 Old 02-18-2010, 03:11 PM   #401
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
87% is full throttle the way we code it into the ECU. You are set!!
www.cp-e.com is offline
 Old 02-19-2010, 11:42 PM   #402
Domino81's Avatar
Posts: 5,081   (View Stats)
Subscribed.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Domino81 is offline
 Old 02-19-2010, 11:48 PM   #403
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Originally Posted by FearUndersteer View Post
I am considering getting this flash soon, what are your impressions?
+1 Any info would be great.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline
 Old 02-20-2010, 10:17 AM   #404
sleeper329's Avatar
Posts: 511   (View Stats)
sleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the world
I pulled these dynos from CP-E's website:
If you search around here and the other forums you'll find some reviews. I want to get it but am waiting b/c im hoping by next year to go BT and will need the XL flash. dont want to do this twice.
^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^
sleeper329 is offline
 Old 03-14-2010, 01:31 PM   #405
nesiospeed's Avatar
Posts: 29   (View Stats)
nesiospeed will become famous soon enough
Smile I NEED SOME HELP WITH THIS LOG...
HI GUYS , IM NEW IN THIS WITH THE STANDBACK , I DID A LOG ON 3RD GEAR WITH THE PRIMARY MAP ON THE STANDBACK, MY MODS ARE :
STANDBACK , CP-E FULL CONTROL FLASH , CAI INJEN, TURBOBACK 3" , AEM WATER METH INJ KIT, BOOST TUBES SILICONE, LAUNCH CONTROL, REAR ENGINE MOUNTH , OIL CATCH CAN, NGK ONE STEP COLDER. ( CDFP STOCK , BOV STOCK ),
IF SOMEBODY CAN HELP ME UP TO MAKE A TUNE FOR THIS MODS I PRECIATE SO MUCH,
I NEED AN AGGRESSIVE TUNE FOR 1/4 MILE .
THANKS!!!
nesiospeed is offline
 Old 03-14-2010, 01:35 PM   #406
nesiospeed's Avatar
Default I FORGOT SOMETHING..
SORRY I FORGOT TO TELL YOU I LIVE IN CANCUN CITY , WE ARE AT THE SEA LEVEL...
I THINK THIS IS IMPORTANT TO BUILD A TUNE ON THIS PLACE . THANKS!!
 Old 03-14-2010, 01:48 PM   #407
FearUndersteer's Avatar
Posts: 189   (View Stats)
FearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the world
First of all please don't type in all caps. It would be helpful to put the cursor ( the red line on the graph) into the relevant area to help us read what you have. Also please post you base tune screen shots from the standback so we can see what were working with.
Looking at the graph you AFR seems to be settling at about 13+ which I think is much leaner than you want to be(atleast for safety sake). I would add fuel incrementally until you AFR is below 12. Fortunately I see no knock in this graph. After your AFR is safer you can add timing slowly until up to the point where you see knock to get a bit more power.
What boost pressure are you running?
2009 MazdaSpeed3 | True Red
35% Tint
CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC
FearUndersteer is offline
 Old 03-14-2010, 02:32 PM   #408
nesiospeed's Avatar
HI FEARUNDERSTEER!! THANKS FOR YOUR SOON REPLY!!
I USED THE PRIMARY MAP WHICH IS SET TO 15 PSI AND BOOST CLIP AT 13 PSI,ALL TIMING TABLES ARE CERO VALUES , MAF TABLES CERO TOO , I ONLY RUN THE FIRST MAP ONTHE STANDBACK..BEFORE THIS I WAS USING A MBC SET TO 20 PSI WITH THE FCD AT ATP ,AND THE CAR WAS AT 10,5 AFR WITH METH .
DO I NEED TO SETUP AT 20 PSI THE STANDBACK ?
AND THE BOOST CLIP HOW MANY PSI?
AFTER THAT DO I NEED TO DO A LOG ON 3RD GEAR TO SEE HOW IS THE CAR RUNNING??
SORRY MAN IM CONFUSED...
File Type: png BASE MAP AT 15 PSI (STOCK ) BOOST CLIP TO 13 PSI.png (134.8 KB, 0 views)
 Old 03-14-2010, 03:05 PM   #409
nesiospeed's Avatar
Default sorry about the caps.
 Old 03-15-2010, 04:52 AM   #410
sleeper329's Avatar
The psi the SB is at is fine to start. once you get the AFR down you could add a lb or two and retune the AFR.
The boost clip is simply the most psi the SB will tell your car its getting. Mine is still stock so its clip is at 13, despite the fact the SB comes tuned to 15psi my dashhawk will only read 12.9, you can raise the clip to say 16, and the DH should read the full 15 coming from the car. The reason they do this though is that some ppl have fueal cut issues if they raise the boost too much.
 Old 03-27-2010, 12:30 PM   #411
pekka83's Avatar
Posts: 26   (View Stats)
pekka83 will become famous soon enough
Hi! Can someone help me with SB-tuner. I installed SB today for my car and that was very easy but now I have problems with the program v2.59. When I start the program everything works great.
But when I hook up SB to my laptop with USB-cable the program crashes everytime. I have tried two different cables for every USB-ports and still crashing.
I have framework 3.5 and I have Windows XP. I have also tried to update drivers but it says that there's no better available.
Program works great with my table computer but I would like it to work rather with my laptop. Has anyone had same kind of problem?
pekka83 is offline
 Old 03-29-2010, 05:00 AM   #412
sleeper329's Avatar
Idk how to fix it on the laptop really but i do know you can unplug the SB from your car and take it in to your desktop and the USB will power it to connect to the software...
Try getting in touch with CPE. Lou knows his stuff about the SB and might be able to help with the laptop.
 Old 03-29-2010, 12:30 PM   #413
pekka83's Avatar
I've mailed to CPE, but they are quite busy and reply takes some time so I tried if someone here have been the same problem than me. Maybe the problem is with my USB ports because they are only 1.1 on my 5 year old laptop, but I'll wait what CPE says about my problem.
pekka83 is offline
 Old 03-29-2010, 12:48 PM   #414
Are the ports on your desktop 2.0?
 Old 03-30-2010, 12:12 AM   #415
sleeper329's Avatar
I've found if you can call them its usually easier. They've always been good to deal with and im sure can help you out.
Did you try a search on the forum? ive seen a few threads, one by me even, about getting the SB and DH to run right on and vista.
Also on the laptop are you logged in as a full administrator? windows sometimes gives you a hard time if you arent...
 Old 03-30-2010, 02:54 AM   #416
pekka83's Avatar
I'm not so good in English that I could call them. Mailing is better and I don't have any complainings about CPE service. I just meant that like any other company sometimes reply to the mail can take some time.
I'll try to first update my USB ports to 2.0 if its possible. But if someone have also older computer and have update ports to 2.0, could try to erase them and try with 1.1 if the program works. I don't want to buy new parts or new laptop if USB aren't the problem. I can't understand why this program would need so high data transfer. I have also tried USB TV tuner and that works well. I think that would need much higher data transfer than this program.
But I'll keep trying...
pekka83 is offline
 Old 03-30-2010, 03:13 AM   #417
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
SpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the world
Groans: 778
where u from
2003 SilverStone Grey Honduh S2000
SpeedSixxx is offline
 Old 03-30-2010, 04:45 AM   #418
pekka83's Avatar
I'm from Finland
pekka83 is offline
 Old 03-30-2010, 07:18 AM   #419
sleeper329's Avatar
ITs probably going to be hard to update a laptops usb ports... the internal cards are usually built with the laptop they are going into in mind. Or at least thats always been my understanding.
 Old 03-30-2010, 07:23 AM   #420
pekka83's Avatar
What do you mean by that? I put printscreen on my USB controllers. I think I have USB 2.0?
Also I put the picture about the error what Windows says always when I hook up the SB to the laptop.
File Type: bmp USB.bmp (0, 0 views)
File Type: bmp Vika.bmp (0, 0 views)
pekka83 is offline
 Old 03-30-2010, 07:33 AM   #421
pekka83's Avatar
I think that PCMCIA USB 2.0 reader card could solve the problem if I have only USB 1.1, but like I put my previous message I believe that I have USB 2.0. And I would like wait and hear what CPE says about the USB. Do I need the USB 2.0 to use the program? I put dorlov@cp-e.com mail about this situation two days ago. He/She should be an expert about computers but haven't hear nothing yet.
pekka83 is offline
 Old 03-30-2010, 09:06 AM   #422
sleeper329's Avatar
The person ive always dealt with for the SB related stuff is lou. IDK if he has a seperate email but id try to get a hold of him. Just email sales@cp-e.com and have them get you his email i guess...
 Old 03-30-2010, 09:33 AM   #423
pekka83's Avatar
First I put CP-E tuning box my mail and jhershorin@cp-e.com (I don't know the name only address because they don't have signatures on their emails) answer to me and told me to contact dorlov@cp-e.com. I'll think that they at least now know my problem and maybe are trying to think what might be the problem and then contact to me.
I'll have to try to change my table computer USB ports back to 1.1. That computer is also couple years old. I remember that first there was only USB 1.1 and then I updated those to 2.0.
SB even with zero maps are so awesome that I can't wait until I can tune my car.
pekka83 is offline
 Old 03-30-2010, 04:54 PM   #424
SpeedSixxx's Avatar
Groans: 778
Hyvää päivää, Mitä kuuluu?
Mikä sinun nimesi on?
Nimeni on Eric
En puhu suomea. but i'm learning
Onko teillä vapaita huoneita? I want to visit Suomi.
 Old 03-30-2010, 05:07 PM   #425
sleeper329's Avatar
Nimeni on Eric
Como se dice?
 Old 03-30-2010, 05:10 PM   #426
SpeedSixxx's Avatar
Groans: 778
Como se dice?
it's Finnish dude.
I been teaching myself for a while now.
no espanol TY.
only languages I'm interested in right now and teaching myself are
Finnish, German and Japanese.
after I master these 3 I'll move on to French or something else..
FUCK, i'm a retard...My step sister is brazilian and I can easily learn Portuguese...
BUT, eh they all sound like retards even worse then Mexicans. so NO TY
 Old 03-31-2010, 05:44 PM   #427
sleeper329's Avatar
yea ive picked up a little spanish and polish from working on construction sites. Never really wanted to learn either though.
 Old 05-16-2010, 03:23 AM   #428
vicamps6's Avatar
Posts: 7   (View Stats)
vicamps6 is an unknown quantity at this point
Hi all, I'm new on the forum and a recent 05 mps6 owner. Performance mods are CS FMIC, cat bak 3inch, Standback, PNP.
I have read the majority if this thread. Attached is my recording in 3rd gear, Can anyone give me there thoughts on it.
vicamps6 is offline
 Old 05-16-2010, 05:38 AM   #429
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Default "Standback Tuning For Dummies Guide" The Official Q&A...
I don't see the log. I would love to help though. NM I see it.
Alright well you can't do much tuning without a dashhawk. We need to see afr. Also is your target boost 20psi? With stock turbo the most I would do is 17. Do you have an upgraded fuel pump or stock?
2012 WRX HB w/mudflaps yo!
spnkr21 is offline
 Old 05-17-2010, 03:09 AM   #430
vicamps6's Avatar
No I don't have a dashhawk. Yes stock turbo, standard fuel pump and yes it was set at 20psi for that run. I usually run 14psi on one map (for everyday) and 18 on another map.
vicamps6 is offline
 Old 05-17-2010, 05:05 AM   #431
spnkr21's Avatar
Groans: 105
Well you're fuel pump is holding but it dips way down. You could take some stress off it if we lean the car out but you don't have a dashhawk so we can't. Also don't run 20psi on stock turbo I would stick with 17 tops. You can get some more power out of that car but you need to buy a dashhawk first.
spnkr21 is offline
 Old 05-18-2010, 05:05 AM   #432
vicamps6's Avatar
ok - all points noted, thanks for the help.
vicamps6 is offline
 Old 05-26-2010, 02:34 PM   #433
GregScuba's Avatar
Posts: 96   (View Stats)
GregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the world
great thread. sub'd.
GregScuba is offline
 Old 05-29-2010, 09:08 PM   #434
RacingToaster's Avatar
Posts: 426   (View Stats)
RacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the world
Groans: 40
CP-E i need to know if the software is the same for all platforms or not. I got the disc it has the label for the MS3 but the installation file is labeled for BMW, also how do I get instructions for the MS6?
RacingToaster is offline
 Old 06-01-2010, 05:26 AM   #435
Email me at jhershorin@cp-e.com and I will send you the proper software. What instructions are you looking for? How to install? Or how to tune?
 Old 11-25-2010, 09:42 PM   #436
theo's Avatar
Posts: 53   (View Stats)
theo is a name known to alltheo is a name known to alltheo is a name known to alltheo is a name known to alltheo is a name known to alltheo is a name known to all
Default Dashhawk Kr parameters
Hi i dont know if i am just stupid but i cant see the parameter for kr is it under something else?
theo is offline
 Old 11-25-2010, 09:47 PM   #437
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
sb cant monitor kr along with many other parameters. You need a dashhawk or dashdak to monitor and log all parameters, thats if you have a gen1. if you have a gen2 there is no way to monitor kr or afr unless you get an aftermarket wideband/gauge . Hope this helps you.
Now go donate to the forum please.
NJSPEED3 is offline
 Old 11-28-2010, 12:46 AM   #438
theo's Avatar
Default Help with Standback tuning
Hi Guys
I need some help with the tuning on my standback please.Mods are 76mm full cat back exh,cai,d/pipe,dashhawk,fmic,gt35 turbo,8.8 comp arias pistons and pauter rods.I did a log on the dashhawk,everything is still on zere on the standback.It is a mazdaspeed 3 or here we call it the mps 2007 model
theo is offline
 Old 11-28-2010, 02:49 AM   #439
theo's Avatar
Thanks for the reply yes i do have a dashhawk.i did a log and placed it,I get a spike on full load it is like a cut and i see on the kr it spikes.but i am not a expert on these things and nobody in South Africa are willing to give me a propper tune
theo is offline
 Old 11-28-2010, 08:12 AM   #440
spnkr21's Avatar
Groans: 105
Do a log using these parameters on the dashhawk: rpm, afr, timing, knock, and boosted air temp
spnkr21 is offline
"Standback Tuning For Dummies Guide" The Official Q&A... AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 929 06-19-2012 10:07 AM
Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" Haltech Automotive News 0 10-20-2011 02:20 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
Automotive Traveler offers "Car photography for dummies" Haltech Automotive News 0 06-28-2008 03:50 PM
Page generated in 0.60871 seconds with 34 queries
