 Old 09-11-2012, 09:13 AM   #121
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Originally Posted by NavySVO View Post
@ms3blackmica can the 4th gear portion of the cal be done on a dyno? I only ask because:
A. I want to dyno the car for numbers, and I can then kill 2 birds with one stone, and
B. It aleviates trying to find an area around here where I can open up to that speed while logging, traffic and cops.
of course it can be done a dyno !
www.tunedbynishan.com
ms3blackmica is offline
 Old 09-19-2012, 12:51 AM   #122
Nishan
@Pierre Loubser
how did that scalar work out for you ?
 Old 09-19-2012, 11:57 AM   #123
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
This is great! Thank you for this!
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline
 Old 09-19-2012, 12:26 PM   #124
Nishan
Not a problem.
If you have any other questions, feel free to ask.
 Old 09-19-2012, 12:35 PM   #125
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
If this was covered before, I apologize. I am looking for a consensus.
1. What is the target # and what is an acceptable #. (for example, anything less than .08 etc. with 0 being ideal.) Also, is there a oh crap moment? (If it is above 10.0 do a maf cal right now kind of thing)
2. Is a + or - number prefered if there are LTFT values.
3. Do you believe revisions are necessary? If so at what interval.
4. If someone is doing a cal, starting with + numbers, next revision they are -, and the third revision they are back in the +, what is the best course of action?
Thanks a bunch in advance. This is a great tool!
UnknownSuperhero is offline
 Old 09-19-2012, 12:53 PM   #126
Nishan
1. I am usually happy if the LTFT's are within 3-4%. 3-4% seems to be a good number between cold and warm weather changes. Although trims up to 6% aren't really an issue either. 10% really isnt an "OH CRAP" moment. My fuel trims will go to +10% when i put the AC on. This is normal. I'd say anything in the 20% range is an "oh shit i need to do a maf cal now" type of moment.
2. They can be + or - (absolute value). The ECU will either be pulling fuel out (-) or adding fuel in (+). As long as your within + or - 3%, you have a good maf calibration.
3. What exactly do you mean? It usually takes a couple revisions until your MAF cal is nice and tight. If you add any intake flow mods, you will have to revise.
4. This can happen a lot. For example, someone might have a 4.7% LTFT. Then they take 4.7% out, and now they have a LTFT of -3.9%. And then they try to add 3.9% and the same thing happens. This is usually the cause of not putting enough miles on the car before taking a maf cal log. Also some people like to only add as much as they need..For example, if your LTFT is +4.7%, some people might add only 4% to the maf breakpoint in order to bring the LTFT's around 0.7%. That is another way of going about it. Takes some time and practice. Also make sure you have no leaks.
 Old 09-19-2012, 12:53 PM   #127
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Target trim is 0%, you are correcting towards this value, based on the latest learned trims. Trims will change throughout the year, so I don't worry for anything less than 6 or 8%. If I see trims beyond those (after a good Cal), I know there are other issues (leaks).
Negative is probably preferred for the closed to open loop transition range. The thinking is the car will be biased rich as it transitions, thus being safer. It doesn't exactly work this way, but whatev, it's a good sentiment haha.
Revisions are usually only necessary when hard parts change. I tend to leave them as is so I can identify significant variances caused by other issues. Again, 1 proper Cal is typically all it takes. [If you dick with vtcs or repair issues, this may not be true].
If you're doing a MAF Cal right, you won't have revisions with significant variance after. If you see big swings, you're likely trying to tune around a leak.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 09-20-2012, 07:37 AM   #128
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: MAF Calibration Tutorial
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/maf-calibration-tutorial-125204/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-03-2014 01:36 PM
MAF Calibration Tutorial ms3blackmica MazdaSpeed 3/6 - ECU Computer Tuning 301 04-09-2019 07:50 AM
Monterey: 2012 Pebble Beach Concept Car Lawn offers a tutorial in cars to come Haltech Automotive News 0 08-19-2012 05:50 PM
AP maf calibration buckeyepost MazdaSpeed 3/6 - ECU Computer Tuning 1 08-24-2011 10:20 AM
Page generated in 0.29681 seconds with 25 queries
