 Old 10-11-2009, 04:34 PM   #1
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
This is great! May be we'll finally get some concrete info, instead of all the conjecture..
SSinstaller is offline
 Old 10-11-2009, 04:43 PM   #2
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
So here are some vids, triggering off the rising edge of the fuel injection event (when injection has stopped). The scope was set this way from when i used it last, and i didn't think to change to falling edge for beginning of injection event until later (cause i wasn't the one looking at the scope, i was the one with tight sphinctor going 140 trying not to kill us, lol).
Here's a 3rd-4th vid with a datalog to match
Boost curve on teh 3rd gear portion looks a lil fucked up, but that's cause i rolled into it wierd, the rest of it is legit and a good representative of the boost & afr's and slight creep i experienced.
Here is a 2-3-4th, it looks pretty good and filmed well:
Here is a 2-3-barely 4th. You can see how the injector spray will overlap with the spark event slightly. I think this happens at teh shift point.
Here's 2 vids of 2-3-4 i think after i started triggering on the falling edge (injector beginning). It helps kinda with seeing the injector event relative to crank signal. There is glare, but you can see the cursor in the upper right hand corner, this is when the injector opens.
Some things to note:
- The injection event is taking up ALOT (read ALOT) of the intake stroke. And you can see how close it gets to the spark event (which when at wot is usually no more than 12-13 degrees BTDC)
- The injector appears to start spraying quite near TDC on the intake stroke. Adam and i did a pull, and stopped the scope at 4500rpms, and counted 24 pulses (to the left of when the injector starts) between the pulse (missing tooth) of the crank sensor. We did the same thing again and stopped the scope at like 6300rpm, and only counted 21 pulses..... so to summerize
...4500 rpm: 24 pulses between missing tooth and injector opening
...6300 rpm: 21 pulses between missing tooth and injector opening
That's about 18 degrees or so moved to the left in the higher rpms. So for the most part, the fuel injector will just stay open longer (closer towards the spark event, as evidenced in the videos), but maybe if it has to, it will move to the left (closer to TDC of intake stroke) a bit, not much, just a bit.
- The time scale during all these videos does NOT change, so as the crank signal and spark event start to squeeze in (cause rpms are increasing) the amount of fuel injected is going to be pretty much constant. We are looking at a single cylinder event, so the amount of fuel injected is pretty much constant across the rpm range (boost creep probably offsets some of my ve lol, keeping my torque decent ish, not sure). My afr's stay right in mid 11's throughout wot.
Have at it guys. To me... This looks like at my power levels (3071, dynoed at 355 sae corrected, so not as powerful as many people at sea level, but definitely not weak) i'm already looking at a very little room for further fueling. But maybe i'm missing some stuff here.
I'll still leave everything hooked up for another week and i'll drive my jeep, but i have to bring the scope back to work during the day lol. I think the vids give us exactly what we need, so not sure what else anyone would want me to film, but just cause it's alot of setup time, i'll leave it hooked up.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 10-11-2009, 04:47 PM   #3
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
to some up what you said am i right that when you command more fuel to meet command it sprays longer so theres a chance its overlapping injection time into the exhaust stroke?
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 10-11-2009, 04:54 PM   #4
Captain
Yes, the injector does look like it starts spraying right near TDC on teh intake stroke, so if you have mega overlap, some of that fuel could certainly flow right out.
It also looks like the injectors could possibly even spray during the combustion power stroke. At least definitely during the shift points. You can see the the injector trace goes right of the spark in a few of those vids.
It looks like the injector spray during both the intake stroke, and well into the compression stroke, and like i stated above, possibly after spark.
www.permtuning.com
 Old 10-11-2009, 04:52 PM   #5
Captain
Lol, just realized i up loaded a ridiculously long video, i'll leave it, but i was basically us trying to figure out if the injector started earlier right at the shift. What was actually happening was the crank sensor and spark were moving left also, and the injector was spraying past spark. This is an aberration caused by triggering at the end of the injector event, not the beginning, and watch the vids again with a careful eye, you'll see that the injector start doesn't change much at all with respect to TDC (or missing tooth).
www.permtuning.com
 Old 10-11-2009, 04:54 PM   #6
Fux Wit It
Darksun280's Avatar
Groans: 175
Roar im gonna throw a slipper at you dumb it down more give me a theory on what happens when you command more fuel.
 Old 10-11-2009, 04:57 PM   #7
Fux Wit It
Darksun280's Avatar
Groans: 175
we are fucking our selves by asking for more fuel or even stock ecu trying to met commanded requirements probably even fucking up our own mixtures. ehh......
 Old 10-11-2009, 05:03 PM   #8
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
wasn't there a thread about people pulling fuel and actually gaining power? Somewhere...
Btw nice job DJ, only helping this platform get on it's way !
Deadman is offline
 Old 10-11-2009, 05:05 PM   #9
Captain
I do want to throw this out there...
We pretty much only saw the injectors stay open past the spark event during a shift.
during a shift...
Could spraying fuel after the spark during a shift contribute to a fouled injector or blown motor?
Thanks, and pulling fuel will almost always result in more power , lol.
Here's another vid for shits and giggles:
www.permtuning.com
 Old 10-11-2009, 05:17 PM   #10
Fux Wit It
Darksun280's Avatar
Groans: 175
shits starting to get deep in here so im gonna fall back till my man Lex naws on this info for a little.
 Old 10-11-2009, 05:34 PM   #11
c'mon lex!!!!
OM NOM NOM
superskaterxes is offline
 Old 10-11-2009, 05:18 PM   #12
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
deep is right. im too scared to post in here!
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 10-11-2009, 07:07 PM   #13
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
You can spray after the spark event, but at diminished returns as far as power goes. It certainly doesnt hurt anything. It should also be said that the air fuel mix doesnt combust instantly when the spark goes off, the flame front takes time to cross the chamber.
One thing I would like to see, if its not too much to ask, is a log at your currect psi and a log at say 5psi. If the injector is injecting for less time at the lower psi then we can probably rule out a change in injector flow. Ide like to know if injection duration is changing due to rpm or due to total intake cfm. If the logs show about the same injection duration then we know injection volume is at play and ide like to rule that out for certain because believe it is not variable but I also have no proof.
Lex: I had heard that our injectors were 100v from someone who logged the voltage, 60 to 70v is more the industry standard though. Also, from the designs I have seen, I have a very very hard time believing that our injectors have no closing cycle, im going to need a injector signal graph for me to believe that.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 10-11-2009, 07:21 PM   #14
Captain
I'd like to see a lower psi log too, and also request a ridiculous afr like 8 to 1 or something at my current psi. I'll put together two maps tonight and try to get those logs sometime this coming week.
Low psi log is going to be very very very difficult for me to do with the fact that i'm already creeping to 22 ish at 75 degrees outside temps. As it gets cooler, my creep gets worse (really wish i had my fucking manifold). So maybe ridiculously low afr's would suffice for your needs 06speed6? I'll try both, but may only be able to deliver one.
www.permtuning.com
 Old 10-11-2009, 07:30 PM   #15
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
You make me horny when you get all smart like this.
jmhinkle is offline
 Old 10-11-2009, 07:45 PM   #16
Captain
Also 06speed6, i think we could also show what your asking by simply boosting to lower psi, like part throttle boost. If the duration is less, then we know flow isn't change when the injector is open. i can definitely do some part throttle boost logs!
www.permtuning.com
 Old 10-11-2009, 08:06 PM   #17
Speeeeeed
06Speed6's Avatar
I mainly wanna see full throttle, near redline, max load logs that show some difference between different fueling requirements.
Changing the AFR could do that I suppose.
I wanna know if the ECU is changing injection duration in relation to crankshaft degrees due to rpm or fueling requirements. I noticed that your injection duration appears to extend after hp and intake charge CFM should be dropping off on a usual dyno log. That made me wonder if it is doing that due to RPM and the injector driver has some way of increasing injector flow with higher voltages etc.
If it is infact extending the injection duration due to RPM then it would seem that we have a theoretical injector redline on our hands.
It could also be that as RPM inceases the injection window decreases and the ECU then extends that window to maintain overall injector duration as RPM increases.
Just to clarify what im getting at...
As RPM increases, if the injection time in crankshaft degrees remains a constant, total injection time in time decreases.
To make up for that lost injection time the ECU could be extending the window in crankshaft degeees in an attempt to keep the total injection time a constant between idle and 6000rpm.
If thats the case, then we have a injector redline and not a hp redline.
BUT if that was the case, then the ECU must also have a way to vary the amount of fuel injected independent of the injection time in time or crankshaft degrees.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 10-11-2009, 08:33 PM   #18
Captain
You need to remember that the time scale on teh scope doesn't change even though the crank signal contracts adn teh spark event moves around. So assuming that my VE is constant across redline, the injection width would not change on teh scope, cause it would have have to inject the same amount of fuel for each cycle. thus be open for the same amount of time for each cycle.
I think as rpm increases, the window does indeed close on us, and necessarily the injection event takes up more and more of crank degrees.
My gut tells me that the injection driver wouldn't be able to change the amount injected with any odd voltage trick. I just sounds a bit fantasy to me. but nonetheless needs to be proven.
One other thought, is how would the injector driver know when to increase or decrease the flow, even if it could. There are only 4 lines that go back to the ecu, so only 4 lines for control. What would tell the injector driver module when to increase for a given width. I think the amount injected directly corresponds to the length of time the injector is open.
www.permtuning.com
 Old 10-11-2009, 09:30 PM   #19
Speeeeeed
06Speed6's Avatar
That is where the mystery begins.
But I also think that if that were strictly the case, the expansion of the window in crank degrees would have slowed in the higher rpm ranges and would have increased speed in the lower rpm ranges where we make power.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 10-11-2009, 09:41 PM   #20
Captain
It does show by teh fact that the injector width stays the same, while the crank signal and spark event shrink around it.
You can think of it the other way around, if the crank signal stayed the same, and spark event stayed the same, teh injector signal would grow!
I'll prove this by triggering off the spark event instead of the injector signal tomorrow!
Ugh, nevermind, i just realized i can't prove it this way. It would look the exact same way, cause the time scale is fixed. But everything i just said still stands IMO.
Basically, to inject X amount of fuel, the injector would have to be open for Y miliseconds, which with an x-axis on the scope of 5ms per division, would take up Z divisions.
So as long as X amount of fuel was requested per cycle (as in a perfectly flat torque curve & flat VE), the injector would always stay open for Yms per cycle, and appear as a fixed width taking up Z divisions on the scope.
The crank & spark however would become faster and faster with increased rpms, and thus appear to squeeze in on the scope screen.
Okay, i'm off to bed. Tomorrow i'll log some part throttle mid boost stuff. After that i'll try ridiculously low afr's and then i'll try low boost (but still not sure if it will work with my IWG).
www.permtuning.com
 Old 10-12-2009, 12:15 AM   #21
Just got back from family dinner (thanksgiving is today in Canada) so I will have to chew on this a little bit more tomorrow. Wanted to thank Dustin for the work put in though!
Lex is offline
 Old 10-12-2009, 12:39 AM   #22
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
I'll just observe.
glocK23 is offline
 Old 10-12-2009, 06:56 AM   #23
so wait if we are injecting fuel from intake to compression whats the diff between DI and PI? this doesent make sense lol
 Old 10-12-2009, 07:16 AM   #24
Fux Wit It
Darksun280's Avatar
Groans: 175
*Warning for possible false information*
Amount and actual time of injection? Bare with my simple mind.. So lets say like instead of PI injecting twice per cycle a di motor will fire 4 times lets say. Needing less total amount of fuel but split between two burst to a total shorter time then a PI fire since its being injected directly into the combustion chamber. Am I COMPLETELY off on that one? Smart guys chime in.
*end false info*
Wait a minute how can a high pressure DI injector stay open during the entire intake stroke do you know how much fuel would be going into the motor? These HP injectors could flow a PI one under the table with the pressure they use.
Edit: shit my info may be from a different type of di injection cycle doubt it applies on our car.
 Old 10-12-2009, 07:27 AM   #25
*end false info*
only some DI applications spray short bursts of fuel, its called stratified fueling.
and the injector can stay open the whole time if its DC is low enough. it only flows as much as its commanded. it wouldent make sense to me from a DI theoretical standpoint to spray during the intake stroke because the point of DI is to spay right before the compression hence the need for uber pressure injectors
 Old 10-12-2009, 07:29 AM   #26
Fux Wit It
Darksun280's Avatar
Groans: 175
Yeah I'm going back to the side lines cause im trying to remember info i don't have in front of me at my work computer.
 Old 10-12-2009, 09:03 AM   #27
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
From what you have discovered about the injectors being open from intake to compression, and HP injectors being able to flow tons of fuel because of pressure, does this now mean that the amount of fuel available isn't the problem? Or that the only option if we need more fuel is to find someone to build a bigger injector, aside from going PI of course because there is no more time to inject? Also could the injectors starting so close to TDC on the intake stroke cause the fuel to pool on the pistonhead and not fully ignite, which would throw soot out the back?
Sry for asking so many questions, trying to wrap my head around the implications of your findings.
psychophyr is offline
 Old 10-12-2009, 09:22 AM   #28
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
so...
Why do the injectors spray twice after a shift ?
could that second spray result in pre-ignition and give us all these bent rods ??
It can't be singled out either cause there has been cases where all four rods were bent and not broken.
Im confused lol
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline
 Old 10-12-2009, 09:36 AM   #29
Captain
Okay, i had a hella epiphany this morning.
First though, here are the part throttle boost vids i promised. I gotta say this was much easier with adam in the car, lol. I'm putting my life on the line here .
Part throttle pulling away from a light
2 psi ish
7 psi ish
10 psi ish
WOT
IMO, this is just as good as running a lower boost map, because like i said, the injector driver module has no logic, no sense of what my throttle is, what my rpm is. It simply opens when the ecu tells it to. And the ecu will simply inject enough fuel to meet the requested afrs.
Okay, now here's the juicy epiphany i had, and i think it helps prove the VVT stuff.
Some assumptions are needed:
- VVT table values are indeed in degrees, but that is crank degrees not cam degrees, so 16 cam degrees = 30 crank degrees. This is plausible.
- Intake valve, with 0 degree cam advance opens right at TDC.
- Exh vavle is fixed and not adjustable, lets assume it closes like 15 degrees ATDC (for arguments sake, i really have no clue at all).
So with a 0 in my VVT table, the intake valve will open right at TDC, giving you 15 degrees of overlap. With a VVT table value at 30, the intake valve will open 30 degrees ATDC, 15 degrees after the exh valve has closed.
When adam and i froze the scope at 4500 rpm and 6300 rpm, we counted 24 crank ticks and 21 crank ticks respectively. My VVT table has 30's (roughly) in the 4500 range, and 7's at or near redline. We know TDC is 20 ticks after the missing tooth, so 24 crank ticks is 24 degrees after TDC (hmmmm, that matches my VVT setting @ 4500rpm). And at redline, we counted 21 ticks (each tick is 6 degrees), so the intake valve opens 6 degrees ATDC (hmmmm, that matches my VVT setting at redlnie).
So i would like to propose that injection spray starts right when the intake valve opens, and further, that the VVT table is indeed in degrees, but it's crank degrees. And a larger VVT value = larger lobe separation angle = lower dynamic compression (cause intake valve opens and closes later) & vice versa.
Originally Posted by psychophyr View Post
...does this now mean that the amount of fuel available isn't the problem? Or that the only option if we need more fuel is to find someone to build a bigger injector, aside from going PI of course because there is no more time to inject? ...
I believe fueling is a problem. I'm not leading the pack with power (but i am a 90% bolted 3071 & my car ISN'T slow), and already we're seeing the injectors open almost entirely from beginning of intake stroke to spark. That's alot, and a definite limit on the amount of power we can make.
Bigger injectors or secondary fueling would seem to be the only potential solution.
Originally Posted by Scatt Nasty View Post
so...
I don't think they are spray twice, I believe it has more to do with the + & - control signals that lex had posted above. There is seriously no way our injectors would spray during the exhaust stroke lol.
www.permtuning.com
 Old 10-12-2009, 09:45 AM   #30
Fux Wit It
Darksun280's Avatar
Groans: 175
I'm confused to. also could it be we are spraying so close to the compression stroke we don't really have much time to lengthen the time of injection so we so actually be starting it earlier? I think thats been mentions but that involved actual control of the ecu logic whihc no one has so this post of mine is moot....
 Old 10-12-2009, 09:47 AM   #31
Captain
When i'm at wot, I'm apparently spraying damn near all the way from teh beginning of the intake stroke, all the way through the compression stroke and very close to teh spark firing.
Start any earlier and your spraying during the exhaust stroke.
Start any later and your spraying during the power stroke.
www.permtuning.com
 Old 10-12-2009, 09:49 AM   #32
Fux Wit It
Darksun280's Avatar
Groans: 175
but in that theory bigger injector that sprays more fuel during the event fixes the issue and we all know it ain't that simple. Any one know how much out stock injectors flow per minute under a given psi?
 Old 10-12-2009, 10:18 AM   #33
Speeeeeed
06Speed6's Avatar
*end false info*
The net fueling requirement is virtually the same between PI and DI, the bonus that DI has is that less excess fuel is needed to control detonation due to chamber temps because the fuel is sprayed directly into the chamber.
If the injectors are staying open for that duration due to intake charge CFM then we need a bigger injector, if they are staying open for that duration due to RPM then we probably have some extra fuel.
~800cc/min @ 1000 net psi, more or less.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 10-12-2009, 10:28 AM   #34
Fux Wit It
Darksun280's Avatar
Groans: 175
Lol yeah we don't need bigger injectors i knew it wasn't that straight forward. They got us regular joes trying to reverse engineer shit. Damn you mazda.....
 Old 10-12-2009, 10:48 AM   #35
psychophyr's Avatar
If this is true we have a ton of headroom, but I was under the impression that noone has actually tested our injectors at thier normal operatiing pressures.
 Old 10-12-2009, 10:01 AM   #36
Captain
Why wouldn't it be that simple? Nobody's ever tried bigger injectors. It's that simple in other applications, right?
www.permtuning.com
 Old 10-12-2009, 10:02 AM   #37
Fux Wit It
Darksun280's Avatar
Groans: 175
whoosh tried. granted his only flowed like what 10% more fuel i think maybe alittle more.
 Old 10-12-2009, 10:04 AM   #38
Captain
And we're still trying to catch his dyno...
www.permtuning.com
 Old 10-12-2009, 10:05 AM   #39
Fux Wit It
Darksun280's Avatar
Groans: 175
It can't be that simple cause then we are getting a false reading when people are pulling fuel. When I tried a 28 psi pull my aem said 10.3 a/fs granted i had raw fuel and soot coming out the back of the car which means i was getting over lap and maybe the wideband was reading wrong? But my DH was reading similar a/fs too. also you got SU mark and P3 pulling fuel. it don't all add up.
 Old 10-12-2009, 10:10 AM   #40
Captain
I think you may have been spraying into the power stroke, and ALOT of that fuel probably went un-burnt, but possibly still registered on the 02 sensors.
Either that, or maybe the ecu knows when the injection window is maxed out, and it closes the throttle as a protective measure. I dunno, but we have hard facts right in front of our faces.
www.permtuning.com
Have you measured when the injectors... djuosnteisn MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 241 05-15-2016 01:31 PM
New Injectors 06Speed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 50 02-25-2014 04:08 PM
Measured Exhaust Manifold Pressure Ziggo MazdaSpeed 3/6 - Turbo Induction 30 06-19-2012 11:40 AM
Anyone take out their injectors? AFcadet MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 14 03-22-2012 01:29 PM
Review: 2010 Ford Taurus SHO gets measured against the original Haltech Automotive News 0 09-14-2009 10:30 AM
Page generated in 0.75916 seconds with 32 queries
