 Old 12-31-2009, 04:38 PM   #1
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Well I went ahead and got the Ford stuff xt m5 qs, a 24mm wrench, and a hand pump.
Put the fluid in and will go for a drive later.
The fluid that came out didnt look bad at all, I am wondering now if they changed the fluid when they replaced my drive shaft a couple of months ago.
If they did, who knows what they used.
The dealer is a combo Subaru Mazda dealer, they could easily have put some Subie GL-5 stuff in there!!
EDIT:
I just read the service manual and it calls for draining the fluid when changing the shaft.
No wonder things went down hill recently tranny wise, glad I caught it so soon, 2600miles on whatever they put in there, didnt notice a difference at first, but it has deteriorated rapidly over the past Month or so (shaft was changed mid October).
I am almost positive this is where my recent notchy hard shifting came from.
Cost me $80 for the oil and tools to fix what I think was caused by some dealer SNAFU.
If I had thought that might have been the reason earlier I would have taken it in and had them fix the problem, would have been useful to document it in case of future problems.
Anyway I'll let you know, if it gets better.
Never had any complaint about the tranny till the last Month or so.
Suspension:
FreeFlyFreak is offline
 Old 06-13-2011, 07:37 PM   #2
Domino81's Avatar
Posts: 5,081   (View Stats)
Originally Posted by darth vader View Post
Any Ford technician/parts guy will know exactly what I am talking about. It's a little 4 oz bottle and it's is called "friction modifier". It is used in alot of ford's Trak Lok diffs from millions of cars in the 70s, 80s and 90s. Basically it makes gear lube a touch more slippery than usual, to reduce LSD chatter. It's called fish oil because it reeks like rotting fish. Costs a couple bucks, no more.
Ford Racing Performance Parts []
GM has something similar.
I called Ford today using United Auto's (my place of employment - I'm in commercial parts) account... $18 and change. Fuck you, Koerner Ford.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Domino81 is offline
 Old 12-29-2009, 04:50 PM   #3
The Kamikaze King!
Groans: 754
Hmmmm, just read something VERY interesting in an article describing some of the differences between Gen 1 and Gen 2 MS3's:
In terms of technological advancements, the MAzdaSpeed3 has plenty of them. For starters the new engine features an advanced boost controller that reduces peaks for a more linear power delivery. The left and right drive shafts have been modified to reduce torque steer. The six-speed manual transmission now has wider ratios than before and the tranny uses a low-viscosity fluid to reduce shift effort.
After doing a little research it turns out the Gen 2 MS3 owners manual calls for GL-4 75W80,
The Gen 1 spec is 75W90, doesnt sound like much of a change, but if you look at the centistokes it is.
My guess is the 75W80 will work better in the gen 1 too, same gearbox AFAIK just slightly different gearing.
Low Viscosity Manual Transmission Lubricants:
http://www.members.shaw.ca/jbarge/MTF.htm
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
razortechrs (07-22-2014)
 Old 03-16-2010, 07:17 PM   #4
BolvangaR's Avatar
Posts: 117   (View Stats)
BolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the worldBolvangaR is the leader of the world
Groans: 113
Groaned at 91 Times in 89 Posts
I realized nobody ever responded to this..... I think this is the most interesting post of the whole thread. It deserves a second reading.
'07 MS3 GT - CS SRI - CS TIP - TP - CP-E RMM - JBR SSP - E4 Knob - Amsoil MTG
BolvangaR is offline
 Old 12-30-2009, 01:45 PM   #5
shpankey's Avatar
Posts: 496   (View Stats)
My speed 3 held a little over 3 quarts btw... but I think you would be fine with 3. Mine definitely held more than 2.6 though.
shpankey is offline
 Old 12-30-2009, 07:58 PM   #6
The Kamikaze King!
Groans: 754
Been hearing that a lot. Seems strange, OM says 2.6, Service manuall says 2.6 buy you guys are getting 3+ in it..... You are level right? not jacked up or anything?
Suspension:
 Old 01-01-2010, 02:51 PM   #7
shpankey's Avatar
Yea, perfectly level. Even put a level on the battery. I spilt some, so I would guess it took right at 3 quarts, maybe a hair less. I filled it over a bit then let it drain for 30 minutes until it didn't come out while being level. My pinky in the hole, the fluid was right there level with the bottom of the hole. I am not worried at all about being overfilled b/c I know I had it level.
shpankey is offline
 Old 01-01-2010, 05:07 PM   #8
The Kamikaze King!
Groans: 754
Yeah me too, I was level and took almost 3. My guess is 2.8 quarts
Suspension:
 Old 01-23-2010, 02:19 AM   #9
bf360's Avatar
Posts: 2,069   (View Stats)
Can over filling damage your transmission at all?
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
bf360 is offline
 Old 12-31-2009, 08:57 PM   #10
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
I bought this some of this stuff today, too. I actually posted this in the M3F topic in the OP. My factory tranny fluid is draining overnight as I type this, I'm going to put the XT-M5-QS in tomorrow morning and report back on impressions.
wassup, thanks for the recommendation. I don't know if you remember this, but you actually suggested XT-M5-QS to me way back in July when we were at Ken's taking the front bumper off my MS3 so he could look at the FMIC.
Well i am happy to say that everything went off without a hitch - shifts are smooth and click-clickity now! I have to say that this XT-M5-QS stuff is a QUALITY product!
Cataphract_40 is offline
 Old 01-24-2010, 03:41 PM   #11
nue
nue's Avatar
Posts: 110   (View Stats)
nue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud of
So, that's why we don't have transmission dipsticks.
nue is offline
 Old 01-24-2010, 03:52 PM   #12
Tcman2006's Avatar
Posts: 165   (View Stats)
Tcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to all
anyone know how much the average dealer charges to change fluid
Tcman2006 is offline
 Old 01-24-2010, 04:30 PM   #13
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
too much, if you can change your oil you can do this.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline
 Old 02-02-2010, 01:54 PM   #14
Alpha's Avatar
Posts: 3,711   (View Stats)
My dealer does it for $79.95, but since I'm supplying the fluid they're only charging me $50... Not too bad at all.
They're doing it on Friday so I'm pumped to feel the difference over the stock gunk.
Alpha is offline
 Old 01-24-2010, 04:35 PM   #15
Tcman2006's Avatar
my dealership kinda has this deal going..they do all the service and then give me a lifetime powertrain warranty
 Old 01-24-2010, 04:49 PM   #16
The Kamikaze King!
Groans: 754
Tranny fluid is not required to be changed according to the Mazda Maintenance schedule.
Therefore do it yourself, how will they know?
Suspension:
 Old 01-24-2010, 04:53 PM   #17
Tcman2006's Avatar
oooh ok good to know thanks....is there a how to on this?
 Old 01-24-2010, 05:05 PM   #18
The Kamikaze King!
Groans: 754
Link to a "how to" in post # 6 of the thread linked below:
Synthetic transmission oil suggestion
Suspension:
 Old 01-26-2010, 04:14 PM   #19
Mudpie's Avatar
Posts: 7   (View Stats)
Mudpie will become famous soon enough
If you are in the Marietta/Atlanta GA area, they carry the Motorcraft stuff at Original Equipment Marketing (340 Franklin Road, Marietta GA, 770-919-2515). The invoice from last May shows a retail price of $17.94/qt, they sold it at $13.12/qt. The big thing is have the Motorcraft part number ( XT-M5-QS ) with you when you go to any of the dealers. A number of people on miata.net have commented how the parts guys keep trying the sell the 75W140 smutz for diffys and claim it replaces the 75W90 stuff. WRONG ANSWER! Even at Original Equipment marketing, they pulled the diffy smutz and I had to show them the right stuff in the Motorcraft catalog, see screen shot below. Also note that Original does not take checks from individuals.
If you want directions involving "you go to the Big Chicken and...," send me a PM indicating where you will be coming from and directions will be supplied. Note, directions may involve mention of Waffle House or street with Peachtree somewhere in the name as well.
Mudpie is offline
 Old 01-28-2010, 02:24 PM   #20
Hank3's Avatar
Posts: 516   (View Stats)
Hank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the world
Thought about ordering this Ford fluid since I'm at 26K now, but I have had complaints with the stock fluid. Haven't had any grinds. Only thing I've experienced is when we had the cold snap in FL a few weeks back and it was somewhat hard to shift into 2nd in the mornings.
Where can you purchase the stock fluid at?
5% off Redline leather goodies HERE. Pics of them installed in my Speed3 HERE.
Hank3 is offline
 Old 02-02-2010, 01:20 PM   #21
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Uhhh.... Dealership?
hnda etr is offline
 Old 02-02-2010, 03:30 PM   #22
Groans: 30
have you considered doing it yourself?
I mean, you'll save $50...
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 02-02-2010, 03:44 PM   #23
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
I in-fact changed my trans fluid last night. I put in the Motorcraft XT-M5-QS, as recommended by Jeff (wassup61). Don't pay a dealer to do it, unless you have no tools or means to lift the car. It's really easy to do yourself, with some tubing a funnel and a BIG-ASS 24mm wrench. I actually did it w/o lifting the car.
I also put in my stock RMM, cause the vibes from my cp-e RMM were getting annoying. I'll put the cp-e back in, come my next track day.
Anyways, my car now shifts as smooth as glass. I was having 2nd gear engagement issues, that now seem to be completely gone, thanks to the Motorcraft fluid.
Current Fail:
MATT DAMOND is offline
 Old 02-02-2010, 04:33 PM   #24
Groans: 30
good shit, isn't it?
1995 Miata
 Old 02-02-2010, 08:40 PM   #25
Alpha's Avatar
Hmm... You've got me thinking now.
I might just it then. I mean, $50 is $50.
Alpha is offline
 Old 02-03-2010, 04:38 AM   #26
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Takes less than an hour. So unless making $50/hr is not interesting to you then go for it.
If you need to buy a tool or two? So what, you will still come out $30 ahead and with useful tools.
cld12pk2go is offline
 Old 02-03-2010, 09:23 AM   #27
The Kamikaze King!
Groans: 754
That is the way I always look at it........ it is like the dealership buying me tools.
Suspension:
 Old 02-02-2010, 06:13 PM   #28
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
I got it for a pretty good price off Ebay. $32.49 for 3 quarts + $13 for shipping.
Frequentflyer is offline
 Old 02-02-2010, 06:18 PM   #29
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I think I'm going to go ahead and jump on this bandwagon..
madvillain is offline
 Old 02-03-2010, 11:10 AM   #30
Alpha's Avatar
Haha! SOLD!
Alpha is offline
 Old 02-03-2010, 12:06 PM   #31
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
just ordered mine!
Fagwagon is offline
 Old 02-03-2010, 09:57 PM   #32
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ur a bitch! I sent them a message and asked them for a 3qt auction lmao.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 02-13-2010, 07:05 PM   #33
bani's Avatar
Posts: 335   (View Stats)
bani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond repute
Groans: 35
Groaned at 35 Times in 17 Posts
Isnt our tranny a Getrag? think I remember reading that somewhere.
no. our trans is an Aisin BG6.
bani is offline
 Old 02-13-2010, 07:31 PM   #34
The Kamikaze King!
Groans: 754
That was cleared up in posts #4 #7 and #11......
Maybe read the thread next time.
Suspension:
 Old 02-14-2010, 10:18 AM   #35
FULLBLOWN's Avatar
Posts: 78   (View Stats)
FULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to behold
So this is probably a long shot but from what I read in here, by only one person, would amsoil be a better way to go even if its more expensive?
FULLBLOWN is offline
 Old 02-14-2010, 11:17 AM   #36
Groans: 30
Buy the XT-M5-QS. It is the lube of the Gods. It flows in a giant, slippery river from its source on top of Mount Olympus, spreading smooth shifts to mortals throughout the land
1995 Miata
 Old 02-14-2010, 12:26 PM   #37
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
It is truly outstanding. I put this stuff in last week, and it really does make quite a difference in shift smoothness. The shifter seems much less reluctant to push through the gates. I also installed my solid shifter base bushings, and shifter weight a few days ago, which further pleases my right hand. IMHO these are the first 3 things you should do to this car. It really makes it quite a bit more enjoyable to drive. For under $100 bucks total for those 3 mods, you can't go wrong. DO IT.
banditscout is offline
 Old 02-17-2010, 12:58 PM   #38
I put this XT-M5-QS shit in today. I haven't driven it very much since, but from what I can tell, it's smooth as butter already.
 Old 02-17-2010, 02:27 PM   #39
Groans: 30
just you wait. this shit is like a fine wine...only gets better with age
1995 Miata
 Old 02-17-2010, 11:01 PM   #40
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
Mine hasn't got better yet.. I have other issues though. Amsoil and mt90 was smoother than this. IMHO
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline
*Only* the transmission Ingle Mazdaspeed3/6 General Discussion 10 07-30-2018 08:39 AM
Transmission Cured FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 305 11-08-2017 08:36 AM
Rattle Not Cured TRex MazdaSpeed 3 - Engine, Transmission & Driveline 35 09-16-2011 07:20 AM
Page generated in 0.67991 seconds with 43 queries
