 Old 09-14-2011, 04:18 PM   #161
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I also have the PTP valve.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 09-14-2011, 04:37 PM   #162
JumpingJackson's Avatar
Posts: 967   (View Stats)
+1 I have one too no issues so far.
2006 Titanium Gray MS6 Mods:
DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator
Cobb AccessPort + 3 Bar Map Sensor
CP-E TIP , RMM
Aquamist HFS-4 WMI Injection System
Bullseye - T3 .55AR S259 Turbo
Synapse - BOV
Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC
PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return
Turbine Tech / Street Unit - Front & Rear Diff Mount
eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers
JumpingJackson is offline
 Old 09-14-2011, 07:18 PM   #163
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
so his valve has the adapter thinggy that SD is having issues with?
yeah when cobb/anthony gets the scalars figured out you guys will be set.
that and once you get some 20% larger injectors LOL
His valve has almost exactly the same dimensions as the oem. It doesn't require any adaptors.
My ported injectors seem to be helping... I don't know of anyone else who's hit 425~450g/s with no aux fueling at all..
SSinstaller is offline
 Old 09-14-2011, 07:54 PM   #164
708
Erich's Avatar
Posts: 4,274   (View Stats)
Just to be clear. I think when dano said "his valve" he was referring to superskater's and when you say "his valve" you are referring to John's. Besides that, accurate post... including the comment about fueling requirements for 450g/s... but hey, what is wrong with a little meth, keeps the intake runners clean.
Erich is offline
 Old 09-14-2011, 08:11 PM   #165
also just to clarify, the adapter that scott made is not what failed, its just a simple right angle adapter cause the RV is so freaking huge.
it was his RV that failed. im going to keep an eye on mine to see how it does over the next year.
i got an update from cobb tonight and the car def runs alot better and seems to hit its targets but when i go WOT it just dumps an insane amount of fuel and i get a studder from being so rich. were def getting closer guys and between christian, braden, david and even trey, everyone of them is working on this one issue right now and they have been racking their brains over it as they keep discovering more ish.
more updates to follow!!!
superskaterxes is offline
 Old 09-14-2011, 08:43 PM   #166
708
Erich's Avatar
Sounds like what happened when I commanded 2100.
Erich is offline
 Old 09-14-2011, 10:42 PM   #167
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I'm in the 90's at 360 g/s and mid 11 AFR.s So with the same AFRs, i guess i'd be around 400 g/s at 100.... and if i leaned it out to 12:1, i'd maybe get another 10.
That's very optimistic rice cake though.... fortunately my meth is up and running, and i won't have to rely on optimism for the short term hahaha.
Oh yeah... and you should dyno.
What timing are you able to run without KR issues?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 09-15-2011, 06:35 AM   #168
Realgib3's Avatar
Posts: 2,443   (View Stats)
I have the 2150money from John waiting to be installed cuz I'm lazy, but I should haveit to start messing with this weekend and... he says he's working on a complete "kit" to allow us over 2500psito once the sensor is figured out... not sure about that one yet but we'll see. Oh and he said they'll only use the 2150 on our cars for now cuz using the 2250 valve lines started exploding
Realgib3 is offline
 Old 09-15-2011, 07:00 AM   #169
Groans: 60
I havent found my limit yet. Currently at 16deg adv at 7k rpm ~23psi, 12.1 afr.
 Old 09-15-2011, 09:29 AM   #170
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I'm fueling the equivalent of 425-450g/s with E85, and I'm seeing that fueling @ ~4k rpm all the way to 6.5k rpm. No upgraded HPRV or meth, here. Actually, the car went rich a couple nights ago after I fixed a small vac leak I had been tuning around - the car logged 469g/s @ .78l (~11:1 gas AFR), lol.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 09-15-2011, 12:53 PM   #171
Captain
You ever going to dyno? I love your setup man.
www.permtuning.com
 Old 09-15-2011, 04:25 PM   #172
Speeeeeed
06Speed6's Avatar
The line didnt explode, it was the seal where it connects to the rail that started leaking.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 09-15-2011, 07:36 PM   #173
Groans: 60
I'm never finished, so I've never been ready to dyno...lol
My butt dyno feels the power dropping in the upper rpms(when my InjDC gets above about 85%), so until I get it below that level for the entire power band I won't bother to dyno..
I will eventually, but not before I switch to a blow through MAF, get a full 4" intake made, and get the new IM installed and some port injection working... When will you have that injector controller finished/for sale??
 Old 09-19-2011, 09:31 PM   #174
Realgib3's Avatar
Any updates Skates? I'm finally putting in my RV Wednesday and I wanna know how long it will be before you've done all the hard work and gotten out all the kinks with the new sensor, so I can just put the sensor in and not have to do any of the heavy lifting and just enjoy all your testing!
Realgib3 is offline
 Old 09-21-2011, 05:10 AM   #175
UPDATE:
so things seem to be working correctly but i think the scaling is still off some. cobb has figured out all the tables we need and everything is matching up but the slope of the new sensor is still a little bit off from what ti should be. at this point hopefully its just a matter of trying some new scalars to get it to match up perfect but otherwise all the hard work and questions are over!!!
 Old 09-21-2011, 05:46 AM   #176
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
so john's valve is working? how much is it?
xcoldricex is offline
 Old 09-21-2011, 07:10 AM   #177
kmac's Avatar
Posts: 1,792   (View Stats)
When is the new atr release for fuel corrections
kmac is offline
 Old 09-21-2011, 07:26 AM   #178
is this towards me? im not using it
which corrections are these? for the sensor? if so i have no idea
 Old 09-21-2011, 07:31 AM   #179
kmac's Avatar
That be the one.
kmac is offline
 Old 09-21-2011, 07:51 AM   #180
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Can this be STICKIED PLEASE??????
07 MS3
The original Genpoo Hater
Chimmike is offline
 Old 09-21-2011, 10:14 AM   #181
i groaned you because its already a sticky n00b haha
 Old 09-21-2011, 10:17 AM   #182
Just in case, @CCC may want to hit up the last couple of pages of this thread.
(I know the title says sensor, but this page mentions available proven valve replacements and upgrades)
rfinkle2 is offline
 Old 09-21-2011, 10:37 AM   #183
Will fuck up ur day
Chimmike's Avatar
Groans: 433
deserved
07 MS3
Chimmike is offline
 Old 09-21-2011, 01:50 PM   #184
I have been working with BMotorsports, as a result of this you can now order a preassembled adapter harness from them
Home » Shop » Connectors / Harnesses » Tyco / AMP » Mazda Pressure Sensor Adapter Harness
CP-E TIP , RMM
Synapse - BOV
 Old 09-21-2011, 03:32 PM   #185
good job phil!!!!
FWIW, you can make you own for like 13 bucks if u bought it all separately but thats up to you
 Old 09-21-2011, 04:36 PM   #186
Captain
Sooner than later.... i'm tired of my pos meth injection.
www.permtuning.com
 Old 09-21-2011, 07:42 PM   #187
708
Erich's Avatar
I'm just starting to like mine. The failsafe on the other hand, not so much.
Erich is offline
 Old 09-21-2011, 08:01 PM   #188
ILL3ST
xcoldricex's Avatar
Groans: 105
i apologize, i'm behind as i went on a hiatus, but now i'm in BT territory and am curious when these higher pressures are needed. what are the current options for relief valves? i read that SD's isn't in production/working? superskaterxes, you have your own? then just ptp?
 Old 09-21-2011, 08:03 PM   #189
708
Erich's Avatar
With my S259 I was running out of injector at 16PSI at the top of 5th (7000+ RPM)
Erich is offline
 Old 09-21-2011, 08:14 PM   #190
im out in injector mid summer on a ATP 3076. just depends on your VE.
i have the SD RV for reference
 Old 09-21-2011, 11:20 PM   #191
ILL3ST
xcoldricex's Avatar
Groans: 105
so what's the hold up with the SD RV - the thread seemed to have died off.
so i just have John's to go with? i'm going to run into problems - i'm running fp hta3076.
 Old 09-22-2011, 03:42 AM   #192
kmac's Avatar
Johns is fine and there's no modification required , just remove and install the valve.
kmac is offline
 Old 09-22-2011, 03:58 AM   #193
ILL3ST
xcoldricex's Avatar
Groans: 105
ouch $295! does the IM have to come off? wondering if you can finagle it on without going through all of that, especially if you've taken that foam piece off, that cover on the end and the EGR tube.
 Old 09-22-2011, 04:30 AM   #194
i did mine with no cover, EGR tube, or CP
 Old 09-22-2011, 05:00 AM   #195
Realgib3's Avatar
Yeah the install took me 20 min last night, its not hard at all and call John and u can get it for that $22 I think
Realgib3 is offline
 Old 09-22-2011, 10:13 AM   #196
708
Erich's Avatar
Yup not hard, just kind of a pain in the ass. 1/8 of a rotation, flip wrench, 1/8 of a rotation flip wrench. Scrape knuckles a couple hundred times.
Erich is offline
 Old 09-24-2011, 10:51 AM   #197
ILL3ST
xcoldricex's Avatar
Groans: 105
he said it was for the first batch only :\ anyone have one for sale?
 Old 09-24-2011, 11:52 AM   #198
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i will be happy when all this testing is done and in stone
Nitr0EngiE is offline
 Old 09-26-2011, 01:36 PM   #199
so looks like the pressure matches up good but theres still something missing that needs to be found because my LTFT's are still pulling almost 20% and my AFR's are in the 9's at WOT. cobb is still working super hard on this and they know just how important it is!!!
 Old 09-26-2011, 02:00 PM   #200
708
Erich's Avatar
If they need more testers I should be ready to do so by the end of the week. I wonder if you are on the edge of what the injectors can handle and they aren't closing as efficiently as they should, letting unmetered fuel past.
Erich is offline
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
Possible Fuel Rail Pressure sensor failure? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 07-06-2012 04:17 PM
fuel rail pressure sensor Skup1993 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 02-05-2011 09:14 PM
where can i find a mazdaspeed 3 fuel rail pressure sensor? Skup1993 MazdaSpeed 6 - Engine, Transmission & Driveline 8 02-05-2011 08:29 PM
Page generated in 0.58116 seconds with 33 queries
