 Old 02-14-2012, 09:02 PM   #1
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
Default THE OFFICIAL HPFP CDFP FUEL PUMP THREAD
****2015 update, thanks @SarcasticOne;!
The following applies to all 2.3 MZR DISI powered mazdas as they all share the same pump. (ms3 both gens- ms6- cx-7)
GENERAL
Direct injected engines require a far higher fuel pressure then a port injected engine. This is why we have two fuel pumps. We have an in-tank pump and a high pressure cam driven pump.
The high pressure pump is commonly referred to on this site as the HPFP(high pressure fuel pump) and occasionaly as a CDFP(cam driven fuel pump)
The in-tank pump sends fuel at a low pressure to the HPFP which vastly increases the pressure and sends the fuel to the injectors.
For a very basic overview, here's a MSPaint picture:
From the fuel tank, fuel gets pumped via an "in tank fuel pump" (ITFP) at ~50-60psi through the red "line"... that's enough pressure for your port injectors, and it's really all about how much fuel it can flow, rather than the pressure.
The HPFP then takes this fuel, and pressurizes it up to 1600+ psi...
As you modify your car and make more power the engine requires more fuel to feed the ignition process. At some point the stock HPFP will lack the ability to keep up with fuel demands. When this happens your engine enters a dangerous scary world of possible boom.
Thankfully we have some upgrade options making real power a possibility for us.
So how do you know when you need to upgrade?
The ONLY real way to know positively is through a logging/ ecu data device which can read/log your fuel pressure, such as an access port or dashhawk. Any thing under 1600 psi at WOT is a case of needing an upgrade. However, many would say to upgrade before it is NEEDED. Who wants to drive around like a grandma while waiting for parts and install anyways?
What does this look like in your logs? Well, something like this:
See how it's dropping below 1600psi? this is a sure sign that the HPFP is not capable of keeping up with the fueling demands.
The modification level that requires a HPFP uprade varies from model to model, gen to gen, and even car to car. (READ THE PARAGRAPH ABOVE AGAIN)
GEN 1 MS3 & MS6
Most low level flow mods are ok( intake,test pipe, CBE etc)
Add an upgraded intercooler or a tune and your pushing it.
Add a downpipe and you might as well get the internals installed FIRST.
Don't even think about upgrading your turbo without an upgrade.
GEN 2 MS3
The genpu does not play as nice with the HPFP.
Many need an upgrade with just an intake, and Cobb states that some HPFP's will not keep up with stage 1 maps.
Upgrade should be very early on your list.
CX-7****
Much like MS3's, refer to 1st and 2nd Gen MS3 above
I cannot say this enough the ONLY way to know for sure is through logging.
OPTIONS
So you've decided to upgrade, now what? Well, you can either buy yourself an upgraded pump, or save some money and buy upgraded pump internals to install into the pump yourself. The full pump is about as easy as it can get to install, but many members here have installed internals themselves with no issues(this is the route most take).
All these items are available from many different vendors both on MSF and not, and at varying prices. I am only linking to the manufacturers site and giving their prices.
You will notice some are listed as VW/AUDI parts, this is because we share a common HPFP with some of their engines- do not worry about that
I will list the internals kits first.
Autotech
part number 10-127-100k $399.95
VW Performance - Autotech Sport Tuning: Hi-Volume Fuel Pump UpGrade Kit 2.0T FSI
KMD
part number 03020 $329.95
Audi - A3 - 2.0T FSI - Engine - KMD Tuning - 2.0T FSI High Pressure Fuel Pump Kit - KMD Tuning & Engineering
HPFPupgrade(ptp)
part number HPFP00005 $349.00
Mazda DISI Do It Yourself Pump Internals | HPFPUpgrade.com
CorkSport Max Flow Fuel Pump
part number Gen-6-999-10 $349.99
CorkSport Max Flow HPFP Fuel Pump Internals
Now for the full pumps
Most pumps will require you to pay a core charge added to the price of the pump, when you install your new pump you send your old pump back to them and get your core charge refunded back to you.
CP-E
part number MZR23HPFP $667.56+$350 core
MZR DISI 2.3 HPFpump
HPFP upgrade(ptp)
2 options
1-upgrade your pump(send it to them, they upgrade it and send it back)
part number HPFP00004
A-stage 1 $549.00 B-stage 2 $799.00
Mazda DISI Upgrade Your Pump | HPFPUpgrade.com
2-complete HPFP(prebuilt and core charge-no wait)
part number HPFP00003
A-stage 1 $549.00+$350.00 core B-stage 2 $799.00+$350.00 core
Mazda DISI Complete High Pressure Fuel Pump | HPFPUpgrade.com
Need some help with install?
Luckily you've found the best damn Mazdaspeed tech site in the world and we can help you with that.
Fuel Pump internals Install!
CDFP internals upgrade
How-to: Install your Autotech fuel pump internals
aromig and jcutler0622 like this.
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline
The Following 3 Users Say Thank You to themytb For This Useful Post:
aromig (06-17-2015), Cheapspeed (03-16-2013), Fingerlicker (05-17-2015)
 Old 02-14-2012, 09:08 PM   #2
nindoja's Avatar
Posts: 2,395   (View Stats)
Protip, compliments of @superskaterxes when he helped me with my install: you don't need to remove battery box or TIP/TIH when doing this install. There is enough room for you to do it without removing all that crap. End result is a lot less time spent doing the install.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
nindoja is offline
 Old 02-14-2012, 09:28 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Well written...this may stop all the other over talked about pump questions...props!!
Dmurray06 is offline
 Old 02-15-2012, 03:00 PM   #4
sharky's Avatar
Posts: 93   (View Stats)
sharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant futuresharky has a brilliant future
I had a suggestion. Might you add something about the reliability of the kits listed above? I know that there have been some sketchy players in the past. Are all of the parts listed above high quality (or at least seem to be so far)?
sharky is offline
 Old 02-15-2012, 04:42 PM   #5
POWERED BY POLSKA
themytb's Avatar
Groans: 38
My understanding is that all these "official" threads are supposed to be unbiased as far as listings of products. Pre purchase research is always a good idea anyways. Hopefuly these threads will be around a long while and this way they will not need to be changed if a vendor goes to shit.
25%E85FREEKPERMED
themytb is offline
 Old 03-20-2012, 05:17 PM   #6
xI Leveler Ix's Avatar
Posts: 1,752   (View Stats)
xI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the world
Groans: 75
Groaned at 31 Times in 20 Posts
Probably a stupid question but does upgrading the HPFP make you lose MPG? The way I see it it does.
///VRM 2006 UNICORN Speed6 GT #02418///
STOCK AS OF 2015...
Old Stuff....
/// COBB AP /// AT HPFP /// 20psi Teck5 Tune by Ekanddsm /// JBR RMM /// HTP 3" Intake System /// SURE Dreadnaught and Juggernaut ///
/// Denso ITV22 /// Mystery Testpipe /// Fidanza Lightweight Flywheel /// Eagle Motorsports Full-Faced Clutch Upgrade ///
/// Megan Racing Springs /// SPC Adjustable Balljoints /// JBR TIGS, EGR Delete and Coolant Bypass ///
xI Leveler Ix is offline
 Old 03-20-2012, 05:33 PM   #7
POWERED BY POLSKA
themytb's Avatar
Groans: 38
No it does not. The ecu decides how long to open the injector based on the fuel rail pressure(amongst other things ofcourse).
Anyways while cruising the upgraded pump will be putting out about the same pressure as a properly working stocker. It's only at WOT that the stock pump cant keep up with flow demand at required pressure.
25%E85FREEKPERMED
themytb is offline
 Old 03-20-2012, 05:44 PM   #8
Groans: 75
YES! Thank you so much! I was pretty worried about it. Cause I'm looking at getting the Genpu and I realize its a much needed mod (practically mandatory), and I drive everyday 50+ miles, so I need as best gas mileage as possible....You know when I'm not squashing hondas
STOCK AS OF 2015...
Old Stuff....
 Old 03-23-2012, 07:19 PM   #9
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
Fuck off. Racecar!
2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's
Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice)
OBAMA SUCKS
Stratified Tune by Lex
Bosox is offline
 Old 04-16-2012, 12:56 PM   #10
Jerd2189's Avatar
Posts: 7   (View Stats)
Jerd2189 will become famous soon enough
So, If my '12 ms3 is getting a lean code with a cai, should I upgrade the pump or get it tuned to fix it? Not looking for too much power, 300 would be good.
Jerd2189 is offline
 Old 04-16-2012, 05:17 PM   #11
POWERED BY POLSKA
themytb's Avatar
Groans: 38
99% of lean codes have nothing to do with your fuel pump---- you should be looking for a vac leak first thing.
25%E85FREEKPERMED
themytb is offline
 Old 04-16-2012, 06:35 PM   #12
Blackrider's Avatar
Posts: 356   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 20 Times in 14 Posts
I just did an internal install and my idle fuel pressure is down to 60 PSI, it will climb up to around 300 with a but of throttle. Everything seams to be installed correctly and moving nicely. I followed the AT instruction and removed and cleaned everything ensuring to reinstall everything as it came out. Advice?
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's
Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM
Random - Pontiac G8 Horns
2013 Ford Edge Sport AWD, the family car...
Blackrider is offline
 Old 04-16-2012, 01:50 PM   #13
FLHXterp's Avatar
Posts: 192   (View Stats)
FLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the worldFLHXterp is the leader of the world
What pressure is your AP logging at WOT?
I believe I know the answer so tread lightly.
FLHXterp is offline
 Old 04-16-2012, 06:41 PM   #14
hung380's Avatar
Posts: 127   (View Stats)
hung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond repute
Originally Posted by Blackrider View Post
I just did an internal install and my idle fuel pressure is down to 60 PSI, it will climb up to around 300 with a but of throttle. Everything seams to be installed correctly and moving nicely. I fallowed the AT instruction and removed and cleaned everything ensuring to reinstall everything as it came out. Advice?
Take it out and double check everything. 60 psi at idle is very low. Mine idles 410-430 psi. blip of my throttle is around 600-800 psi. Make sure the O-ring isnt torn and the clips are in place.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
hung380 is offline
 Old 04-16-2012, 07:05 PM   #15
Blackrider's Avatar
Yeah, I'm going to have to. You can tell the engines not happy with me right now. I just watched some install videos and I honestly cant think of anything I did wrong.
2008 MazdaSpeed 3
 Old 04-21-2012, 04:01 PM   #16
Blackrider's Avatar
I showed up today to work on it, started it up, and it held 430PSI. I let it idle for a bit and it was still holding 430PSI. So I took it for a drive and it was hitting all its pressure targets. Perhaps there was a nasty air bubble on the LP side that worked it way out. I have no idea. But I put about 50KM on it today before my Access Port died and it seams to be running great. Now I have to find out why my AP took a dump!
2008 MazdaSpeed 3
 Old 04-21-2012, 04:10 PM   #17
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
At 60 psi you were running off the in tank fuel pump psi.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline
 Old 04-21-2012, 04:17 PM   #18
Blackrider's Avatar
That was my guess, I was about to get more pressure out of it when reving however, everything looks to be good now... Other than my AP!
2008 MazdaSpeed 3
 Old 04-26-2012, 04:28 AM   #19
jrocket420a's Avatar
Posts: 11   (View Stats)
jrocket420a is an unknown quantity at this point
I think i must have missed something. What makes the motor enter a dangerous area of possible boom if the stock fuel pump doesn't meet the fuel demand? Would you not just hit some peak limit and then back down? Thanks in advance.
jrocket420a is offline
 Old 04-26-2012, 11:21 AM   #20
POWERED BY POLSKA
themytb's Avatar
Groans: 38
Not sure what you mean by that,but the fuel does not like to atomize properly at lower pressures amongst other things.
25%E85FREEKPERMED
themytb is offline
 Old 04-26-2012, 02:08 PM   #21
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You would lean out. More air than fuel. Read: What Are the Dangers of Running Lean? | eHow.com
I get the impression you're not entirely sure what you're asking about. Nothing to be ashamed of, everyone is ignorant at one point or another.
CWP_MS3 is offline
 Old 04-26-2012, 02:28 PM   #22
POWERED BY POLSKA
themytb's Avatar
Groans: 38
No- truth is most do not lean out. In a PI motor you would be correct, in our case the stock pump can flow the quantity of fuel no problem(in most cases). Its the pressure that dwindles and in response to the low psi the ecu in fact adds more fuel further lowering the pressure and decreasing atomization to the point of possible fuel puddling etc.
I do not mean to call you out here-- I simply do not want people thinking as long as AFR's stay on target they are ok.
25%E85FREEKPERMED
themytb is offline
 Old 04-26-2012, 02:47 PM   #23
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Not at all man; I don't mind being wrong. I appreciate learning new things. Thanks for the correction. So what actually bends the rods then if its not leaning out.
CWP_MS3 is offline
 Old 04-26-2012, 02:32 PM   #24
m4tic's Avatar
Posts: 4,928   (View Stats)
yes its a vicious cycle: low pressure, ecu dumps fuel further straining pump, pig rich, low pressure etc...
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 04-26-2012, 04:06 PM   #25
Ah ok i see it. By "hitting some peak", i was figuring you'd start running lean and to compensate the ecu would possibly close the throttle or something like that to regain air/fuel balance. But the ECU regulating fuel demand makes more sense. Thanks guys.
 Old 04-26-2012, 07:18 PM   #26
Wait, (sorry trying to rationalize all this in my head and why i should get an HPFP upgrade), if fuel pressure goes down, wouldn't this mean less fuel enters the cylinder to an extent that the motor will just shut off? Is the danger in a possible blow-up due to the fuel INSIDE the pump itself as its overworking to meet demands?
 Old 04-26-2012, 08:48 PM   #27
POWERED BY POLSKA
themytb's Avatar
Groans: 38
Also, you have a lot of reading to do. It is a lot to take in, I know. Keep learning, the knowledge on this forum is astounding. Eventually you will be trying to teach noobs stuff and telling them to..............................DONATE!
25%E85FREEKPERMED
themytb is offline
 Old 04-26-2012, 08:42 PM   #28
POWERED BY POLSKA
themytb's Avatar
Groans: 38
Ecu regulates injector pulse width(time the inj is open) based on fuel rail pressure and amount of fuel requested. So if the ecu sees a lower pressure than it expects it just opens the injectors for a longer period of time.
It is hard on the pump to try to keep up when it is past its potential, but this is not the boom im speaking of. Boom means one of your rods taking a tour of the engine bay.
25%E85FREEKPERMED
themytb is offline
 Old 04-27-2012, 04:21 AM   #29
Ah thanks a lot man. You've definitely been helping me. And i will know doubt definitely continue to check this site out for information. That cleared up a lot of stuff.
 Old 05-17-2012, 03:08 PM   #30
speed3r's Avatar
Posts: 2   (View Stats)
speed3r is an unknown quantity at this point
Has anyone experience fuel leaking into the motor via the cdfp after upgrading the internals? Assuming both o-rings (inside pump and the one that joins to the motor) are okay, is it possible that the pump could leak from the internals while in operation? I'm refering to where the internals are actually outside the pump under the spring where it is in contact with the cam?
speed3r is offline
 Old 05-21-2012, 01:12 PM   #31
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
@Javi
also, the HPFPupgrade internals are just $299.95, not $349.99 as listed in OP.
it's fun to do bad things
jack_hammer is offline
 Old 05-21-2012, 03:53 PM   #32
Javi's Avatar
Posts: 589   (View Stats)
Javi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the worldJavi is the leader of the world
Javi is offline
 Old 05-21-2012, 05:05 PM   #33
bobbylight707's Avatar
Posts: 16   (View Stats)
bobbylight707 will become famous soon enough
Are there any guys running intakes, turboback's, and fmic's on stock internals? Cause I really don't wanna have to crack open my block to install those as my car is my dd.
bobbylight707 is offline
 Old 05-21-2012, 05:09 PM   #34
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
lol...Crack open your block? We are talking Fuel pump internals here right?
If so no there are no guys doing that. They all blew up.
Search a bit more man.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 05-21-2012, 05:15 PM   #35
Derpity derp. That's what I get for skimming this thread after studying for finals.
 Old 07-14-2012, 05:50 AM   #36
Raider's Homie
Wings_Fan_1986's Avatar
Posts: 56   (View Stats)
Wings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant future
GENERAL
GEN 1 MS3 & MS6
GEN 2 MS3
CX-7
I'm sorry I can't find much info on your car, I will add it later if I get more data.
OPTIONS
Autotech
KMD
HPFPupgrade(ptp)
CP-E
HPFP upgrade(ptp)
2 options
ran out of time for tonight will fix the mistakes i'm sure are there, as well as add some borders etc. tomorrow, please let me know anything you find grammar, blatant fuck ups etc.
can i order this stuff directly from the cp-e website or do i gotta find them somewhere else?
Wings_Fan_1986 is offline
 Old 07-14-2012, 09:03 AM   #37
smoogs12's Avatar
Groans: 423
Yes. Check their site...
http://www.cp-e.com/products/hpfpump...hpfpump™
Sent from my iPhone using Fapatalk.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-21-2012, 02:14 PM   #38
shawn19's Avatar
Posts: 51   (View Stats)
shawn19 is infamous around these partsshawn19 is infamous around these parts
Groaned at 38 Times in 11 Posts
Sorry if this a stupid question but would a walboro 255 be enough fuel pump for full bolt-on through stage 2?
shawn19 is offline
 Old 07-21-2012, 05:37 PM   #39
POWERED BY POLSKA
themytb's Avatar
Groans: 38
troll question+twilight=troll in tutu?
25%E85FREEKPERMED
themytb is offline
 Old 09-06-2012, 03:37 PM   #40
Triz187's Avatar
Triz187 is an unknown quantity at this point
Default Fuel Pump Failing!
Went to get Dyno'd at Cobb last week. Running stg 2 with Auto Tech internals. Tuner said my FP failed while tuning. He tuned for my intake before the pump gave out so he built me a baseline map and said for me to put the stock internals back in and to investigate the Autotech ones for scoring or defects. I went home took the pump appart and found the Autotech internals ok with No sign of scoring or damage. While I had the pump out I investigated the housing and found a four-digit number on the high pressure line out of the pump. After research I found that the number which was 7215 was the manufacturing date of that pump and there was a service bulletin online from mazda stating that any pump manufactured before march 2007 should be replaced. When opening the pump with the 18mm socket to reinstall the OEM internals the stainless steel cylinder where the piston comes through was loose enough that I didnt have to place the pump in a vice to unscrew the stainless steel cylinder.Went ahead and put the stock internals back in.This time I took my torque wrench and tightened the 18mm stainless steel cylinder to about 35lb/ft, to ensure it would unscrew. Now running that base map, I keep throwing P2187 over and over again. Does this mean I need to purchase a brand new pump. I do have they Autotech internals cleaned and ready to install again. Did my pump fail on the dyno becuase the stainless steel cylinder started to back it self out, or did it fail because it was a faulty pump assembly from the factory( new internals were installed) Knowledgable people please help as I dont want to have to spend 400$ on a brand new pump if I dont have too. I want me car to run good again so I can get it back on the dyno for a protune.
Triz187 is offline
THE OFFICIAL HPFP CDFP FUEL PUMP THREAD themytb MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 297 06-29-2017 07:11 PM
Page generated in 0.65484 seconds with 41 queries
