 Old 03-01-2012, 09:24 AM   #121
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I am picking mine up today and will be pulling IM tonight and doing this over the weekend.
Can you grab some pictures of the stockers next to the Toyota ones?
Edit: Not such a huge deal. Just checked the OP and there was a pic there comparing them!
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 03-01-2012, 12:15 PM   #122
aviator79's Avatar
Posts: 3,934   (View Stats)
what happens if one of my injectors gets stuck? Make a removal tool I guess? We will see tonight...:
aviator79 is offline
 Old 03-02-2012, 11:05 PM   #123
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Badass substitute OP... nice looking out
pzr2874 is offline
 Old 03-02-2012, 11:20 PM   #124
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Replacing seals does suck, but its not too terribly bad, just annoying and a little time consuming...especially when you button up the car only to realize you didn't plug in the injector harnesses!!!
Still on stock seals here, too.
I'm interested in these seals, but replacing them is a job I'd want to do just once.
Tapadatass
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
mrmonk7663 is offline
 Old 03-02-2012, 11:21 PM   #125
pzr2874's Avatar
Groans: 146
^LOL
pzr2874 is offline
 Old 03-04-2012, 10:16 AM   #126
aviator79's Avatar
I installed them. My stock seals were fine it seems. These do look like they are better than stock. Mine were not brass, they were aluminum I guess. I replaced Torx with studs as recommended and cut dimpled washers off torx to reuse. Knowing the torque spec for the toyota’s might be useful but I have no torque wrench. But I can imagine someone could over torque and crack a crowsfoot. Wish I had bought an extra so I could have seen how much they crush. For $8 they look like they will do the job.
 Old 03-04-2012, 10:50 AM   #127
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Haha. This is awesome. I hope it works.
2012 WRX HB w/mudflaps yo!
spnkr21 is offline
 Old 03-04-2012, 01:46 PM   #128
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
How did you get the injectors out Aviator? Did you use the CP-e tool or did you use your girly fingers to extract them out?
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline
 Old 03-04-2012, 01:51 PM   #129
mrmonk7663's Avatar
I would not attempt this without an injector removal tool on hand. All 4 of mine were stuck solid, and it took at least 5 hard slide hammer bulls to break them out. Something else to try is spray WD40 around the bottom of injector under crowsfeet and let sit for 10 minutes.
 Old 03-04-2012, 02:30 PM   #130
driver311's Avatar
Posts: 1,769   (View Stats)
Wierd mine slid right out of my 9k motor.
Mazdaspeed
driver311 is offline
 Old 03-04-2012, 02:43 PM   #131
mrmonk7663's Avatar
Lucky!!!
 Old 03-04-2012, 08:43 PM   #132
Nataphen's Avatar
Posts: 2,704   (View Stats)
I'd definitely want to get some sort of torque specs on them, but other than that, they look like they'd work great for high power applications. What fuel pressure did the Toyota diesels with these run? Probably a lot more than our measly ~2000.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 03-05-2012, 10:06 AM   #133
aviator79's Avatar
I used a pry tool to pop them loose and then sprayed a bit of lube under them and then they will twist loose as you pull them. Had electrical tape on the tip so didnt damage them when I popped them. Damaged the first one because I didnt realize all I had to do was spray lube and twist lose.
http://www.mazdaspeedforum.org/forum/foru...g-sits-106942/
Probably a good idea.
 Old 03-05-2012, 10:14 AM   #134
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
waiting on the words:
"They WORK & I'm happy with the results! Go ahead & order yours now!"
340hp / 371tq
TiGraySpeed6 is offline
 Old 03-05-2012, 10:28 AM   #135
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
How did they work out? Now that my 6 is running, i have more time to wrench on the 3, and it needs seals bad. I may throw em on sooner than later.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 03-05-2012, 10:39 AM   #136
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
In for Irish cock ring on the cheap
dougefresh_ is offline
 Old 03-05-2012, 03:08 PM   #137
pzr2874's Avatar
Groans: 146
^Didn't know you were Irish...
Bump for ANY results...
pzr2874 is offline
 Old 03-05-2012, 07:05 PM   #138
@qtrmile beast
superskaterxes is offline
 Old 03-06-2012, 11:51 AM   #139
1/2 Irish, 1/2 Italian, 1/2 Mexican. Nah, I am a euro mutt though.... mostly Irish/Italian with a sprinkle of French, Danish, & Gestapo.
 Old 03-06-2012, 02:40 PM   #140
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
1/2 plus 1/2 plus 1/2????
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline
 Old 03-06-2012, 02:49 PM   #141
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
That's 150% mother fucker.
"Exclusivity" - CP-enis
Demodded.
The Seals
Tokay444 is offline
 Old 03-06-2012, 03:10 PM   #142
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Psst...He's really Russian.
Enki is offline
 Old 03-06-2012, 03:22 PM   #143
1:30
^This!
 Old 03-06-2012, 03:32 PM   #144
MS6FL's Avatar
Groans: 43
hahahahahahahaha!!!!!!! Damn, compleatly forgot that scene! Love that movie!
MS6FL is offline
 Old 03-06-2012, 03:47 PM   #145
aviator79's Avatar
They work. Buy them from your local toyata dealer. Only cost me $8. I havent driven the car yet but I will...I will. Hooked up Synapse BOV and was Ts. Had to order a bung 1/8 npt to 3/16 barb and will have the bung welded onto CPE FMIC hotpipe for boost only source as I have the old synapse. Wanted to buy a new one but this will work fine. I got some Ts and for now I just Td into WG again so I will drive to work tomorrow.
Anyways, I could feel them crush a couple of thousanths so I know they worked. Like I said, the next person, order 5 and if you have a micrometer or calipers measure before and after, if not just post an after pic to show hom much they crush. 50-60ftlbs and you will see they probably flatten right out. Ive no idea what I tighted to so that is just a guess...Ive never used a torqe wrench and have never had an issues but I have worked on cars for a while and had a job repairing spindles so I have an OK idea of how much force to use. Im not DJ, but I know how to wrench on stuff.
I have no way to monitor as my spare DH cable disappeared and I just sold the one I was using with the DH EGT probe. I just got an AP as I just removed my SB and am trying to figure out how to use it. Well I havent tired yet actually. I figure I should hook up the AP to monitor some stuff but am unfarmiliar how to do that and if you can only do logs it wont allow me to see what is going on while I am driving so not that usefull. I will probably just take it easy as I ordered OBD connectors and DH plugs to make a few spare DH cables.
There that was my long usseless unimformative reply. Now I go home and play with car.
 Old 03-06-2012, 03:53 PM   #146
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
ORDER NAO BEFORE BACKORDER!
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline
 Old 03-06-2012, 07:40 PM   #147
ORDER NOW BEFORE ST. PATTY'S DAY RUSH!!
 Old 03-07-2012, 07:58 AM   #148
aviator79's Avatar
Car drove great on the way to work today. Synapse BOV hooked up and working so I am happy. Valves all clean so my car is happy. Seals upgraded so now I have no worries about them failing and I saved $172.
 Old 03-07-2012, 08:21 AM   #149
J-Liss's Avatar
Groans: 81
WOW CP-E just got f'ed.
<3 the MSF community.
2004 mazda 3-Daily
2008 mazda 6-Wife
J-Liss is offline
 Old 03-07-2012, 08:39 AM   #150
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Purchased, because 120+ is a lot....I bought 12.
Death-From-A-Mile is offline
 Old 03-07-2012, 08:48 AM   #151
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
how much PSI and load are you generating on those? And lets not forget it takes some time at higher cylinder pressure to work the OE seals lose. Not trying to be negative just realistic
I hope to have mine installed sometime this month or next.
Dano is offline
 Old 03-07-2012, 09:09 AM   #152
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
Subbed. I have a fairly high amount of gray smoke come out the exhaust after I go WOT sometimes. Could this be blow seals?
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline
 Old 03-07-2012, 09:13 AM   #153
most likely that's a negative-
Blown seals are usually found by high amounts of false KR, funny popping sound by the injectors, and a loss of power, even a slight fuel smell.
gray smoke from exhaust mid-shift I'm pretty sure is usually the result of going rich during shift.
340hp / 371tq
 Old 03-07-2012, 09:13 AM   #154
aviator79's Avatar
Well lets see. They kind of fucked everyone that bought the standback, but that’s not really their fault. There was no AP when I bought the SB. But discontinuing it made the decision easy to pull it and switch to the AP. Thank god I never had my ECU flashed as I would have had to pay them to unflash it.
Also, they advertise the CPE dual catback as “quiet”:
Well, after innumerable requests, cp-e™ has finally developed a quiet, full 3” stainless steel dual outlet exhaust system for the SPEED6!
I could not stand it. Sold it, put my OEM back on. Just bought a MF catback so hopefully that will be better. And at $444 shipped it’s a pretty good deal. Paid CPE $800 (GB price when if first came out about 10 months late) + shipping + had to ship it back to have them weld in the resonator that they left out, but is on the sound clip they use as advertisement and pay them $100…
They sell the seals for way too much as they HAD the market cornered. If you have not already, go to the first post and thank @paveltol for providing this info to us.
Anyways, there are certain things I liked about CPE, but im not as huge of a fan as I was back in the day. Im just happy that they are not the only place I can buy parts these days. Just don’t let them know about these seals or they will buy out the market (would not be surprised if they did this) then resell them for $20 a piece or just throw them out so they could continue to sell the SAFE SEALZ!
As I stated here:
http://www.mazdaspeedforum.org/forum/foru...ml#post1296196
the OEMs are conical with a rubber like coating on them which get squished to create the seal. This coating could shear off over time causing them to fail, however a crush washer will not fail over time. IMO these will work fine.
Again, the only thing I was worried about was not being able to properly clean the surface in the injector mounting hole on the engine that the crush washer would be sealing against. You can clean the injector, but there is no easy way to clean this surface. It looked like some rubber from the OEMs was left behind, but hopefully it was nothing that would cause a problem. This is the only reason I can see that would cause these to not seal.
 Old 03-07-2012, 09:27 AM   #155
Just a few minutes ago I started looking for a set to order-
called my local Toyota dealer, who tells me that while this is the correct part number (11177-64010), but that they are no longer made or available, and that there are none in country according to their system.
This is only one counter guy, at a single Toy dealer, so do not consider this gospel.
The parts guy suggested contacting local parts places to see about ordering an aftermarket version, and I'm also looking online.
Again, this is only one counter guy, at a single Toy dealer, so do not consider this gospel....
-edit to add my local NAPA couldn't find them under the toyota number, and couldn't cross reference anything in the US.
-edit #2- second dealer, this one in Georgia (Thomasville), confirmed none in the southeast US, far as he could tell there are none in the US.
340hp / 371tq
 Old 03-07-2012, 09:57 AM   #156
CPE beat us to them?
or PTP bought them all so he can claim he thought of it first and invented them all.
Easter Bunny is offline
 Old 03-07-2012, 09:58 AM   #157
placed order with Toyota Parts Zone, we'll see how this goes...
11177-64010 - OEM Toyota GASKET, INJECTION NO
340hp / 371tq
 Old 03-07-2012, 09:58 AM   #158
Captain
easter beat me to it, lolol.
www.permtuning.com
 Old 03-07-2012, 10:02 AM   #159
Tokay444's Avatar
Groans: 793
As I stated here:
I fucking like this guy.
You've got a touch of the sharp British whit.
Demodded.
The Seals
Tokay444 is offline
 Old 03-07-2012, 10:51 AM   #160
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
Gay.. how the fuck are they all gone!
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 09:30 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 08:34 PM
Page generated in 0.60779 seconds with 41 queries
