![]() Join Date: May 2008
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score .026/18 psi ATR map - I just tapped them a little to see if I could get them down to .026 and basically did. Gapping these things is not fun and I'm not confident in the accuracy of doing it by hand. To someone above - jets have 3 altimeters so they have a tie breaker, i.e. how do you know which was off if you only compared two?
__________________ ![]() |
| Lurkers
Posts: n/a
| what step colder would i want for this setup 1.Cobb inlet 2.cobb SRI 3.Cobb Turboback exhaust 4.SU TMIC 5.denso ?????????? 6.hks bpv 7.cpe HPFP 8.cpe standback |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score 1 step/ITV22. You probably wouldn't start to look at 2 steps unless you go BT.
__________________ Some things. |
| Lurkers
Posts: n/a
| whats BT besides for my initials?? edit, is that BIG TURBO???? |
| Not Ranked : 0 score Yea, Bigass Turbo
| Lurkers
Posts: n/a
| i hurd BigASS turbos can suck little children in them and because i live near a school i wont get one. speed is not worth murder |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score What is the torque specs for the spark plugs? I will be getting densos soon. |
| Lurkers
Posts: n/a
| 8-10 ft lbs |
| Not Ranked : 0 score That seems very low for a boosted car |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score subbing... interesting topic
__________________ |
![]() Join Date: Jun 2008
| Not Ranked : 0 score what gap? i had missfire toady nothing big I will strech spring in my coild and look at plugs...what gap for fully bolted car making around 280whp?? I have denso step colder plugs |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score scroll to the top of the page and click on thread tools > subscribe to thread. don't post "subbing" please .030 eh |
| Not Ranked : 0 score |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score what type of plug gapping tools are you guys using? |
| Not Ranked : 0 score The cheap 99c coin from autozone works fine for me, doesn't have to be dead on.
Groans: 90
I compared the feeler gauge 0.028 against the $0.99 gapper, and the cheap gap tool is so far off it's not even funny...
__________________ ![]() [SIGPIC][/SIGPIC] | |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
Groans: 70
| Not Ranked : 0 score ^^^ feeler gauge is the way to guy, way more exact. back to plugs tho, i have been using the itv-24 2 step colder for awhile now no issed i switched from the 1 step. noticed big decreace in knock from 1 step to 2 step. |
Groans: 90
| Not Ranked : 0 score how are you noticing the knock? datalog with AP or DH? My AP datalogs show hardly any KR w/ITV-22's.... But then again, I didn't have a lot of KR with the OEM plugs either...
Groans: 70
| Not Ranked : 0 score AP. i did not have ap with stock plugs so i could not comment. but just simple switch from step 1 to 2 made a reduction in knock. i just recently applied the ol cl fix to my stage 2 setup and wow knock is almost 96% better/gone |
Groans: 90
| Not Ranked : 0 score Huh?
Groans: 70
| Not Ranked : 0 score open loop/ closed loop makes it go open loop faster. http://www.mazdaspeedforum.org/forum/foru...op-tables.html |
Groans: 90
![]() | | #24 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score I just got my Denso ITV 22 plugs, they appear to be gapped to 0.028 with one at 0.030 so I tightened that one up to 0.028 also. I will be running an ATR modified Stage 1+ map. Cobb says: "Our data has shown that the factory spark plug temperature range (6) and gap (~.034”) are sufficient for stock boost levels and normal driving conditions. Although, operating the car with higher than stock boost levels or with the calibrations that are on the AccessPORT, require that a spark plug gap of .026” - .028” (6.6 – 7.1mm) be used on a 1-step colder temperature plug. Denso currently offers this spark plug as part # ITV22 (please be sure to verify each plug is properly gapped before installing them). Our experience has shown that operating your turbo-charged engine at higher than stock boost levels requires that your spark plugs be replaced at around 15,000 mile intervals." So what gap are you guys running the Denso ITV22 at?? Give answer as gap, and map you run.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Has anyone ran the copper plugs listed in the op? Been looking for a 1 step colder copper plug, but did not think they existed for the mazdaspeeds until I saw the ngks in the op but no comments on temp rating on them. |
![]() | | #26 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Display Modes | |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 74 | 08-02-2019 08:18 AM |
| Spark Plug Database - Gen2 | Haltech | 2010 MS3 - Engine, Transmission & Driveline | 23 | 09-27-2017 05:09 PM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 6 - Engine, Transmission & Driveline | 41 | 05-05-2016 08:49 AM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 205 | 09-22-2015 06:52 PM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline | 95 | 09-19-2012 02:11 PM |
