 Old 12-27-2011, 09:33 PM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Default The Motor Mount Thread
*****Thank you to @Inquisitive; for a 2015 update!******
This thread will be for discussion of motor mounts for the MS3 & MS6. All currently available mounts are listed, relative prices, & links where they can be purchased. Note: you may be able to find them for sale elsewhere, possibly for cheaper. I simply linked them to their own company's site. If you have any questions regarding mounts, want to know which duro is best for you, etc, read thru this thread first! IF and ONLY IF it has not been answered already in this thread, post your new question in this thread. Do NOT create a new one.
Most of these if you buy brand new will come with installation instructions, but if you buy used and can't figure it out, or simply want to plan ahead, How-To's may be found in here:
MS3 How-To Database
MS6 How-To Database
One of the first mods almost everybody does is the Rear Motor Mount (RMM). As well you should. The factory bushings are mediocre and allow too much movement. There is a small amount of drivetrain slop and shifting may feel a bit notchy. Upgrading the RMM stiffens up the drivetrain slop quite a bit allowing for smoother shifting for one. The Passenger Side Motor Mount (PMM) & Transmission Mount (TM) are mediocre and are big eye sores to boot. Upgrading the mounts allows for much better shifting response and handling as the engine isn't rocking or being tossed around in the bay, but it comes at the expense of some NVH. Vibrations are felt at idle, tho this can be remedied by raising idle RPM if you have an AP. Vibrations often lessen after several months/several hundred miles of breaking in.
Genpu MMs:
• JBR RMM 88 & unknown durometer
• CP-E RMM Stage 2
• JBR TMM unknown
• CorkSport RMM
• JBR PMM unknown
• JBR RMM 80
• Sure RMM TorqR3 WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
• JBR PMM 80
• JBR RMM 70
• Cobb RMM
• CorkSport TMM
• Damond Motorsports RMM
• JBR PMM 70 & 88
• CP-E TMM
• TRZ RMM
• CorkSport PMM
• Street Unit RMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
• Ford Electric Focus RMM (RMM part number CM5Z-6068-A; bolt W500545S900)
• Minerva PMM & TMM (probably best to avoid, see Minerva Motorwerkz? )
• Sure PMM & TMM WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
• AWR RMM 88
• Torque Solution RMM
• Turbine Tech Front Engine Mount
• Turbine Tech Differential Mount
Update using 2015 prices:
JBR RMM Urethane
MS6
MS3
Available from:
MS6
JBR RMM Urethane MS6
MS3
JBR RMM Urethane MS3
MS6 (Yes: 80a $105), MS3 1st Gen (Yes: 88a $100, 80a $125, 70a $125), MS3 2nd Gen (Yes: 88a $100, 80a $125, 70a $125)
CP-E RMM Stage 2 Rubber
MS6
MS3
Available from:
MS6
CP-E RMM Stage 2 Rubber MS6
MS3
CP-E RMM Stage 2 Rubber MS3
MS6 (Yes: 70a xFlex) $139, MS3 1st Gen (Not found), MS3 2nd Gen (Yes) $198
JBR TMM Urethane
MS6
MS3
Available from:
MS6
JBR TMM Urethane MS6
MS3
JBR TMM Urethane MS3
MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 88a, 80a, 70a) $185, MS3 2nd Gen (Yes: 88a, 80a, 70a) $185
CorkSport RMM Urethane
MS6's Insert
MS6's Full Replacement
MS3's Insert
MS3's Full Replacement
MS3's Race
Available from:
MS6
CorkSport RMM Urethane MS6
MS3
CorkSport RMM Urethane MS3 Gen1
CorkSport RMM Urethane MS3 Gen2
MS6 (Yes, Standard 70a) $115.99, MS3 1st Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99), MS3 2nd Gen (Yes: Insert 70a $39.99, Standard 80a $99.99, Race 80a $125.99)
JBR PMM Urethane
MS6
MS3
Available from:
MS6
JBR PMM Urethane MS6
MS3
JBR PMM Urethane MS3
MS6 (Yes: 80a, 70a) $175, MS3 1st Gen (Yes: 80a, 70a) $185, MS3 2nd Gen (Yes: 80a, 70a) $185
Cobb RMM
Available from: Cobb RMM MS3
MS6 (Not found), MS3 1st Gen (Yes) $159, MS3 2nd Gen (Yes) $159
CorkSport TMM Insert Polyurethane
MS6
MS3
Available from:
MS6
CorkSport TMM Insert Polyurethane MS6
MS3
CorkSport TMM Insert Polyurethane MS3
MS6 (Yes) $54.99, MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $39.99
Available from: Damond Motorsports RMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $145 in black or gold mount and black or red bushing
CP-E TMM
Available from: CP-E TMM MS3
MS6 (Not found), MS3 1st Gen (Yes, 75a) $271.30, MS3 2nd Gen (Yes, 75a) $271.30
TRZ RMM
Available from: TRZ RMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $100
CorkSport PMM
Available from: CorkSport PMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $229.99
Available from: local Ford dealership
MS6 (Not confirmed), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $43.92 + $1.10
AWR RMM Urethane
MS6
MS3
Available from:
MS6
AWR RMM Urethane MS6
MS3
AWR RMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $82, MS3 1st Gen (Yes: 95a, 80a, 70a) $95, MS3 2nd Gen (Yes: 95a, 80a, 70a) $95
AWR PMM Urethane
MS6
MS3
Available from:
MS6
AWR PMM Urethane MS6
MS3
AWR PMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $172, MS3 1st Gen (Yes: 95a, 80a, 70a) $172, MS3 2nd Gen (Yes: 95a, 80a, 70a) $172
AWR TMM Urethane
MS6
MS3
Available from:
MS6
AWR TMM Urethane MS6
MS3
AWR TMM Urethane MS3
MS6 (Yes: 95a, 80a, 70a) $140, MS3 1st Gen (Yes: 95a, 80a, 70a) $225, MS3 2nd Gen (Yes: 95a, 80a, 70a) $225
Torque Solution RMM Polyurethane
Available from: Torque Solution RMM Polyurethane MS3
MS6 (Not found), MS3 1st Gen (Yes, 75a) $134.99, MS3 2nd Gen (Yes, 75a) $134.99
TRZ TMM
Available from: TRZ TMM MS3
Damond Motorsports PMM
Available from:
Damond Motorsports PMM MS3
MS6 (Not found), MS3 1st Gen (Yes), MS3 2nd Gen (Yes) $225 in black or gold mount and black or red bushing
MS6
MS3 Gen 1
MS3 Gen 2
Available from:
MS6
Turbine Tech Front Engine Mount MS6
MS3 Gen 1
Turbine Tech Front Engine Mount MS3 Gen 1
MS3 Gen 2
Turbine Tech Front Engine Mount MS3 Gen 2
MS6 (Yes) $359, MS3 1st Gen (Yes) $399, MS3 2nd Gen (Yes) $379
Available from: Turbine Tech Differential Mount MS6
MS6 (Yes) $289, MS3 1st Gen (Not found), MS3 2nd Gen (Not found)
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline
The Following User Says Thank You to RhoadBlock For This Useful Post:
joemd (02-10-2018)
The Motor Mount Thread RhoadBlock MazdaSpeed 3 - Engine, Transmission & Driveline 341 06-30-2018 02:45 PM
Motor mount thread issue ziwang55 MazdaSpeed 3 - Engine, Transmission & Driveline 39 04-04-2012 06:29 PM
Page generated in 0.72882 seconds with 39 queries
