 Old 03-24-2012, 12:48 AM   #281
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
Originally Posted by gpower07 View Post
shit...today i did my autotech internal...but i didn't lop with motor oil on the piston and spring....am i going ok? i already start the car...warm up for 30 min. and drove for half mile!!!!!
Really??
i dipped the piston with the O ring into gasoline. will that kill the O ring? if so. i can take it out and redo everything again.
This cannot really be a serious post, right? I am the last guy to be a straight up asshole to someone but it looks like you didn't read any of this thread or any other thread and installed your internals. If I am wrong, I apologize, but come on.
2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's
Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice)
OBAMA SUCKS
Stratified Tune by Lex
Bosox is offline
 Old 04-29-2012, 09:46 PM   #282
Dubcnea's Avatar
Posts: 223   (View Stats)
Dubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond repute
is it best to go through Eric@edgeautosports to get the best pricing on these internals?
2012 CPW Mazdaspeed 3
Dubcnea is offline
 Old 04-29-2012, 09:51 PM   #283
Bosox's Avatar
I did and was happy
OBAMA SUCKS
Bosox is offline
 Old 04-30-2012, 08:01 AM   #284
bigriver's Avatar
Posts: 1,123   (View Stats)
Price and service. They will even talk you through the install if necessary.
bigriver is offline
 Old 05-08-2012, 08:23 AM   #285
soulglow's Avatar
Posts: 58   (View Stats)
soulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to behold
So I did the upgrade with KMD internals yesterday, and I've got a few notes that might help people. This is on an MS6, so ymmv for a 3:
- Definitely remove IC cover, I ended up removing the IC too but that's not necessary (see note on blue line). I don't see any logical reason to remove the TIH or the battery, they do not restrict access at all. I did remove the SRI, mainly so I could get the big air hose out of the way of the fuel lines...this is the most useful prep.
- The blue fuel line clip...that shit is from another dimension. I ended up prying it completely off before the connector would come off the nip. I still don't understand it, and was pretty sure I was going to break it. Hopefully you're smarter than me.
- Rather than prying on the pump, I just used a flatblade against the vertical surface and tapped with a mallet. Slid right out.
- Don't worry about bending the metal fuel line out of the way before sliding the pump out. Once I slid the pump out and away enough, it separated on it's own with no grief.
- I ended up breaking my vice trying to get the main threads loose, forcing me to ride my bike through the rain to use my dad's vice. HAVE A GOOD VICE, and use some wood shims or rubber strips to hold the pump.
As far as the rebuild itself...just be wary and clean. The inside of the sleeve on mine had some pretty heavy crud. The instructions that come with the KMD internals are useless as far as the mechanical process, but fairly explicit as far as lubrication so follow that (grease internal parts, use oil on o-rings, don't forget the outer o-ring before re-installing.
In the process of threading the pump back in, a bunch of grit/corrosion from the housing would break loose and land in the body, forcing me to clean it out again. This happened a number of times, just be careful.
Primed it a few times and it fired right up...immediately hit 1700 PSI before eventually settling down. It's very clicky and noisy right now but seems to be working well. I let it idle for about 20 minutes then shut it off. After I put my exhaust on today I'll go for a long drive and see how everything goes.
2006 MS6 GT: CorkSport CBE and RP, TMIC / tubes; SURE Aeros v2 SRI w/AEM, Torq RMM, Short Cut, anchors; Cobb AP, TIP, XPE BPV; KMD HPFP; BC coilovers; SPC balljoints; JBR TIGs, EGR delete, OCC S2, spacers; Technafit SS lines; Hawk HPS; Iridium plugs
:::: STRATIFIED Lex tune on hold :::: Coming Soon: a few boxes of crap I haven't had time to install. ::::
2002 MP5 w/ HELLA RICEY BITS, Daily Driven with some embarrassment and lots of love.
soulglow is offline
 Old 05-10-2012, 10:01 AM   #286
J_Logik's Avatar
Posts: 129   (View Stats)
J_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the world
All, I did the internal install on the weekend gone by (@rghispanic88 thanks for the instructions) and I'm trying to determine what is the average fuel pressure people are seeing after the upgrade?
I was seeing almost 1700psi with the OEM internals, but after the install I'm currently seeing between 1700-1780psi, but this is with me only pressing the pedal to about 5psi of boost. I haven't gone WOT throttle yet as I'm concerned I'm not seeing significantly higher output.
Any suggestions, could it be installed incorrectly?
2010 VRM MS3
JBR RMM, AUTOTECH HPFP INTERNALS,
FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS
J_Logik is offline
 Old 05-10-2012, 10:03 AM   #287
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
If it was installed incorrectly your fuel pressure would be in the 60's. As long as you don't go under 1600 at WOT, you're fine. Nothing wrong with having higher pressure.
adlpb is offline
 Old 05-10-2012, 10:53 AM   #288
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
no prob man
pressure under part-throttle is really not what we are really concerned about.
you want to focus on the pressure at full throtle or WOT. catch a log with the Ap strating at 2500 to redline, about 6300 RPM and makae sure that your pressure is not below 1600
2010 Black Mica
rghispanic88 is offline
 Old 05-12-2012, 10:13 AM   #289
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
Can someone more thoroughly explain step #8.5....? The one with the zip tie.
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline
 Old 05-12-2012, 10:29 AM   #290
adlpb's Avatar
Groans: 669
Look at the bottom of the fuel pump where there a metal line. You need a 19mm wrench to take out the nut that attaches the pump to the metal line. When you remove that nut, it will fall down to the fuel line and be a pain in the ass to get back. That's why you put a zip tie to prevent the nut from sliding down the metal fuel line.
adlpb is offline
 Old 05-12-2012, 10:30 AM   #291
RobLoMS3's Avatar
Posts: 21   (View Stats)
RobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of light
You wana place a zip tie bellow the nut on the bottom fuel line, so when u take it off it doesn't slide out of your reach. I just used some tape. Then after its all put back together u remove the zip tie
tapin
2008 MS3 AEM CAI, COBB TIP, HKS CB, TURBOXS BPV, COBB FMIC, JBR RMM, JBR OCC, CP-E CATTED DP, TB TIG, SnailD Tune E85
RobLoMS3 is offline
 Old 05-16-2012, 07:24 PM   #292
Dubcnea's Avatar
subbing
Dubcnea is offline
 Old 05-26-2012, 10:05 PM   #293
Werm's Avatar
Posts: 157   (View Stats)
Werm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond repute
Groaned at 8 Times in 3 Posts
anyone know if the stock fuel pumps on the send gens are the same as the speed6? thinking of just buying a new fuel pump and putting the internals in it and just swaping it out for mine. i know the part number for the speed6 pump and not the speed3 so I can't be certain im ordering the right part
Werm is offline
 Old 05-30-2012, 11:02 AM   #294
Acedelgado's Avatar
Posts: 39   (View Stats)
Acedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud of
Why? The hardest part of the install is taking the pump off and putting it back on the car. Why do it twice? Internals themselves are super easy to do and hard to screw up. Just make sure you wear some dust-free nitrate gloves to handle the parts, lube lightly and don't force anything.
2012 LSM Non-tech
Kensun 6000k HID / SURE 70a RMM \Cobb AP/ Autotech Internals\ Corksport SRI + TIP/ Synchronic BOV
Interior:
AppRadio 2 + ARLiberator + ScanTool Bluetooth OBDII Reader + Torque Pro = Win.
Acedelgado is offline
 Old 05-30-2012, 11:11 AM   #295
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
This makes almost no sense to me. Either way you are going have to disassemble a pump and put one back together. Its not like you are eliminating any chance of something going wrong. You are preforming all the same steps as someone that just simply swaps out the internals.
Why would you want a whole new pump assembly?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-04-2012, 08:19 AM   #296
pwned's Avatar
Posts: 762   (View Stats)
pwned has disabled reputation
I did my install last weekend.
Seen how too's that say remove the intake and batt box. Hmmm too much work for me!!
-Removed tmic
-shoved rag down by fuel line under nut
-took my 19mm wrench and loosened nut
-removed upper quick disconnect lines
-removed inverted torx
-removed pump
-placed pump on clean surface
-pulled out spring/rod portion
-air comressor filled up to 60psi(half of capacity so its not full power)
-used my 1/2in mac air gun to zip off nut while holding pump in hand
-removed bottom part of pump pay attention what sise is up and facing down
-lubed up oring on inside of nut you zipped off
-took shaft and slid in and out of oring(it did take convicing this was the most tedious part i thought i was going to fold the oring over or damage it at first
-reinstalled into pump itself
-hit the nut with the gun 2 times
-slid spring down over rod and installed keepers then pushed down to lock inplace
-lubed up main oring that slid into pump on car
-installing into car the fuel line top itself was in the way of sliding the pump back in so i took a long skinny screw driver and slightly pushed the line over to allow clearance
-all fell right into place with no issues
-tightened all bolts and reinstalled everything
-done!!!!!
Sold
-12' Ms3 // 305hp 336tq SAE
-13' CWP MS3
JBR 88a Trilogy // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs // JBR Rsb
323hp/351tq SAE
Current..
02 Regal GS-Go fast stuff-286hp/314tq 12.8 @ 108.....248k original motor/trans(Broken........Trans failed at 249,334 12/6/15)
16' Mazda 6 GT (sonic silver)
pwned is offline
 Old 07-12-2012, 03:37 AM   #297
Seaton's Avatar
Posts: 233   (View Stats)
Seaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the world
Thanks to OP for this,
Did my HPFP upgrade, very easy, i didnt have to pull anything off the car apart from the TMIC shroud to remove the pump
Seaton is offline
 Old 07-12-2012, 06:22 AM   #298
h0ckeyman's Avatar
Posts: 1,126   (View Stats)
h0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the world
Groans: 32
Nice instructions, will be doing this soon.
h0ckeyman is offline
 Old 07-17-2012, 04:58 PM   #299
soaptray's Avatar
Posts: 138   (View Stats)
soaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond repute
Thanks for the write up! Will be doing this to mine in the next few days!
[ 2010 MAZDASPEED3 - Crystal White Pearl ]
Lighting 6000k HID Bi-Xenon, Painted, LED Halos, HID Fogs, LED Interior | Autotech HPFP Internals | MagnaFlow CBE | CP-e DeltaCore FMIC | Cobb SRI, TIH, AP, Knob | TurboXS Hybrid BOV | UR Catted Downpipe, Test Pipe | Denso ITV22 Plugs | SURE Anchors, Counterweight, Shortcut | Rally Armor Flaps | AutoEXE Strut Bar | Speedline Hood Damper | Prosport Evo Boost Gauge, Evo Wideband AFR Gauge | JBR 80a RMM, 80a TMM Mount, Stage 2 OCC | Hella Supertones | Misc 30% Tint | Varrstoen 18 x 8.5 ES2 +35 | Koni Yellows | H&R Springs
In Garage: XSPower Exhaust Manifold, Garret GTX3076R EWG
soaptray is offline
 Old 08-02-2012, 10:02 PM   #300
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
This thread helped a TON today! Thank you OP.. Though as I was working I forgot to add a zip tie on the metal fuel line... Luckily a pair of pliers helped get the but back from the depths of hell!
I think it's been mentioned, but if anyone is looking around.. The E8 Inverted set is sold at harbor freight tools.. like 8 bucks for a set of inverted star sockets.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline
 Old 08-02-2012, 11:01 PM   #301
Martinezs89's Avatar
Posts: 16   (View Stats)
Martinezs89 will become famous soon enough
Groaned at 8 Times in 2 Posts
This is a good write up! ill be doing this soon to my car a must needed mod
Martinezs89 is offline
 Old 08-03-2012, 05:43 PM   #302
punisherB273's Avatar
Posts: 181   (View Stats)
punisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
Just did my install today and thought i would share a few things I found that make the install easier I haven't read about yet.
1. If you are installing auto techs the directions have you completely dissasemble the pump to clean. On the sensor part that has to be removed I left the pump bolted up and used a crescent wrench to loosen the sensor before removal. If you don't have a vice or don't like clamping soft aluminum in a vice this helps with removal as you can't get an impact on there with the sensor in the way. I used a 3/8ths impact for everything else. No vice needed.
2. Removing the TIP is a lot easier than trying to loosen the lower fuel line 1/16th of a turn at a time. I even have crows foot line wrenches but i didn't have any luck getting those to work.
3. Removing the intercooler makes no sense.
4. My TIP clamp was finger tight from the factory with only 6k miles on the car. I'd check yours As I've never even touched the thing for it to be loose. While your at it just replace the darn thing it's cheap looking plastic junk
5. The fuel line fitting has tons of red lock tight on it that flakes off when cleaning the pump. Spend extra time getting that clean as it can fall off and get in the pump when rebuilding
6. If you watch the video op posted in a link don't be like them. Wear gloves and use lint free cloth . They looked like a couple of monkeys humping a football especially when installing the piston retainers. Seriously push the piston all the way up, put the silver retainer on the spring, slide keepers in place and then push the piston down to lock into place
2011 Liquid Silver Mazdaspeed 3 - Cpe Nano Intake - Corksport Test Pipe - Cobb XLE -Corksport RMM inserts - Autotech HPFP internals - Cobb AP stage 2 tune in progress
punisherB273 is offline
 Old 08-03-2012, 10:54 PM   #303
DingoDave's Avatar
Posts: 764   (View Stats)
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
Just installed an aftermarket TIP on a buddy's gen2 MS3 the other day and the clamp on his stock TIP was finger tight as well.
2013 Black Mica Mazdaspeed 3 - Current daily
2006 WWP Mazdaspeed 6 - Soon to be daily
2006 BCM Mazdaspeed 6 - Project
Tuned with by
DingoDave is offline
 Old 08-23-2012, 12:28 PM   #304
3starmagnum's Avatar
Posts: 348   (View Stats)
3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world
Just did this today. Thanks OP for the nice write up!
Word to those who haven't done this yet and are planning to: get 'er done!! Don't be scared. Just read up
2011 Mazdaspeed3
Power Mods: JBR 3" intake//CP-e top mount IC//AT internals//CS testpipe//NGK step colder plugs
Other mods: JBR 88 rmm//Swift springs//RA mud flaps//JBR ssp
STRATIFIED TUNED by Lex
3starmagnum is offline
 Old 08-28-2012, 06:00 PM   #305
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Autotech internals still going strong.
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline
 Old 08-30-2012, 09:25 AM   #306
IHIERBal's Avatar
Posts: 144   (View Stats)
IHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond repute
Gonna be doing the install hopefully this weekend. Thanks for the write-up OP. And wish me luck! lol
2010 MS3 purchased 02/11/12 (11,9xx miles) II Headlight Armor yellow fogs II CS RMM insert II CS SRI/TIP II DDM HID Kit low beams 4300k II Plasti-dipped rear valence II Eibach prokit II OEM Rear bumper guard II OEM roof rack II Thule 44" fairing II Privat Akzent 18x8.5+40 II 235/40 Falken Ziex II UltraGauge II Cobb AccessPort II OBX test pipe II AT Fuel Pump Internals II HKS bov VTA II CP-E TMIC II ATP Long Downpipe II CS Shift Plate II Koni Yellows II
Re-tune in progress!
Engine oil : Rotella T6
Oil filter : Motorcraft
IHIERBal is offline
 Old 09-10-2012, 01:52 PM   #307
strukoff's Avatar
Posts: 24   (View Stats)
strukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to all
Finished my AT internals install this morning. Very easy install, easier than my TIP install. Here's some notes from my experience:
-remove fuse and let the car die as you will have virtually no fuel spillage (may take a few minutes)
-just removed IC cover and valve cover breather tube
-removing IC lower tube and battery/ecu tray would be easier if you can't fit the open end wrenches in
-crow's feet do not work so don't waste your money/time
-blue clip on fuel line, just lift the blue clip out a bit with one hand and pull the line out
-yellow clip will release with a flat head screwdriver easily
-when putting pump back on, I just tightened the 3 bolts down evenly and the lower hard line clicked into place
-primed the pump and it fired up easily
Honestly don't be worried about this install!
Now on my way to getting Stratified!!!!!
strukoff is offline
 Old 09-11-2012, 05:46 PM   #308
manila's Avatar
Posts: 1,767   (View Stats)
Maybe I can get your guys opinion, I have a friend who was offered to switch his OEM internals with Autotechs (with roughly less than 500 miles). Here's the scenario the Autotechs were installed by a shop PTuning located in Manassas VA if your not familiar with them. Does this seem like a good/even trade? I saw that the internals required gloves, soaking in gas/fresh oil.
The reason for the swap the guy with the Autotechs is trading in his speed for a focus ST
'12 MS3 Black Mica w/ Tech
manila is offline
 Old 09-11-2012, 06:06 PM   #309
smoogs12's Avatar
Groans: 423
He would be an idiot not to. Seems pretty straight forward to me
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 09-11-2012, 06:57 PM   #310
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Have one of them log it and see how much fp it's holding.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosted Beluga is offline
 Old 09-17-2012, 03:42 PM   #311
manila's Avatar
Can any of you shed some light on this question? I'm about to install my internals soon and my test pipe. I understand your suppose to drive easy for a good 100 miles or so with the internals in correct? I was wondering if I should install the internals first and let them set for a few miles and then install the test pipe, or would it be fine to install them simultaneously?
manila is offline
 Old 09-17-2012, 03:46 PM   #312
adlpb's Avatar
Groans: 669
Simultaneously is fine. And 100 miles is excessive. You don't need anywhere near that
adlpb is offline
 Old 09-17-2012, 03:54 PM   #313
manila's Avatar
Ok sounds good appreciate your input!
manila is offline
 Old 09-27-2012, 08:57 PM   #314
Originally Posted by wolly6973 View Post
Not sure what the OTS maps command for fp for stage 1, but that may be all that is requested.
Also, cpe pumps tend to run closer to stock pressures than autotech & kmd.
Try upping the boost and increasing fp and see if you are still holding pressure. Do these in separate map revisions though, so you will know what pushes it over the limit.
Discuss:
Fuel Pump internals Install!
Raider is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f633/fuel-pump-internals-install-125915/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-29-2014 05:22 PM
Fuel Pump internals Install! rghispanic88 2010 MS3 - How-To's 445 07-17-2017 11:53 AM
oil in engine bay after pump internals install Realgib3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-24-2009 05:04 PM
Page generated in 0.54678 seconds with 47 queries
