Like Tree3Likes
 Old 02-14-2013, 02:52 AM   #41
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I ran this on my new Mazda maf sensor (finally got tired of reman inconsistencies). The curve looks beautiful, I can't wait to load it up and take it for a spin.
Just an FYI for any dummies out there like me, when @TiGraySpeed6; provided his excel example and included =J2*I2^K2 where J = base, I = MAF volts from ATR, and K2 = power, this equation has to be entered exactly this way in Excel or the computation is wrong. I was doing I2*J2^K2 and my numbers were wrong (of course because its the base to power).
Use a row of @TiGraySpeed6;'s and/or @rfinkle2;'s data to verify the equation and numbers in your own spreadsheet as a check before running your own data, i.e. run a row of their data in your equation and make sure the numbers match theirs. I did this to figure out what I did wrong.
MINI H1 6.0 - CAR LED TAILS
dale_gribble is offline
Mistersix (01-24-2014), Pointless (10-14-2013), rfinkle2 (10-27-2013)
 Old 02-14-2013, 03:00 AM   #42
I'll make a thread about it maybe, but I found the reman had poorer granularity and flat spots in its response through the voltage range. Even on my initial comparisons, the Mazda OEM MAF responds more linearly across its response range and even has better voltage range response given the same airflow. Of course I don't flow any more, but now the sensor responds from 0-4.3v whereas the reman only responded from 0-4.1v in my car. Doesn't sound like much but this gives more granularity in the MAF sensor calibration table and will probably give me a much flatter AFR curve.
rfinkle2 (10-27-2013), rob ms6gt (11-27-2013)
 Old 02-15-2013, 10:59 AM   #43
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
.2 is still like about 4.88 percent....
Plenty of error/room to screw things up.
CosmicArkie is offline
 Old 02-15-2013, 11:11 AM   #44
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
This should be added to the KB and stickied. @Raider;
sidekick is offline
 Old 02-15-2013, 11:24 AM   #45
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Good question. I know DJ asked David about the maximum amounts of trim allowed and those tables to be exposed, but I haven't heard anything else about it.
Still in the testing/experimental stage to make sure we have all the controls you need before letting it go out.
-David@COBB
Cobb Tuning is offline
 Old 02-15-2013, 11:52 AM   #46
Discuss here
Using Excel to dial in your maf curve (meth users, perfectionists, etc.) - Mazdaspeed Forums
Raider is offline
rfinkle2 (02-15-2013), VulgarKyle (07-16-2013)
Using Excel to dial in your maf curve (meth users, perfectionists, etc.) rfinkle2 2010 MS3 - ECU Computer Tuning 1005 07-14-2018 10:06 AM
Trying to dial in this tune Guerra88 2010 MS3 - ECU Computer Tuning 23 05-24-2012 10:50 PM
Help me dial in my 3076. :) dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 63 09-04-2011 09:45 AM
cpe stand back users and meth phillyb MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 14 04-24-2009 12:06 PM
Page generated in 0.27389 seconds with 25 queries
