Mazdaspeed Forums
-   MSF KB - Mazdaspeed 3/6 - Fuel (http://www.mazdaspeedforum.org/forum/forum/f633/)
-   -   Methanol Mixing Calculator (EXCEL) (http://www.mazdaspeedforum.org/forum/forum/f633/methanol-mixing-calculator-excel-125089/)
Haltech 09-28-2008 10:40 PM
1 Attachment(s)
Use this to calculate your own mixtures.
oskinosmee 09-29-2008 04:58 AM
I might try to mix some now
gsrtype1 09-29-2008 07:17 AM
cool sub
Stan-O 12-24-2008 11:38 AM
Great Calculator!
One question,
With a 50/50 mix ( or any other ratio mix ) are the mixes specified by Volume or weight?
Thanks
Stan-O
aaronc7 12-24-2008 11:39 AM
50/50 mix means by weight
MarkyMark 12-24-2008 11:47 AM
effin A cotton, effin A.
Stan-O 12-24-2008 01:24 PM
So if you use a refractometer, a 50/50 will read 50% correct?
I have a refrectometer for my marine aquariem, but it's in S.G. and i'm not going to contaminate it, I'm going to buy one with a brix scale. ( or an alcohol one )
Thanks
Stan-O
aaronc7 12-24-2008 01:27 PM
I dunno, I am just gonna use that excel sheet to attain my 50/50 mix. 5 gallon pure meth with 4 gallon of distilled water = 49/51 or something
Stan-O 12-24-2008 01:47 PM
can you use R/O water? and where can you buy 5 gallon of pure meth?
Thanks
Stan-O
aaronc7 12-24-2008 02:06 PM
R/O water?
as for meth, call around to local performance shops. I found some local for $9+ a gallon, but that was a bit much, so I found some in Orlando (little farther away...) for about $6.30 a gallon which isn't bad. I just got a red 5 gallon gasoline container thing and filled that up.
Stan-O 12-24-2008 03:37 PM
R/O = Reverse Osmosis just as pure as Distilled
Thanks, I'll call around
18psiWhiteMS3 07-31-2009 04:14 PM
i mixed 1 gallon meth and 1 gallon water. what the fuk mixture is that
aaronc7 07-31-2009 08:47 PM
Quote:
2 gallons of fail
18psiWhiteMS3 08-01-2009 12:51 AM
what mix are you using aaron?
aaronc7 08-01-2009 06:49 AM
vp m1 meth
nesiospeed 02-21-2010 10:27 PM
GREATS CALCULATOR ..
robertjskidmore 08-02-2010 10:36 PM
what do i need to do to run meth?? anything crazy and if anyone wants to help we dont have to do it here so i dont look like a total tool bag!! lol
Haltech 08-02-2010 10:55 PM
Quote:
You need a meth kit first of all.. Then plumb it in about 8-12 inches from the tbody on your cool pipe from the IC into the throttle body.
Then comes the decision of either running straight 100% meth vs mixing.
Erich 09-19-2012 01:54 PM
Discuss here:
http://www.mazdaspeedforum.org/forum/foru...r-excel-12312/
Page generated in 0.18332 seconds with 11 queries
