 Old 06-19-2010, 12:20 PM   #161
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
So doing research on the web, there seems to be another fluid that is highly recommended, although I am uncertain as to well it would work with our tranny. It's called GM syncromesh Friction modifier, and people seem to swear by it on other forums. Only thing is they have different trannys and I don't know if we'd necessarily get the same results.
Speed3eak is offline
 Old 06-19-2010, 01:56 PM   #162
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
I'm going to go out on a limb and say that what you've got there is a *drum roll* fricton modifier and is therefore an additive to transmission fluid, and would not work well if you put only it in the transmission. Plus it probably comes in tiny containers (a few oz). Am I right?
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
Cataphract_40 is offline
 Old 06-19-2010, 02:05 PM   #163
Speed3eak's Avatar
Groans: 82
Actually, no - It's a manual transmission oil with friction modifiers put into it at the factory. It comes in quart-sized containers (being the smallest container you can get it in).
Although I did hear about it when I was looking around honda/acura forums IIRC. Could have also been a focus forum, as I've been looking around for the best manual transmission oil available for our transmissions.
edit:
 Old 06-19-2010, 02:46 PM   #164
Groans: 30
Ah, I see - friction modified, not modifier. Gotcha. Well if you want to take a stab at it, go for it. Let us know if it feels smooths or not, and whether or not you get any LSD chatter.
1995 Miata
 Old 06-19-2010, 11:13 PM   #165
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
that stuff worked well on my 96 cavalier. I was told that it needed to be rebuilt with 2nd gear and synchro being bad. changed fluid to that and drove it hard for another 60k with no issues ever again. It was a getrag tranny too.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline
 Old 06-21-2010, 09:42 AM   #166
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
If you read back (im too lazy to go find the quote) but our "cone style" differential does not need or react well to a friction modifier.
The motorcraft or amsoil is all you will need, Adding a friction modifier will not "help" our situation only create a new one.
Any confirmation that mt-90 and amsoil are the same thing? or very similar?
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline
 Old 06-24-2010, 03:50 PM   #167
HutcHJC's Avatar
Posts: 248   (View Stats)
HutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the world
MT-90 is Redline Oil (Manual 75w90 GL 4 Tranny Fluid
MTGQT-EA is AMSOil (Manual 75w90 GL 4 Tranny Fluid)
XT-M5-QS is Motorcraft (Manual 75w90 GL 4 Tranny Fluid) (GL 4 according to their Data Sheet)
None of these are 75w80. The only oil I can find that's 75w80 is Esso. The viscosity #s are all consistent with each other but the Esso #s are a bit lower. Which makes sense given the weight difference.
Redline #s
Vis @ 100°C, cSt 15.6
Vis @ 40°C, cSt 90
Viscosity Index 185
AMSOil #s
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 14.7
Kinematic Viscosity @ 40°C, cst (ASTM D-445) 84.5
Viscosity Index (ASTM D-2270) 181
Motorcraft #s
Viscosity:
cSt @ 100°C 15.4
cSt @ 40°C 76.0
Viscosity Index 211
Esso #s (Esso Gear Oil BV 75W-80 GL 4)
cSt @ 100°C 8.2
cSt @ 40°C 47.1
Viscosity Index, ASTM D 2270 149
Saw something on another MSF Thread:
Redline 70w80 states on website that it's good for 75w80. Here are the numbers.
Vis @ 100°C, cSt 10.6
Vis @ 40°C, cSt 56.2
Viscosity Index 183
HutcH
2010 Black Mica MazdaSpeed3 - jbarone stage 2 ssp w/ weighted shift knob - cp-e 60D rmm - 15% Tint + AIR Blue 80 - DDM 55w 5000k HIDs (waiting to install) - CorkSport SRI+TIP (on order) - EBC RedStuff Brake Pads (on order)
HutcHJC is offline
 Old 06-24-2010, 05:45 PM   #168
Groans: 30
A higher VI is 'better', right?
1995 Miata
 Old 06-24-2010, 07:07 PM   #169
HutcHJC's Avatar
Stolen from Wikipedia:
Viscosity is a measure of the resistance of a fluid which is being deformed by either shear stress or tensile stress. In everyday terms (and for fluids only), viscosity is "thickness". Thus, water is "thin", having a lower viscosity, while honey is "thick", having a higher viscosity.
Anyone please correct me where I'm wrong here...
Basically the thicker an oil (higher viscosity) the more resistance in the engine/transmission/differential and the thinner an oil (lower viscosity) the less resistance. A higher viscosity imparts more protection to the parts of the component but provides more resistance. Basically as standards have gotten tougher they've been reducing, a bit, the Viscosity recommendations. They are trying to balance proper lubrication of components with MPG, Emissions, etc. This is why some oils make it harder to shift. There's less and less tolerance, and the oil actually gets in the way of the parts working together because they don't flow easily enough.
This is where friction modifiers can play a part. It helps make the oil more slippery so every thing meshes easier and allows for thinner oils to keep parts protected. But friction modifiers aren't always a good idea when you need friction to perform, like a wet-clutch on a motorcycle.
HutcH
HutcHJC is offline
 Old 07-17-2010, 10:11 PM   #170
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
One reason the '10 shifts better is the lower viscosity.
I've asked around if the Gen1 can run GenPu fluid and everyone acts like I'm asking the meaning of life.
Mizzle is offline
 Old 07-17-2010, 10:19 PM   #171
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
The meaning of life.....the universe.....and EVERYTHING....:
"42"
Suspension:
FreeFlyFreak is offline
 Old 07-29-2010, 10:34 AM   #172
Sniper2606's Avatar
Posts: 569   (View Stats)
Sniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the world
Groans: 33
Groaned at 32 Times in 15 Posts
soooo i been reading the whole thread, im guessing some people had good experience with amsoil and others with motorcraft, or depends on the car lol im on 27k 08 with short thrown plate and metal SU bushings. i would ask which fluid i should get but i guess it doesnt matter either one amsoil or motor seems to work fine
edit heres the links
Amsoil http://www.amsoil.com/catalog.aspx?code=MTGQT-EA
Redline http://www.streetunit.com/Redline_MT...p/red50304.htm
Motorcraft http://k-mansparts.com/items/focus/M...5qs-detail.htm
Silly Lebron, rings are for Kobe
2011 WRX STI pro tune Invidia Downpipe and Exhaust,Cobb Intake Cobb AP 91
The nigga bought aluminum tubes! Do I need to tell you what the fuck you can do with an aluminum tube!?! ALUMINUM!!
Dave Chappelle
Sniper2606 is offline
 Old 07-29-2010, 07:55 PM   #173
chieftjs's Avatar
Posts: 128   (View Stats)
chieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond reputechieftjs has a reputation beyond repute
I just replaced my tranny fluid with the Motorcraft fluid, and it feels a lot smoother. I'll post an update once I get a few hundred miles on the new fluid. The install was easy. I found that jacking up the passenger side of the car allowed the fluid to drain easily. I would also recommend removing the plastic cover under the engine to make draining easier.
08 Red Mazdaspeed3 GT, CORKSPORT SRI and TIP, Cobb DP, ETS TMIC, KW V2 Coilovers, Hotchkis FSB and RSB, DRZ RMM, 235/45/R17 Hankook Ventus V12s on Gold Enkei RPF1's, JBarone SSP and Heavy Shift Knob, Cobb AP, PTP HPFP internals, DASHHAWK, Solaire Sunroof
For Autocross: Hankook Z214 245/35/R18 C71 on RX-8 rims
chieftjs is offline
 Old 07-29-2010, 08:02 PM   #174
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
I seriously didn't not much difference with the Motorcraft, i was actually happy with the OEM stuff. It whines on sharp turns for me but it is a little smoother than the OEM fluid.
One thing that actually improved my shifting was the re-adjustment of the link on the shifter itself, there's a video on youtube and i think it's from the guy that sells the shifter plate.
R.MS3 is offline
 Old 08-02-2010, 02:04 PM   #175
evidence's Avatar
Posts: 1,033   (View Stats)
So I installed the PTP IM gasket last weekend, and ever since then my tranny whine/'wah-wah-wah' at low speeds has been a bit louder. Did a log and noticed my WG was working a bit harder than normal so figured I had a boost leak. Turns out the hose from my OCC onto the IM was kinked when I reinstalled and was indeed leaking. Fixed this up and no more leaks. To my surprise, the tranny noise quieted down quite noticeably. Something in the system must use vacuum to operate? Not sure why else a leak would cause the audible change. Just a heads up as something to check for you guys with a louder tranny.
I've been running MT-90 since 500 miles. It's been said to swap it out at 20k (I'm 24k) to get the crap from break in out, then your set for good, so I have some Amsoil I'll be throwing in this week. I'll comment on my experience with the 2 shortly.
Some things.
evidence is offline
 Old 11-09-2010, 06:54 AM   #176
chumpsteak's Avatar
Posts: 83   (View Stats)
chumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond reputechumpsteak has a reputation beyond repute
I swapped out the OEM stuff at 7K miles due to a bad 2nd gear grind problem. Put in MT-90 and the grind problem got better but didn't go away. Shifting was improved overall though. Just changed again at 39K miles and put in the Motorcraft stuff this time. 2nd gear still isn't perfect when cold, but the overall shift feel is much improved even over the MT-90. I'll be using the Motorcraft from now on.
chumpsteak is offline
 Old 11-11-2010, 11:02 AM   #177
801MS3's Avatar
Groans: 30
I hate to poop all over this thread with my negativity... BUT
I have been following this thread for a while now with the plans of using the motorcraft fluid. And being really optimistic because of all the positive feedback people are giving.
I wanted it mostly because i live in SLC, UT and the winters here are a bitch and cold weather shifting is a joke.
So i finally got my Motorcraft fluid $57 later my tranny feels almost exactly the same as it did with the stock fluid.. Cold shifting feels the same so does warm shifting. I was hoping it would help with my sometimes "crunchy" 1-2 shift but it didn't, if anything it made it worse.
I will propbably either try amsoil in the spring or the BG syncromesh. I used BG in my DSM and it was awesome.
Side note: 2 other local ms3 owners swapped to the same fluid the same day i did, and their thoughts were mixed. But that could just be the placebo effect and hopes that the $57 "upgrade" you just did actually made a difference..
Dissapointed
801MS3 is offline
 Old 11-11-2010, 11:19 AM   #178
The Kamikaze King!
Groans: 754
Glad to hear the other side.
If I were to try another oil it would be Redline MT-85 75W85 GL-4 Gear Oil
Or even Redline MTL 70W80 GL-4 Gear Oil
Those may need some friction modifier, but I would try it without first, it is easy enough to add afterward.
Why those fluids?
The 75/85 is recommended in mitsubishi and sentra gearboxes which are very similar to ours. Mitsubishi and Nissan however spec a thinner fluid than Mazda.......... and now Mazda for the gen 2 specs a similarly thinner fluid. Actually, their fluid spec is similar to MTL 70W80 GL-4 Gear Oil which is also listed as an alternative to XT-M5-QS
If you try either let us know how it works out.
The other fluid I would like to try is the Mitsubishi Diaqueen Transmission fluid BUT it is even more expensive than the ford stuff.
Suspension:
 Old 11-11-2010, 11:45 AM   #179
TRex's Avatar
Posts: 3,139   (View Stats)
^which friction modifier would you use?
TRex is offline
 Old 11-11-2010, 11:48 AM   #180
The Kamikaze King!
Groans: 754
Any, it doesnt really matter IMO.
Just try whatever fluid you are trying without FM first.
Then IF needed add the minimum required to make the diff noise acceptable.
Suspension:
 Old 11-13-2010, 01:29 PM   #181
nyghtryder's Avatar
Dissapointed
how many miles you put on the new fluid. most say that it gets better with time
NATOR PA
 Old 11-13-2010, 02:06 PM   #182
801MS3's Avatar
Groans: 30
Only a few hundred.. I drove a good 40-50 miles in one trip and it feels better. I don't know if it has to do with it getting hot or what but it felt fine.
But with my commute only being 6 miles to work and 6 home, it wont get up to that ideal temp so its a bit of a let down. Especially when one of the main reasons i bought it was to improve the cold shifting.
Hopefully it improves because im about to drain it.
801MS3 is offline
 Old 11-13-2010, 08:22 PM   #183
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
I drove all over today Austin and by the time I got home the shifting felt great, not sure how many miles I have put on the new fluid but I am hoping it is getting better with age.
417whp 428tq 12.037@117.2mph
Snyeed is offline
 Old 11-14-2010, 10:23 PM   #184
801MS3's Avatar
Groans: 30
Seems to.. It felt tons better today..
Ill post up again in a couple of days, hopefully with more positive feedback.
801MS3 is offline
 Old 11-14-2010, 10:38 PM   #185
snailD's Avatar
Posts: 3,039   (View Stats)
i kind of find it weird that it gets better over time.... enlighten me on why this would possibly happen? could it be your just getting used to it?
snailD is offline
 Old 12-03-2010, 07:34 AM   #186
Teethkikr's Avatar
Posts: 677   (View Stats)
Teethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the world
Groans: 50
Groaned at 15 Times in 8 Posts
So I work for Chrysler and we have a 75-80 Full Synthetic M/T Fluid.. What is in the Motorcraft stuff to make it better for our cars than another when they are all synthetic
2012 CWP Tech Package:
Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems//
Teethkikr is offline
 Old 12-03-2010, 09:18 AM   #187
The Kamikaze King!
Groans: 754
I would try that Chrysler stuff, especially if you have a Gen2 let us know how it is.
Suspension:
 Old 12-03-2010, 11:54 AM   #188
Tommy's Avatar
Posts: 2,309   (View Stats)
Tommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the world
Groans: 155
Groaned at 44 Times in 37 Posts
Thanks for this.
Tommy is offline
 Old 12-24-2010, 11:42 AM   #189
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Did the tranny oil change yesterday and went with Amsoil.
I hate it. Much worse than stock. LSD whines like crazy accelerating out of tight turns in 1st gear. Gears don't feel smoother engaging at all. On the contrary. Feels like they clonck and grind more. I never really had any major grinding issues on the stock oil. Only did the change as a part of maintenance.
Only have 30 miles after change. Is there are break in period or somthing similar?
I am thinking If it does not get better in another 200 miles I'll change it for something else.
Edit:
09 MS3
25K miles
Tomas is offline
 Old 12-24-2010, 02:21 PM   #190
Groans: 30
Go for the XT-M5-QS
1995 Miata
 Old 12-24-2010, 03:20 PM   #191
Bob Ross Fanclub
Tomas's Avatar
yeah, but I've read a few posts in here where people have tried both Amsoil and Motorcraft and they said Amsoil was better. Idk, might try it anyway
Tomas is offline
 Old 12-24-2010, 08:28 PM   #192
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
I've tried both Amsoil and the Motorcraft stuff I would say the Motorcraft works better for the transmission. However I use Amsoil for the motor.
ms3077 is offline
 Old 12-27-2010, 04:32 PM   #193
801MS3's Avatar
Groans: 30
Im still not enjoying any benifit at all from the motorcraft.. I changed it because my car has 48k, if it doesn't improve with warmer weather i will be going back to stock oil.
I had zero problems with stock oil and now i have a crunchy second gear.. Not awesome.
801MS3 is offline
 Old 12-27-2010, 05:00 PM   #194
Bob Ross Fanclub
Tomas's Avatar
I ordered some motorcraft and will change the amsoil for it. Post to follow.
Will keep the amsoil in a container after draining just in case I want to put it back.
The amsoil has gotten a little better after 200 miles.
Tomas is offline
 Old 12-28-2010, 10:49 AM   #195
mouse0330's Avatar
Posts: 1,104   (View Stats)
mouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the world
first trans fluid change at 30k miles to redline and now at 67k with no problem whatsoever....wonder why other ms3 trans would have problems, would not change to anything else until redline fails lol, if other trans fluid work for you stay with that brand
mouse0330 is offline
 Old 01-04-2011, 08:04 PM   #196
bait's Avatar
Posts: 29   (View Stats)
bait is on a distinguished road
Groaned at 7 Times in 4 Posts
I've still got some redline sitting around, I might give that a shot and see if it helps.
bait is offline
 Old 01-20-2011, 01:58 PM   #197
nue
nue's Avatar
Posts: 110   (View Stats)
nue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud of
Any consensus as to when to change the tranny fluid? Or is what FFF posted a good enough interval?
nue is offline
 Old 01-20-2011, 04:50 PM   #198
R.MS3's Avatar
15k miles max from 0 miles, i would say every 30k miles after that.
R.MS3 is offline
 Old 01-20-2011, 08:58 PM   #199
paramount's Avatar
Posts: 4   (View Stats)
paramount is an unknown quantity at this point
So I am new here and I am too stupid to figure out how to post a new thread. I do not actually own a mazdaspeed3, however I am installing the same transmission that the ms3 has in my automatic car as a project. I would like to know what you guys are at RPM wise while traveling 65 mph. Thanks!
paramount is offline
 Old 01-20-2011, 09:22 PM   #200
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
luckily no problems just whine since day one
forcedinduktion is offline
*Only* the transmission Ingle Mazdaspeed3/6 General Discussion 10 07-30-2018 08:39 AM
Transmission Cured FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 305 11-08-2017 08:36 AM
Rattle Not Cured TRex MazdaSpeed 3 - Engine, Transmission & Driveline 35 09-16-2011 07:20 AM
Page generated in 0.59616 seconds with 44 queries
