 Old 05-04-2011, 09:07 PM   #81
2010Speed3's Avatar
Posts: 607   (View Stats)
2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world
Originally Posted by Smily27 View Post
Ok, so looks like I'm in the clear?
Yeah I was kinda the same way you're feeling. I didn't know when I was really in the clear or if I knew that the internals were failing. I kinda got an idea of how bad it can be when I saw a couple of videos of some PTP pumps failing. lol
SOLD on 08/2013
2010 Black Mica MazdaSpeed3
Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC
2010Speed3 is offline
 Old 05-09-2011, 06:01 PM   #82
mrFanel's Avatar
Posts: 487   (View Stats)
mrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the world
Woot! Looking forward to getting this done this weekend
Can you guys please confirm whether taking down the SRI/TIP is really necessary? I don't feel like dicking with that again
Thanks!
mrFanel is offline
 Old 05-09-2011, 06:04 PM   #83
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
It is not necessary.
The only thing I removed was the TMIC.
wolly6973 is offline
 Old 05-09-2011, 06:18 PM   #84
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
Thanks!
not necessary but it definitely give u a lot more space to work with. its up to u
2010 Black Mica
rghispanic88 is offline
 Old 05-09-2011, 06:44 PM   #85
mrFanel's Avatar
w3rd. I am heading out to my homie's this weekend to do the pump internals since i have no tools at my apt complex not to mention they don't allow you to work on cars.
Probably will drop itv-22 spark plugs too since I hope to get them by that time and since the TMIC will be out
mrFanel is offline
 Old 05-09-2011, 07:48 PM   #86
Groans: 263
nice man
2010 Black Mica
 Old 05-10-2011, 12:55 AM   #87
speed_AK's Avatar
Posts: 20   (View Stats)
speed_AK is a splendid one to beholdspeed_AK is a splendid one to beholdspeed_AK is a splendid one to beholdspeed_AK is a splendid one to beholdspeed_AK is a splendid one to beholdspeed_AK is a splendid one to behold
Thanks!
I only removed the TMIC shroud. Removing anything else is not necessary, and is a waste of time. Take your time and you'll be alright.
speed_AK is offline
 Old 05-10-2011, 01:34 AM   #88
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
great job with the write up
forcedinduktion is offline
 Old 05-10-2011, 11:29 AM   #89
justint5387's Avatar
Posts: 608   (View Stats)
Thanks!
No, I will show you the way lol
justint5387 is offline
 Old 05-13-2011, 08:00 AM   #90
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
thanks for the write-up! nicely done. did the install last night and this made it a hundred times easier.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline
 Old 05-13-2011, 08:10 AM   #91
indianaryan's Avatar
Posts: 496   (View Stats)
Groans: 39
I installed my internals as well...finally! I will mention that for the 19mm open wrench, it may be beneficial to find a stubby one. The normal length one is really hard to fit down in the tight space behind the fuel pump. I took off the TMIC and the hose coming from the turbo to help open up some space.
Also, for those afraid to take apart the fuel pump and install KMD or Autotech internals, don't be. The hardest part by far is taking the fuel pump off and putting it back on. Once you have it off, it's easy to install the internals. Be sure you've got a vise though.
2010 Silver Mazdaspeed3
indianaryan is offline
 Old 05-13-2011, 08:30 AM   #92
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
I installed mine last week and everything went perfect. only thing i removed was the sri because I wanted some extra room.
Mods: stock
faeker is offline
 Old 05-13-2011, 12:02 PM   #93
Uranium9v's Avatar
Posts: 142   (View Stats)
Uranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond reputeUranium9v has a reputation beyond repute
quick question, how do the internals lubricate? Do they continually run in the original oil you put on them or do they maintain a thin fuel layer for lubrication? I know there's a little hole in the one piece, thought maybe that's to allow fuel or oil to lubricate it.
Uranium9v is offline
 Old 05-13-2011, 03:36 PM   #94
TulsaVR93FD's Avatar
Posts: 214   (View Stats)
TulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the worldTulsaVR93FD is the leader of the world
Groaned at 60 Times in 32 Posts
Read the thread
TulsaVR93FD is offline
 Old 05-13-2011, 04:53 PM   #95
faeker's Avatar
Groans: 731
SKEET SKEET MOTHERFUCKER!!
donate you non heterosexual person
Mods: stock
faeker is offline
 Old 05-14-2011, 03:55 PM   #96
mrFanel's Avatar
Did mine today with a buddy who did it on his GenDone a while back - here's my take on things:
1. You do not need to depressurize the system; just let it sit for 10-15 minutes to let the engine cool if you drove it; if you did not drive it - get going, it's not primed anyway.
2. Removing the Intercooler is NOT necessary... but I removed mine anyway because I changed my plugs.
3. Definitely use vice grips. Definitely.
4. You can drop your pump once - it will survive /facepalm
5. The bug nut for the bottom feeder metal hose is a bitch. I hate it. We're not talking.
Other than that - it's pretty much straight forward. Oh - and as someone mentioned - make sure you bolt the pump in evenly!
mrFanel is offline
 Old 05-29-2011, 12:21 PM   #97
RMCAT's Avatar
Posts: 170   (View Stats)
RMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond repute
woodworker vice should be good?
||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots||
RMCAT is offline
 Old 05-29-2011, 02:53 PM   #98
Groans: 263
as long as that motherfucker doesnt move, then yes
2010 Black Mica
 Old 06-03-2011, 11:06 PM   #99
reckywind's Avatar
Posts: 99   (View Stats)
reckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant futurereckywind has a brilliant future
great write up! thanks so much for this.. about to order mine in a couple of weeks i think.. just to be sure, this is the one right?
Audi - A3 - 2.0T FSI - Engine - KMD Tuning - 2.0T FSI High Pressure Fuel Pump Kit - KMD Tuning
reckywind is offline
 Old 06-03-2011, 11:27 PM   #100
Groans: 263
yep, that or autotech. i will be doin another install with autotech internals very soon. should be the same process
2010 Black Mica
 Old 06-10-2011, 05:58 PM   #101
memoriesmazda's Avatar
Posts: 157   (View Stats)
memoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond repute
for all the people saying the took out the full pump without removing the TIP bull crap lol there is no way to losen that bottom plug made of metal without removing the TIP unless im missing somthing..
Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech Internals
Coming Soon: ll UR Cat-back ll
memoriesmazda is offline
 Old 06-10-2011, 06:05 PM   #102
0187
esr010's Avatar
Posts: 486   (View Stats)
esr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the world
Groaned at 9 Times in 5 Posts
I did mine and another ms3 without removing the tip. I used a big wrench at an angle no problem.
esr010 is offline
 Old 06-10-2011, 07:43 PM   #103
Groans: 263
it is possible but u can take BIG risk of bending or possibly breaking the lower aluminum fuel line. All i have to say is that it is better to be safe than sorry
2010 Black Mica
 Old 06-11-2011, 09:09 AM   #104
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
well since iam doing the cobb inlet turbo install and change the pump ill be easy on it ,
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline
 Old 06-11-2011, 09:57 AM   #105
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I did mine without removing the CS TIP... No problem at all.
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 06-11-2011, 12:30 PM   #106
alright so went up to ace and got the 18mm deep socket and with i vice the bolt came out no problem, now that i have the stock internals out do i need to remove anything else before i put them in? I tried to slide them in from the bottom but it felt like they weren't going in and i didnt want to force them and scratch them. Here is the stage im at now.
 Old 06-11-2011, 12:36 PM   #107
Bucker's Avatar
Groans: 451
Yeah put the new internals in the same way the old ones were. I think it slides in from the top, then the big part goes in from the bottom. When you put the "Hat" on, set the little shim things inside of it and make sure it will stay in place.
After that, put it all back together.
Bucker is offline
 Old 06-11-2011, 12:54 PM   #108
well i couldnt get the long cylinder thing in thro the top (spring) so i had to push it in thro the bottom, i had to force it a bit to get in in and the long cyclinder that goes throw the hole thing doesn't slide well thro the thing, but the Botton fat part does, is this normal?
Also with that "hat" peice all i do is place them inside that hat and set it on top? when i did this i could pull it off easily, that correct?
 Old 06-11-2011, 01:21 PM   #109
man i must be stupid i cant get the stupid Hat shaped piece with the 2 black pieces in it to snap onto the top of the piston cylinder. The directions say to not push down on the Hat piece but to push up with you thumb from the bottom of the cylinder, but when i do that it goes up into the fatter piece and i cant push no more with my thumb. im puzzled.
Edit: ok figured it out end up your suppose to put the Hat peice ont he pistion first then put the 2 black pieces on... i am an idiot lol
 Old 06-11-2011, 08:19 PM   #110
Bucker's Avatar
Groans: 451
Sounds like you got it! No man, it took me a couple minutes to get that right... it didnt seem right just sitting in there haha.
Bucker is offline
 Old 06-23-2011, 10:32 AM   #111
shingojr's Avatar
Posts: 22   (View Stats)
shingojr will become famous soon enoughshingojr will become famous soon enough
just a quick question on #15..."make sure nothing fell in the fuel pump." you mean when the parts in the gasoline?
shingojr is offline
 Old 06-25-2011, 02:08 AM   #112
nuprin503's Avatar
Posts: 488   (View Stats)
nuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the worldnuprin503 is the leader of the world
Groans: 30
Groaned at 40 Times in 13 Posts
Great write up!! I just installed my KMD's this evening. I just removed my TMIC and had no problems with taking off and replacing the pump. Did a few logs, pump is holding up great!! I'm gonna take it easy on her for a few hundred miles... It's gonna be tough!
nuprin503 is offline
 Old 06-26-2011, 06:01 AM   #113
3mazdaspeed's Avatar
Posts: 485   (View Stats)
3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world
Removed my TMIC and my intake. I was installing sparkplugs and SRI. But it was easier then I thought. I had a little issue putting it back in but i just turned the engine over real quick and it was good.
Was a little worried aobut starting it, because I worked on it. But everything turned out good
3mazdaspeed is offline
 Old 06-27-2011, 09:38 PM   #114
tooslow10's Avatar
Posts: 700   (View Stats)
tooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the world
Thanks op for the write up, gave me just the push I needed to work on mine.
no more MS3 in the driveway
but there is an EcoBoost FX2 that will be hunting on the freeways soooon!!
TEAM LBN BEERS -- FYCN
TEAM MEAGHAN -- FYCN
tooslow10 is offline
 Old 07-12-2011, 10:25 PM   #115
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
subbed for doing this next month
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline
 Old 07-24-2011, 02:57 PM   #116
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Just did mine. Things are so much harder the first time around and for no good reason. I didn't print the directions fully but its a easy install. I was just so paranoid about making sure the internals were clean I spent most of my time on that. Redoing it and making sure everything was clean. I was stupid and when i unclipped the yellow fuel line I got fuel sprayed straight into my eyes. That was a bit scary. I wish I didn't take off the battery and tray cause when I first looked at the space I had to work with I thought there is no way I can get to that fuel bolt, but I guess you can from reading this thread again.Everything turned out well none the less and the car is running fine. I'm going to be taking it easy for a bit.. DP is next..
specvspeedfreak is offline
 Old 07-25-2011, 12:36 AM   #117
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
Just finished my install. I took off my TMIC cuz i wanted to look at some stuff but it didn't have to come out. Only the shroud.
I did KMD internals and everything went very smoothly.
Thanks for the write up!
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline
 Old 07-25-2011, 03:22 PM   #118
RMCAT's Avatar
any kind of motor oil will do the trick right?
RMCAT is offline
 Old 09-01-2011, 12:58 PM   #119
jimmyx27's Avatar
Posts: 52   (View Stats)
jimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud ofjimmyx27 has much to be proud of
Ok so im having a bit of trouble on the removal of the pump. I removed all of the lines except for the aluminum one. I unscrewed the nut but I cant seem to get the line off. I read that post about possibly kinking it so I didnt want to try to hard. Is there a trick or sumthing im missing or do I just need to man up and pull it off? Any help wiukd be appreciated. Thanks
jimmyx27 is offline
 Old 09-01-2011, 01:07 PM   #120
skeurton's Avatar
The metal fuel line is recessed a bit into the fuel pump itself. Just takes a little bit of force when pulling the fuel pump out. Same goes for re-installing the pump.
2011 MAZDASPEED 3
skeurton is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f633/fuel-pump-internals-install-125915/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-29-2014 05:22 PM
Fuel Pump internals Install! rghispanic88 2010 MS3 - How-To's 445 07-17-2017 11:53 AM
oil in engine bay after pump internals install Realgib3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-24-2009 05:04 PM
Page generated in 0.58864 seconds with 46 queries
