 Old 09-28-2008, 10:40 PM   #1
Default Methanol Mixing Calculator (EXCEL)
Use this to calculate your own mixtures.
Haltech is offline
 Old 09-29-2008, 04:58 AM   #2
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
I might try to mix some now
Gotta Love The Turbocharged Wagon
oskinosmee is offline
 Old 09-29-2008, 07:17 AM   #3
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
cool sub
gsrtype1 is offline
 Old 12-24-2008, 11:38 AM   #4
Stan-O's Avatar
Posts: 182   (View Stats)
Stan-O is just really niceStan-O is just really niceStan-O is just really niceStan-O is just really niceStan-O is just really nice
Groaned at 5 Times in 1 Post
Great Calculator!
One question,
With a 50/50 mix ( or any other ratio mix ) are the mixes specified by Volume or weight?
Thanks
Stan-O
Speed-less
Stan-O is offline
 Old 12-24-2008, 11:39 AM   #5
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
50/50 mix means by weight
aaronc7 is offline
 Old 12-24-2008, 11:47 AM   #6
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
effin A cotton, effin A.
MarkyMark is offline
 Old 12-24-2008, 01:24 PM   #7
Stan-O's Avatar
So if you use a refractometer, a 50/50 will read 50% correct?
I have a refrectometer for my marine aquariem, but it's in S.G. and i'm not going to contaminate it, I'm going to buy one with a brix scale. ( or an alcohol one )
Thanks
Stan-O
Speed-less
Stan-O is offline
 Old 12-24-2008, 01:27 PM   #8
aaronc7's Avatar
Groans: 370
I dunno, I am just gonna use that excel sheet to attain my 50/50 mix. 5 gallon pure meth with 4 gallon of distilled water = 49/51 or something
aaronc7 is offline
 Old 12-24-2008, 01:47 PM   #9
Stan-O's Avatar
can you use R/O water? and where can you buy 5 gallon of pure meth?
Thanks
Stan-O
Speed-less
Stan-O is offline
 Old 12-24-2008, 02:06 PM   #10
aaronc7's Avatar
Groans: 370
R/O water?
as for meth, call around to local performance shops. I found some local for $9+ a gallon, but that was a bit much, so I found some in Orlando (little farther away...) for about $6.30 a gallon which isn't bad. I just got a red 5 gallon gasoline container thing and filled that up.
aaronc7 is offline
 Old 12-24-2008, 03:37 PM   #11
Stan-O's Avatar
R/O = Reverse Osmosis just as pure as Distilled
Thanks, I'll call around
Speed-less
Stan-O is offline
 Old 07-31-2009, 04:14 PM   #12
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
i mixed 1 gallon meth and 1 gallon water. what the fuk mixture is that
 Old 07-31-2009, 08:47 PM   #13
aaronc7's Avatar
Groans: 370
2 gallons of fail
aaronc7 is offline
 Old 08-01-2009, 12:51 AM   #14
18psiWhiteMS3
Lurkers
Posts: n/a
what mix are you using aaron?
 Old 08-01-2009, 06:49 AM   #15
aaronc7's Avatar
Groans: 370
vp m1 meth
aaronc7 is offline
 Old 02-21-2010, 10:27 PM   #16
nesiospeed's Avatar
Posts: 29   (View Stats)
nesiospeed will become famous soon enough
GREATS CALCULATOR ..
nesiospeed is offline
 Old 08-02-2010, 10:36 PM   #17
robertjskidmore's Avatar
Posts: 15   (View Stats)
robertjskidmore is an unknown quantity at this point
what do i need to do to run meth?? anything crazy and if anyone wants to help we dont have to do it here so i dont look like a total tool bag!! lol
09 White Pearl MS3
COBB FMIC
COBB SRI
COBB TUNING STAGE 2 SUSPENSION KIT
COBB DOUBLE ADJUSTABLE STS
COBB 3" DP
COBB CATBACK 3" EXHAUST
COBB AP
DNP TURBO MANIFOLD
KMD FUEL PUMP
STREET UNIT ENGINE MOUNTS
FORGE BPV
robertjskidmore is offline
 Old 08-02-2010, 10:55 PM   #18
You need a meth kit first of all.. Then plumb it in about 8-12 inches from the tbody on your cool pipe from the IC into the throttle body.
Then comes the decision of either running straight 100% meth vs mixing.
Haltech is offline
 Old 09-19-2012, 01:54 PM   #19
708
Erich's Avatar
Posts: 4,274   (View Stats)
Discuss here:
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
Methanol Mixing Calculator (EXCEL) Haltech MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 17 08-02-2010 10:55 PM
ATR Excel Tuning Worksheet Haltech
Cobb ATR Support
0 04-20-2009 02:31 PM
How to make graphs in Excel dread
Cobb Access Port/Maps
27 12-29-2008 06:21 AM
Methanol: Chemical Saftey data, things to know before mixing your own booya620 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 12-10-2008 07:52 AM
Page generated in 0.35758 seconds with 29 queries
