post
hey guys sorry for the nob question,
but I'm seeing late on my AP the KR reading 8.0
So I'm really not sure if this really means 8.0 of KR, that's why I'm asking just to make sure. The weird thing is that it's happening when cruising at the time I wasn't punching the car when I'm suddenly reading this on the AP. So no load on the engine when this is happening.
My tuning is not completed yet. There is still the regular gas pump to be tune out.
Anyone else seeing this?
I'm starting to see the same thing. Not NEARLY that high, but like 5.5* or lower. But mine only does it when the motor is "cold". once i've driven around a bit, it has a quick fit of KR, then i'm good for the rest of the day (unless i park for 8-10 hours). I've ran WOT, and seen a blink of .3 every once and a while, but never anything more.
I NEED ANSWERS. I'm running a Stage 2 91 SF+TIH+IC.
Side note: i did add some octane booster to this tank, so we will see.
99 miata: sold
Mortose is offline
 Old 05-06-2012, 12:30 AM   #83
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Yeah, i got DJ Look into that. then got a reevised map that looks much better now.
I bearely See KRs now. I'll check what changed on that map and Update you.
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline
 Old 05-06-2012, 09:43 AM   #84
Mortose's Avatar
Groans: 39
Thanks man.
99 miata: sold
Mortose is offline
 Old 05-07-2012, 09:36 PM   #85
DickFitzwell's Avatar
Posts: 996   (View Stats)
DickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the world
good thread @Lex. starting my tune from @atvfreek tomorrow for 50/50 (assuming he thought my logs looked good enough to warrant this). looking forward to meeting you finally in a few weeks for the SOCAL NATOR dyno day; ill keep ya posted on what i find in my new tune
09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERMFREEKTUNE 330/380
07 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS
07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H
Long Signature made especially for Micha
DickFitzwell is offline
 Old 05-08-2012, 09:11 PM   #86
Mortose's Avatar
Groans: 39
Update: Seems i MAY be getting hot spots. I found that if i drive out of boost for about 10 min, i can drive like normal and not get a single hint of KR.
Any in-site on this from the guru's?
99 miata: sold
Mortose is offline
 Old 05-08-2012, 09:21 PM   #87
You're in good hands - you should make some solid power on the dyno!
Lex is offline
 Old 05-09-2012, 12:26 PM   #88
If injector seals are a suspect of false KR, is there a specific portion of the rev band in which KR would be reported or is it random?
rfinkle2 is offline
 Old 05-15-2012, 06:51 PM   #89
KevMS6's Avatar
Posts: 316   (View Stats)
How much knock can these cars handle before causing damage?
If timing is out causing knock of around 5* throughout WOT runs, can there be immediate engine damage?
Tuned with by
KevMS6 is offline
 Old 05-15-2012, 06:57 PM   #90
Yes there can be damage. The longer you are in those conditions the more likelihood for damage.
Lex is offline
 Old 05-15-2012, 07:04 PM   #91
x09MS3GT's Avatar
Posts: 409   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
If i ever once logged KR over 2 in my car at any time during WOT, i would pull over, turn the car off, kneel down by the front driver side quarter panel, and quietly apologize to my 2.3 DISI until I was deemed forgiven by the car Gods.
--Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned --
x09MS3GT is offline
The Following User Says Thank You to x09MS3GT For This Useful Post:
CWP_MS3 (10-09-2014)
 Old 05-15-2012, 07:05 PM   #92
KevMS6's Avatar
I wasn't out long, about 5 miles, consisting of a 3/4/5/6 4/5/6 and then slowly back home... Consistent knock in every run, every gear seeing around about 5
My normal timing is around 7, it was up around 20 this time however
Hopefully no damage done
Tuned with by
KevMS6 is offline
 Old 05-20-2012, 11:07 PM   #93
maddocx240's Avatar
Posts: 823   (View Stats)
hey im looking for a little help with my logs im seeing the last couple of days.. im on a stage 1 ots stock tune, only upgrade i have is kmd internals. my kr is all over the place. fuel pressure is good, my a/f ratios are a bit iffy as well.. it fluctuates from 11's to 12's.. im not sure whats going on, maybe one the tuning gurus on here can help me out..
maddocx240 is offline
 Old 05-24-2012, 05:51 AM   #94
atvfreek's Avatar
Posts: 7,787   (View Stats)
Your car is running a bit lean. Some OTS maps need a bit more work than others. Need to start with a good maf cal for both PT and WOT. Then adjust all your fuel tables to a conservative afr to start. Looks like you are running a good amount of timing, so that mixed with the lean/erratic afr's is causing the kr.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
atvfreek is offline
 Old 05-24-2012, 08:39 AM   #95
This was a bug with VT. Make sure you upgrade to 1.7.2
Lex is offline
 Old 09-20-2012, 06:49 AM   #96
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
DISCUSS HERE: KR explained
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
KR explained Lex MazdaSpeed 3/6 - ECU Computer Tuning 161 04-29-2015 10:07 AM
PID tuning explained wassup61 Mazdaspeed3/6 General Discussion 7 03-21-2009 09:47 AM
Page generated in 0.37176 seconds with 31 queries
