Mazdaspeed Forums
-   MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline (http://www.mazdaspeedforum.org/forum/forum/f629/)
-   -   Spark Plug Database - Colder Than Stock ( Stage 1&2 ) (http://www.mazdaspeedforum.org/forum/forum/f629/spark-plug-database-colder-than-stock-stage-125106/)
Haltech 05-19-2008 04:14 PM
This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread.
Mazdaspeed Forums Spark Plug Index Database
Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28
Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
Code:
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
  • Denso Iridium
  • itv-20 - Stock heat range
  • itv-22 - 1 stage colder heat range
  • itv-24 - 2 stage colder heat range
  • itv-27 - 3.5 stage colder heat range
  • HKS
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
  • NGK IX Iridium
  • NGK LTR7IX-11 (6510) - 1 Stage Colder Heat Range
  • NGK ILTR6A-8G (3787) - Stock Heat Range
  • Torque Master Spark Plugs
  • SVTP8BR Stock Heat Range
  • SVTP7YR 1 Stage Colder Heat Range
  • Autolite Iridium
  • Autolite Iridiums XP5364 - Stock Heatrange
  • Autolite Iridiums XP5263 - 1 Step Colder
NGK Copper Plugs
LZTR4A-11 (5306)
LZTR5A-13 (4306)
BKR7E
whoosh@Realtune 05-20-2008 04:58 AM
HKS has plugs available for the MS3/MS6 as well
I actaully have a set of the heat range 7 (1 step colder)
from the HKS-USA site:
BTW, I've also been running the NGK 6510's gapped @ .32 for almost a year now and they are great
Haltech 05-20-2008 05:26 AM
Thanks very much Whoosh!
speedster 3 10-04-2008 01:48 PM
so what would the best spark plugs be for just having TBE, CAI, and BOV?
phailerider 10-04-2008 01:53 PM
what are the ngks supposed to be gapped at stock... anybody know?
Laloosh 10-04-2008 02:03 PM
stock they come at something stupid like 42
phailerider 10-04-2008 02:31 PM
i dont think the ones on my car were ever gapped. ken just told me it isnt necessary unless the car doesnt run right...lol we'll see.
Speedy3 10-18-2008 08:04 PM
What is the torque setting for spark plugs?
Haltech 10-18-2008 08:06 PM
Twist in until it stops by hand using the extension of the ratchet.. than one 1/4 inch turn to secure. Be sure to use a dab of anti seize on the threads and a dab of di-electric grease on the top of the plug where the coil connects to.
bioevolve 10-26-2008 04:19 PM
Here is a good spark plug reading link. Someone rip the info from there and sticky it! Well for non-iridium types, but you kinda get the idea.
Spark Plugs
Phantom 11-18-2008 06:29 PM
I am guessing the .30 to .32 gapping is in mm?
ms6acton 11-22-2008 09:10 AM
i kno nothing about gap and what not, what plug would u guys reccommend just to make the motor run better? no mods yet
ptperformance 12-07-2008 06:06 AM
Quote:
Start at .038 and work your way down from there. We have found that on stock gap (.042) the NGK's seem to work very well with stock boosted applications. If you turn up the boost your going to want to knock that gap down a little bit. We have ran them as high as .038 at 21 psi on the stock turbo. I have yet to have blow out problems with the one range colder plugs.
ptperformance 12-07-2008 06:07 AM
Quote:
No, it should be .032 in inches.
zoom-zoomhatch 02-02-2009 11:00 PM
Has anyone tried just running a plain ole copper plug?
Haltech 02-03-2009 09:34 AM
Quote:
No one has sourced a copper plug compatible with these COPs yet.
Monstar 02-13-2009 12:59 PM
I just wanted to Throw this out there. I thew in a set of NGK 5610s last night and found that the stock plugs in my car (fomoco) were gapped at .030!!!!!!!!!!!!!!! Started the ngks at .038. I wondered what the deal was. I think stock was supposed to be around 40-42???? The car was only touched by mazda before I got it at 30k miles, its around 44k now. Input?????
It smoothed it out alot, still getting flames out the back between shifts though sometimes.... :evil:
phillyb 02-21-2009 02:32 PM
did you read anything in the first post?
Dash08 05-01-2009 08:38 AM
Should I switch to step colder plugs? What's the advantage?
How often should I be swapping plugs?
10,500 on the odometer.
Monkey_3 05-20-2009 11:45 PM
so...any advantages?
jmhinkle 05-21-2009 12:57 AM
I personally think it would be useful to post the gap issues with some plugs. For example, both the stock heat range Denso and one step colder NGK are both factory gapped at ~.045. That isn't correct for our motor and requires a funky bend on the ground electrode. They work, but are not ideal. Denso 1 and 2 step colder are the proper gap.
djrivera 05-28-2009 12:04 AM
What is the advantage to using +1 +2 step colder plugs?
straydoginc 06-05-2009 07:44 AM
I am looking at buying some plugs. Ditto on the "What are the pros for getting a +1 +2 plug set?"
phillyb 06-05-2009 10:42 AM
my understanding is as follows: good for more extensive mods.
and they will also help keep knock at bay
jlocurto 06-25-2009 01:56 PM
does anyone know the part number for the denso itv 22's trying to get them at an advanced auto parts near my house and theyre retarded and cant find it by "itv 22" they need a part number
ToledoSpeed3 06-25-2009 09:35 PM
Quote:
5340
Nitr0EngiE 09-12-2009 04:46 AM
I have repeated issues with colder plugs, I fry then in like 2k miles. the arm over electrode looks glazed white like ceramic and i get misfire trouble codes. this happened with Densso itv 22 and 24 and the NGKs, So i am gonna go back to stock plugs ! fuck this bs.
I may consider trying itv 20 stock heat and see if they hold up. its happening more often ive got the maf tuned to about 12-12.5 A/F
I wanted to ask can anyone explain why i am having plug issues .... they come out looking like the car runs lean even before I made air/fuel higher. and we all know the car runs rich.
2007speed3 09-12-2009 08:29 AM
^ thats a strange issue, i am running the denso 2 step colder and the only issie i have after 8k miles is a rough idle sometimes.
Are they gapped correctly?
atomic_rice 09-12-2009 09:35 AM
im having the same issue. I've gone through 2 sets of ITV22s, getting misfire codes in different cylinders. I've changed the coil packs around, so i know its not the problem. Im thinking of goin back to stock as well. :aargh4: and yes i've checked the gap multiple times.
on the good side, i can get my TMIC off in 5 mins flat now cause i've had to change my plugs so many dang times.
DCLXVI 09-12-2009 09:52 AM
the ITV22s come gapped at .32 i thought, and i just spoke to cobb and they said to gap to .28 if you have the AP. is prefered gap what people who have the AP are running? or is that for stock ECU in which case the ITV22s come ready.
Nitr0EngiE 09-13-2009 02:40 PM
Quote:
the only reason cobb says that is for increased Boost im told .28 is better. but on my car i cant get past like 16 psi no matter what i set it to in SB, our turbos blow ass.
And i had a coil go bad on my half mile from my house i limped(ran off 3 cyl, car shook really bad barely accelerated.) to mazda fully bolted with fmic and they replaced ignition coil. Dashhawk said misfire cyl 1 i changed 4 plugs still same thing, i swap coil from 1 to 2 and the error switched from 1 to 2. Coil is bad. And earlier same day i had cyl 4 misfiring, i replaced plug and it went away and it only misfired under boost 10 psi or more, this is getting annoying !
i think this colder plug bull shit is just an excuse for people who cant tune out knock or something, people with stock plugs have no issues at all. i ordered 4 stock plugs at a rediculous 15 ea. mazda dont even stock coil nor plugs because theyve never seen any go bad they said ! parts made me pre pay for plugs because they are special order, not stocked.
my friend has stock plugs cpe tbe and cpe cai and he dynoed more power then me ...... with stock intercooler. And i have everything. so wtf ? he got 272 i got 265, then they sprayed our intercoolers with NOS and i got 281 he got 285. My intercooler made the difference here.
camdensms6 10-19-2009 06:57 PM
Glad ive read this thread, Ive been asking this ? for some time now.
TongMan 10-22-2009 08:55 AM
Someone confirm these are the correct plugs for the mazdaspeed3:
4 DENSO IRIDIUM Power Spark Plugs ITV22 5340 - Chevy:eBay Motors (item 270389179968 end time Nov-07-09 11:13:06 PST)
bioevolve 10-22-2009 09:07 AM
YES, ITV22 are the correct ones.
TongMan 10-22-2009 03:36 PM
Thanks. I will be ordering a set.
curtspeed6 02-08-2010 07:12 PM
what have you guys found to be the most reliable aftermarket plugs, it seems to me that these colder ones arnt lasting as long.
shpankey 02-19-2010 11:45 AM
Ditto. Having same issue. ITV22s gapped at .30 and already fouling w/ less than 2k on them.
shpankey 03-01-2010 07:53 AM
Quote:
For aluminum heads I always use 13 ft lbs.
Btw... my stock, from the factory plugs (09 MS3) were at .28 gap. From the factory. I checked them all w/ feeler guages. All 4 were at .28 perfectly.
shpankey 03-11-2010 02:30 PM
Sorry for the multiple post. It's in just 1 thread now. Thanks phillyb, apologies.
phillyb 03-11-2010 02:32 PM
mhmm...my understanding of ngks is that we use 6510 for 1 step colder. not that part number.
Page generated in 0.20380 seconds with 11 queries
