Other Platforms
> Ford Focus ST Ecoboost - Turbo Induction
Like Tree93Likes
 Old 01-22-2013, 07:46 AM   #41
kmac's Avatar
Posts: 1,792   (View Stats)
Originally Posted by Jhornbrook View Post
Well I feel inadequate. Nice work, is that diamond plate on the prototype? Well done as always and let's hope ford put some better rods in this bitch.
Lol, like i said i used what i had laying around. I'm a firm believer as spending as little money as possible unless need be something cnc or whatever. If u can puch a flange with shit u got around do it. But diamond plate lol yup.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 4 Users Say Thank You to kmac For This Useful Post:
djuosnteisn (01-22-2013), Easter Bunny (01-22-2013), sl33py24 (06-03-2013), Vader (01-22-2013)
 Old 01-22-2013, 09:47 AM   #42
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
You'd have to cnc the adapter in 2 pieces. Or, a simpler approach would be to cnc each flange to a round lip, then weld in a sched 40 weld el, maybe a 2" dia.
Shoot me a PM if you want help on any of that stuff. I've been building enough stuff that i have a decent idea on how to make life easy.
kmac likes this.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
atvfreek (01-22-2013), cld12pk2go (01-22-2013), kmac (01-22-2013)
 Old 01-22-2013, 10:54 AM   #43
kmac's Avatar
Ill let u know after all is fitted and i know everything clears and works. I appreciate it. I left everything reversable so when i get the factory turbo back i can put it back on and try out the super stock.
<3 Tokay.
The Following User Says Thank You to kmac For This Useful Post:
 Old 01-22-2013, 11:07 AM   #44
willix231's Avatar
Posts: 1,315   (View Stats)
willix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond repute
subbed to see what numbers you get.is the factory k03 on these smaller than the ms3 k04?
Corksport Sri+Tip, Cobb FMIC, Turbosmart BPV, NGK 1 step colder Plugs,Cobb accessport v2,Cobb RMM,cobb shift weight, Megan racing test pipe, Racing beat catback exhaust, Labonte wmi controller with cooling mist pump,stratified 91 octane & e85 ots tunes,Mazdaspeed oem coilovers,CS camber plates,whiteline ALK, whiteline bumpsteer kit, whiteline poly bushings, JBR rear sway bar, SPC rear camber arms,Gtspec mid chassis Aluminum brace, Gt spec rear cross member Brace with V brace addition,Wilwood 4 pot BBk+hawk DTC 60 with DBA 4000 rotors(F),Stoptech high carbon rotor(R), stoptech street performance pads(R), Stoptech stainless steel braided brake line(FxR), Enkei Rpf1 17*8.8 +30, Aluminum hubcentric rings, Work Rs open ended lug nuts, Hankook Rs3 245/40/17
willix231 is offline   Reply With Quote
The Following User Says Thank You to willix231 For This Useful Post:
kmac (01-22-2013)
 Old 01-22-2013, 11:08 AM   #45
kmac's Avatar
Way smaller. I couldn't believe how small it was.
<3 Tokay.
Koke382 (01-22-2013)
 Old 01-22-2013, 01:27 PM   #46
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
That's what she said about @8.5MS3;
Dr. Speed likes this.
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
The Following 9 Users Say Thank You to triphop631 For This Useful Post:
apena85 (01-22-2013), Ckmazdaspeed3 (04-14-2013), dantes5823 (01-22-2013), Easter Bunny (01-22-2013), kmac (01-22-2013), robry (05-16-2013), Roddiy (01-25-2013), that1rowdyracer (03-10-2013), WAHBAM (02-04-2013)
The Following User Says NO Thank You to triphop631 For This Un-useful Post:
8.5MS3 (01-22-2013)
 Old 01-22-2013, 01:35 PM   #47
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Originally Posted by triphop631 View Post
That's what he said about @8.5MS3;
Fixed
The Following 10 Users Say Thank You to daafisch For This Useful Post:
8.5MS3 (01-22-2013), alexryan (01-30-2013), apena85 (01-22-2013), dantes5823 (01-22-2013), kmac (01-22-2013), Monotonous ONE (01-23-2013), RobT2009 (01-25-2013), Roddiy (01-25-2013), triphop631 (01-22-2013), WAHBAM (02-04-2013)
 Old 01-22-2013, 01:41 PM   #48
kmac's Avatar
I'll be running later tonight
daafisch likes this.
<3 Tokay.
The Following 8 Users Say Thank You to kmac For This Useful Post:
Boosted Beluga (01-22-2013), daafisch (01-22-2013), dantes5823 (01-22-2013), djuosnteisn (01-22-2013), doubleflusher (01-22-2013), Koke382 (01-22-2013), Raider (01-22-2013), triphop631 (01-22-2013)
 Old 01-22-2013, 02:21 PM   #49
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
fuck you
Fixed
this man got it right
The Following 6 Users Say Thank You to 8.5MS3 For This Useful Post:
alexryan (01-30-2013), daafisch (01-22-2013), dantes5823 (01-22-2013), kmac (01-22-2013), Roddiy (01-25-2013), WAHBAM (02-04-2013)
The Following User Says NO Thank You to 8.5MS3 For This Un-useful Post:
 Old 01-22-2013, 02:25 PM   #50
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Is 3 smaller than 4?
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 19 Users Say Thank You to Tokay444 For This Useful Post:
amggilly305 (03-22-2013), amoosenamedhank (01-22-2013), BigRedSpecial (01-23-2013), caesura (01-26-2013), chaser27 (06-05-2013), Dano (01-22-2013), Easter Bunny (01-22-2013), El_Diablo (01-23-2013), impossible (11-29-2013), jax ms3gt (01-27-2013), Keko (01-22-2013), kmac (01-22-2013), Koke382 (01-22-2013), lilred (01-22-2013), Micha (01-22-2013), Monotonous ONE (01-23-2013), robry (05-16-2013), Roddiy (01-25-2013), silvapain (01-22-2013)
 Old 01-22-2013, 02:37 PM   #51
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
good to see K man.
kmac likes this.
kmac (01-22-2013)
 Old 01-22-2013, 02:46 PM   #52
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Well that escalated quickly... from stock K03 to PTE 6261 with a little field trip to SS land in the middle? Excited to see how this goes.
Bone stock so far
Darth_Nuruodo is offline   Reply With Quote
The Following 3 Users Say Thank You to Darth_Nuruodo For This Useful Post:
Boosted Beluga (01-22-2013), kmac (01-22-2013), Micha (01-22-2013)
 Old 01-22-2013, 02:47 PM   #53
triphop631's Avatar
Groans: 30
How late will you be at the shop?
@8.5MS3; why the groan faggot?
The Following 2 Users Say Thank You to triphop631 For This Useful Post:
 Old 01-22-2013, 03:05 PM   #54
kmac's Avatar
Till about 730
<3 Tokay.
 Old 01-22-2013, 04:40 PM   #55
kmac's Avatar
Well the car is running and idling on the lift
<3 Tokay.
The Following 13 Users Say Thank You to kmac For This Useful Post:
BlueStreak (01-23-2013), Boosted Beluga (01-22-2013), daafisch (01-22-2013), djuosnteisn (01-23-2013), dot584 (05-23-2013), Easter Bunny (01-23-2013), Koke382 (01-22-2013), lilred (01-22-2013), robry (05-16-2013), robspeed3 (01-22-2013), Tokay444 (01-22-2013), triphop631 (01-22-2013), Vader (01-23-2013)
 Old 01-22-2013, 04:44 PM   #56
Get that bitch tuned!
kmac likes this.
The Following 3 Users Say Thank You to Haltech For This Useful Post:
kmac (01-22-2013), kritz (01-23-2013), robspeed3 (01-22-2013)
 Old 01-22-2013, 04:49 PM   #57
kmac's Avatar
Lol, for u I'll do anything sweetheart.
<3 Tokay.
The Following 6 Users Say Thank You to kmac For This Useful Post:
Boosted Beluga (01-22-2013), Easter Bunny (01-23-2013), Koke382 (01-22-2013), kritz (01-23-2013), Raider (01-22-2013), Vader (01-23-2013)
 Old 01-22-2013, 08:08 PM   #58
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I am interested in what the ST's can do as it is the type of car I might get in a few years...
kmac likes this.
kmac (01-22-2013)
 Old 01-22-2013, 08:25 PM   #59
kmac's Avatar
Well I drove the car home, no oil, exhaust or air leaks. Drives well sounds good. I'll install the direct port methanol system tomorrow and I'll have enough fuel to get on it and see what I'm working with.
<3 Tokay.
The Following 10 Users Say Thank You to kmac For This Useful Post:
Boosted Beluga (01-22-2013), daafisch (01-23-2013), djuosnteisn (01-23-2013), Hush (01-22-2013), Raider (01-22-2013), robspeed3 (01-22-2013), taf0422 (01-23-2013), TWOptSL0W (01-24-2013), Vader (01-23-2013), wolly6973 (01-23-2013)
 Old 01-22-2013, 08:33 PM   #60
I hope to say the same but replace ST with RS
Nliiitend1 likes this.
The Following 20 Users Say Thank You to Lex For This Useful Post:
BigRedSpecial (01-23-2013), Boosted Beluga (01-22-2013), Chief_Wiggum (01-23-2013), Ckmazdaspeed3 (04-14-2013), daafisch (01-23-2013), Deldran (01-22-2013), djuosnteisn (01-23-2013), Dumyz (02-04-2013), Keko (01-22-2013), kmac (01-22-2013), Koke382 (01-22-2013), kritz (01-23-2013), Nliiitend1 (01-22-2013), RichieRichness (02-04-2013), robry (05-16-2013), robspeed3 (01-22-2013), silvapain (01-23-2013), that1rowdyracer (03-10-2013), The General (11-11-2013), Vader (01-23-2013)
 Old 01-22-2013, 08:53 PM   #61
Cannot wait to hear you installed a self-made awd setup.
The Following 10 Users Say Thank You to Raider For This Useful Post:
Boosted Beluga (01-22-2013), bstover17 (01-23-2013), daafisch (01-23-2013), kmac (01-22-2013), kmpeeps (01-23-2013), Koke382 (01-22-2013), kritz (01-23-2013), lilred (01-22-2013), robry (05-16-2013), Roddiy (01-25-2013)
 Old 01-23-2013, 05:18 AM   #62
8.5MS3's Avatar
Groans: 326
because you insinuated that i have sexual relations with people of the opposite sex
kritz likes this.
The Following 8 Users Say Thank You to 8.5MS3 For This Useful Post:
BigRedSpecial (01-23-2013), Ckmazdaspeed3 (04-14-2013), kmac (01-23-2013), Koke382 (01-23-2013), Monotonous ONE (01-23-2013), Roddiy (01-25-2013), triphop631 (01-23-2013), uncorked11 (01-27-2013)
 Old 01-23-2013, 05:59 AM   #63
triphop631's Avatar
Groans: 30
I guess the rumors weren't true...
The Following 4 Users Say Thank You to triphop631 For This Useful Post:
8.5MS3 (01-23-2013), bluemarker (01-24-2013), kmac (01-23-2013), Koke382 (01-23-2013)
 Old 01-23-2013, 08:56 AM   #64
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Hey @kmac; be nice to that snail!
kmac and 5doorsoffury like this.
Nator is what it does.
kmac (01-23-2013)
 Old 01-23-2013, 10:12 AM   #65
dubunderpar's Avatar
Posts: 841   (View Stats)
dubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the world
Very interested in the performance numvers from this. However awd is still a must have for me to even consider switching platforms.
sent from god
dubunderpar is offline   Reply With Quote
 Old 01-23-2013, 10:25 AM   #66
lug
lug's Avatar
Posts: 315   (View Stats)
lug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the world
Technically it is a mid size sedan. As far as smaller, more along the lines of smaller than the SHO. A lot of people I have talked to as well as myself can't stand the heft, looks and interior of the SHO. A Fusion ST is the car that the market needs. Good HP, good fun, good mileage and probable AWD. This checks the boxes for many consumers that have grown from the sporty hatch or boy racer AWD cars and expect a bit more. Keep in mind that many of the domestic buyers still see the fusion as almost a borderline compact.
On a different note, I'm really hoping they will offer a Fusion ST Wagon or atleast a Fusion Wagon. Either of these have potential and fit a growing market segment due to poor mileage in many SUV's. Granted, you can get an AWD Escape that gets over 30mpg now which is just amazing considering where we were at 5yrs ago. Sadly, most likely because of this, there has been no news on a Fusion Wagon that I have heard as of yet.
I wish they'd just bring the Focus ST wagon here. So far only Europe gets that one.
lug is offline   Reply With Quote
The Following 3 Users Say Thank You to lug For This Useful Post:
El_Diablo (01-23-2013), kmac (01-23-2013), magicka (01-23-2013)
 Old 01-23-2013, 11:27 AM   #67
ms3rick's Avatar
Posts: 2,959   (View Stats)
Videos, logs, pics! PLEASE!
Oh by the way GOOD FUCKING WORK MAN!
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
The Following User Says Thank You to ms3rick For This Useful Post:
kmac (01-23-2013)
 Old 01-23-2013, 12:34 PM   #68
kmac's Avatar
On my way back to install the meth kit.
kritz likes this.
<3 Tokay.
atvfreek (01-23-2013), Boosted Beluga (01-23-2013), daafisch (01-23-2013), djuosnteisn (01-24-2013), kritz (01-23-2013), lilred (01-23-2013), robry (05-16-2013), Seatime3 (01-23-2013)
 Old 01-23-2013, 06:16 PM   #69
lilred's Avatar
Posts: 5,792   (View Stats)
Car manufacturers under rating cars common knowledge for some thread derailment for others...
Meth up and good @kmac;
tapafuck
kmac and Koke382 like this.
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
The Following 2 Users Say Thank You to lilred For This Useful Post:
kmac (01-23-2013), robspeed3 (01-23-2013)
 Old 01-23-2013, 07:47 PM   #70
kmac's Avatar
I didn't get to finish the install. It'll be done tomorrow for sure. I have 2 secret weapons going n soon.
kritz likes this.
<3 Tokay.
daafisch (01-24-2013), djuosnteisn (01-25-2013), Hush (01-23-2013), Koke382 (01-23-2013), kritz (01-23-2013), lilred (01-23-2013), robry (05-16-2013), robspeed3 (01-23-2013), Vader (01-24-2013), wolly6973 (01-24-2013)
 Old 01-24-2013, 01:17 PM   #71
Cleaned up. Keep it on topic, kids, this thread will be historic.
kmac (01-25-2013), kritz (01-24-2013), lilred (01-24-2013), robspeed3 (01-24-2013), Vansquish (01-24-2013)
 Old 01-24-2013, 01:21 PM   #72
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Dang it raider why you have to abuse your powers so much. I am going to go make a thread crying about it
Raider likes this.
Damond Built Speed 6
The Following 9 Users Say Thank You to Deldran For This Useful Post:
Boosted Beluga (01-24-2013), Dr. Speed (01-24-2013), Easter Bunny (01-27-2013), Jhornbrook (01-24-2013), lilred (01-24-2013), Raider (01-24-2013), robspeed3 (01-24-2013), SarcasticOne (01-24-2013), Vader (01-24-2013)
 Old 01-24-2013, 03:01 PM   #73
kritz's Avatar
Groans: 95
I still know @kmac; s ace up his sleeve. Madness I tell you.
Sent from my frontal cortex.
kmac (01-25-2013)
 Old 01-24-2013, 03:51 PM   #74
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
dammit old man just tell us @kritz;
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
 Old 01-24-2013, 05:00 PM   #75
kritz's Avatar
Groans: 95
Really can't relinquish that information without the nod from @kmac;
kmac (01-25-2013)
 Old 01-24-2013, 05:23 PM   #76
Cujo (01-27-2013), Dano (01-24-2013), kmac (01-25-2013), Koke382 (01-24-2013), RobT2009 (01-25-2013), Roddiy (01-25-2013), superdave2335 (01-27-2013)
 Old 01-25-2013, 03:56 PM   #77
RobT2009's Avatar
Posts: 108   (View Stats)
RobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond repute
Subbed for an amazing build!
2008.5 CWP MazdaSpeed 3
SURE Aeros // SURE Sidewinder // Autotech Internals // CNT Catless DP - Catback // Custom FMIC // SURE TIG TB/IM // Denso ITV-22's // StreetUnit EGR Block Off // Turbosmart 50/50 // Streetunit RMM // SURE Oil Rig // BC Coilovers // RPF1 17x9 +45 // Nitto Motivo 255/40 // SURE AGS Heavy Weight Knob // JBR SSP// SURE Countershift // Shift Anchors // Cobb AP // Stoptech brake pads Powerslot rotors Stoptech SS lines //
RobT2009 is offline   Reply With Quote
 Old 01-25-2013, 07:58 PM   #78
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Well like i said I'm either doing cnc or cast don't know yet waiting on pricing on both. For a one off cnc willbe cheaper , but production cast will be cheapest. Obviously the oil lines and stuff will also be an fittings. I built everything with just extra stuff I had laying aroud. I wasn't even planning on doing it, just kind of did it. As long as everything works how it's supposed to I'll be putting it in production. The final piece i have drawn up with dimension on how i want the transition to be from factory to t3. It's def going to be a bitch either way.
Hey man,
I don't know what your timeline is on this, but within 2-3 weeks I should be done building my own CNC.
If you need anything, you can send me 3D CAD files and I'll do the machining for you. All you need to do is send me the files, materials and shipping.
It also depends on what kind of material you are using. I should be good to go with Aluminum, if you decide on steel I'll buy an end mill for steel. (on my own dime, since I'll need it anyways in the future)
Just to be clear, I won't charge you anything, the joy of seeing this done and helping out a member is good for me!
2010 LSM Speed3
#BakeryTuned
The Following 28 Users Say Thank You to Roddiy For This Useful Post:
beachshoer (01-25-2013), BigRedSpecial (01-26-2013), Boosted Beluga (01-27-2013), bradkn (02-03-2013), Dano (01-26-2013), Darth_Nuruodo (01-25-2013), DingoDave (01-30-2013), Dumyz (02-04-2013), Elvisrosales88 (02-04-2013), Hush (01-25-2013), jax ms3gt (01-27-2013), Jhornbrook (01-25-2013), kmac (01-26-2013), kritz (01-26-2013), lilred (01-25-2013), maisonvi (01-26-2013), Micha (01-29-2013), ms3rick (01-25-2013), Ms3_Miami (01-27-2013), Raider (01-25-2013), robry (05-16-2013), robspeed3 (01-25-2013), Seatime3 (01-25-2013), that1rowdyracer (03-10-2013), TiGraySpeed6 (01-25-2013), Tokay444 (01-26-2013), wolly6973 (01-26-2013), woodfloor (01-26-2013)
 Old 01-26-2013, 11:45 AM   #79
kmac's Avatar
Originally Posted by Roddiy View Post
Hey man,
I can't thank u enough. I also think I found a new bff.
<3 Tokay.
socks (02-02-2013)
 Old 01-26-2013, 11:47 AM   #80
Roddiy's Avatar
Groans: 279
Hahaha, no need to thank, it's my pleasure.
Of course, down here we use the term "biffles"
I'll be updating you on the process of my CNC, I'll take some pics of how it sits as of now so you have an idea.
kmac likes this.
2010 LSM Speed3
#BakeryTuned
The Following 5 Users Say Thank You to Roddiy For This Useful Post:
Boosted Beluga (01-27-2013), kmac (01-26-2013), kritz (01-26-2013), Ms3_Miami (01-27-2013), woodfloor (01-26-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f651/first-big-turbo-st-135643/
Stroked 2.0EB to 2.3L by Speed Perf6rmanc3 - JDL Auto GTX3076R - 550hp+ Daily Goal - Page 12 This thread Refback 07-02-2015 07:14 AM
JDL Auto Design GTX3076R Kit - Motor and Fueling By Speed Perf6rmanc3 - 550whp+???? - Page 12 This thread Refback 02-25-2015 05:45 AM
JDL Auto Design GTX3076R powered ST - The kit is real!!!! Fueling details coming soon - Page 12 This thread Refback 10-21-2014 09:44 PM
GTX3076R powered ST - Ditched the VF48 idea - Page 12 This thread Pingback 09-22-2014 01:06 PM
Big Turbo Set Up This thread Refback 04-23-2013 10:42 PM
Ford Focus ST review @ 1000 miles - Page 4 - Nissan 370Z Forum This thread Refback 04-12-2013 10:30 AM
Ford Focus ST review @ 1000 miles - Page 3 - Nissan 370Z Forum This thread Refback 04-10-2013 11:47 AM
Bumping the power up Post #149 Pingback 02-17-2013 05:21 PM
How flexible is the stock fuel system and tune to engine modifications? - Page 2 This thread Pingback 02-13-2013 04:57 PM
www.FordSTOwnersSA.co.za - View topic - Bigger turbo ST250 This thread Refback 01-24-2013 11:16 AM
www.FordSTOwnersSA.co.za - View topic - Most power can get out of the new ST This thread Refback 01-24-2013 10:43 AM
Turbo adapter Post #37 Pingback 01-22-2013 06:59 AM
Turbo adapter Post #37 Pingback 01-22-2013 06:58 AM
So the Ford Focus ST is a reality... - Page 75 - NASIOC This thread Refback 01-22-2013 06:26 AM
Big Turbo Set Up - Page 4 This thread Pingback 01-21-2013 09:32 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.62082 seconds with 42 queries
