 Old 05-05-2012, 01:35 AM   #1
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Sorry for the noob question but is the cat in the downpipe the only cat on the car? If its not the only cat is it possible to pass emissions with a Catless dp?
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline
 Old 05-05-2012, 01:37 AM   #2
greatdane68's Avatar
Posts: 456   (View Stats)
greatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the world
Groaned at 45 Times in 22 Posts
It's not the only cat, and no, you can't pass emissions with a catless DP.
2010 Mazda Speed3
Autotech HPFP internals, Cobb AP V3, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP, Catted DP,
Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ruff Racing 355 wheels, 18x8, +40, 235/40-18 tires
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
2011 Dodge Challenger R/T
1997 Geo Prizm
greatdane68 is offline
 Old 05-13-2012, 01:52 PM   #3
gyoku2006@gmail.com's Avatar
Posts: 55   (View Stats)
gyoku2006@gmail.com has disabled reputation
good thread, very helpfull for when i get around to installing an exhaust system
gyoku2006@gmail.com is offline
 Old 05-14-2012, 06:42 PM   #4
VertigoM's Avatar
Posts: 27   (View Stats)
VertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of light
Who has the new catted CS downpipe? Does the divorced wastegate design have a significant benefit over a bellmouth design?
2010 CWP MS3
Cobb AP | Corksport SRI+TIP | Mangaflow Catback | Autotech Internals
VertigoM is offline
 Old 05-17-2012, 11:51 AM   #5
VertigoM's Avatar
Anyone?
2010 CWP MS3
VertigoM is offline
 Old 07-23-2012, 05:49 PM   #6
93silvergt's Avatar
Posts: 554   (View Stats)
93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world
Groaned at 18 Times in 11 Posts
Exhaust Downpipe Mazda 07 08 09 Mazdaspeed 3 Cat-less | eBay
Does this "m2 performance" have the secondary o2 bung extended to avoid a CEL? I can't see from the pictures
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline
 Old 09-19-2012, 01:29 PM   #7
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Yes you can, And no it doesn't.
Do you have a 1/2" drill bit? Order some spark-plug non-foulers and make the extender yourself. It's really simple and works like a charm.
Does anybody make a 3" v-band upper downpipe for the MS3? I haven't been able to find one. The old style UR DP looks like it was made for a 3" v-band but knowing UR they would most likely charge extra for a non-standard option. It doesn't look like the MS3 flange -> v-band adapter would work either because I'd be working with a very limited amount of space.
Speed3eak is offline
 Old 08-05-2012, 03:57 PM   #8
EddyV1987's Avatar
Posts: 7   (View Stats)
EddyV1987 is an unknown quantity at this point
Hey Guys quick question,
I have a MazdaSpeed 6 that has a Corksport racepipe and CBE. I'm looking into getting a downpipe but I can not use Corksports because they are Catless. With good ol Connecticut law I can not run catless. Will these other downpipes be compatible with what I'm running now? Will it make the car sound like Crap?
EddyV1987 is offline
 Old 08-05-2012, 04:05 PM   #9
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Just go catless and run a couple non-foulers on the second o2 sensor.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 08-05-2012, 07:11 PM   #10
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
it depends on how conneticut does emissions testing, visual, code scan, or sniffer, or all three?
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline
 Old 08-05-2012, 07:20 PM   #11
smoogs12's Avatar
Groans: 423
We only do a scan in CT.
If the tech is a reaaal dick he might visual check. But most give no fucks.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 08-05-2012, 07:30 PM   #12
chuckms6's Avatar
oh. then catless and delete code in ap. if they check system readiness then go with the o2 sensor spacer.
chuckms6 is offline
 Old 08-05-2012, 07:33 PM   #13
smoogs12's Avatar
Groans: 423
...if they check system readiness....
This they do. Dont go in after clearing codes or pulling power to the car. You will fail
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 08-05-2012, 07:35 PM   #14
chuckms6's Avatar
fersure lol. yea o2 spacer is the way to go.
chuckms6 is offline
 Old 09-19-2012, 09:55 PM   #15
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
@Raider.......this isn't a sticky anymore??
______________________
Built By NATOR
Tons of Ricer Mods
09Speed3Z is offline
 Old 09-20-2012, 05:58 AM   #16
Not sure whathappened, but it is fixed
Discuss::
http://www.mazdaspeedforum.org/forum/foru...-thread-99627/
Last edited by Raider; 09-20-2012 at 05:58 AM. Reason: MSF Database - Automerged Doublepost
Raider is offline
The Official Downpipe/Test Pipe/Race Pipe Thread MS3-a(sore)ASS-rex Mazdaspeed3/6 General Discussion 415 02-06-2020 08:55 PM
Page generated in 0.40453 seconds with 31 queries
