THE OFFICIAL HPFP CDFP FUEL PUMP THREAD ****2015 update, thanks @SarcasticOne;! The following applies to all 2.3 MZR DISI powered mazdas as they all share the same pump. (ms3 both gens- ms6- cx-7) GENERAL Direct injected engines require a far higher fuel pressure then a port injected engine. This is why we have two fuel pumps. We have an in-tank pump and a high pressure cam driven pump. The high pressure pump is commonly referred to on this site as the HPFP(high pressure fuel pump) and occasionaly as a CDFP(cam driven fuel pump) The in-tank pump sends fuel at a low pressure to the HPFP which vastly increases the pressure and sends the fuel to the injectors. For a very basic overview, here's a MSPaint picture: http://www.mazdaspeedforum.org/forum/foru...1&d=1422683250 From the fuel tank, fuel gets pumped via an "in tank fuel pump" (ITFP) at ~50-60psi through the red "line"... that's enough pressure for your port injectors, and it's really all about how much fuel it can flow, rather than the pressure. The HPFP then takes this fuel, and pressurizes it up to 1600+ psi... As you modify your car and make more power the engine requires more fuel to feed the ignition process. At some point the stock HPFP will lack the ability to keep up with fuel demands. When this happens your engine enters a dangerous scary world of possible boom. Thankfully we have some upgrade options making real power a possibility for us. So how do you know when you need to upgrade? The ONLY real way to know positively is through a logging/ ecu data device which can read/log your fuel pressure, such as an access port or dashhawk. Any thing under 1600 psi at WOT is a case of needing an upgrade. However, many would say to upgrade before it is NEEDED. Who wants to drive around like a grandma while waiting for parts and install anyways? What does this look like in your logs? Well, something like this: http://stable-networks.com/ms6r/images/forum/log.jpg http://stable-networks.com/ms6r/imag...um/kmdfail.jpg See how it's dropping below 1600psi? this is a sure sign that the HPFP is not capable of keeping up with the fueling demands. The modification level that requires a HPFP uprade varies from model to model, gen to gen, and even car to car. (READ THE PARAGRAPH ABOVE AGAIN) GEN 1 MS3 & MS6 Most low level flow mods are ok( intake,test pipe, CBE etc) Add an upgraded intercooler or a tune and your pushing it. Add a downpipe and you might as well get the internals installed FIRST. Don't even think about upgrading your turbo without an upgrade. GEN 2 MS3 The genpu does not play as nice with the HPFP. Many need an upgrade with just an intake, and Cobb states that some HPFP's will not keep up with stage 1 maps. Upgrade should be very early on your list. CX-7**** Much like MS3's, refer to 1st and 2nd Gen MS3 above I cannot say this enough the ONLY way to know for sure is through logging. OPTIONS So you've decided to upgrade, now what? Well, you can either buy yourself an upgraded pump, or save some money and buy upgraded pump internals to install into the pump yourself. The full pump is about as easy as it can get to install, but many members here have installed internals themselves with no issues(this is the route most take). All these items are available from many different vendors both on MSF and not, and at varying prices. I am only linking to the manufacturers site and giving their prices. You will notice some are listed as VW/AUDI parts, this is because we share a common HPFP with some of their engines- do not worry about that I will list the internals kits first. Autotech part number 10-127-100k $399.95 VW Performance - Autotech Sport Tuning: Hi-Volume Fuel Pump UpGrade Kit 2.0T FSI http://www.autotech.com/mm5/graphics...chfuelpump.jpg KMD part number 03020 $329.95 Audi - A3 - 2.0T FSI - Engine - KMD Tuning - 2.0T FSI High Pressure Fuel Pump Kit - KMD Tuning & Engineering http://www.kmdtuning.com/images/uplo...-03021tc_4.jpg HPFPupgrade(ptp) part number HPFP00005 $349.00 Mazda DISI Do It Yourself Pump Internals | HPFPUpgrade.com http://hpfpupgrade.com/images/produc...ternals-tn.jpg CorkSport Max Flow Fuel Pump part number Gen-6-999-10 $349.99 CorkSport Max Flow HPFP Fuel Pump Internals http://corksport.com/images/product/...-Pump-600b.jpg Now for the full pumps Most pumps will require you to pay a core charge added to the price of the pump, when you install your new pump you send your old pump back to them and get your core charge refunded back to you. CP-E part number MZR23HPFP $667.56+$350 core MZR DISI 2.3 HPFpump http://cp-e.com/sites/default/files/..._Pump1_big.jpg HPFP upgrade(ptp) 2 options 1-upgrade your pump(send it to them, they upgrade it and send it back) part number HPFP00004 A-stage 1 $549.00 B-stage 2 $799.00 Mazda DISI Upgrade Your Pump | HPFPUpgrade.com http://hpfpupgrade.com/images/produc...ternals-tn.jpg 2-complete HPFP(prebuilt and core charge-no wait) part number HPFP00003 A-stage 1 $549.00+$350.00 core B-stage 2 $799.00+$350.00 core Mazda DISI Complete High Pressure Fuel Pump | HPFPUpgrade.com http://hpfpupgrade.com/images/produc...en-hpfp-tn.jpg Need some help with install? Luckily you've found the best damn Mazdaspeed tech site in the world and we can help you with that. http://www.mazdaspeedforum.org/forum/foru...install-76252/ http://www.mazdaspeedforum.org/forum/foru...upgrade-11215/ http://www.mazdaspeedforum.org/forum/foru...ernals-146760/ |
Protip, compliments of @superskaterxes when he helped me with my install: you don't need to remove battery box or TIP/TIH when doing this install. There is enough room for you to do it without removing all that crap. End result is a lot less time spent doing the install. |
Well written...this may stop all the other over talked about pump questions...props!! |
I had a suggestion. Might you add something about the reliability of the kits listed above? I know that there have been some sketchy players in the past. Are all of the parts listed above high quality (or at least seem to be so far)? |
Quote:
Probably a stupid question but does upgrading the HPFP make you lose MPG? The way I see it it does. |
Quote:
Anyways while cruising the upgraded pump will be putting out about the same pressure as a properly working stocker. It's only at WOT that the stock pump cant keep up with flow demand at required pressure. |
YES! Thank you so much! I was pretty worried about it. Cause I'm looking at getting the Genpu and I realize its a much needed mod (practically mandatory), and I drive everyday 50+ miles, so I need as best gas mileage as possible....You know when I'm not squashing hondas ;) |
Fuck off. Racecar! |
So, If my '12 ms3 is getting a lean code with a cai, should I upgrade the pump or get it tuned to fix it? Not looking for too much power, 300 would be good. |
Quote:
I believe I know the answer so tread lightly. Sent from my iPhone using Tapatalk |
Quote:
I just did an internal install and my idle fuel pressure is down to 60 PSI, it will climb up to around 300 with a but of throttle. Everything seams to be installed correctly and moving nicely. I followed the AT instruction and removed and cleaned everything ensuring to reinstall everything as it came out. Advice? |
Quote:
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
Quote:
I showed up today to work on it, started it up, and it held 430PSI. I let it idle for a bit and it was still holding 430PSI. So I took it for a drive and it was hitting all its pressure targets. Perhaps there was a nasty air bubble on the LP side that worked it way out. I have no idea. But I put about 50KM on it today before my Access Port died and it seams to be running great. Now I have to find out why my AP took a dump! |
Quote:
Quote:
I think i must have missed something. What makes the motor enter a dangerous area of possible boom if the stock fuel pump doesn't meet the fuel demand? Would you not just hit some peak limit and then back down? Thanks in advance. |
Quote:
Quote:
Quote:
Quote:
I do not mean to call you out here-- I simply do not want people thinking as long as AFR's stay on target they are ok. |
yes its a vicious cycle: low pressure, ecu dumps fuel further straining pump, pig rich, low pressure etc... |
Quote:
Ah ok i see it. By "hitting some peak", i was figuring you'd start running lean and to compensate the ecu would possibly close the throttle or something like that to regain air/fuel balance. But the ECU regulating fuel demand makes more sense. Thanks guys. |
Wait, (sorry trying to rationalize all this in my head and why i should get an HPFP upgrade), if fuel pressure goes down, wouldn't this mean less fuel enters the cylinder to an extent that the motor will just shut off? Is the danger in a possible blow-up due to the fuel INSIDE the pump itself as its overworking to meet demands? |
Ecu regulates injector pulse width(time the inj is open) based on fuel rail pressure and amount of fuel requested. So if the ecu sees a lower pressure than it expects it just opens the injectors for a longer period of time. It is hard on the pump to try to keep up when it is past its potential, but this is not the boom im speaking of. Boom means one of your rods taking a tour of the engine bay. |
Quote:
Ah thanks a lot man. You've definitely been helping me. And i will know doubt definitely continue to check this site out for information. That cleared up a lot of stuff. |
Has anyone experience fuel leaking into the motor via the cdfp after upgrading the internals? Assuming both o-rings (inside pump and the one that joins to the motor) are okay, is it possible that the pump could leak from the internals while in operation? I'm refering to where the internals are actually outside the pump under the spring where it is in contact with the cam? |
Are there any guys running intakes, turboback's, and fmic's on stock internals? Cause I really don't wanna have to crack open my block to install those as my car is my dd. |
Quote:
If so no there are no guys doing that. They all blew up. Search a bit more man. |
Derpity derp. That's what I get for skimming this thread after studying for finals. |
Quote:
can i order this stuff directly from the cp-e website or do i gotta find them somewhere else? |
Quote:
http://www.cp-e.com/products/hpfpump...hpfpump™ Sent from my iPhone using Fapatalk. |
Sorry if this a stupid question but would a walboro 255 be enough fuel pump for full bolt-on through stage 2? |
Quote:
Not sure if serious. But no. Keep reading. Sent from my SCH-I535 using Tapatalk 2 |
Quote:
| All times are GMT -7. The time now is 01:48 PM. |
