 Old 07-12-2011, 04:43 PM   #881
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
Its not beneficial to do anything different than normal tuning practices. The most important and basic aspect of tuning timing is to pull timing at peak TQ and ramp it back in appropriately.
-JEWBERT
jhershorin is offline
 Old 07-12-2011, 09:07 PM   #882
Mfinlay04's Avatar
Posts: 827   (View Stats)
Thanks for the clarification...
If you have the time I have uploaded a few more data logs that I worked on today. Any input would be greatly appreciated
Mfinlay04 is offline
 Old 07-17-2011, 05:40 PM   #883
Joellc2434's Avatar
Posts: 232   (View Stats)
Joellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to behold
Originally Posted by Mfinlay04 View Post
seems everyone else has jumped ship to Cobb.
I'm still here also. Looks like we started trying to tune our cars a little late in the game. Ive been getting a little help here and there also. Exchanged a couple emails with Sander at cp-e. Seems to be willing to help with some e-tuning. I haven't even gotten a chance to start playing with timing yet. Fell my AFR's are about in line but I disconnected by battery the other day and this time it took about 130 miles to get fuel trims to start showing up. But instead of getting any help from the forums I just got bashed by people who hate cp-e.
Good luck to both of us?
2007 Mazdaspeed 3 GT: Cobb AP running stage 2+ 91 oct. w/ 3.5 gallons E85, cp-e Xcel CAI, cp-e FMIC, cp-e injector seals, Dashhawk 2 w/ cp-e mount, cp-e side engine mounts, Magnaflow CBE, M2 (ebay) Downpipe, TRZ Dogbone RMM, Denso ITV 22's, SURE Sidewinder TIP, SURE Return, SURE Intake Plenum and Throttle Body TIGs, SURE Shortcut and Countershift, SURE Anchors, KMD HPFP Internals, PNP'd Intake manifold and Throttle Body by Grimmspeed
Working on my Tune
In garage: New exhaust Mani
Joellc2434 is offline
 Old 07-17-2011, 10:29 PM   #884
Mfinlay04's Avatar
Yeah, and honestly I've been quiet disappointed with the customer service of cp-e. you always hear great things however I've had many bad experiences just in the short time i have had my standback. Although they did replace my used standback for free so can;t complain there not too many companies offer true lifetime warranties... But phone calls get lost and NO ONE calls you back, and emails go days without a response. I mean if the guys are going to be outta the office, NP but set up a "out of the office" auto email just so I'm not waiting for days for a response. Simple things like that seem to piss me off.
Anyways, I have been tuning a lot by myself and think I've got the concept down for the most post. Want to get it tweaked and then send it over to Sander for any addition advice comments etc...
 Old 07-22-2011, 02:22 PM   #885
wankular's Avatar
Posts: 4,343   (View Stats)
Has anyone used the ProFuel controller? I'm going to be using it with a DO stage one and was wondering what the meth chart should look like. My peak boost is 17 psi and I was thinking to have it start at 50% at 5 psi and 100% by 13-14 psi.
2009 MS3 sport MGM
wankular is offline
 Old 07-25-2011, 03:17 PM   #886
Mfinlay04's Avatar
Played with my settings some more in the standback to get the AFR all straightened out and did a pull the other night, Pretty happy so far just need to fine tweak all the numbers to get 11.3-11.5 AFR. Let me know what you guys think.
Ps. This is a 3rd to 4th gear pull
 Old 07-25-2011, 03:42 PM   #887
SilverDemon's Avatar
Posts: 3,034   (View Stats)
You guys are not alone, I am running the SB with a BT and built motor, with a custom intake manifold. I have the pro fuel controller, and I am using to control AEM w/m kit. Everything works flawless, and very easy to adjust flow requirements.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
SilverDemon is offline
 Old 08-05-2011, 02:08 AM   #888
mike000g's Avatar
Posts: 241   (View Stats)
mike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
can someone tell me what does ecu side and harness side means on the instructions on the cpe standback hardwire.I KNOW THERE DIVIDED INTO HARNESS 1 AND 2,BUT WHY IS IT SPECIFIED HARNESS SIDE AND ECU,CAN SOMEONE PLEASE CLARIFY,AND ALSO IS THE MAP REQUIRED TO GET THE STANDBACK RUNNING? THIS FOR ME heres and example
1 GRAY BLACK / WHITE STRIPE HARNESS side 2AA
2 WHITE (Gray Jacket Cluster) N/A Attached to Map Switch N/A Attached to Map Switch
3 RED (Gray Jacket Cluster) N/A Attached to LED N/A Attached to LED
4 BLACK (Gray Jacket Cluster) N/A Attached to LED N/A Attached to LED
N/A GREEN (Ring Terminal) N/A Attach to chassis ground N/A Attach to chassis ground
5 WHITE / BLACK STRIPE WHITE / RED STRIPE HARNESS side of 1AK
6 WHITE / BROWN STRIPE WHITE / GREEN STRIPE HARNESS side of 2R
7 BROWN WHITE / PURPLE STRIPE cp-e™ Injector Box. (COMING SOON)
8 ORANGE WHITE / RED STRIPE ECU side of pin 2W
9 BLACK BLACK 1BG
10 RED GREEN / ORANGE 1BE
mike000g is offline
 Old 08-05-2011, 05:33 AM   #889
If I understand you correctly, harness side dictates the wire on the SB plug, and ECU side is the wire that is on the car.
There does not need to be a map a switch hooked up to make the car run. it will just run off the primary map. Nothing needs to be changed in the actual map to make the car run. Once all the wiring is done, the car should fire up and run.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-05-2011, 08:32 AM   #890
mike000g's Avatar
But why would they have ecu and harness side but then again its labeling the actual ecu pins.I did the hardwaire on the car by soldering directly to the ecu wires.when I plug in the standback the car doesn't crank.when I unplug the standback the car starts.is this due to the map settings?when I plug into the pc the parimeters show everything on zero except the boost which is set to 15.6,if this is wrong where would I obtain the base map?
mike000g is offline
 Old 08-05-2011, 08:38 AM   #891
The map zeroed out is fine, the car will run with everything zereod out.
I am not sure why they label it like that.
So, with the bypass plug installed, the car starts and runs fine, but when the SB is plugged in the car will not even crank? If that is the case, then the SB has an issue.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-05-2011, 10:52 AM   #892
mike000g's Avatar
Well when connecting the bypass the car works perfectly fine assuming the the grey wire hanging from the bypass has nothing to do with a hardwire.but would it work on the computer but not function a car?
mike000g is offline
 Old 08-05-2011, 11:09 AM   #893
possibly... it could function fine on the software side of things but could keep it from operating the car.... CP-E can test it for a small fee, if you bought it used. If you bought it new then deff. send it to them.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-05-2011, 05:15 PM   #894
mike000g's Avatar
thanks im gonna look into it,by any chance can they repair it?
mike000g is offline
 Old 08-05-2011, 07:50 PM   #895
Yeah, I am sure they can either repair it or tell you what it needs.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 08-06-2011, 02:10 PM   #896
mike000g's Avatar
thanks
mike000g is offline
 Old 08-07-2011, 10:21 PM   #897
Mfinlay04's Avatar
Same issue with mine, bought it used off a N/A guy hardwired it in and didn't crank with the SB plugged in. Sent sales an email explained what happened after a few trials of things they had me send the unit in. Needless to say they sent me a new unit and all has worked great.
A little late on the wiring question,
ECU side is the wire connected to the ecu
harness side is the side coming outta the firewall or from the wiring harness from the motor
[ECU]------ECU Side---[standback]----harness side----- Motor and Sensors
Hope this helps
 Old 08-09-2011, 06:20 PM   #898
mike000g's Avatar
''when your saying the firewall i need to attach wires there????
mike000g is offline
 Old 08-10-2011, 09:25 PM   #899
Mfinlay04's Avatar
Do you have a MS3 or MS6?
 Old 08-11-2011, 08:53 AM   #900
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
you need to ground the wire that comes off the toggle switch.
mine wouldn't start without grounding the switch wire.
Rich-PMS is offline
 Old 08-11-2011, 11:57 AM   #901
mike000g's Avatar
mine car is a ms3.
@Rich-PMS what toggle switch if you are refferingto the map switch i am not running one
mike000g is offline
 Old 08-11-2011, 12:36 PM   #902
Rich-PMS's Avatar
Groans: 68
mine car is a ms3.
yes- the map switch.
Rich-PMS is offline
 Old 08-11-2011, 08:06 PM   #903
mike000g's Avatar
Ok cool so I should look for that ground and see if it works,when I used the standback bypass I saw my dashhawk had cel saying malfunction crank postion sensor a.
mike000g is offline
 Old 08-13-2011, 10:44 PM   #904
Mfinlay04's Avatar
mine car is a ms3.
disregard the firewall statement as that would be more for the MS6.
 Old 08-14-2011, 09:10 PM   #905
mike000g's Avatar
i might just skip all this and buy the pnp harness
mike000g is offline
 Old 08-14-2011, 09:25 PM   #906
Rich-PMS's Avatar
Groans: 68
I got my PNP harness with standback for 225 shipped from the classifieds here.
There'd s few people on here selling their standback and PNP harness, should shoot them a PM and see if they'll seperate. Or you can spend the $250 and get both. It'll still be cheaper than buying a new PNP harness from cpe
Rich-PMS is offline
 Old 09-03-2011, 11:28 AM   #907
mike000g's Avatar
update on my standback,i sent it in to cpe,turns out there was an issue with sb.so they are replacing it with a new one.
mike000g is offline
 Old 11-01-2011, 05:52 PM   #908
acejm25's Avatar
Posts: 9   (View Stats)
acejm25 will become famous soon enough
Hey, I know no one has posted here for a while, but, I am looking for a bit of information. When I try to read the charts from my standback I am getting numbers that make no sense. Anyone else have this problem?
acejm25 is offline
 Old 11-02-2011, 12:07 AM   #909
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Get a clean map and resend the data. You never want maps to look odd. If they keep reading odd, despite sending clean data, may be a bad SB.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline
 Old 11-10-2011, 05:16 PM   #910
mike000g's Avatar
i just hooked up mine,and to me it seems foreign.im still new to this.if you need a base map i have for the ms3 1st gen.
mike000g is offline
 Old 11-16-2011, 03:11 PM   #911
Lost hawaiian's Avatar
Posts: 226   (View Stats)
Lost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the world
I am new to this too. Does anyone have a map for a 6.
Sent from my SCH-I510 using Tapatalk
Lost looking to build a fast way back to the islands!!
Lost hawaiian is offline
 Old 11-16-2011, 06:47 PM   #912
Honestly off the shelf maps are not the way to go. Start empty, calibrate MAF (Maf Transfer), Set AFR, Up boost, adjust timing, and eventually buy an AP when your mods get too much.
 Old 11-16-2011, 08:00 PM   #913
Matt is correct, do not use the OTS map on the SB, start with a zeroed map, and start working on it.
The SB is still capable making big power.....Ran out of waste gate spring pressure at about 26 psi (I was only using a 15 pound spring) Another 5 - 7 psi and 500 would have been right there...
450 hp
370 trq
EDIT: I dialed the AFR's on the street, and worked on the timing on a 1 hour dyno rental. There is a slight dip in the torque around the 5500 rpm mark, but that was from over looking the cells in that area, I need to bump the timing in that area by a degree or so to bring it back up...
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 11-19-2011, 03:12 PM   #914
MazdaSpeed Six's Avatar
Posts: 10   (View Stats)
MazdaSpeed Six is an unknown quantity at this point
Hey guys.
Ive had my MazdaSpeed 6 for almost a year now, and got a standback and a pnp harness. I read up on it a little, but it seemed like it was mostly for people with more/a lot of mods than the beginning modder.
After searching around, I see that CPE isnt really interested in customer service with it any more. Is that right or did I just read the wrong thread(s)? Seems from what Ive read there are more unsatisfied people with standbacks than satisfied ones.
Can you guys lmk in a nutshell, what the issues are/have been? Is it just issues for guys that are heavily modded or does it affect all users.
I only have a MazdaSpeed cai installed currently with a TIP ordered. I may do a few other small mods, but am unsure if I will be doing a TMIC or FMIC unless I can find a reasonably priced one that works well. I have picked up a set of Denso itv 22's, but havent installed them yet.
I am wondering if I should bother with trying to install/use it for my mild mods or if it would be of use to me at all. Or maybe if I can find a buyer, I should sell it and buy a Cobb? But I would prefer to use this if I could benefit it. Maybe use that money for other mods instead.
2006 MazdaSpeed 6 GT w/Nav Whitewater Pearl
MazdaSpeed Six is offline
 Old 11-19-2011, 06:01 PM   #915
I think it is perfect for you at your mod level. Its will up your boost, dial in your AFR's and overall make it drive much better. In my experiance it is once you start pushing the mods to the max, then the SB's issues come out. Some have had good luck though with it even on a heavily modified car, I just didn't. If you get a SB for a great price then I say use it. If it costs you more than an AP, then just get an AP as it has more potential in the long run.
 Old 11-19-2011, 08:34 PM   #916
I already have it, so, I would have to find a buyer, which from what ive read, will be pretty hard, then put up more money to get a AP. I have the standback and pnp in hand, BUT, I guess it has an old version of software. I called them and they said they would flash or reprogram it to the latest software for $75. I was just wondering if I should put the $75 in if it was going to really work for me or not.
Could you be specific on what the mods to the max would be where the issues are or come about? Examples? That way, I can think/decide if I would ever make it to that point or even close.
Thanks for the info.
 Old 11-19-2011, 08:52 PM   #917
How is the ease of use of the standback? Is it complicated or simple? Wheres the best place to get that kind of info? That way, I can get an idea and see if I can get comfortable with it. Ive read the product description, but that doesnt really tell me what Im looking for.
I really dont know anything about using it or how it works. Do I use a laptop to program/access everything? Are there programed/maps for certain "tunes" like mpg? Performance? etc?
 Old 11-20-2011, 08:59 AM   #918
This thread is your best resource. Read it from start to end and you will have more than enough info on all the pros and cons. The SB is very simple to work with. It really has 2-3 tables that you care about and thats it. Hook it up to your laptop via USB, open the SB software, edit the tune, and write it to the SB. Just start off with a zereod out map and take it slow and steady until you understand what you are doing.
Read this thread (its not terribly long) and then get back to us. You will learn alot from the first 5 pages alone.
 Old 06-08-2012, 04:00 PM   #919
Mfinlay04's Avatar
Alright so I'm having this issue lately and it's driving me crazy. I have tried changing everything I can think of without any success of killing this...
Here is a datalog in 3rd gear at 15psi
Here is a datalog in 3rd gear at 18psi
And here is a 4th gear pull at 18psi.
I keep getting this little blips in the log and what feel like harsh backfiring when driving. I've just installed new spark plugs properly gapped, did the spring stretch thinking it was spark blow out. Nothing is helping except lowering the boost. Only thing left that I can think of is maybe the clutch is giving out and with the increased boost > increased TQ it's causing it to slip and that is what I'm seeing... Anyone else ever have this?
 Old 06-08-2012, 05:18 PM   #920
I had similar issues and it was always spark plug related. ITV22 at .026 is about what I use. I end up changing them every 10k or so.
"Standback Tuning For Dummies Guide" The Official Q&A... AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 929 06-19-2012 10:07 AM
Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" Haltech Automotive News 0 10-20-2011 02:20 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
Automotive Traveler offers "Car photography for dummies" Haltech Automotive News 0 06-28-2008 03:50 PM
Page generated in 0.62232 seconds with 31 queries
