 Old 05-19-2008, 04:14 PM   #1
Default Spark Plug Database - Colder Than Stock ( Stage 1&2 )
This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread.
Mazdaspeed Forums Spark Plug Index Database
Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28
Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
Code:
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
  • Denso Iridium
  • itv-20 - Stock heat range
  • itv-22 - 1 stage colder heat range
  • itv-24 - 2 stage colder heat range
  • itv-27 - 3.5 stage colder heat range
  • HKS
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
  • NGK IX Iridium
  • NGK LTR7IX-11 (6510) - 1 Stage Colder Heat Range
  • NGK ILTR6A-8G (3787) - Stock Heat Range
  • Torque Master Spark Plugs
  • SVTP8BR Stock Heat Range
  • SVTP7YR 1 Stage Colder Heat Range
  • Autolite Iridium
  • Autolite Iridiums XP5364 - Stock Heatrange
  • Autolite Iridiums XP5263 - 1 Step Colder
NGK Copper Plugs
LZTR4A-11 (5306)
LZTR5A-13 (4306)
BKR7E
Haltech is offline
 Old 05-19-2008, 04:23 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Heh, was about to correct you on the gap. Also perhaps we should sort them by Iridium/Platinum/Copper etc and list a link/price? Great idea though. why preferrably between .03 and .032? I jsut gapped mine to .028 dammit!!! lol
aaronc7 is offline
 Old 05-19-2008, 04:25 PM   #3
aaronc7's Avatar
Groans: 370
Autolite APP5364. Stock heat range as far as I can tell - Platinum - $3.99
AutoZone.com | Shopping | Parts | Product Detail - Spark Plug
aaronc7 is offline
 Old 05-19-2008, 04:28 PM   #4
We want colder stage plugs please. We can find stock plug applications all day long, but this isn't why this database is being created. You also do NOT want to be running platinum plugs in boosted applications. Big NONO.. Copper or Iridium plugs only please. Thanks!
Haltech is offline
 Old 05-19-2008, 04:32 PM   #5
aaronc7's Avatar
Groans: 370
How is platinum a big no no. WRXs come with them stock
aaronc7 is offline
 Old 05-19-2008, 04:32 PM   #6
jlarson1983's Avatar
Posts: 887   (View Stats)
jlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the world
yeah i have always heard the same thing.
jlarson1983 is offline
 Old 05-19-2008, 04:36 PM   #7
They are junk in high boost... the electrode usually falls right off into the cylinder because they cant handle constant heat temps that boosted engines put out. Platinum work great in NA stock applications and can take day to day abuse... until you boost them.
Haltech is offline
Tedspeed6 (12-19-2012)
 Old 05-19-2008, 04:37 PM   #8
aaronc7's Avatar
Groans: 370
Thanks for the info. Guess I need to change mine again, LOL. At least they were only 16 bucks. Hope we can find some copper ones in the right size.
aaronc7 is offline
 Old 05-19-2008, 04:39 PM   #9
Im trying to get some copper numbers, but so far, im having no luck. Hopefully when NGK answers my email, i can get some numbers.
Haltech is offline
 Old 05-19-2008, 04:42 PM   #10
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
sub
gsrtype1 is offline
 Old 05-19-2008, 04:44 PM   #11
aaronc7's Avatar
Groans: 370
14mm; 5/8 hex; 25mm reach; projected tip; resistor plug.
some useful info: for those looking for a traditional NGK copper core spark plug.....
aaronc7 is offline
 Old 05-19-2008, 04:47 PM   #12
here are the specs of the NGK LTR7IX-11 (6510)
Iridium IX Plug, 14mm Thread, 25mm (.984") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Fine Wire (0.6mm) Iridium Center Electrode, Tapered Cut Ground Electrode, .044" (1.1mm) Gap
 Old 05-19-2008, 04:48 PM   #13
not the right heat range, stock is 6 colder is 7
 Old 05-19-2008, 04:50 PM   #14
aaronc7's Avatar
Groans: 370
yeah good call. i just quit at this whole spark plug thing, lol
aaronc7 is offline
 Old 05-19-2008, 04:54 PM   #15
He should have tried the BR7 series as they are resistor plugs... I run BR7EFs in my truck, which are 2 stages colder than stock.
Haltech is offline
 Old 05-19-2008, 06:54 PM   #16
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
Not trying to jump off topic or anything, but would there be a greater benefit to going 2 stages colder plugs? I was gonna go colder, but haven't heard of the 2 steps colder plugs till now. I am mild to heavily (at least soon to be) modded.
The fastest MS3 in the whole garage...
winniep is offline
 Old 05-19-2008, 06:56 PM   #17
2 stages will make you idle a little more rough but will be fine.. You will lose a bit of power with stage 2 plugs, over stage 1, but your safety margin is greater.
Haltech is offline
 Old 05-19-2008, 07:06 PM   #18
aaronc7's Avatar
Groans: 370
If a plug is too cold, will it foul easier/faster?
aaronc7 is offline
 Old 05-19-2008, 07:17 PM   #19
2 stages isnt cold enough to cause fouling. Not with 20 psi of boost.
Haltech is offline
 Old 05-20-2008, 02:21 PM   #20
Christian.'s Avatar
Posts: 274   (View Stats)
Christian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the world
Here is some initial work. IMO, the stock plugs for the STi and EVO9 are excellent and should be used where possible. Although, I do like copper plugs due to them being less expensive. The below picture has (from left to right) the MS3 stock 6 temp range plug, a 7 temp range plug for the EVO9, and a 7 temp range plug for the STi. Unfortunately, the STi and EVO9 plugs do not seat against the head the same! Otherwise, these would be excellent stock MS3 replacements.
The ILTR6A stock MS3 plug is gapped at ~.031" from the factory.
The LFR7AIX Iridium STi (one range colder than stock) plug is gapped at ~.029" from the factory.
The ILFR7H Laser Iridium EVO9 plug is gapped at ~.022" from the factory.
A few things to note, the different plug MFGs use different numbers for temperature ranges. For NGK and Denso, the higher the number the colder the plug (or the more heat the plug pulls from the combustion chamber and transfers to the head/coolant passages). Temperature ranges of 6 and 7 should be fine choices for most cars. You cannot easily adjust the gap on platinum, iridium, or laser iridium plugs without scratching off the special coatings that make these plugs so expensive...so please be careful. We should be able to find a good replacement spark plug soon, and we will have better input once we analyze the stock used plugs that are being shipped to us by customers.
Christian.
Christian. is offline
 Old 05-20-2008, 02:31 PM   #21
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
bioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the worldbioevolve is the leader of the world
Mazdaspeed/Cobb Forums Spark Plug Index Database
Gap size - 0.28 - 0.32 Preferably between 0.30 to 0.32
  • Denso Iridium
  • HKS
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - Stock Heat Range
  • NGK IX Iridium
I said on US (backwards) the HKS 50003-M40LF is a heat range of 8, so it's 2 step colder not stock need to edit that first post lol.
And don't forget the itv27 3 step colder (or 3.5).
Sorry off topic. I really don't like US (backwards) due to a wholesale account not getting done with them. I buy my stuff from PG now. I had $10,000 to do an initial buy from them, so now I'm spending it at PG. And will be coming to this forum more often also. :friday:
bioevolve is offline
 Old 05-20-2008, 02:32 PM   #22
From NGK...
The 7 heat range is the coldest plug we currently offer with the 25mm thread reach.
As time goes on I am sure NGK will release even colder versions of these plugs (possibly even racing versions) and plugs that will have a smaller gap to better match these turbo applications.
He also adds:
While this plug is dimensionally correct I would not suggest using the
LTR7IX-11 for this application as the gap setting is too large (factory set to .044"). You do not want to gap any plug more than .008" from where it is factory set, as more than this and the inner surfaces between the electrodes will not be parallel and can cause the plug to misfire and wear out very quickly (iridium plugs seem to be very sensitive to this gap adjustment range especially under boost).
Haltech is offline
 Old 05-20-2008, 02:52 PM   #23
Alittle Faster
bioevolve's Avatar
So .036 reduction is the least safest with iridium.
Copper would be best then, as said before lol.
 Old 05-20-2008, 03:44 PM   #24
aaronc7's Avatar
Groans: 370
Anyone know what the Denso itv-20/22/24s are gapped at?
aaronc7 is offline
 Old 05-20-2008, 05:35 PM   #25
Alittle Faster
bioevolve's Avatar
itv20 1.1mm or .044 can gap down to .036
itv22 0.8mm or .032 can gap down to .024
itv24 0.8mm or .032 can gap down to .024
itv27 0.8mm or .032 can gap down to .024
 Old 05-20-2008, 05:39 PM   #26
aaronc7's Avatar
Groans: 370
Awesome, looks like the ITV 22/24/27 will work great for us
aaronc7 is offline
 Old 05-20-2008, 10:07 PM   #27
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
* Above information is just for reference
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline
 Old 05-21-2008, 12:45 AM   #28
What heat range is the 27? 3 stage colder or 4?
Haltech is offline
 Old 05-21-2008, 03:30 PM   #29
Alittle Faster
bioevolve's Avatar
I'm guessing 3.5, since they are increamenting 2 numbers per 1 heat range number.
 Old 05-24-2008, 07:15 AM   #30
Alittle Faster
bioevolve's Avatar
  • HKS
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
This still needs to be fixed!!!
M35LF is 7 heat range - 1 step colder
M40LF is 8 heat range - 2 step colder
 Old 05-24-2008, 12:19 PM   #31
fixed
Haltech is offline
 Old 06-06-2008, 10:03 PM   #32
Haltech's Personal Bitch
PDXImportRacer's Avatar
Posts: 275   (View Stats)
PDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond repute
Do we have any answers as too which are the best plugs to run when upping the boost?
PDXImportRacer is offline
 Old 06-07-2008, 12:43 AM   #33
aaronc7's Avatar
Groans: 370
denso itv22 recommended by me!
aaronc7 is offline
 Old 06-07-2008, 11:50 AM   #34
Denso hands down.
Haltech is offline
 Old 01-05-2009, 12:59 AM   #35
aaronc7's Avatar
Groans: 370
at what point do you all think 2 steps colder should be used?
aaronc7 is offline
 Old 01-05-2009, 02:23 AM   #36
Bump
Haltech is offline
 Old 01-05-2009, 10:17 AM   #37
gsrtype1's Avatar
Groans: 102
I like my ste2 colder, I had requested 1 step colder but got 2 step does this cost power? Car runs great, but am I losing a tad of power with the 24 vs 22?
gsrtype1 is offline
 Old 01-16-2009, 09:00 PM   #38
Speedie6's Avatar
Posts: 1,838   (View Stats)
sub
Speedie6 is offline
 Old 01-17-2009, 04:58 PM   #39
RIP May 9th, 2012
sbspeed's Avatar
Posts: 111   (View Stats)
sbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to behold
any sources on the Denso Iridium itv-24 - 2 stage colder heat range plugs?
haven't had much luck locally
sbspeed is offline
 Old 01-26-2009, 03:01 PM   #40
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
what step colder would i want for this setup
1.Cobb inlet
2.cobb SRI
3.Cobb Turboback exhaust
4.SU TMIC
5.denso ??????????
6.hks bpv
7.cpe HPFP
8.cpe standback
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - Engine, Transmission & Driveline 23 09-27-2017 05:09 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 08:49 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 95 09-19-2012 02:11 PM
Page generated in 0.55309 seconds with 30 queries
